PDA
View Full Version : Batteries & Chargers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67
  1. Do the CellTek Chargers Actually work?
  2. 4.8 VS 6.0 volt
  3. battery tech. specs.
  4. Glow starter battery capacity?
  5. Best price on a Triton Charger?
  6. Schulze leads
  7. Battery Pack Building Guide/FAQ/Tutorial
  8. Please help me find a manufacturer that can buy this battery from!
  9. Test LiPoly
  10. gas electric hybird
  11. Charger or Converter for LI Cells
  12. 100 mah wallwart, 700 mah battery, first charge, how long?
  13. Standard Charger and Charge Time.....
  14. Supernova 250s/Triton charger/discharger advise!!!
  15. 5 cell 720 sanyo rx pack
  16. Alpha 4 question
  17. Building my own nicad chargers.
  18. Reverse polarity
  19. Wall warts and Ni-mh
  20. Wall warts and Ni-mh
  21. Charging Nicad Battery
  22. Roasted Battery Usefull?
  23. Digipeak Charger
  24. wingo battery
  25. Comparing battery packs
  26. Conditioning Nimh ?????????
  27. field battery charge
  28. TX/RX cycler
  29. Hitec Tx Battery connector - where?
  30. Tekin Bc870
  31. SuperNova & SuperTurbo ????
  32. *** VOLTWATCH in nimh useless ??? ***
  33. HELP!! I'm a first-timer!
  34. Triton – Liar???
  35. Anyone no the name of these Chargers from Germany???
  36. DELETE
  37. discharge/charge battery, need help!!!
  38. NiCd or NiMH
  39. 33% battery
  40. Power Panel Chargers?
  41. Fuses popping on charger
  42. 12V Field Battery Chargin
  43. Frustrated Triton Owner
  44. Setting up NiMh pack on SUpernova
  45. Power source for supernova charger
  46. Alpha 4 question
  47. Another source for Triton Power supply ?
  48. Question about charging??
  49. ni mh batteries
  50. Super Cycle -- Electrostar Systems, Inc
  51. Ok let me refrase it, would Duralite be against
  52. 6v 1650mA NiMH w/ WallWart? (NiMH charging formulas)
  53. Wall wart chargers
  54. How old are my batteries?
  55. Triton and 12V AC Adapter
  56. Another Triton Question
  57. Alpha 4: Charging new NiMH
  58. Charging Rates
  59. Broken + tab on Li Poly cells (fix)
  60. Peak chargers and transmitters
  61. SR vs Radical Rc
  62. Help, I need instructions for the Simpro charger, in english!
  63. Alligator to Banana
  64. Battery help-giant scale power requirements
  65. Multiple Output Trickle Charger
  66. Charger caught on fire!?
  67. charger acting weird.....
  68. Ratings of batteries ?
  69. battery backers are good?
  70. Slow Charge Question - Triton & 3000 mah NiCad
  71. Making my own RX pack, what kind of wire?
  72. When to charge?
  73. Newbie question: why 2 chargers??
  74. What size pack for my bird?
  75. Battery for an older expert radio transmitter please help
  76. Dynamite Vision Peak Plus Charger....
  77. replaced 600mah nicads with 1100 mah nicads - was this a bad move?
  78. cells for rc car racing
  79. Need a charger
  80. Nicad cell dimensions
  81. NiMH ratings
  82. Alpha 4 as a fast field charger ?
  83. 6.35 volts from a 5.6 volt reg?? Sounds a little high.
  84. Question about peak chargers
  85. how many amps can a hbco tm 180 withstand?
  86. NiMH Cycle Weirdness - What's going on here?
  87. Ni-Cd Battery cycling
  88. FMA LiPoly Rx Packs?
  89. Receiver Pack for TF Giant Corsair
  90. Charge Timer
  91. Orbit Microlader Discharge
  92. batteries that last longest
  93. should I trust this pack?
  94. Triton Question
  95. Charger turns off after battery discharge
  96. need help
  97. Shopping for charger/cycler
  98. Making Batteries from Radio Shack
  99. battery cycler
  100. Hobbico 925 Peak Detection charger.....
  101. twin batteries
  102. Where to buy surplus li-ion cells
  103. Battery Reconditionig Algorithm?!
  104. Nicad - Shelf Life?
  105. Futaba charger??
  106. CG340 Charger
  107. Triton - Charging NiMH packs
  108. stupid question
  109. Another Triton and Lithium ??
  110. 3 letter date code
  111. Do it all charger
  112. I Need a charger that plug in to house current
  113. Discharge confusion
  114. Getting Ready To Purchase Batteries
  115. Charging & Discharging
  116. Nimh In Auto Mode?????
  117. Duel battery system
  118. Ever Seen a Field Box Setup Dedicated to Charging?
  119. sirius quad
  120. Triton - Ni-MH maximum charge input
  121. Duralite +
  122. Digipace 1 and 6v?
  123. Servo load on battteries by 6 ds8411's
  124. Futaba Ends For Alpha 4
  125. Battery or charger problem
  126. Batterie For My Zero
  127. Kokam 1020 and Triton, what am I doing wrong...
  128. 12V gell cell question,,,Red, you there??
