- Trouble with Esprit Model Order
- Airplane Battery Question
- Aristo-Craft charger
- LiPo in micro helicopters?
- If parallel is OK for LiION, why not NiMH
- QUESTION ABOUT ACE SUPER DIGIPULSE
- Making AA battery Packs
- Does the Triton charge at C/10 ?
- replacement battery for ferias ep
- 4500 mAh NiMH cells
- Charger Help!!!
- No Support From Hobbico
- FMA no longer a Kokam Dealer?
- Indi 16x2-nitro battery charger
- Very basic battery information needed.
- Cycling a ni-starter
- Charging RX Bat
- Ofna violator & battery packs
- Can I use Kokam 2cell in TX?
- Super Test Settings
- NiMh not fully charging
- Li Po - number of charges per pack
- Help !! New at this, need some imput on switching to NiMH
- LiPo Safety
- Nicad Peak charger questions
- Charging question for 6V 2000mah NiMh rx batttery.
- Triton Charger and Nicads
- Voltmeter
- Lost in Rx battery packs!!!
- what kind of batteries can be used in standard radio systems?
- AA or AAA Flight Pack
- Inaccurate Voltage Reading
- Need help with my Great Planes DC Peak Charger
- Suitable batt pack....Rx
- The Classic NICAD vs. NIMH
- changing 12v - 4.8v
- BE AWARE LIPOS TAKE ???? To INFORM
- HELP. Shulze got wet.
- How 2 Chg NimH's with Regular Nicd Chgr?
- Miniron charger info.
- Trition update. Why ?
- Weight of Hobbico 9.6 Volt 600 mah please
- Batt Help
- Hobbico HydriMax sanyo batteries, anyone use them, how are they?
- Lipos charge time ? NEWBE HELP
- NEW 6 Battery Charger?
- rechargeable alkaline
- Cycling Large Capacity Bateries
- Looking for charger/cycler for $100.00 or so
- 1
- Triton setting Question
- Have I used this delta charger right?
- Hobbico MK II charger problem
- Best Battery for Hornet 2
- Duralite voltage checking....
- Discharging batteries
- LiPoly Question 1C
- What current for Rx pack discharge??
- NiMh and NiCad AA cells max power question.
- Futaba 6XA battery life
- Cell phone batteries
- New Battery - Can't wait
- Battery life data
- NiCD to NiMH
- Field Charger Question
- HR3U 2100 in GS540?
- unattened Triton?
- Sanyo Rapid Charge vs Standard
- Hobbico Power Core 12v Charger
- Voltage regulators
- Does anyone use a MPI CH818 Charger?
- 12v LawnMower Battery wont charge Receiver Packs
- NI-MH 4500 mAh
- Triton Question
- Hobbico charger circuit change for NiHy
- Can battery get wet and still be reliable?
- redundant setup?
- Charger Thoughts?
- Boat battery problems
- Hitec CG340 Charger Needs Fixing
- lipos rate ? on TRITON/// Help
- 6v charge display
- Position Of the connector - airtronics(not z)
- Get more than 6 cells in a car.
- E-Flite Pinnacle- Quality or economy?
- Please vote - Hobbico MKII or DuraTrax Piranha
- charger for aerobird
- New Charger!!!!!
- Need Help
- li-poly and triton old software,is it save?
- 8.4 volt regulator
- Triton Peak settings for charging LiPo...HELP!!!
- Anyone seeing "C" 3500/4500 mah NimH batts.?
- Digipace 3 Schematic
- triton as a quick charger
- Alpha 4 manual
- Lithium Ion, Poly Use same charger?
- Never slow charge NiMh?
- Charger station
- Redundant batteries
- NEED SOME LI-PO HELP
- Digipace 2 charger/cycler manual or info neded
- Question on moving to 6V Rx Packs
- Sirius VS Hobbico
- What is it going on with schulze-elektronik
- JHM Aero Engineering Still in Business?
- Will a 4/5 AA 7 cell pack fit into a Park Flyer
- NI-MH Question !!!!!!!
- Some of the Best Customer Service I've Ever Seen
- Anyone see the new Futaba charger?
- NiMH batteries getting Hot!!
- Radical RC
- charging while charging
- Hughes Charge +
- anyone ever heard of this
- Kokam or E-TEC
- Battery and general guideance needed
- Were to buy Regulators online!!!!
- NIMH charging problem....I am cursed!!!!
- CHARGING LARGE PACKS AT LESS THEN 10%
- What to use????
- OK...What uses can we use .......
- **Can you charge a 12v car battery with an integy charger?
