PDA
View Full Version : T-Rex heli
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18
  1. WHAT ESC DO I USE WITH 430L? BL25G
  2. Hacker A20 6XL
  3. PARK BEC Question
  4. Sound Advice
  5. Should we be concerned about the T-Rex 600 delays??
  6. futaba s9650 digtal servo
  7. Align 25A ESC and 420L setup
  8. What's wrong with this as a base unit?
  9. How much does this cost?
  10. T-REX Parts and Upgrades
  11. T-REX 600 sim (NEW VIDEO OF 600)
  12. What transmitter, what model of Trex? Blade CP coming over
  13. Low Head Speed Vibration
  14. TREX VIBRATING/SHAKING VIOLENTLY
  15. trex w/ blade cp tx
  16. CCPM Interactions (Bob, help please!)
  17. T-Rex 450se..How much can it lift?
  18. 400DH motor + 35A ESC + 11T pinion
  19. Trex 450SE & Copilot questions
  20. Sparks?
  21. Flying 3D with a broken T-Rex (Video)
  22. TREX 450 hde DX6 settings!
  23. First T-Rex (very newbie questions)
  24. First T-Rex (very newbie questions)
  25. T-Rex Tail Wiggle
  26. 450 XL linkage question
  27. Trex 450 SE or Trex 450 SE-V2? any difference?
  28. what pinion to run
  29. trex 450se slow roll rate
  30. Blades not fit in the 450SE blade grips
  31. shogun v2 whats up??
  32. ALIGN CHARGER HELP
  33. shogun v2 spins!!
  34. GY401 setup using Optic 6 gyro feature in HH and normal
  35. servo horns hitting inside canopy
  36. T-Rex 450SE CDE V1
  37. tail driff
  38. Which ESC to get?
  39. TRex Upgrades
  40. T-REX 450SA
  41. Lets see those Trex pictures!
  42. T-rex 450 SE vs HDX 450 SE
  43. TP Li-Po
  44. gyro help for shogun
  45. 3D MOVES
  46. Align 35a ESC
  47. gy401 and jr radio
  48. Removing 1-Way Bearing
  49. Heliman13 aka TrexBuilding = SCAMMER
  50. T-rex blade tracking -please help
  51. SHOGUN SE V2 vs. T-REX
  52. AMAZING T-REX AIRBRUSHED CANOPIES
  53. Tail Direction
  54. UPGRADE TIME
  55. 450XL swash problem
  56. T-REX 600 electronics
  57. T-REX SIM
  58. T-REX 600 VIDEOS
  59. Now what!!! Newbie
  60. China's new GY191 HH gyro
  61. What tail gear to go with
  62. T-Rex models ??
  63. Just Bought a TRex SE, Help Me with Picking Electronics!
  64. Tail rotor servo
  65. Tracking problems with the 315 Align wood blades. Any ideas?
  66. Servos for 450 xl ?????
  67. Fine Tuning
  68. hummingbird elite 3d pro
  69. Which T-REX?? Too many different ones????
  70. Futaba GY401 and 6 volt BEC
  71. Need Help TREX 450
  72. Anyone try "High-Timing" ESC setting with Align 430L motor?
  73. ANYONE SWITCH MOTORS FROM STOCK 430L?
  74. 450xl ccpm need help
  75. Best Motor for TREX 450 SE
  76. batt chargers
  77. Problems with Gyro Setup
  78. Do i need to ues?
  79. KX850140TA align lipo charger
  80. GY401 with DX6 TX ?
  81. TRex Tail Drift on JR 500T Gyro
  82. Trex 450SA size
  83. Breaking in new battery
  84. Tower Pro servos and canopy rub :(
  85. speed control choice
  86. How much juice does the align 35 amp esc sent to the servos?
  87. HDE to eccpm
  88. FUTABA 9CH Transmitter Pitch adjustment
  89. DX6 Transmitter connecting to the PC?
  90. A few question about the T-Rex
  91. questions after rebuild.
  92. SUPER BLING TREX for sale on EBAY!
  93. trex skids
  94. All belt drive frame?
  95. hitec eclipse 7 on a 450xl cde
  96. Where does Rx power come from?
  97. Sling Load
  98. NEED HELP,PICKING GYRO HEADING HOLD
  99. HELP! JR XP8103 & Futaba GY401 Gyro setup
  100. Align 430L which pinion fro 3D
  101. futaba 9chp super HELP PLEASE!!
  102. align t-rex lineage
  103. What should my head speed be?
  104. JR G410T gyro with Futaba 9z
  105. Belt binding!!!
  106. HS-65 Servo Installation Question
  107. GEARS TURNING THE WRONG WAY!!!! PLEASE HELP
  108. Hacker A20 6XL, Info???
  109. Thread Lock on top of Thread Lock?
  110. 25 amp CC ESC enough for 450XL?
  111. THIS IS WHY YOU DONT GET CLOSE TO SPINNING BLADES!!!!!!!!!
  112. Carbon blades?
  113. Align ESC problem
  114. How do you install the Futaba 9650 tail servo?
  115. trex 450 or trex 450xl
  116. Tail wondering in idle up
  117. LHS in New Hempshire
  118. Need help with ESC problems
  119. TREX aluminum servo horns - FINALLY!
  120. I finally solved the belt tracking issue for free!!!!!!!!!!!!!!
  121. PCM on TREX 450 SE? Please Help...
  122. XP6102 Pitch/Throttle Curves
  123. Canopy Painting
  124. Newbie TRex Advice Please
  125. Futaba 3110
  126. trex battery issues
  127. FUTABA 9CH TRANSMITTER
  128. Stumped building TREX frame...
  129. Apec battery
  130. which pinon is right?
