View Full Version : Batteries & Chargers
- Gens Ace Lipo Banana Plug vs. Traxxas Plug ?
- 1900 nicd charging
- Charge eflite battery with triton/electrifly balancer?
- ECO Power Charger review!
- Vista power
- How much abuse can a LiFe take??
- AC power supply for DC carger
- where do i look?
- ACCU-CYCLE PRO SERIES ELITE CHARGER
- Running Two Power Supplies in Series
- lipo protector??
- IMAX b6 or onyx 345?
- Charging NiMh with Tahmazo T15
- Time on the water
- New NiMH pack
- Balance Connector Info Please
- New Boy
- replacing old nicads, but what with?
- China Hobby Line batteries any good?
- reviving old nicads.
- Hobbico ventura battery needed
- Thunder Power TP820CD charger .. any good?
- My esperience for online buy a123 battery
- New to LiFePo4 packs
- help with charge times
- Is this a good deal?
- what power supply for this charger?
- Now what?
- Which charger has these features?
- nimh batteries not charging
- How to charge a LiPo??
- Battery replacement suggestions
- Battery to motor question
- I either need a charging connector or a new charger
- Tenergy LiFe Cells
- Hanger 9 amp/volt meter question
- battery and charger question
- TrakPower VR-1 dual charger
- Glow plug igniter won't charge?
- LIFE battery charging in the plane question
- 5 yr old LiPo battery charging issue
- TX charger
- GT Power A606 Dual Charger Questions?
- What Connector To Use?
- Noob here. LiPo battery charger??
- Hobbico LIFE battery and charger
- Sirius 2 Amp Dual RX Charger
- Voltage Cutoff Settings for DX8
- Suggest a battery and charger for my traxxas slash 4x4
- confused about batteries, I have searched still confused
- First foray into batteries, looking to charge a Ni-MH via solar power.
- My lipo Batteries
- My lipo Batteries
- NIMH Intellect/IB damaged cell? NEED HELP
- Breaking-in NiMH Battery Pack
- What does the "C" Mean On a Li-po??
- Desire Power Batteries
- LiPo Tx Pack
- Lipos in Hot Shed
- newbie needs help
- DX7 Unused for a few years - battery question
- Wire harness for running 3x 2s lipos?
- Decent NIMH and LIPO charger for under $100?
- Lit. ION batteries WHERE
- Lipo batteries 2 vs 3 cells
- li-po & lithium-Ion charging question
- lipo battery suddenly died, then restored itself back *** ?
- Tenergy batteries
- Gens Ace Lipos
- Can I fast charge NiMh batteries ?
- Charging 2 batteries
- 3W Ignition connector
- Battery Question
- 6v 700mah battery can be used for rc?
- gens ace battery lead help
- Do hobbico LiFe packs load test just like normal batteries?
- Confused as can be with chargers.
- Gforce batteries?
- Gforce batteries?
- Lipos and Ohms law
- power supply
- my 2s went under 6 volts, is it okay ?
- Resistance
- Whats a good charger. Just starting out
- Eflite 3 wire mini plug to JST 2 wire
- Repairing a lipo battery
- T connectors from Hobby King
- need help with a charger totally new
- What batteries?
- Question about Voltage used to charge batteries
- Charging Li-Ion with cellpro multi-4 Help
- Powerbox 40/24
- Charger for multiple 4.8V RX packs?
- Charging multiple packs on one charge?
- iMAX C-403 Super Simple Balance Charger
- 5200 2s lipo with 5000 4s lipo?
- How Can I Test To See If Lipo Is Damaged?
- Attaching leads to a multiplex plug?
- New ROC LiPo Batteries
- How much is too much?
- c- rating
- powering a charger
- scary find in the shop today
- post you charging set up
- Charger Question- Duratrax Onyx or???
- Dynamite passport Lipo Issues
- Converted PC power supply keeps turning off?
- Post in this thread to win a FREE 100W soldering iron from MaxAmps.com
- Wiring
- Which LiPo Should I Use?
- A123 Files for Bankruptcy
- cofused on batteries and charging
- Converting Power Supply For LiPo Charger Quick Help Question!
- Faster NiMH Chargers?
- A123 & Cellpro multi-4 almost up in smoke!!!
- Thunder 1220 charger problem
- Lipo Battery Fails
- Charging times and Chargers
- Why so long to charge?
- Turnigy Nano-tech 5C charge rate, really?
- Hitec X1AC with Sky Lipo problem
- battery amp question
- Losi charger, should I trash it?
- HobbyKing XD-6
- Dynamite Passport Lipo Charging issues?
