- Looking for transmitter
- Blade tracking on a 250
- 450 Sport or Pro?
- 450sa vs. 450 sport
- My New Trex 500 ESP Arrived Today
- Vibrations in camera view
- Do servos need rubber grommets?
- Low head speed
- Scorpion -8 with composite tail and swashplate?
- Trex 450 Tail
- 450 Main and Tail Drive Gears
- Blades for 450 pro
- HK 450 or Copter X?
- help with gear mesh
- 600 Clicking Noise
- Trex500,coastguard 109 video
- Faast RX receiver mounting?
- T-Rex 450 Minimum in/oz on Tail Rotor Servo
- 450 ccpm upgrade
- help with 450 battery choices
- My 1st Trex 600 Build - Thinking Scale?
- 500 elect heli
- What motor? T-Rex 600
- Trex 250 with a jr propo g170 setup
- T Rex 700 .90 size nitro heli
- 450 Trex Clone with RDS8000 TX
- Receiver mounting in TRex 450
- New HK 450 kit...First Build!
- HK 600
- Trying to decide if i want to build the Trex 450
- Heliartist fan kit with ec135
- HK 450 Pro belt edition
- Trex 250 asemble manuel
- Trex 500 Screw Issues..
- Tail Twitching
- Difference btween T Rex 450 pro & 450 super combo
- 450 Sport questions.
- trex 250 diff. size tail rotor blades?
- regular heli maintence!
- Help with setup *UPDATE*
- T-Rex 450 Gyro Options
- HK450 with SG90 on the Tail. It won't hold. Help!
- Trex 250 Batteries HELP
- My First Build Trex 450 Sport
- HK250gt locktite question
- n00b NEEDS advice on WTG for trex 500 stuff
- T-Rex Clone
- T-rex 450 Sportin'
- Why have a separate bec?
- TREX 600 MD 530 In the snow on Skis
- this battery is suitable use on t-rex?
- DX7 on Realflight 5 Does it Work????
- drops while hovering
- 8s options on trex 600
- Trex 450 modification
- trex gone crazy
- trex 600 esp tail jerking need help
- T-rex 450 se
- DO I NEED A BEC?????
- Simple question
- BATTERIES TAKING TOO LONG TO CHARGE!!!!
- PICS OF MY TREX HELOS
- Trex 600 ESP?
- 250 vs 250se ?
- T-REX 500 ESP latest version
- what is a Trex 450Pro best cost?
- Trex 450Pro opinion
- T-Rex 450X
- Align servos.
- Does this sound right ?
- TREX 450s Landing in Backyard Pool
- T-REX 500 Upgrade
- Help Please Futaba 6ex
- Happy New Year
- Where can I find this replacement part?
- Getting back to RC
- Trex 500GF Pitch/Throttle Curves
- aplus battery ?
- HK-450 setup question
- 1320 11.1 Battery in a T-Rex 250
- cheap China blades
- Look what happen to me
- Christmas
- Swashplate in Normal and Idle up different
- align 430L 3150KV
- Tail Blade Recommendation
- trex 250 and 401 gyro
- COPTERX 450 SE RTF or KIT? HELP!!
- Blade 400 outflys TREX all day!!!!
- 60a scorpion esc ?
- Trex 450 Pro build videos
- WHATS CAUSING THIS PROBLEM??
- T-rex 450 main blades
- Where can I get the best deal on T-rex 600 ESP
- HK 450& futaba 7c
- Trex 600 ESP - Good Deal
- T-Rex 450 V1 Spindle Shaft
- anybidy tried GY520 w/ Align DS 650..yet?
- Need some Help!!
- new S9257 on my trex... questions
- Stepdown voltage regulator?
- Questions about purchasing trex 500
- Can you mix controllers?
- Blade tracking problem
- CC TBird 36 and DX7 Heli throttle problem
- ALIGN GP 750
- Trex 600 ESP - sport flying setup
- FUTABA GY502 gyro on a trex 450???help!!!
- Scorpion or align esc?
- 600 canopy question
- newbiiiii
- Align Starter
- Bearing packer
- align t rex 450 pro warranty help
- battery puff
- Does any Fly field clousest to west Houston?
- tail servo issues
- t rex 450 pro servos
- Lipo charging
- jr500ummm?!?!?! weird i dont understand this?!?!?!?! help
- T-rex newbie
- what servos for trex 450 pro
- step down voltage regulator
- Trex 450 Pro Super Combo brushless motor
- Help with lipo charger
- Best Trex 450 Clone Deal ???
- Trex 500, Which Pinion
- IT IS TIME!!!
