View Full Version : Batteries & Chargers
- Ace Super Smart Charger correct use?
- Come on Guys somebody has to know this??????
- Need of a new charger
- How important is a good charger?
- Dynamite Vision Peak 2 or Prophet Plus
- NEED a good VOLTMETER< WITH 1-2 AMP LOADS
- Duratrax Piranha vs MRC Superbrain 959 for 2/3A 1100-1400mah 6-7C Packs
- Lipo charge rates and time
- Only 3000mAh?
- Ultra Balancer
- Ace Super Digipulse Memory Backup Battery burst / exploded
- zagi xt battery pack
- 10,000 mah NIMH D batteries - possible to use in RC Cars?
- Discharge rate chart for LiPo?
- Which wires to use
- Why Fromeco or Duralite why not off brand?
- nimh hydra max batt.
- will a ni-cd charge a ni-mh battery?
- Can Battery Explode?
- Lead Calcuim Battery Question
- Lithium Charging ???
- Ignition Battery Question
- Any one got on of these bad boys?
- Discharge rate to = 400 speed motor?
- Lithium goes on fire inside a plane!
- Wiring Controller to Motor?
- Ofna charger w/ 1200mah venom...
- NIMH Impedence
- Can I use this charger for Heli and xp8103 batts?
- Oh and one more question!!
- Hey Guys surely not!!!!!!!!!!!!
- triton Charger - Peak Sensitivity setting?
- Li-poly
- 640mAh LiPo with Flatana Flat Out, flying time?
- Is 1C Too Much Chg Rate for OEM NiCDs?
- review: T-1000 Ultra Fast Dual Use Charger
- could electronic ignition cause a battery to go dead?
- URGENT HELP PLEASE NIMH
- is there a book "batterie charging for dumbies"?
- is it the pack or the cycler?
- Need a 16 cell NiMh+NiCad series charger for a special application
- Thunder Power 425 Charger
- Glo starter nicad 1.5V?
- Triton flashing DLY?
- Hobbico R/C Multi Charger - ADJUSTABLE??
- Marez on Parallel Operation - One more time.
- Batteries and Chargers Questions
- hot wires
- voltage drop
- Charging N-MH
- Regulators, dual packs, switches question
- Capacity of DuBro Sub C NyStarter?
- Charging voltage question?
- Freezing pack?
- Sirius Pro Plus
- New to lipos-rc18t- quick question.
- sub c chargers?
- Computer power pack as a charging source
- A few newbie questions about chargers and batts
- a "special situation" charge?
- Pickup charger adapter
- Where to buy heavy gauge wire
- Ni-MH Pack ratings UNDER rated??
- GP vs. IB NiMh batteries?
- Cycling new battery
- 22E NiMH Burnt!!
- Newbie slow charge question
- Lipo Battery connector Help!
- LiPo Balloon?
- Futaba Batteries
- 2-cell Li-pol; anybody want it?
- LIPO Charging with Swallow Charger
- Lipo Newbie
- 1/10 and 1/18 scale battery size?
- L R Taylor power panel
- lipo safety question
- Confusion on Cycling RX & TX NiCd Pack w/Triton
- Accu-Cycle Plus - Optional 12v DC Power Converter?
- LiPo - convert a 2S1P pack to 1S2P?
- Dynamite Vison Peak 2 -- should I charge at 3300 at 2 or 4 amps?
- Newbie Charging Question
- Charger Help!!!!??
- lipo discharged too low?
- Great Planes LiPos with FMA Cellpro?
- Li-po charging.......
- questions about Li-Poly batteries
- Help Checking packs
- Fast Charging a Torque Master
- Triton Charger heating up
- Old Ace Vari-Charger
- Dumb polarity Question
- BATTERY PACK CELL TESTING
- BATTERY PACK SELL TESTING
- Help with new batteries and a old pack
- Li-po & Pb Charging
- Li-po and RPM question
- Hitec Charger
- LI-PO....Bah...Humbug!!
- A friends Smartech .15
- 9.6v charger for 7.2v packs
- Quick Question
- Hobbico Volt Watch on 6 Volt RX pack
- Platinum EX power supply
- Triton says "Bat Temp too Low"
- 2000MAh pack
- Conditioning batteries?
- Battery connections
- How to charge a 'NEW' pack?
- RX charger
- Voltage Regulator 7.2v output
- Accu-Cycle Elite, Over time limit ???
- Careful with those batteries!
- HUMP 7cell pack question??????????
- dynamite twin peak
- Cooked batteries
- Integy INDI 16X512 charger?