- Singpost hobbyking problem?
- Duratrax 9.6v nihm
- Rookie iMAX B6 AC
- nickle metal hydrite (sp) voltages
- What lipo for jr rx?
- NM
- confused about this fromeco battery
- Cermark Issues
- Hitec x4 USB charge monitor
- RX battery question.....
- Safe TX Battery Low Level
- Hitec Full Telemtry Pk
- One charger for everything?
- Abused LiPos
- 2 5s packs for 10s question...
- Running lipo batteries in series
- What brand do you prefer that is made in china when it comes to lipo?
- Hitec Charger does anyone know if there is a Version of this one coming out of China.
- Itchy LiPo
- LVC IC PCB for 5S Lipo
- IMAX B6 confusing me, I need to measure amps
- External LVC needed.
- what do i need to connect 14.8 one pack into 2 pack cables ?
- New Receiver pack question
- Question about this specific battery
- Noob to lipo's- series AND parallel
- Lipo for Speckturm Dx7
- Li ION Packs
- Hobbykings Turnigy battery DX8 problem
- hitec charger
- battery charger and cycler
- question on plane crash and battery
- thunder power tp820cd, or powerlab 8 decision
- Turnigy 4x6 Charger need a little help.
- Convert Hobbico Nexstar from NiMH to LiPo
- Noob, what battery would be best!
- Brand New Nimh batteries how to treat
- i am considering using a123 or life batteries for my rx and tx. I would like to get an idea what the
- LIFE batteries
- LIFE Charger
- A new coupon code from MaxAmps.com
- Charging 5 cell NMH pack
- A123 Question
- Safe voltage to fly
- Charging Nimh batteries using an intelligent charger
- LiPo rookie
- help with battery for sullivan smoke pump
- Help me understand lipo run times
- Shink wrap high-street sources
- Battery selection
- NiMH charging
- Lipo problems
- BP hobbies cheetah LiFe packs
- Malfunctioning Charger Help?
- How to use LiPo sotrage on iMax B6AC charger
- Hyperion Duo 3 720i overload
- Eos0606i charger question
- Help with identifying connectors!
- Sanyo NiCads: are they still made in Japan?
- Is This For Real?
- Soldering made easy with The Jigs Up by MaxAmps.com
- Hobbico digital meter
- Break in for lipo 2s
- What lipo to buy
- Blade CX2 Charger
- batteries ok to swap?
- Lipo brake-in
- 8S Lipo and A123 charger?
- LiPo Batteries
- NimH Battery Questions
- VENOM PRO CHARGER UNBALANCED CHARGING?
- Charging Frustration ...
- Charging and balancing Life Batt with taking plane apart at Field?
- nigh battery question
- Lipo complete discharge?
- 2 cell VS 3 cell lipo
- Mobile App: RCcoPilot - assist with calculations
- duralite a123 sent batt ?
- Hyperion charger/battery help
- LIPO'S and minimum discharge voltage
- best deal on battery and charger.....
- LiPo Life
- Charger adapter help
- How Much Is too Much Internal Resistance?
- Battery Boss - RC's first reality show
- Looking for Clip-on Direct Current meter
- adapter board between eflite 4 pin 3s and hyperion lba-10
- Is This a Good Test?
- New battery charger and Nicd batteries
- What do I have to do with brand new Lipo's?
- Turnigy 8150 Charger no display back light
- 2000 mah 5 cell 6 volt
- Lipos, Regulators and Redundancy Questions
- Is it ok to run 14.8 or higher on standard servos?
- Lipo Question 2 x 3S in series or 1 x 4S?
- will these batteries work in this car?
- Thunder AC6 - Software Download here
- Thunder AC6 - Nimh charging
- Will this power supply work for this?
- TME Auto trickle adapter
- XT60 or 4mm Banana Connectors?
- lipo charge?
- beware Hobbyking warranty claims
- Charging question
- two cell li-po uses four prong plug
- imax-b6 charge set up
- duratrax onyx fan
- Battery field test load?
- Flight Packs source?
- just another charger
- China Sanyos???
- Why are we using NiMh...really?
- What amps on Avg?
- Dynatron Starter Battery Selection ??
- 18 v battery
- Locked up Triton EQ, advice on upgrading to a better charger
- Field charging
- Newbie looking for a chager....
- Life battery packs
- Using the Life discharge function on my Accucell 6 charger
- IMAX B6AC PRO questions
- charger/battery help
- What 6s lipo to run in Ofna buggy, Castle Mamba Monster motor/speed conteoller
- Charging with a Wall Wart
- Hobby King Buddy Code