- Recommend Flybar control pitch for 450 PRO
- New Heli Advice: Trex 500 or 600 ESP
- new scorpion -6 motor
- stainless steel ball part #agnhs1155 on backorder
- t-rex 250 vs 450 vs 600
- need a new gyro
- Trex 450 tail boom coming loose
- Paddles Rotating. Can it be stopped?
- Digital servo / Lipo question
- HK 450 Gyro / Servo
- Vibration Problem
- My Trex 600 E will only fly for 30 secs.
- Hitec Hs 65 carbonite or metal gear servos for Trex 450
- 500 ESP / Flying-Hobby..Please help
- problem with trex 450
- Screamer 450
- inolab 202MG or Hitech 65MG?
- Tail Drive Gear Question
- good motor/esc for trex 450
- T-Rex 250
- Advice on TREX 250
- How do I know my heli is too heavy?
- Recommend a good site to purchase T-rex 450
- Can I use my Blade 400 motor on my 450 sa?
- Belt CP to Trex 600 ??
- Trex 600 gyro ?
- Possible Gyro Defect ?
- 325 WOODEN BLADES IN 3/PACK????
- T Rex and DX6I Binding Problems
- Is this a good deal? Trex450 Pro Super
- LATEST PICS OF MY TREX 500
- NEW BLADES
- Scorpion ESC Commander 45A + KHii 2221-8 Motor need advice
- trex 450 ESC
- Trex 600 motor won't start !?
- Newb Question
- What servos, gyro and RX for Trex 500
- Trex 450 se v2 belt problem
- Trex-450 kit questions
- Trex 250 owner's lounge
- New to this, tons of questions
- Trex 450 glitching issue
- Need servos for T-Rex 500
- Question about Blade Weight?
- misbehaving trex collective on new battery
- Cheap Lipo
- hobby city hk500 clone trex500
- Align Trex User Manuals ....
- wiil a
- dx7 ar6100 setup for newbi
- What is the difference?
- Green loctite r48 on t-rex 250 pinion will it hold?
- used trex 450 SE v2 OR new trex 450 sport
- cheapest trex 500
- Spending around a Grand then out of hobby ;(
- difference between belted and geared helis
- 450 pro airframe
- How to build a Trex 450 clone. As told by a puppet.
- T6EXHP and gy-401
- 450 pro / dx7
- New Trex 450 SA - servos and stability issue
- 450 pro Tail boom
- Question About T-Rex Clone
- MY NEW TREX 450SE AFTER FIRST FLIGHT
- tail problems
- 450SE V2 Spins.
- T Rex 450 help?
- Upgrading to T-Rex 450SA
- T-REX 450 - Weird behavior
- trex 600 torque tube
- Scorpion Esc
- Different versions of trex 450
- Trex 450 se v2 tail issue
- Aluminum Control Horns For DS510's
- Show off your TRex 600's
- LiPo battery set for 450
- T Rex 600 Ordered Need Some Advice
- DS821 on Trex ESP
- T-REX 500 elevator servo install help needed.
- R-Rex 450 Jerking
- FINALLY......FIRST CRASH!! TREX
- Weird problem with my Trex SA....
- I need to tight a little the belt...How to?
- Trex 350 JR 81023 Help
- belt snap
- 450 pro shaft tail on v2 trex?
- need help with 250 setup
- throttle and pitch curves for trex 600esp
- Battery not ballanced?
- My new bird is a "Tarot 450SE V2" (CLONE)
- Trex 600 in your face
- Blade 400 blades on the trex 450.....e
- Does Align sell tail boom stiffiner inserts?
- Settings to tame a Trex 450 ?
- Best blades for a begginer?
- SMALL QUESTION!?!?
- tail belt prob
- Trex 250 clones coming!
- MY TREX 500 PICS
- The best heli
- tail spins faster clockwise
- My 450 on floats
- t-rex 500 clone
- Stock config...Whose more powerfull? Trex 450 or Blade 400?
- T-rex servos
- Motor for Scale Trex 600.
- T-rex CDE
- Trex pro built question
- What do you think of this Trex 450 set up....?
- jr g770gyro
- 35g ESC
- trex 600 esc?
- Trex 450 + GY401 tail lets go
- 4050kv Align Motor
- Help ASAP Please
- New ! CLONE Align 450v2 helicopter (Black / Orange)
- Convince me to buy a Trex 450 SE....
- Can I use the Blade CX2 transmitter on a Trex 450?
- Good main blades for a 450?
- CLONE OF THE YEAR AWARDS
- 45 deg up project
