PDA
View Full Version : Batteries & Chargers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67
  1. twin sail servo power
  2. Charger suggestions and questions/help plz
  3. Hobby Services/Triton
  4. Wander plug
  5. NiCd pack capacity changing!?
  6. Where to put plugs
  7. Triton on a 12V Battery?
  8. Proper care and feeding of NiMh???
  9. LiPol-potential WMD!?
  10. Lipo????
  11. Orbit Orbit Microlader V6.2 Info
  12. Graupner
  13. Need advise for charging
  14. Old batteries
  15. Slow Stick Battery
  16. what should i do?
  17. 6v vs. 4.8v?
  18. Alpha 4
  19. Multi Pack LiPo Charger/Cycler
  20. Which charger & cycler should use?
  21. Hobbico Accu-cycle Plus or GP Triton?
  22. Wall Wart ?
  23. Battery & charger question
  24. Chargers
  25. Amp. question
  26. 6v wet cell battery
  27. nickles and nikes on same charger
  28. Please help figure this out!
  29. Glow Plug Ignitor Charger Gone Bad?
  30. Battery pack suggestions for Aerobird Challenger
  31. Sirius Pro Charger
  32. ESV?
  33. MWhy is my Triton charging at 7.2 volts?
  34. mpi onboard glow batery setup?
  35. NEW Pro Peak Charger
  36. So very new to this! (Charger question)
  37. Thumbs up for the Triton
  38. Consumption of energy
  39. li poly and pjs 550
  40. Futuba CR2000/BR2000 New Products?
  41. Battery for off-road TL-01
  42. Where to buy the Orbit v6 pro
  43. US Repair Station
  44. Schulze I6-330/430 - Do they have a cycling mode?
  45. nimh and digital servo's
  46. Charging batteries
  47. Graupner Mc-Ultra duo Plus II
  48. Accucycle Readings + Digipulse Charger
  49. How long should a NiCd flight last?
  50. li=poly with lion charger
  51. 2 batteries, 2 switches, not enough RX channels available
  52. field power supply
  53. "TIMEOUT" when charging at C/20 rate- What does it mean?
  54. Reviews - Litco A4, FMA Supernova, Sirius Charge Pro & Ltd Edition & GP FFC.
  55. Bill Baxter where are you?
  56. redundancy? I don't think so!
  57. Triton and the Challenge
  58. Hobbico MKII Field Charger
  59. Hobbico Accu+Cycle plus
  60. Genesys In Flight Power System????
  61. Lithium Poly Cells: Technical Aspects
  62. self made rx pack
  63. JR Battery Question
  64. Multi port chargers
  65. Triton....What problems have you had???
  66. high amp batteries
  67. Battery Charging does it realy matter????
  68. triton charger and small capacity packs
  69. swallow
  70. Were to get 380 NiMH reciever batt.
  71. Nicd or Nimh or Li-po
  72. Nicad Cell charging. Help Red
  73. Hitec NiCD Charger
  74. Please Red, Pick my charger for me!
  75. charging help please
  76. battery shorted?
  77. Competition Electronics
  78. More specific charger question.
  79. 12 CHARGING
  80. How many more hrs to charge with 45 ma intead of 70ma?
  81. NiMh Break-in help needed
  82. battery charger???????
  83. Accu-cycler
  84. What charger?
  85. Longer flight time...for elec. trainers
  86. Accu-Cycle Plus - Problem
  87. ACE "add a trickle",schematic?
  88. Schulze isl6-330 as a Field Charger?
  89. Li Po source
  90. Servo extensions ect.
  91. NiMh Charging Question
  92. How Low can Li-Poly Go?
  93. charging 11.1v with 10.8v charger
  94. R/C Accessaries
  95. ni-cad battery
  96. battery packs
  97. Nimh Charging Question
  98. Connector Question
  99. Battery Trouble
  100. My Triton charges my Li-Po but I can't charge to capacity!
  101. lowest voltage level on my TX?
  102. xmitter battery voltage
  103. Basic Charging Info Needed
  104. tamiya 4000 mah 6v
  105. 12V Field charger 1200 - 1900 mA rx only
  106. Best Bang for the Buck Charger
  107. Express Tech No Longer Repairs Tekin
  108. a question for current gurus
  109. Ultimate Charger II...will it overcharge?? Red, you there?
  110. CHARGING NIMH IN AUTO MODE HERES THE RESULTS
  111. Ace Dual Meter Vari-charger
  112. Need customed batteries ?
  113. Charging small battery packs.
  114. li-ion and li-poly
  115. What is the difference in Lithium-Ion and Lithium-Polymer?
  116. charge Lithium batteries.... WHY?
  117. single cell lithium battery for receiver???
