View Full Version : Batteries & Chargers
- Mitsubishi NiMH better than Sanyo NiMH
- Li-ion Experience
- Mah ?
- NiMH vs Nicad Failure
- batterys
- accu cycle Plus
- Am I in the neighborhood on this?
- Chargers,which one?
- I forgot to C/10 charge my new NiMh pack and fast charged it...
- Gel-cell starter batteries in parallel OK?
- 9.6v Wall Wart charging 2-4.8 v packs
- 6 volt rx batteries....any negatives...?
- what is the difference?
- Charging 800mAh NiMh on 200mAh Rate for first time
- Please Delete..
- Ok to charge Tx through charge jack with SuperTurbo?
- Attaching batteries to a starter?
- How do i use a computer power supply to power my charger?
- Delta Peak Point
- DigiPace 3 Bad - Ace Hobby Nonresponsive - What Gives?
- Accu-cycle plus pc interface
- nimh charger
- Super Turbo NIMH Results
- Help - Charging NiMH Batteries (2000mAh)
- Checking Batteries at the field
- RC Accessories
- Can a bad battery damage your charger?
- accu-cycle not discharging totally
- SuperTurbo and 12V Hobbico Battery
- Super Turbo ????
- "Matched" batteries - for packs
- what type of battery for my application?
- Super Turbo vs. Sirius Limited
- 1100mah NiMH only runs 4 minutes?
- Fast Chargers
- Silver among the gold - connectors that is
- Sirius Quad Charger
- Supernova NIMH Results
- AC/DC Chargers
- Please need advice, do I need a new charger for a 1500 battery?
- New battery and a Super Turbo Charger
- TX battery question
- SuperNova vs SuperTurbo
- Help with Hobbico multi charger
- Maximum sage discharge current ?
- Low wing balancing
- Super Turbo and Car Battery Charger?
- Batteries in the fridge
- NiMH with wall charger
- simple battery question for R/C cars
- Battery zapper?
- Battery Cyclng
- Measuring batt.capacity charging or discharging
- 6 volt battery question
- battery weight
- nimh battery.. can I yse a car charger? is it ac or dc charge?
- nicad batteries
- Battery Cycling Results
- Which Charger do I need
- 12v Battery
- How can I tell if a charger is working?
- Heat!
- Recharging 12V
- Sanyo RC3000H okay for R/C aircraft?
- Jump the diode
- hitec 335 charger question
- Dymond TC problem? Help!
- discharging nicd down to zero volts
- liltrickler, how do you get a hold of these folks ?
- super turbo set up.
- Duratrax Intellipeak Digital Pulse Charger, any thoughts?
- Sanyo NiMH's, Dark Green?
- Trickle useless on smaller packs w/Superturbo & Supernova?
- NiMH & NiCAD in parallel ?
- ESV to Discharge?
- Old/Used Battery Disposal
- The FMA SuperNova/NiMH charging "urban legend"...
- Cycling with Dymond ST ????
- Can I charge a 4.5 amp starter battery with a 6 amp car charger?
- Need info on M.E.N. Charger. Model Engineering of Norwalk
- Chargers, Ni-Cd,Ni-MH,lithium, umm ??
- Sirius Pro Charger Upgrade is Nice!
- 5 cell nicad pack ?????
- 1100 ma vs. 700 ma packs
- 3.6Volt Battery with Accucyle plus
- Soldering a battery lead to a battery?
- where is the best place for Nicads
- Can Anyone Recommend ESV for 6Volt Battery?
- Super Turbo & new NiMH packs
- 12V Battery
- how to install a receiver battery pack?
- New Battery question
- Red- ?? about cycling
- SuperNova and NIMH--How?
- Cirrus Cycle Pro
- Is battery pack ok?
- rechargable alkaline, lowest safe running voltage
- Superbrain 959 manual requested
- Question on ampere.
- Can I use this charger?
- For Evan re:Super Turbo
- SuperNova 2.0 firmware revision?
- flying time with a 600mAh Sanyo Battery ?
- Which charger/cycler?
- new battery for soarstar?
- what can't I charge w/my cg340
- TMAXX power pack hookup.
- Dual Batteries / Single Rx question
- Super turbo TX/RX
- small reciver pack
- Panasonic 3000 NiMH
- Got my Super Turbo and have a question
- Battery charger for Wingo
- dual battery charging
- cordless phone battery
- Simple Recharging question
- Battery Charger for big gasser
- Another charger question
- New Super Turbo ?
- Lions... Life span?
