View Full Version : Batteries & Chargers
- Selecting the right size battery
- HELP please Duralite batteries and charger
- Hooking up 2 Battery Packs
- help me with my dura traxx charger!!!
- how many volts?
- Reedy Quasar Pro for Rx/Tx charging?
- Can I test my batteries with a 9ZAP?
- Battery Discharger
- Charger problems
- "Forming" 1100 mA NiCad ?
- Top off...
- Need advice on a charger........
- 6v nimh 1100ma for 400 motor?
- inexpensive nimh peek charger suggestions?
- Question on 2cell vrs. 4cell
- Quality charger for small NiMh/NiCd RX packs
- Battery Newb has some questions.
- Field Charger or Spare Battery Packs
- Discharging Rate Questions
- charge rates??
- Help please! need some advice on wire size
- Ace ChargeMaster Info (manual?)
- powered glider batt HELP!!!!! li-ion
- Weird Happenings!!! What went on here??
- Voltage at which Lead Calcium battery considered fully discharched?
- batteries
- Soldering to Nimh batteries
- rx chargeing
- How can I charge NiMh while inside something?
- Help a newbie, 6v pack charging?
- Battery Tester
- recharge alkalines
- How fast can I charge my TX NiCads?
- Triton with Koolatron ac adapter
- suggestion for AC/DC charger < $100
- Hangar 9 Sure Cycle Analyzer
- Gel Cell Battery Life
- On Board Battery Checker
- Tamiya and Deans, what to do?
- Something wrong with radical RC???
- HITEC 270mah + 10 Months Exposure???
- Battery packs?
- bat pak ??'s
- Question for Triton users
- How do I drop voltage from a transformer?
- Power supply for in home fast charging
- How many milliamps?
- "Converted" Lithium Ion Charger? Please help!
- Charge oversize with Einstein XL?
- MRC 959 rates
- Duralite charger
- Tritron charger questions
- ATX computer Power Supply 12V DC
- What type of charger for Hobbico LC 7 Ah battery
- Astroflight 4005b AC/DC NICAD charger question
- SUB-C or AA
- Is there really NI CD memory?
- Duratrax IntelliPeak Deluxe Pulse Charger
- Advantages of NiHM?
- What's a good high capacity field battery?
- SuperNova 250s used for NiCd forming
- I like my AC/DC Charger / Cycler
- "y" cord with battery packs?
- how long do you charge it for
- battery or charger problem: really need help!!!
- Spring battery check up
- Dymond Super Turbo Question
- CG 335 Voltage Question?
- Wiring a ESC
- Battety back up system
- two battery pacs can one go on a Y used channel?
- mAh... Is more better?
- Hobbico Acucycle Plus Charger
- 4.8 V 270 mah run time?
- Battery connector for Aerobird
- Mini Tamiya connectors
- Making your own rx batteries?
- Battery Jargon??
- What does the 4.8/6 switch do?
- Two out put charger, like triton?
- MPI CH-816 Charger?
- Failure detection
- Hobbico Quick Field Charger Mark II
- modify charger for NIMH?
- GP batteries
- Need information on charging
- NIMH peak sensitivity/Triton manual
- 1600mah 4.8 volt Charger?
- energizer nihm 9v batteries
- (Not really) independent chargers (HQFC Mark2)
- Diodes
- charging a 6v pack with wall charger?
- Triton and Sub C's
- NiCd's for my engine starter
- reconfigure rec pack
- Which Charger ?
- Two Battery Packs For Great Planes Wagstaff Extra
- Sanyo Nc-lc01ex
- help
- 2 year old NiMH
- Battery charging?
- Where can I find out more about duralite batteries?
- SuperNova Charge 1700 Mha Battery
- PC Power Supply Question
- charging NiMH
- TME battery products....?? Anyone used them?
- Slow Charging
- charger ac or dc or one that does both
- Charging batteries?
- Charger, good or bad?
- Question about Extra Cell in RX pack
- Is this the right set up for a %27 extra?
- are my cells ok?
- Futaba white battery connector.
- *newbie* needs battery and charger help!
- Triton current cut-out
- Starter Battery; NiCad or lead acid
- Chargers with no load...
- Depressing Lithium battery situation
- Help with Triton
- Wanted instructions for hitec CG 335 charger
- How to check for bads cells?
