PDA
View Full Version : Batteries & Chargers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. *Battery Damage Or Not**
  2. Solder or crimp ends on batteries?
  3. I need a battery replacement...please help!
  4. Radio shack 3300 pack?
  5. Charging Fromeco Relion???
  6. Small some what advanced charger for field use
  7. heli charger
  8. Sonic Charge problems?
  9. Ni-MH EXCHANGE FOR LIPO
  10. New Lipo
  11. Li-Po: What ma rate should I charge at?
  12. sonic charge balance cable connections?
  13. Making more use of charger.
  14. A123 batteries for European people
  15. New to LiPo - need help
  16. charging 1 pack of 12c VS 2 packs of 6c in series
  17. help with batteries
  18. Help with cycling results
  19. 3E Model Smart Lipo Charger
  20. Gell Cell with reversed polarity
  21. HANGER 9 SURE CYCLER
  22. 12v charger on 6v battery - problems?
  23. Need a versatile NiCad charger.
  24. Fried Charger
  25. Help me find a Charger
  26. Should NiMh's be cycled ?
  27. Did I fry my Duratrax Piranha Peak Charger?
  28. What is considered the safe Low Voltage ?
  29. Am I charging these things the right way ?
  30. D cell sized battery packs ?
  31. THE a123 charger
  32. lithium ion flight packs
  33. Second Batt Pack For Rceivers
  34. Charge nimh through lipo balancer output plug?
  35. charge dilemma
  36. Battery placement
  37. Using Triton Jr for Futaba TX pack?
  38. lipo battery help
  39. Charging batteries in the field off a 12v battery?
  40. LIPO battery charger question
  41. Hitec flash 5 battery
  42. NiMh batteries for car and controller?
  43. Someone help me please
  44. Dynamite 1900mAh 7.4v Lipo / CS Digital Charger
  45. When is FMADirect is coming out with the new Cellpro?
  46. Lipo Individual cell discharge protection(where are we headed)
  47. electronic circuit question
  48. eryProblem with DC 12V 7A Prolux Power SUpply with Apache 2030 charger
  49. Balancing by discharging or charging?
  50. Connecting two 5cell in PARALLEL.
  51. Charger help!!!
  52. battery maintenance i need help!!!
  53. Blinky Balancer
  54. Li-ions
  55. Storing charged lipos
  56. Bad Li-Po?
  57. Triton Jr. problem charging Li-Ions
  58. stupid double charging im a noob question
  59. FMA Einstein Service
  60. EASY Q FOR THE EXPERIENCED
  61. 4.8v 1100 MAH Nicad
  62. storing lipo's
  63. Looking for Sub-C single cells
  64. JR "Extra" receiver packs
  65. charging 2400mah battery with jr radio?
  66. 12C, 15C or 20C?
  67. charging nimh & nicd with ICE
  68. Replacement charger for a Accu Cycle
  69. Einstein XL stopped cycling
  70. Cells Warming Up?
  71. Best charger for the money?
  72. charging multiple lipos
  73. Integy 16X908 Batt charger - Help w/ Settings Please?
  74. Nicad batteries
  75. 2700 NIMH 4.8V pack cycled at at 1000 mah first time, and 1300 second time
  76. sanyo 4.8 vt 2400 sc -Charging ????
  77. New A123 cell in Winter?
  78. Where can I learn about LiPoly?
  79. Ni-MH 8.4V 300 mAh charger to LIPO?
  80. looking for a good field NiMH charger
  81. Charging 12v Gell Cell Battery
  82. Lipo or Li ion for flight pack battery
  83. Salvaging 2-yr old lipos
  84. Need help getting started in lipo
  85. Glow lighter fast field charger?
  86. Volatge charger specifications
  87. nimh charger?
  88. Charger question
  89. Did I hurt my NIMH pack?
  90. Triton / charge issue??
  91. Moving up to lipo!
  92. Charging AAs?
  93. power supply???
  94. 2Amp charge rate on tx battery?
