- GPU power supply for receivers
- Battery Talk
- Need help with Litco multi-cycle
- Re-peak charging
- Internal resistance
- Manual for Hobbico MKII charger
- Need a good peak charger
- All About Wall Wart Chargers / batt clinic
- Superbatterypacks Li-ions???
- What is the best website to buy batteries from?
- Ace Pro Series Smart Charge help
- ACE Fast Field Charger Instructions Needed
- Older Airtronics, waht battery do I need for the Rx?
- did i kill them? (Nicds)
- There Has Got To Be A Basic Primer Some Place!!
- 6v charge at home
- Answer One Simple Basic Charging Question - Please!
- Battery Question..Nicad
- Reverse-charged!
- Hitachi Rechargeable Battery for 12Vropelight
- nimah rx batteries
- Soldering Directly To Cells - NOT
- I need some batteries!!
- mA not adding up
- WHAT IS THE FASTEST RATE YOU CAN CHARGE NIMH BATTERIES
- Taylor power pacer
- too cold to charge ?
- Sirrus smart charger..is it ok for NiMh
- NiMH for a 480 motor?
- NiMH as electric plane power source?
- Starter pack battery questions
- Charging Batteries from a running car
- cells vs voltage
- Astro-Flight 110D charger
- Best Battery Cycler/Charger?
- Some help with cyclers and battery status?
- TRITON - Memory Recall
- NiCad Shelf Life--FMA **RED PLEASE
- Graupner Duo 12 Auto Charger
- Electronics circuit help
- Walmart 12V Lawn Battery Ok To Charge With At Field?
- Where can I get a Triton ??
- Can Stock Radio/Reciever Charger charge 6V Rec Battery
- First Charge on 2100 mha pack, question
- Battery box w/ Schulze
- NIMH batteries failure
- 12V Supply for Charging at Home
- power pacer battery cycler
- Are you happy with your Triton Charger ? Tell us here !
- Which battery for which plane
- SuperNova 250S, Who Carries Them?
- Suggestions are appreciated!!!
- Brushless high current delivery recommendations
- Shrink wrap for batteries???
- Forming Charge.
- charge time?
- Can I use the NiCad charger to charge the NiMH batteries ?
- Template for recording cycles
- Suggestion for multi-purpose charger for Firebird XL
- Trickle Charging Maximum?
- Would a1650 mah Nimh be enough?
- charging 4.8v 1100mah pack
- Superbatterypacks
- Li-Ion battery performance
- Firebird XL battery question
- help with t maxx rx battery selection
- Cycler info please advise on best for my needs....
- Sirius super test accuracy ?
- battery charging qustion
- Has anyone used this gell charger?
- why duralites or powerflites?
- is a 1450 mah nimh ok in quarter scale?
- Possible to tell-low battery?
- What charger for 6V receiver pack?
- How to Determine Unknown Battery Capacity
- Battery Terms For Dummies
- got a question for BC112C owners or former owners
- HELP! What's wrong??
- Where to get 12V AC-DC power supply for Robbe Inf 2.
- SCR v. standard cells for starter batteries
- litco multi cycler- any good?
- Charger recommendations?
- Greatplanes Triton charger good or Not !
- Dropping resistor
- 12volt charging VS. 120AC?
- Where can i find those battery connectors ?
- Charge Sealed Lead-Acid battery with SuperNova
- Lithium Polymer Battery
- Radio South pro series MkII chargers?
- How to find the Ampere rating
- Battery size for .60 plane
- Hangar 9 battery discharger
- 6V Question
- What Charger??
- partially charging a battery pack
- Is this normal
- Will this PS work???
- 500 Mah Battery Pack - Ground wire turned black !
- Lead/Acid battery trickle charger.
- Sirius Pro
- Need resistor value or schematic for World Engines charger
- Nicad life
- Aerobird charger
- Triton - (Error) Input Voltage
- Triton - Data View Menu - Peak/Average
- TRITON - Output Voltage
- Hitec CG-340 to charge Laser 4 battery?
- pro-maxx activator to charge rx pack??
- Cermark Power Panel--->12V battery
- discharger-homemade-HELP
- Anyone Here try the KAN950 2/3A NIMH
- how to charge a 12v 7ah battery?
- Good Triton Questions...
- NiMH charge characteristics
- wanted/old style duralite charger
- I need a charger
- Duralite Package
- How long will it take to charge....
