View Full Version : Electric Training
Pages :
1]
2
3
4
5
6
7
8
9
10
- what size bullet connectors
- Safe Select Rx/Tx Channel Usage
- Power supply requirement calculation
- What is an easy build foam board starter and...
- FMS Sky Trainer 182 V2 Blue 1400mm Wiring
- I need some advice...radios
- Eflite Valiant 1.3m
- looking for a hobbico nexstar EP RTF
- How do I determine the best e propeller?
- Is this an ESC problem?
- Soarstar Revival
- New to electric need help/BPH 35W Charger
- Need help with electronics!
- DHC-2 A600 trainer FREE GIVEAWAY
- Please advise, I am new to all of this and need a starting place
- lipo
- New to electric but not to flying
- Just Getting Back Into the Hobby and Have a Queation
- Confused about correct ESC to Motor connection...
- Motor not turning on until half throttle position???
- Old radio as buddy box
- Which 1st trainer is best
- no motor power
- Multiplex Pilatus PC-6 Turbo Porter
- LaStick Fuselage Question
- Propeller Pitch Speed vs Level Flight Speed
- new to electrics
- I Need a conversion list for gas to electric motors
- Help me diagnose my problem!
- Electric Warbird: Help with ESC Selection
- Anyone having inexplicable Apprentice 15S Crashes?
- Select Motor for a Carl Goldberg Tiger 2 Kit build
- XH or HP/PQ Balance Adaptors?????
- Flyzone Sensei Needs Repair!
- ARF's and CG, motors and engines
- Tips on using the forums
- low rate/expo settings for UM T28, P40
- 3.5mm bullet connector extractor?
- Battery Qustion on flight time and max drain
- Swith harness with brushless motor & ESC?
- N00B question: Low Cell Count & Higher KV vs High Cell Count & Lower KV
- Questions from an electric noob
- Motor recommendations for hob warbirds
- Spectrum DX6I transmeter
- P-51 Mustang "Marie"
- Basic Information for A New Electric Flyer
- How long my battery will last ?
- E-Flite Program Card
- n00b In need of help - loss of power
- Need help with DX6i switches please
- Major RC Universe upgrade planned for Monday July 22 - This should be COOL!
- Hymax Motors
- Second plane?
- Plane flight simulators
- Power generator
- 12' Telemaster - Good trainer?
- Electrics burns
- Which Charger?
- Got a question on lipo battery charger
- Firebird stratos offical thread?
- Battery Management
- old dawg looking for answers
- J-3 cub Identifly.
- Things to check on an arf
- What is the difference between 6S1p and 6S?
- Firebird Stratos Fairway Landing
- Firebird Stratos Beach Takeoffs and Landings
- EasyStar help
- TRYING TO PICK YOUR FIRST PLANE? Ask your Questions here
- First Airplane!
- Speed control close to receiver OK?
- LiPo's Not Balancing - Do I Need New?
- using those rechargeable AA batteries in my radio for RC
- C rating
- WWI Props
- Newbie motor control - dead!
- Christmas Switch
- charging question
- What is it?
- How To Select Your First Radio
- electric plane
- Firebird Scout
- lipo batteries
- plane ID. point 25 brushless, 40 esc, 4000 Mah, 10 x 8 prop
- Prop change to plane slow down ?
- Balsa trainer rolling left on take off ?
- Need some helping with Setup of a Slow Stick
- Binding
- EP Falcon rolling at take off ?
- Best RTF foam mid-wing trainer?
- What Are The Top Rated LiPos?
- New bat for tower system 3000 tx,best price.
- Air Hogs Entity conversion to full RC
- Advice on a new plane
- Need your Support to solve the problem
- NEW TOP RC HOBBY Hawker Hurricane 750mm PREVIEW
- NEW TOP RC HOBBY 965mm Wingspan 400 class cessna 182
- New to Electrics HELP
- Seeing success with the Hobbico Sensei
- balancing problems
- Eflite T-34 PTS Glitching
- Parkzone F4F Wildcat (HELP)
- Props
- Help troubleshooting a setup
- NextStar EP
- Blade450 block cap came off and lost?
- rebinding my throttle hold is now reversed?
- Watch out, training kits can be fragile
- Thanks to you all.
- Some very scary.
- My first Blade 450 experence
- Which connectors?
- New electric set up on my yardbird MiG-29 Question
- Everything about Electric Twins...!
- E-Flite T-34 owners, check your LG
- New to electric. Have a few Q's
- Replace Motor Shaft
- Flyzone Albatros TX-R airplane - Don't buy it unless you have a computer radio
- Radio Suggestions
- problems with new EDF jet
- Newbie Just Purchased NexStar EP
- Help me choose a battery please!!