- Radio Shack 7.2V 3000mAh
- optimum charge rate for Pb cells
- AstoFlight 112D Manual Needed
- Battery capacity
- nimh multiple chargers
- Nickel Metal For Ignition
- can mah be read with a meter
- What's the capacity of a 4.8V 600mAh RX pack?
- Gell Cell problem!! melting chargers!! :o
- Hitec CG-330 overcharges Ni-Mh
- Lions and NiCds and NiMhs OH MY!
- Super Turbo
- I have another Dymond ST question
- What setting to charge my battery on?
- SuperTurbo Problems !
- Pig tail atachment
- Duralite Plus???
- Two smaller NiMH versus one larger NiMH (help)
- Need an explanation, please....
- Help with Charger purchase
- Will a 12V field charger work w/ NiMH?
- Charging >1000 mah packs
- Nickel Metal Hydride Batteries
- WTB Einstein Charger
- Trickle Rate??
- Super Turbo
- Charger
- dymond super turbo charger
- Schulze Chargers for less
- The first few NiMH charges
- Tell me it aint so
- WTB Dual redunant system
- New Battery or Not?
- Looking for Good AC multi Charger
- NIMH vs NICD ???'S
- accurate capacity on old battery
- Duralite set up for sale
- Lithium
- Definitive Chart
- Paralell battery operation and Loaded VOM questions
- The CG - 340 charger?
- Simple charger circuit
- NiMH no fly voltage?
- Sirius Limited Edition and NiMH
- BEC and JST connectors: the same?
- hobbico voltwatch
- NiMH and Graupner Ultra Duo+ Chgr
- Where to buy NiMH batterys?
- super turbo
- Evaluating new power systems
- super turbo
- Volt Spy
- super turbo (or) sirrius pro plus
- Will FMA Chargeall Charge NiMH Batteries?
- Do you have to discharge a Nimh pack prior to charging?
- Charging Batteries - Fast or Slow
- batteries
- 4.8v VS 6.0v RECEIVER BATTERY
- How long does it take to get a reply from Litco?
- Overlander Batteries
- Anybody using NiMH RX packs here?
- Ace Digipace II (help)
- Question regarding Super Turbo
- 1 of 3 SuperNovas don't work !!! (updated)
- Information on Ace Super Digipulse
- Multiple Charging of differnt capacities/voltages
- Has anyone used solar cells to...
- Best under $50 charger?
- Super Turbo at Toledo
- Storing my rx, tx batteries
- Trickle charge on the Supernova
- hobbico 12v 7a battery
- Lithium Ion Batteries - Seeking Information and places to purchase
- Lithium Battery Discharge Limit???
- Potential hazards
- How to tell if a switch is bad
- For new nicd rx packs...which is best first charge?
- how long to charge?
- Need Astroflight 110D Peak charger help
- Elftmann Spring Engine Starter
- muti output charger for NimH (1650 - 2700 ma)
- charging 12v field bat with car charger
- Litco
- all in one charger/cycler???
- ESV Article in RCM
- orbit microlator charger. any owners out there
- cirrus super pro
- Cooling fan on a Soper Turbo charger??
- Does anyone have a Wattage PF Charger?
- Which battery cycler shoud I get?
- After research here are some sites I found helpful
- I give up! Dymond ST (trying to understand this)
- name some good/cheap 2400 6-cell Batteries...THX
- 270mA batt. ?
- Need to buy a single cell RC3000H NIMH
- Lithium-ion charger schematic
- Battery capicty and temps
- 2 packs 1 switch?
- leaving Nicads on trickle
- Toshiba NiMH Batteries for R/C?
- quick charging ?
- Cycling without a Cycler ??
- Good AAA
- Hanger 9 Sure Cycle Compatability
- charging NIMH???
- NiMH battery capacity?
- Programming FMA SuperNova 250S for NiMH
- Programming Ace Digipulse
- FMA SuperNova 250S
- Purpose or wrapping batteries in foam?
- AC to DC and more
- R/C charger
- Anyone use Orbit V6 Super Charger?
- Radio South Chargers ?
- What size pack ?
- trickle charger.. good or bad?
- Looking for charger
- How long will your rechargable batteries last ,duration of flight?
- Cirrus Cycler Pro
- Build it yourself Lithium (duralite) charger??
- Fail Safe Switch
- Which one is really the best
- New pack capacity??
- Hanger 9 Sure Cycler Question
- Curious question!!!
- 1800mil. stay chg?
- Charge and Discharge Rates?
- Wall charging question
