PDA
View Full Version : T-Rex heli
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. building a 500 ?
  2. 500 Superior Combo
  3. Need DC power supply recomendations
  4. TREX 450SE & 450SE V2 on sale? is it worth?
  5. T-REX 450 + Graupner R16 SCAN + Graupner MX-16s
  6. T-rex 450se tail servo
  7. T-rex 600 Starts fast
  8. T-rex 450 battery charging system
  9. T-REX 600 IN 10S LIPO
  10. Hitec 5065 servo(digital 65MG)
  11. why is my t-rex turning left?
  12. Flexible Landing Struts for the Trex 500
  13. T-rex 600 for realfligt G4.0
  14. Best electronics for T REX 450SE V2...??
  15. T-Rex 600 nitro with Terrible tail spin
  16. trex 600 skids
  17. define "rock solid tail"
  18. t-rex 250 availability
  19. Blade 400 Comparison
  20. T-Rex 250 Build Thread
  21. T-Rex 600 ESP with 10S A123 cells
  22. Trex 450 Pics Please
  23. video of transmitter during 3d flight?
  24. T-Rex 450 SE ESC size????
  25. Our new Trex 500 cyclic response is very slow compared to our Trex 450!
  26. Mid stick Idle UP throttle and mid stick normal mode throttle...
  27. Dorked in my 450SA
  28. Canadian heli pilots
  29. Trex 600 newbie set up
  30. Question and a problem...450sev2
  31. Frustrating Gyro Issue
  32. TREX 500 SCREWS
  33. woodies vs carbon
  34. so when is the t-rex 250 offical release date?
  35. ALIGN released new Trex-500 ESP ! ! !
  36. My first crash
  37. Looking for advice for Trex 450 with 4s setup
  38. just wondering?
  39. Mechanical settup problem with ve tail
  40. Problem with the tail on my Trex 500 after installing TT drive!
  41. My 450SE V2 Endeavor - Diving Into the Helicopter Hobby!
  42. Trex 450 retracts
  43. trex 600e servos
  44. Need help with servos
  45. Trex 450 V1 head
  46. trex 450 tail wag
  47. Rhino 2350mAh 3S 11.1v 20C Lipoly for TREX 450 ?
  48. align esc
  49. Anyone used two packs in series?
  50. What is the difference between trex450 V1 and V2
  51. 3d with a 450?
  52. Trex 450 rudder servo
  53. ESC beeps normal on each start?
  54. futaba 7c setup problems
  55. Spektrum Receiver for 450
  56. 450SE V2 blade grip play. new bearings?
  57. "normal" to "idle up" transition
  58. 450SE V2 dampener upgrade
  59. new to helis
  60. trex 450 se I need help with a few problems
  61. 30-40% Power loss, no clue...
  62. TREX-500 with 500mm-550mm BLADES
  63. Battery flight times - 80% rule?
  64. Hard throttle turns counter clockwise...
  65. Blades for night flight
  66. Trex 450SA flybar setup question
  67. Futaba GY 401 failures
  68. Cannot pull glow plug extension off
  69. Where should you be hovering?
  70. How to use your DX7 with real flight
  71. how much expo on a 450se v2?
  72. Fact or Fiction?
  73. TREX600 mainshaft bearings loose
  74. Fasst Heli
  75. Spektrum/ AR6100e wiring
  76. T-Rex build questions
  77. HELICOMMAND 3A. Tail wagging issue.
  78. Which is what?
  79. Possible bent head??
  80. ESC - Little round disc.
  81. Gyro question
  82. Spinny side down
  83. 3D - Flight
  84. What batteries for a 600E
  85. anyone ever used an HDX6i radio?
  86. After re-build, flys funny?
  87. Mini-Titan SE
  88. DIY Machinning, parts etc.
  89. ESC programing difficulty. Align BL35X
  90. Inverted......finally
  91. Trex 450 rx Question
  92. smoothing the throttle stick
  93. clone trex
  94. T-Rex 450 ball links
  95. need main gear TREX 450 X 150T/109Auto
  96. NEU 1107
  97. Flying in the wind
  98. Turnigy Accucel-6 V2 Battery
  99. Trex 600 setup problem
  100. Charging lipo's in series
  101. what about gyro colco?