- How Do I Prop Electric For Efficiency
- new to electrics, charger questions
- Hobbico has a new line of TX ready planes and the AnyLink Module
- Slow Stik w/EPS400C (need help w/setup big newb here)
- Plane sizes
- Will This Work (Big Newb Here!)
- Minimum Hinge Gap
- Hobbico Flyzone Cessna 182 Select Scale
- Thermal Charger-Leisure 05 Stock motor??
- ClearView - Very Poor Customer Service
- KMP 96 OV10 Bronco
- New noob here
- giving electric a go
- Looking for a tiny orange micro trainer
- Let's talk about servos - Whatever is on your mind
- Another newb looking for suggestions/ideas!
- End points on the throttle? can't get WOT
- drawing too many amps?
- Where do you get your parts?
- First electric plane should be........?
- Apprentice with 4s and power 15 what prop?
- Servos for GP ElectroStik
- no throttle response with my old recr and txmitter
- Eflite T-34 first flight
- Batteries
- super tigre.10 install problem
- Apprentice 15e Modifications
- Taller gear for Apprentice?
- Good (or bad) flying habits or set-up?
- Kadet senior electric conv.
- Ahh, it's a good day finally.
- Which one would you get
- Error
- Stumped on first plane
- Which plane after Hobyzone CHAMP (micro plane)
- Help flying in ARIZONA
- Turnigy 9 Ch TX
- HZ Supercub flying help.
- Honest speed question
- rx battery question.
- WHAT IS THE MINIMUM WING SPAN FOR BEGINNER HIGH WING TRAINER?
- stopping prop?
- $99 to $109 Hobby Kings Mini Moa 2 Meter Sailplane, floater
- 2-Blade Prop to 3-blade prop
- FLIGHT SIMULATOR? And Club info
- Eflite T34 Mentor
- ESC Not calibrating
- finding a replacement
- Need Club
- Changing Propeller From 2 Blades to 3 Blades
- Brushless motor size???
- Nexstar EP - Can It Be Bought Without Radio?
- Basic set up for first timer
- NooB! Here
- Twin motor hookup
- flight field question!
- Favorite Shops and Stores
- Higher C advantages and disadvantages
- DX7 Charging
- Trouble getting motor to run
- Flight Simulator
- new to flying
- DX6i charge indicator?
- Flyzones New 350 Corvalis Low Wing Flaps Glides !
- Newbie - Futaba or Hitec for buddy setup
- eflite prop mounting
- new to elect and motor wont run
- Rimfire / Multiplex Cularis
- FREQUENCY CONTROL - DID YOU KNOW?
- Hobbyzone mini super cub prop removal
- want to get into rc planes.
- Mentor won't take off.
- BEC question
- hobby zone champ
- Memberships to Clubs
- motor nmaking screeching sound at full throttle
- Nothing can be easier to fly than this plane?!
- think i need a smaller plane
- Spektrum DX5E & Futaba
- Hyperion Charger Question
- Motor won't run?
- Flying the Switch and one small issue
- What Scale is the most used!
- Automatic shut off for batteries?
- Burned out motor.........Why?
- Slowstick abomination
- Short video of me flying....
- Perfect plane for the beginner!!!! This is it!
- Are standard receivers compatible with ESC?
- Alpha 450 Sport
- LT-40 Motor
- Orientation
- Sterling conversion
- LiPo Charging ??
- looking for 27 Mhz receiver with X port
- Proper way to trim an a/c
- I Need Help with Buying a Versatile Electric Setup
- GWS formaza motor
- hard plastic props vs wood
- Turnigy esc/ futaba radio
- Hobbico NextStar Mini EP vs. E-Flite Apprentice 15e
- Needs help
- Recommended trainer, Hobbico?
- paralleling lipos
- Just joined Waldorf, MD
- Brushless connectors
- Brushless ESC to Battery Connections
- Motor "turns"?
- Futaba reciever compatibility
- Newie - looking for some explanations
- power supply
- Lipo charging...
- Second plane, First aileron trainer
- Landing charactaristics (Cessna 182 v. Edge 540 )
- Hot Weather Flying?
- GWS ICS-300J
- Are you a member of a club?
- help with set up
- lookin for new electric?
- 4 simple LIPO Q's for Sum1 w/ LIPO experience! HELP
- Dynam I can fly or pz micro p51
- MAX B6 Lipo Balance Charger
- .25 volt imbalance
- Hobby Zone Super Cub prep
- esc receiver help
- Do you think this is ok for a 2 meter sailplane
- BEC Question
- When is it time to buy new batteries?