  131. Servo choice help
  132. trex problem
  133. WHAT TYPE OF SWASH PLATE FOR CDE
  134. Trex needing JR X8310 setup
  135. How much gain are u guys using?
  136. New TREX 600CF
  137. New trex owner questions
  138. Trex 450SE - Any assembly "gotchas"?
  139. 7chp t-rex with GWS naro receiver
  140. Radio system for T-Rex 450SE
  141. Trex Crash
  142. trex after market frame --- 3dx 450 eccpm
  143. Throttle and Pitch Curve Issues...
  144. Governor Mode?
  145. Digital tail servos
  146. T-Rex durability : 450SE vs. 450XL
  147. trex battery question
  148. Blade tracking issues
  149. t-rex 450xl servo disruption
  150. Smoke from my TREX AGAIN!!!!!
  151. What do I get ?
  152. HELP 911 THERE IS SOMETHING WRONG WITH ME RX!! (i think)
  153. t rex 450 xl
  154. Please Help, Motor quits running for a second
  155. Tail slow drift towards right (Heli Nose to left)
  156. What are some good Blades?
  157. Mntg Loc for GY401 on TrexXL
  158. tail issue...
  159. Swashplate movement
  160. Flight times with Trex / 2100TPPL?
  161. 450 XL AHHHH
  162. Intermittent Tail Issue
  163. Need a hand changing pitch rates
  164. R/C Exper ESC
  165. Which heli is suprior...T-rex XL or SA?
  166. Dual Rate on rudder DX6?
  167. New Tail Servo....
  168. Servos not centering
  169. Need some recommendations
  170. Motor cutting out
  171. crashed my se
  172. TREX SETUP CONFUSION - PITCH & AILERON
  173. Where to buy best upgrades and mods?
  174. New TRex What Pinion to use?
  175. Flight times w/TP2100PL
  176. Major Problem with the T-Rex SE V2
  177. Just curious... Servo connections
  178. Hop ups
  179. TREX MAJOR BELT ISSUES!!!!
  180. Anyone Use DX6 with G3 in idle up
  181. First Flight...big thanks to RCU and Finless
  182. Motor problem
  183. Align BL35X Question
  184. Mounting TREXxL Motor Help please!
  185. Fine tuning..Newbie alert
  186. Spectrum DX6
  187. TP Pro-lite 2000 fitment in Trex
  188. Li-Po Force charge?
  189. help, RCE-BL25X (governor version)
  190. Canopy build up
  191. Align 25amp ESC spool up question
  192. COLLECTIVE IS LIMITED - ANY IDEAS WHY?
  193. What Brusless motor and Speed Control???????
  194. e i just posted
  195. SMOKE FROM MY REX PLEASE HELP!
  196. T-Rex Swashplate Angles
  197. Receiver question?
  198. Losing tracking. Help
  199. Took the SE Plunge !!!!
  200. Glitching with carbon frame?
  201. JR X2610 (6102) Help
  202. Help setting up my T-rex
  203. Does any body have TX. Hitec optic 6 ?
  204. G4 wiring setup glitching
  205. It's time to upgrade! Please help me get the right TREX
  206. ive purchased a SL 420 gyro any good ?
  207. Is My FUTUBA radio Okay to use???
  208. gy401 delay setting for hs 56 hb
  209. Belt tensioning?
  210. All most ready to fly, one more ?
  211. T-Rex 450CD XL - Tail boom question
  212. Minimal requirements
  213. Tail gear spinning on shaft
  214. Computer Radio
  215. whats a good ESC?
  216. newb - am I getting in over my head and which trex?
  217. Tail spin out on TREX
  218. TREX BASICS NEED HELP PLEASE!!!! :(
  219. rc-8000 radio HELP PLEASE!!!!
  220. TrexSE Combo Kit HELP!!!!!
  221. TREX combo kit help!!!!!!!!
  222. Trex V2 eccpm frames....which one???
  223. Airtronics?
  224. which parts will/should break?
  225. Align moved!
  226. The t-rex has stopped talking to me while I sleep.
  227. Idle up mode?
  228. XP6102 Setup
  229. ANY GOOD!!!!!!
  230. Loss of power Align 3500k
  231. Align T-rex question
  232. Hard motor starting?
  233. Trex Owners's Organized Threads and Information
  234. Very hot jst connector: ESC is over?
  235. how to remove one way bearing?
  236. 430L 3550kv with 3 gears with with t-rex?
  237. Spektrumized JR XP6102 is now AMA legal!
  238. Setting swash on sanwa RD6000
  239. First 3-d flying video!
  240. TREX SE tail servos
  241. T-REx Se V2 almost a crash Why?
  242. thief in ok city, ok
  243. T-Rex XL V2 CCPM
  244. Rotors vibrating at 0 degrees?
  245. Which one?
  246. TREX Setup Instructions
  247. No Futaba 3110 gear sets???
  248. Help with LiPo Balance Connectors
  249. Rotorworkz G4
  250. Trex Beginer Setup on JR8103