- Triton - Minimum Amps
- Discharging rate - what do you use?
- Need Help Deciding On Charger
- Am I still in the "Green"...
- Pro-tech 707 charger
- Which Type of Pack? NiMH or NiCd
- Why NicD Vice NiMH for RCS 140 Ignition
- 9 Volt Battery As Power Source?
- Battery options???? which one is FASTER?
- Charging rates What do you use ?
- How to solder the battery to make my own pack ?
- Before I fry something.... help
- Digipace 1
- Stupid battery question
- In great need of charging advice.
- Batteries? What does it all mean?
- Quick question on battery connectors for Einstein
- Triton
- Which charger now?
- Why are my Li-Ion batteries self discharging?
- permission required
- 1800 mah batteries
- High Amps Low Voltage Charge !!! Why
- Super Nova
- Is a load necessary for 12V PC PS
- 6 cell 2400 pack hitting 139 degrees F
- Single Cell charging question
- Prices for Sirius Chargers?
- Supernova 250 problem ???
- Triton charger/cycler - yay or nay
- Computer PS converting for charger use
- Hanger 9 12V 7amp gell cell - question
- Lithuim poly?
- Help with making my own B packs
- discharge battery
- NiMHD
- NiMHD
- How do I check my batterys capacity?
- Whats the best way to solder ?
- 2 x 7.2V for 12V starter?
- @#$%& Charger!!
- Making a discharger
- Ace smart charge vs. sirius pro charger
- formula?
- Accu-cylcleplus...any good?
- ni mah question
- Alpha-4 port and function
- New Battery Forming Charge
- PCPower Resistor/Light Question
- Hagar 9 Sure Cycle
- Can You Say FREE batteries
- Robbe vs Schulze: help requested
- lithium battery jr xp642
- beginner needs help charging batteries
- Fast charging with wattage PF-12 parkflyer charger
- discharging trans. batt.
- Some Battery questions.
- Thanks Y'all for Triton Info
- Batteries and Chargers for sale
- Transmitter batt.
- Triton Memory
- SubC 10cell uneven heat during charge
- Charging Rates
- How can you tell...............
- HydriMax Ultra Ni-MH 1650mAh -Red
- charger
- Robbe vs. Graupner - help me choose
- yet another battery question
- Batteries for F3A
- Robbe vs. graupner - help me choose
- Initial charge settings
- Battery Charger Info Needed
- Battery Charger info wanted
- Milliamps and Battery Selection
- Turn Off beeping on Triton
- Swichable regulator
- Accu+cycle Plus
- C/ rate = What???
- Futaba Power Supply for Triton??
- HAPPY BIRTHDAY **Red! 2/09/03
- Forgot Forming Charge
- Pb charging with Triton
- Globee Charger
- Battery Covering Melted!!!
- What Is It?
- 1.2v vs 1.5v
- ot- digital camera rechargeable batteries
- charger-cycler for nimh packs
- how long to charge 700mah at 50mah
- Could these be used to power my XE2 combatwing?
- Accu-cycle calibration
- 12v power supply problem
- Capacity of auto lead-acid battery?
- Can NMiH's be fast charged?
- new to electrics
- couple of battery questions.
- Discgarging?
- Best field charger
- who makes custom nimh packs
- Shorted pack?
- silly question.
- Slow charge
- Do we over "Cycle" our Nicad's
- Measuring current?
- Help.....Astroflight 112D Charger
- Connectors
- Hmmmmm 1st charge adapter re Futaba
- AC Wall Adapter Question
- Min weight / max capacity
- sirrus super test / hobbico multi charger
- Sirius Charge Pro & NiMh Packs question
- Hobbico Powercore MK11
- Higher charge rate for Ace Super Digipulse?
- Anybody using Lithium POLY on gas planes yet?
- Orbit Microlader Pro Connectors?
- Can I??????
- Anyone have a charger they could sell me?
- starter box for .21 os
- Triton Li-ion Charging
- Kick Start 1500mah NIMH
- Triton and Powerflite
- What kind of connector is this?
- Shulze chargers
- can anyone recomend a good battery assembly tool
- New Dymond ST charger question
- "Hobby shop advice" sanyo 600 mah capacity ?
- SuperNova 250 & JR PCM10X
- Victor Super IQ and NI-MH Batteries
- Triton charging NiMH - Help Red...Please
- matched cells
- Charging Voltage