  118. PRODUCT HAZARD ALERT
  119. Basic questions about charging & discharging Rx & Tx packs
  120. FG series battery/charger
  121. Battery
  122. PowerWheels Peq Perego 12v Battery ?'s
  123. Battery Checker
  124. Kokam Lipo
  125. MRC 969 PRO
  126. NEW source for batteries
  127. SUPER NOVA QUESTION???
  128. nicad charger for NIMH
  129. Is this NORMAL? -7.2v/350mAh peaked to 10.24v
  130. Is my battery going bad?
  131. number of charges from a Lithium
  132. transmitter pack voltage
  133. Supernova Charging Problem
  134. 1.25A Discharge Rate Too HIGH for 250-600mAh packs?
  135. Fuel soaked Battery - What to do next?
  136. NiMH and trickle charge
  137. Hobbico RC Multicharger?
  138. charging 12V field box battery
  139. Cycler and Discharger - What's the difference?
  140. 6 Volt 1100 or 1200 Mah? Help
  141. Triton: Charge current and early charge termination
  142. Winter care
  143. cyclers
  144. nicad vs metal hydride
  145. metal hydride
  146. cooked tx battery
  147. Epic Batteries Good / Bad?
  148. Revamp Old Ace Battery Charger
  149. Powerflite 4.8 Regulator
  150. Supernova 250 S charger
  151. on plane power supplay
  152. Battery or reciever??????
  153. Do car packs need to be broken in?
  154. Astro Flight 110DX - Cycler or Discharger?
  155. HELP!! - Charging Adapters for Astro Flight 110DX
  156. car to plane
  157. help!! 959 not working right
  158. Triton for RC cars application
  159. Triton charger questions
  160. What should I use???
  161. 1200 mah and 700mah
  162. starting to hate my triton
  163. Did I waste my time?
  164. Pro Tech 702
  165. Looking fo rhigher capacity AA cells.
  166. Batteries/chargers...its all so confusing...help please!
  167. What about Cell # when using Lithium????
  168. Best All 'round Charger?????
  169. Sirius or Triton Charger? PC powersupply for AC use??
  170. Wall Charger ?
  171. This could be a ...."well Duhhhh question" !!!
  172. I'llTry this Forum 1 more time
  173. Which Li Po for Speed 400?
  174. Dual Rx batteries
  175. Has anybody got a Super Brain 969 to charge a 12V battery?
  176. 12v Bat to go on starter?
  177. Charging using windpower
  178. PowerBox 40/24
  179. Gellcell blues
  180. gp 3300 discharge ?
  181. Problems with a new replaced Triton Charger...
  182. Chargeing 2100 mAh ?
  183. ever hear of a 10.8 tx batt pack - 9 cells?
  184. Voltage recovery in NiCd. Why?
  185. Can I charge single 1.2v cell with Triton?
  186. Dymond-Super Turbo Charger
  187. Does Dualite still sell 6.0 Volt batteries?
  188. Glow Plug Ignitor Spec
  189. where to find cardboard end pieces
  190. Help using the Dymond Super Turbo
  191. building my own packs
  192. I need portable power for field starter?
  193. How are those batteries??? any input please...
  194. etronic charger
  195. High Capacity Battery Packs for Slowstick
  196. PC Power Supply conversion
  197. BATTERY CHARGER SCHEMATIC
  198. Li-ion, how good are they really?
  199. Powerflite Batteries
  200. Please delete .. Thanks for the info
  201. Is it Ok to add a cell to a batt pack
  202. victor engineering super 2 -iq
  203. Power Maxx Batteries
  204. trident only?
  205. Using 1000mah NiCad instead of 800mah NiCad?
  206. Graupner Ultra Duo Plus II erporm upgrade
  207. GP 3300 8cell with 959 charger
  208. diode question
  209. Charging 50mah Rx packs?
  210. Choice of charger?
  211. Batteries of different capacities in a pack
  212. Newbie (to Battery Care & Feeding) Questions
  213. Dual batt. packs
  214. DC power supply
  215. DC power for Hobbico Accu-Cycle +
  216. triton open circuit error
  217. lithium polymer and speed control
  218. hobbico quick feild charger problems??
  219. Hughes Charger
  220. Cigarette Plug adapter Newbie Question.
  221. The ABSOLUTE best field charger!
  222. Not getting a full charge
  223. replacing pack w/ AA - HELP?!
  224. Dump'r Battery Dump
  225. Proper battery peak charging
  226. Cox J3 Spectra Battery...
  227. Newbie Battery Question
  228. nimh help
  229. Power supply converter
  230. what difference does forming make?
  231. Charging the MC-24 3000 battery?
  232. How do I know it is a Tamiya connection?
  233. battery chargers
  234. AMA Paints a grim picture field charger
  235. who makes the little yellow security clips
  236. NiMH field chargers
  237. Lil Trickler -trickle charge regulator
  238. 4500mah Nimh For giant scale planes
  239. Reverse charge
  240. Bad Cell??
  241. What kind of battey can my electronics handle?
  242. What size battery for a Quick Field Charger??
  243. on board glow battery
  244. Independent LiPoly measurements
  245. Replacing RX and TX batteries
  246. Using Cigarette lighter port for power supply
  247. Triton & Lithium Battery
  248. GP (gold peak) NiMH battery?
  249. Li-Po Discharge Capability
  250. Twin batts on single reciever...discharge question
