View Full Version : Batteries & Chargers
- BATTERY CHARGER QUESTION
- Can you use the Sonic Charger on the new Batts?
- What LiPo/NiCad to use?
- Is this a good battery for my Rustler XL-5?
- Triton Discharge/Hobbico Voltmeter don't mesh??
- Considering LIPO
- My new charger and battery combo are acting slightly strangely
- How to Slow Charge ?
- lipo after crash.
- Batteries from Trinity Products
- Battery substitution question
- Charged too long?
- New Charger
- A123 brand packs - what balance plug is that?
- my venom hump pack has a different plug to my firestorm
- Is there a good AC charger for Lipos?
- e-station bc6 charger
- NIMH and NICD Question
- Help on Charging two packs Lipo
- NiMh packs got so hot, the wrap melted!
- Differene Between ICE and Onyx 230?
- returning to rc
- AC Power Supply for field charger
- li po overcharge?
- 8 cells and 11.26 volts?
- Cell charge/discharge settings and testing
- Accucycle Elite and Input Volt Calibration Message
- Newbie needs cheap charger
- Discharging a 3000 RX
- Hyperion 0610i NET help needed
- Cell Identification ???
- Difference between 15c and 20c lipo worth it?
- LiPo cells at different voltages after flight ... is this OK?
- Thunder Power LiPo Balancer - Question/Help
- Bad Business Experience - Budget-RC.co.uk - Electrolite.eu
- products from nitroplanes.com
- hypersonic charger question
- Tahmazo charger/balancer question
- xxx-t Novak and battery temps (high)
- Custom batteries?
- Charging Rate
- 9-cell 1000mAh Ni-MH battery pack question
- lipo charging
- need help choosing a charger
- How should lead acid be stored?
- New Battery Problem
- Help with an ICE charger
- 4.8v Battery Tester Question
- A123 Field charger
- Cooling while charging?
- e-revo and 4600mah a123s run time ?
- IS THIS POSSIBLE?
- Accu-Cycle Pro Display Problem
- Are the Onyx Chargers Any Good?
- Trimble Batterries
- power wheels charging
- Need Help with Charger setting.
- Gell Cell heats up and blows wall wart charger
- Please help, I am a NEWB
- replacement for accu-cycle plus, or should i go to lip rx/tx packs??
- ICE charging question
- M1's are available
- Best bang for the buck 5s Lipo Charger
- Bosch "Litheon" Battery
- Who moved my cheese .. err ... mAh
- 4-Cell Cut-off Voltage
- "Breaking In" New Batteries
- What configuration is this battery?
- Duratrax Piranha Digital Charger Question
- NEW LIPO WON'T CHARGE "LOW VOLTAGE"
- How do you know a LiPo is wearing out?
- LIPO PROBLEM SUGGESTIONS NEEDED- DETERIATION???
- Question for Wiring Battery Packs
- old schooler converts from nicad to ni-mh packs
- Thinking of switching to Lipo-Will someone volunteer to educate me on some questions?
- New Hyperion, new 3000 mAh, .10C, 30 hours first charge?
- Advice on Rx battery for Showtime 50 (6 servos)
- When are LIPO'S going bad or finished?
- Lipo swelling
- Allowable cell voltage variation
- battery charging
- I have a ? that will show Im lacking sense.
- Weight difference between 123 and lion
- Help picking a charger
- Need help newbie question
- LBA10 on A123 mode !!!!
- Advice on Battery Charger for my new Futaba 10C
- Possible bad new battery
- Vision Peak Ultra AC/DC Charger?
- ACE 0.10 " pin power plugs (Where To Find?)
- A123 Charging Question (I know, another one)
- VARIABLE RATE CHARGER
- LiPo Charging Question; Less than 1C
- Integy 16x7v6 strange behaviour.....
- volts to miliamps
- Decent A123 capable charger
- NIMh battery charging help
- Wild voltage fluctuation while charging
- Help me charge a 3S lipo using Hyperion 606i so i dont blow up my basement
- Battery problem
- NIMH self-discharge rate
- will this work
- Mixing differant mAh size batteries
- What's the difference between these Bantams
- Vintage 2V 10A lead battery help.
- New to the Lipo scene and have some questions...
- Venom VEN-0657 - A123 Charger
- Dead 4600mah A123 pack after 4 charges?
- Winners Circle NiMh's
- First lipo charger hookup question
- Soldering iron
- 12V Starter box batt ?
- Triton Jr DC to AC adapter?
- fastest charger
- Triton - Discharge Cutoff Voltage
- Help with charger wiring!
- Burned out M1 cells
- GT Power A6 charger "calibration mode"?
- does my friends had a nimh problem?