- ACE Super DDVC charger question
- Looking for a cheap 150 ma "wall wart"
- Schulze ISL series and Lomcovak Powercube charger-PC interface software
- Only 2 eight minute flights before charging.
- Is there a 500 Mah lipo battery?
- li-po pack for e-starter with stock motor
- Did I mess up bad?
- Saving an old radio
- slim batteries?
- Best place to buy a triton?
- HITEC Flash 5 SX Batteries
- Charge Rx packs with MRC
- Question on how to Power GWS MC-2002DC Charger
- Charging 6V flightpack batteries?
- MRC SuperBrain 969 Charger?
- 7.2 or 8.4 batteries for A/C
- Bypass switch on PC Power Supply
- Hobbico Quick Peak Charger
- should i discharge my batteries or not???
- RC MultiMeter for LiPo Batteries
- Charge Voltage for 9.6V NiMH pack?
- Need help from the experienced please.
- Any schematics for charger build on PIC ?
- Charger for Li-Poly/Ion
- Hobbico tcap 0100 charger
- Alpha 4 "V.LO" with new NIMH 1650 Sanyo??
- DC power converter for Hobbico Accu Cycle
- Aareva Charger
- Question about battery heat after hard run
- Miniron charger question?
- RX battery question
- 9Z battery pack
- Activator Digital AC/DC Peak Charger???
- Charging times for 110 mah battery?
- Thunder Power 2100mah/7.4v Test with 300 ics
- Battery Charging Leads for Triton
- Testing large 12v gel capacity?
- Is 3C2 on Astro 109 for 2 cell normal
- Triton and NIMH Issue
- Battery Comparison
- Good chargers for RC Car ?
- Repair Service on Triton
- Does 6.4 volts on my 4 cell nicad means its time to replace it?
- Superbrain 969 Questions
- rayovac alkaline rechargeables
- Sirrus Pro
- charging li-po with cv/cr powersupply
- Question for Triton users
- Li-poly AC charger
- Fast charge reduces battery life?
- where to buy Ace chargers
- Problem with Ni-Mh battery
- Difference between battery types?
- Nicad!?!
- GelCell charging ?
- Charging Amperage for Rx & Tx batts in glow planes
- gel cell
- Wal-Mart Energizers
- Shulze Isl6 help???
- DOES ANYONE HAVE EXPIERIENCE...
- Battery Charger with selectable amp and volt settings???
- Kokam - Balsa Products LiPo Questions
- Safety About LiPo Batteries Have Scared the "HELLI" Out of Me
- Eclipse 7 Battery Connector Info
- Bad LiPo battery?
- Parameters for LiPo regulator/monitor....
- lithium batterys
- Great Planes Triton Battery Charger Question
- Help needed for battery idiot
- Is 600 Mah enough for my US 40 with 7 servos ?
- disregard and delete
- Need help finding a SuperSwith
- Questions about Lead Acid batteries
- topping off a battery
- Hey Emory: Positive Terminal Corrosion
- Quick charge a 12V field battery
- NiMH Question
- triton-how to find battery capacity-memory?
- Schultze ISL6-330 question
- SUPERNOVA QUESTION
- Rechargable AAA Batteries...
- WALL WART CHARGING
- best charger for 12 nimh cells for heli
- newbee? triton / LiPoly
- Charger Poll Triton V Astro 109
- Accidentally shorting a new lithium battery
- Disregard-Good price on DC power supply
- Part # for the thermistor on Triton Probe
- LiPo Discharge Curve
- battery's
- newbie question for experts...
- Superbrain 959
- Charging & Capacity
- Charge jacks reversed when charging
- New battery help needed
- What size resistor for 250 ma check??
- Hobbico Quick Field Charger MKII overcharging
- Can Triton charge automobile batteries?
- Triton "Chg to Dsg" cutoff voltage
- DIY charger/discharger schematics?
- on board batt. help
- See the elusive Alpha 4 does exist
- TRANSMITTER BATTERY PROBLEM
- Diodes in dual pack set ups.
- New FMA charger
- I messed up
- mrc809 cahrger
- super brain 969
- home-made rx packs
- determining cell count 4.8/1.2=4 9/??=??
- Do higher capacity cells source higher current?
- 700AR pylon cells
- Battery and starter combo
- Yet another newbie charging question...
- cycling Tx batt prob
- Battery charging question
- 270mah purchase?
- Which receiver battery capacity?
- Field Battery, Is This Right?
- I HAVE 7CELL 900MAH{8.4V}
- why was shipping so much
- MRC 959 charger
- What gage wire for charging
- Red! Help me with on board ignition
- Duralites and Switch question
- Hughes RC charge plus
- “zero deltaV" & "constant current/constant voltage"