  102. T-Rex 450SA arf starting out questions
  103. Neu motor for Trex 450 ?
  104. Trex 450 tail rod switch
  105. PLEASE HELP
  106. 25C vs. 30C
  107. Would you buy a crashed heli?
  108. Futaba 6EX settings for 401Y gyro
  109. I want a t rex
  110. 2,000 Watt T-Rex 600
  111. Miracle Landing Gear for the Trex 500
  112. Severe Vibrations
  113. OUTRAGE 11.1V 4200mAH battery for 450
  114. Flying without gears. Can I?
  115. Other 450's
  116. TREX 600
  117. DX7 problem or not?
  118. T rex 450 sa problems
  119. Which servos for Trex
  120. New Trex - STOKED *w/ pics*
  121. HELICOMMAND => Difficulty to setup for TRex450
  122. Servo
  123. TECH Questions!!!! Insight please!!! interesting!
  124. T rex
  125. Best 3d blades for the rex 450
  126. futaba S3115
  127. T rex 450 se v2 tail belt
  128. TRex 450se - where do you put everything?
  129. Trimming ends up in disaster
  130. Scorpion Motor
  131. Question about my T-rex 2100 20c lipo pack
  132. 9650 and GY401 setup
  133. Xeon flash Strobe lights
  134. T-Rex 600 electric Basic Set Up
  135. I really need some help w/ Trex450
  136. T-REX 600 belt or Tq. tube?
  137. Not crashing has caused new problems
  138. TRex 500 => I / V / W / Weight => reference
  139. Align TREX manufactures web site?
  140. T-Rex 600e choices! Should I wait?
  141. AR6100 light question
  142. Grrrrrrr 5th flight and crash :-( Best place to get parts t rex 450
  143. best battery to use with scorpion 2111-6 motor
  144. Dodged the bullet this time.
  145. T-rex 500 servos/gyro
  146. What size heli??
  147. Spektrum AR6100e
  148. Trex 250
  149. ESC ?
  150. tail shaking/vibrating
  151. How many of you run 4s?
  152. HS65 MG vs HB ?
  153. GY401
  154. t-rex 450 twitching
  155. Little torque control when adding power
  156. What receiver for 401/9650 Combo
  157. T-REX 500 newbie question....I'm confussed!
  158. Trex SE GF or Trex SA
  159. How did you install the header tank on your 600N?
  160. T-rex 450se v2 build....
  161. good source for align/t-rex parts numbers?
  162. Introduce a new products...
  163. Question about Battery for T-rex 450
  164. Trex 450 X Tail Drive Gear Help
  165. 450 V2 running hot, surging...
  166. Help 401 and tail issue
  167. Glitches, Trex 450SE and Spektrum
  168. What is better a Trex v2 or a titan e325se?
  169. Trex Turnbuckles
  170. copterx carbon or aluminium
  171. T-rex 450v2, futaba T6exhp setup up help
  172. question about modefosheli
  173. Anyone else fly there 450 with the JR 6102?
  174. Minor crash ends up with totaled 600
  175. 600 motor options
  176. Horizontal tail jumping on 450 - why?
  177. 600XL motor shaft replacement?
  178. piro speed
  179. Help with Throttle/Pitch Curve DX6i
  180. Blades won't track near take off rpm
  181. Lipos
  182. best way to land a t-rex???
  183. So what is the best T-rex kit you can get?
  184. Electric or Glo
  185. RCE550 Gyro acts wierd after crash on 450sa
  186. Battery weight in a 450SE
  187. Bullet Connectors for motor and ESC??
  188. upgrade SE to SE V2
  189. Big-Time Power System Problem. Please give me some ideas on what to do next!!
  190. 600 Canopy upgrade, where to buy?
  191. ALIGN TREX 450/500/600 ALUMINUM UPGRADES AVAILABLE - KDE DIRECT
  192. t-rex 450 v2 with walkera 60 electronics
  193. Main drive gear/One way bearing - help...
  194. T-Rex 600 Eagle Tree Data
  195. motor and esc work with 4 cell lipo
  196. 600N balance
  197. trex s or se v2
  198. Phoenix ESC in Governor mode - Throttle curve
  199. Trouble calibrating throttle with X9303 & Castle Creations HV-85
  200. T-rex 600E canopy not fitting?
  201. Biggest battery you can use in a trex 450 se v2??
  202. do I need a charger with a balancer -help.
  203. Servos
  204. heli shops in new york or miami (doral)
  205. dx6i gyro travel adjust?
  206. Trex 600 Catastrophic blade failure
  207. tREX 450
  208. trex wont initialize
  209. Maybe I'm a fool But I just bought a Trex
  210. Storm Rock-7 AVCS gyro
  211. Help With Ar7000
  212. Electricfly Polycharge4 battery charger
  213. motor pinion and main block bearing question
  214. My "new to me" T-Rex 600CF arrived today!!!
  215. anyone tried spektrum's 7.5g micro servo? need help choosing
  216. anyone tried spektrum's 7.5g micro servo?
  217. Best Battery?
  218. Best online store to buy a t-rex
  219. tail sub trim?
  220. Just purchased a 600
  221. Futaba S9452 Servos for Trex 600e CF?
  222. wind gauge
  223. 600XL temps
  224. TREX 450 just spins
  225. Memphis Rex Flyers?
  226. Spektrum DX6i setup question
  227. Before I make the plunge
  228. HS-65 MG's
  229. T-Rex 450 Se full check up
  230. Trex 450 HDX servo Questions.
  231. rotor hub V2....
  232. GY240 Gyro in a Trex 450 SE
  233. Anyone using the Hyperion EOS 0606i?
  234. 600E - Bad main bearings?
  235. esc&bec,motor for trex 450 v2
  236. T-Rex 600E Pitch range adjustment problem
  237. Frequent collective inputs to maintain altitude
  238. How to tame a 450SE V2 size Heli
  239. New Build 450 3dx CNC
  240. Copter X 450 CNC machining quality
  241. Tower pro servos on Trex -your opinion
  242. Most powerful motor for TREX 450
  243. 1st 3d ?
  244. Worn dampners on T-Rex 450SEV2?
  245. S-75 E-FLITE SERVO ON TREX 450 SA...please help
  246. Align 420LF Motor Bearing Rebuild
  247. Dx6i Binding and ESC setup/programming
  248. Trex tail, need a part.
  249. idle up or not
  250. I can't figure the esc setup 35a