- Field Battery
- Field box battery Banana jack and Posts
- decrease in charging time lipo's
- "Higher-End" Chargers
- Connecting a Dynatron starter to a Dewalt 18v battery
- Can any of my current equipment charge a123 packs?
- Best Batteries
- Charger comparison
- lead acid capacity for charging LiPo's
- K-TRONICS Field Charger ?
- PC power supply conversion, works sorta ?
- Will these work?
- lipo balancer wiriing
- Hyperion & Accu-Cycle charging LIPO problem
- Lipo Balancers?
- Using the car battery to start engine
- Battery Failure
- LiPo questions.
- Question on TP-610C
- charger mahem
- Lead acid dischargeMyth?
- Hey Red (or other guru), thermal runaway?
- New to RC
- Help me Pick One Please
- max charge on lipos
- Battery Charger
- Is it bad to...?
- Best multi-charger < $100
- Bantam or Hyperion charger for me?
- NiCd Charging Woes
- MRC Super Brain 989
- NICD Battery formation
- Nexstar EP Select & a123's
- Battery problem.
- Lipo Charger
- Max ni-mh discharge rate for 0610i
- Wallwart timer
- Flight power RX charging,Balancing HELP!
- triton jr troubles
- 6.0 v NiMH reveiver pack ?
- Output voltage; Accu cycle elite
- charging a specktrum
- Batteries holding charge
- KR1100AAU or KR1500AUL or KR1400AE
- Easy as A123
- Best Charger for 2000mA/h Nimh
- News: China bans the export of LiPos by air
- Blown up Nickel battery
- A123 and regulators????
- Flyermate Lipo 4500mah 20C 11.1v
- Make a Reciever Battery tester?
- Store LiPo battery
- jr transmitter pack
- ICE question
- What charger will charge this?
- Venom Batteries?
- Venom Batteries?
- Parallel lipos, question
- Looking for a good charger.
- Li Po with glow plane?????
- Charging 2 packs thru a Y connector
- Hyperion temp sensors?
- Hyperion Duo question
- Shipping a LiPo?
- LiPo Battery Error - Need help
- charging LI-On batt with triton charger
- 4s lipo balance tap question (# of leads)
- BUYERS BEWARE OF BATTERIES AMERICA
- 518 watt charger ! chargebug HB1212 ?
- single cell lipo charging question
- 1/10 car application
- does this come with power supply?
- A123 DURALITE PLUS with Stay Balance Circuitry Low Down -TP610C Charger compatibility-
- electrically challenged
- Re-Peaking Lipo Packs
- Good enough?
- Is this battery good?
- li-ion batteries.
- battery charging rates
- Will this battery work
- DuralitE 6232 Doubts Of Wires
- cig. lighter plug?
- Best multi charger
- How many amps to charge LiPo packs at
- DeWAlt 36 Volts Packs / some(?) now with non A123 cells
- charging li-po packs
- T4 suggestions
- Lipo Balancer with Triton I
- What do the "C" numbers mean?
- zippy-r lipo packs
- Battery question for 16.8 Emaxx
- Ace Charge master problem... HELP
- A123racing's Horrible Customer Service
- Accu-Cycle Elite charging amps setting
- Dynamite 1900mah with Losi wall charger?
- How to measure capacity on lipos
- How long do you glow starters last?
- LIPO Newbie Help w/Charger connections
- E-Flite LiPo charger/balancer
- NIMH battery
- A1213/LiFe cells sources
- team orion D67 pro
- Glow batt charger question??
- Great CS from Venom Support
- TX Battery Question
- Am i overcharging my Nimh pack?
- LiPo degrading
- NICD battery formation
- How exact are sizes of the Common Sense RC battery packs
- 2250mah 3S1P 15C Lipo pack $19.95
- Sanyo 2500 mAh AA comes with 0 volts
- Help with charging venom 3600mah nimh batteries
- At what voltage to stop flying a 6V Rx pack???
- tekin bc112c charger experts
- Alpha 4 by Litco
- dual NICD battery
- Soldering wires to lipo??
- lipo balancer connector
- Large packs... Check this out!!!
- DANGERS OF CHARGING NIHM ON LIPO SETTING
- NIMH unexplained fast discharge
- "Hybrio" rechargeable consumer cells for transmitters?
- Is anyone using the McDaniel Super 466 Onboard glow?
- Why do most AC/DC chargers have more amps on the DC side?
- Competition Electronics Pitbull X3 Help
- Basic voltage/maH questions
- Problems with Futaba wall chargers.
- Is capacity always equal regardless of cell size?
- Can I use parkzone charger for car packs?
- Need help w/ charger!
- power lift in battery