- Amps to Mah coversion
- How do I use this complicated charger ?? Multiplex 5014
- vision peak ultra
- nz connection
- Tahmazo T10, don't understand the display
- 7.2V 3300mAh NiMH battery help
- Battery charger for Feber ride on car?
- Capacity and Temperature
- I am after a charger please help me :(
- Charger for my 7.2 Pack
- How to charge a Cyclon 2V-1000mAh battery
- Peak charging NiMH packs: do you or don't you? General consensus...
- The triton Charger, how accurate is it?
- 4.8v RX battery on jet
- Dynamite Vision Peak 2: Does yours beep when battery is fully charged?
- Triton question
- problems charging a single cell.
- HO power supply?
- Futaba CR2000 Charger
- BATTERY CHANGE
- lipo charging difficulty
- AccuCycle PLUS
- 12 Volt field box batteries
- A few questions regarding higher torque servos and NiCad batteries
- Charge rate for LI-Poly
- Dynamite Vision Peak II: Set the Amps to 2 for charging 3300mAhs?
- triton charger options?
- Cells
- Blew a triton charger
- Left TX turned on
- Plugging in Piranha (another question)
- ?Brand of Batteries for Building Packs
- Can I charge new AA NiMH batteries on old NiCd charger?
- large subc mah pack
- battery connectors melts to esc connectors help!
- 30% Edge hi torq digital what battery?
- 1800 mah NiMH troubles *Plz Help*
- Duralites & Powerbox EVO 40/16
- How much juice do I need??
- Cheap LiPo's
- lipo false peaks?
- Needed: Advice on Converting a Charger.
- Parallel Lipos
- balance adapter help
- Does anybody own this smart charger ??
- Prophet Plus or Duratrax Piranha charger?
- New Packs - First Charge?
- ALL-BATTERY.com customer service
- Cycling NiCd batteries.
- Anyone know where I can buy a 5 cell FAUP 3200 pack?
- Looking to Buy a Charger
- LI-Poly charge error
- batts. another new one?????
- Got a New Batt.??????????
- Charger Opinions
- Discharging a 1800mah NIMH 5 cells with Triton
- Over rated batteries?
- Celectra charger with Commonsense lipo
- Charging multiple batteries?
- E-Flite Pinnacle+ Charger
- Field Charging Question
- 12v charging time (quick question)
- Piranha Peak Charger AC/DC vs Dynamite Vision Peak 2
- charger and batteries compatable?
- quick charge advice: NIMH battery
- What's the best charge rate for NiMH?
- Charger Leads for Lipo's
- Tx Battery
- Li Ion Battery Setup for 35%
- Charger settings
- 12v adapter for lipo charger
- Miracle Switch or Fromeco Reliaswitch?
- Bigger Battery??
- Powerbox / Battery Question.
- aStraight answers please
- Help on using ice charger
- Li-Ion testing
- Lithium-Ion battery storage
- LiPo Batterys to ESC
- I bought wrong type of pack.
- More newbie questions
- Backup up charger ??
- Trickle while driving?
- Home made regulators?
- What's with Litco and Alpha4
- GP battries
- How do I wire three 6-cell battery packs in series?
- hitec Micro receiver
- Need double check of numbers
- Cant use car battery anymore
- How does voltage effect charging?
- 6V or 4.8?
- Using 2 battery packs.
- Charging new NiMH pack with Accu-Cycle!?
- Accu-Cycle Elite and NiMH batteries problem
- Astro Lithium 109
- Li Po Jitters!!
- charger settings
- what connectors on a Watts Up meter
- LiPo balancer compatability
- Powered Glider
- JR Receiver pack w/ Tower Hobbies receiver?
- Charging LITHIUMION ON THE ASTRO 109???
- accidental charge of 6 volt like a 4.8 pack
- super brain 809, lol
- Whats better battery? GP or LRP?
- Dynamite Twin Peak charger, proper battery care
- LRP battery conditioner - why use it, and how?
- Dean's discharger, proper use?
- MRC Super Brain 959 Question?
- New Triton
- Super Brain 977 Set Up, Help, Help, Help!!!
- which way do I connect??
- Checking condition of 7.2 nicad packs
- Tenergy packs
- i4c C Volt set up query
- Battery storage
- ATX power supply conversion
- triton recharging a 1.2Ah gel cell
- Battery Forming
- CONDITIONING NIMH'S WHY HOW??
- making new packs
- LOOKING FOR GOOD CHARGER
- Duratrax Intellipeak Digital Charger Help?
- batteries for tc4?
- NiMH faulty
- how many mah do i need?
- AA battery charging question
- Charging Question
- USING HITEC CHARGER ON JR2610
- Large pack configurations..
- Potential Battery/Charger Issue. Advice please
- jr 800rx battery