  129. Battery Charger - need help selecting
  130. Something unclear after reading Reds web site. redundant system
  131. Kokam 1020 and Triton, what am I doing wrong...
  132. probably a stupid question (go ahead... LOL)
  133. Battery charge voltage questions
  134. Astro 110 D and Charging NiMH Batts
  135. Need Recommendations for Charger/Cycle for 3000 mah Battery
  136. Average ma load ?
  137. New Charger from Fromeco Scale Avionics
  138. charging a 6v pack
  139. solder?
  140. battery melted
  141. False peaks and solar chargers
  142. What is this 200 mah figure?
  143. 2 Batts/2Volt Regs and 1 Reciever
  144. Peak Charger?
  145. JR NEC-322 Charger help needed
  146. GM racing Pro Charger
  147. How do I add a load to a Digital Meter
  148. 600 mah enough?
  149. Charge Or Not?
  150. Voltage regulators
  151. PC Power Supply (Help)
  152. ProPeak Supanova
  153. Who Makes the Best Glo Starter?
  154. When to stop charging?
  155. Fast charger heat buildup ?
  156. Battery problems
  157. a 7 cell better than a 6 cell?
  158. Questions for Red / Experienced modelers
  159. Einstein-low readings
  160. Sanyo 3300 ni-mh and Duratrax Digital
  161. Hydrimax going bad
  162. Can you use your cars alternator to charge your field battery
  163. Accucycle Plus Schematic
  164. good quality battery??
  165. Automotive battery charger as 12V power source?
  166. Tips for Unplugging TIGHT Deans plugs?
  167. The reoccuring Wal Mart charger reference
  168. 959 super brain
  169. Alpha 4 Battery "Management" System
  170. Kyosho charger question
  171. new battery charging.
  172. next best charger
  173. charging question
  174. PC Power Supply Questions
  175. 6.0v vs 4.8 v
  176. Alpha 4 Question
  177. Two Battery's one RX
  178. Trickle charging multiple packs - What will do it?
  179. Where to buy Orbit Microlader charger?
  180. Where to buy Orbit Microlader charger?
  181. Simple Question - Batterie Charging
  182. Is my power supply OK?
  183. Hhr-3000scu
  184. Batter Q's
  185. Does anybody have an easy way to discharge batteries?
  186. Simple Question: Which Charger???
  187. Apache Charger? Has anyone used it?
  188. Can someone explain this specification
  189. Where is a good place to buy e-tec lith poly batterys
  190. operational characteristics of the triton charger?
  191. Everyone fast charges..isn't that somewhat bad?
  192. Batteries Still Good?
  193. Alpha4 Order List
  194. Help with einstein
  195. HiTec CG-335 question
  196. Digital Voltameter
  197. Best prices for Sirius Chargers? Also...
  198. Good luck
  199. Protech AC/DC 706 digital autopeak charger
  200. Source for Giant Scale batteries?
  201. 6v 1200ma how long to slow charge?
  202. Anyone modified original Duralite charger?
  203. Can my triton be AC?
  204. What IS correct lithium cut off voltage?
  205. voltage loss??
  206. voltage loss???
  207. MRC 969 pro
  208. This is what I'm looking for? What will do it?
  209. Lithium Poly batteries ???
  210. Computer power supply to run a 12v charger?
  211. Astro 110d manual???
  212. $$$$ Chargers
  213. recommend a decent charger?
  214. TRC Engineering Impulse II charger????
  215. Cycleing batteries ??
  216. Is it OK to charge multiple batteries for an Aerobird from my car?
  217. Radio Shack Batteries????
  218. Trouble charging NiMH on FMA Supernova 250S
  219. Sky Scooter Pro II problem?
  220. Charging 6V 3800mah battery packs
  221. How many cells will a Piranha charger do?
  222. Lead acid - deep discharge
  223. Software
  224. best battery
  225. 1st time charging a 4.8v at 55ma??
  226. Calibrating Accu-Cycle?
  227. Initial Charge Sequence for New TX Pack???
  228. Loadsharing
  229. assembling battery packs
  230. question about power supply/triton
  231. left my radio on, is the battery ok
  232. multiple batterie hook-up
  233. ACC180 Rx Battery Bug from MPI maxx
  234. 1500 pack charged at .5 amps in 24 min ?
  235. Rechargables- worth it?
  236. RC2400 vs CP2400 Sanyo cells
  237. caliber 30 helli battery usage.
  238. Deleted
  239. 720 NIMH pack
  240. A Whole New Can of Worms...
  241. charging puls
  242. Glow stick charger what wire is+
  243. Supernova - max charge time?
  244. Disc Rate For Li Polymer
  245. Average Number of Initial Cycles?
  246. Li-Ion.....need help please.........
  247. Brand New Peak Racing Power Maxx 2400mAh
  248. Sirius Pro series or Pro Series Plus ?
  249. Futaba Diode jumper
  250. Glow ignitor subC dead after only a few uses - I found the problem!