- Charger Question
- KAN 950's
- power supply
- hobbico charger
- Alpha 4 Cycler Question
- Triton and Li-Poly Batteries
- What charger to buy?
- Hecell 1100 mAh nimh 9.6v power pack
- Li-poly ???
- Looking for new NiCad & NiMH battery Charger. Which one the best ?
- TorqMaster 180 + NiCd - Starts Moki 2.10
- Triton problems
- slow stick battry question
- Is this to be expected
- One Stop Battery Charger Info?
- victor engineering hi iq power supply
- Receiver batteries
- Sirius Pro+
- NIMH Problem!!!
- Help in choosing the right batteries
- Tekin BC112C Software
- Help with Duratrax Digital Piranha
- Need good charger
- Ace Digipace 3 question
- lost a large plane due to a bad battery pack
- Is it OK to charge/discharge through a charge switch?---Setting help..
- 8.4v 600mah lead attachment HELP
- Which battery Charger, Alpha 4, Hughes, or Schulze
- Charging a 6 volt battery pack
- 3000+ ma 6v battery?
- Vintage Voltmeter...will it work for hobby uses?
- Hobbico digital multimeter probs
- Motorcycle battery??
- Power Mate II ESV
- Triton Time Out
- battery shelf life
- Best charger for rc10 truck racing
- Charger choice need help!
- 1 battery, 2 switches
- Schulze isl 8-936g*e
- 12V peak charging voltage
- RED, I was just wondering....
- Triton-Display Error?
- Lighter Battery
- Wire harness polarity for futaba tx
- 12v power pack
- In search for a lighter battery
- Cycling Nimh batteries?
- NMH Batteries FAST charge??
- Page 8
- Reviving a Gel Cell
- Cell going bad????
- Recommendation for field box battery
- TX cycle rates for Dymond ST
- MRC Superbrain 959 Instructions?
- Eclipse 7 600mah Bat.
- Triton Discharge Cutoff
- Will this charger work?
- Charger for porta pack electric starter
- 1/2A Batteries
- Want McDaniel 475
- help on AA and AAA batt chargers...
- Li-on charger ?
- External TX battery
- Ace Digipace II, need help
- battery/charge problem
- Reference to PC power supply !
- Help understanding my charger
- Triton power supply
- Alpha 4 Question
- New pack building What I found
- Hotbodies Charger
- Triton Break in charge
- Need super battery charger
- dead batteries
- What to do with four 6-volt golf cart batteries
- Determining Remaining Capacity on Lithuium cells
- What to use, to neutralize Ni-Cad leakage..???
- 2/3 AA 4.8 rec. pack High Rate over 270 mA
- 12v to 8v
- JR Extra 600 Battery Charging ?
- how long to fly before charging
- Looking for SMALL 8 to 10 volt battery.
- Graupner Ultramat 5 - need instructions
- 9z battery pack
- battery location
- Using 2 PC Power Supplies
- What's this? Ace 34K23
- Experience with the Microlader?
- cycling non-flight batts
- NiMH packs dangerous
- Sirius/Triton/Jumpering
- Dyna-sport 1500 batt ?
- hitec battery charger
- LiIon pack for JR10X
- Li Poly Packs
- Rayovac/Eveready
- Coulomb Counter
- Battery connector JR 10X , same as 662?
- Ok Call me an Idiot but ??
- Aluminum-Air?
- Two Battery Packs?
- Li-Poly Connectors
- storing ny cad's
- Quick question. Is this scam?
- loaded voltmeter schematic
- What Battery Type Is The Best?
- Sirius Pro Plus/Futaba 9C problem/question?
- Battery Discharge
- Triton Charging Question
- Fan No Move - Triton
- ULTIMAE CHARGER by SAI
- Ace Super Smart Charge
- Triton Charger Power Supply Question
- Cycling Non RC type batteries
- Fast field charger....
- Is this A Good Formula For Battery Charge Time.
- Concerned about voltage drop under load of NiMh
- Robbe Infinity II: Are those ferrite rings really necessary?
- Voltage vs ma rating for reusing chargers
- Sirius Super Test question..
- Battery care and maintenance
- high charge rate (amps), why high discharge rate?
- ?? re: ESC
- Wattage charger w/CP-1700
- GPU power supply for receivers