  95. Triton and Charging 2) 2100 Lipos in parallel
  96. lipo battery charging
  97. How to charge nicd nimh with Bantam BC-5
  98. Portable Power Supply
  99. Charging AAs in my transmitter.
  100. XPV
  101. Use Miracle Switch Maxx for Li-ion regulator -- Receiver 60 scale ?
  102. Duralite with powerbox
  103. 2500 mah NIMH AA
  104. Testing lipo with Multi-meter
  105. Am I an idiot? Please help me with charger & balancer!
  106. Problem With DEANS PLugs
  107. cycled battery Question
  108. Are these legit deans?
  109. can you run a balancer and lipo charger off of 1 power supply?
  110. Lithiom ion packs at 3.0volts - Is this true??
  111. Balancing Lipos
  112. Lipo Charging
  113. dumbest question EVER!
  114. 3000 mah NiMH Battery Pack trickle charge question
  115. safest high rate discharge for Nicd?
  116. Lipo Balancer
  117. Use of three cell Lipo pack w/ 7.2v 400 can motor?
  118. Ni-cad Discharging
  119. will these lipo's work in my mini baja
  120. Ofna Digi peak (any info on this?)
  121. Racers Edge batteries
  122. Ni-Po Charge
  123. Completed ATX Power Supply Conversion
  124. HELP!!!
  125. Is my Accu Cycle gone bonkers ??
  126. What does battery cycling do?
  127. Accu-Cycle Elite Question
  128. Should I be discharging?
  129. Triton JR question?
  130. Dead Li-po
  131. all-battery - 4200mah (not impressed)
  132. does anyone have the Celectra?
  133. Help me with ATX power conversion!
  134. trition junior for lipo
  135. Are these good brand batteries??
  136. NiMH 3300mah vs 3600mah
  137. Please Help Suggest The Right Battery For Me
  138. New Hobbico Dual Peak Pro Series Charger ?
  139. how to connect Cell Saver
  140. question about GP Triton 2 charger
  141. Dynamite Charger?
  142. Duratrax Intellipeak Pulse Charger with 4200's?
  143. Hyperion EOS 5i DP charger does peak charging?
  144. duratraxx ice charger problems
  145. Lithium Ion question
  146. batt charger??
  147. How to convert an ATX power supply to rc use
  148. TX battery temp after charging ?
  149. Dura Trax charger
  150. Solder batteries while charged or not
  151. Hobbico Accu-cycle - modifications ???
  152. Help me choose the right charger
  153. power scource/charger question
  154. Best cheap batteries out there?
  155. Battery building and charger question
  156. Need some help! RCC-4CX Align
  157. dumbest question in the history of the world
  158. Discharge NIMH batteries
  159. battery for my losi 1/10
  160. Accu-Cycle Elite peak charge stops early ?
  161. Cell balancer
  162. False peak detection?
  163. Receiver Packs
  164. lipo's on ebay any good?
  165. Apogee 1000mah LiMN for receiver pack?
  166. Determining capacity of new RX pack
  167. New Batteries What should max Volts read
  168. Battery issues
  169. duratrax ice and 5 cell sub-c pack
  170. Nimah charging
  171. NEW! - Hyperion EOS1210i and EOSLBA10-A with A123 support
  172. Duralite vs Fromeco
  173. Ballancing plugs
  174. Equinox not working?
  175. Which Charger?
  176. 6v?
  177. New LIPO just came in and decided to charge it immediately!
  178. Best Value $$$ Peak Charger
  179. The safest Li-Poly in existence?
  180. New CSRC lipo's - need to verify settings
  181. Futaba FBC-2 Charger
  182. Nimh charging concept
  183. Li poly for glow plug
  184. Anyone making A123 Balancer yet? (and balancing wiring ?)
  185. Discharge Voltage
  186. New Lead Acid Field Battery Problem
  187. Super Brain 977
  188. International Shipping
  189. Please comment on this li-po charger.
  190. Mini review of bantam BC-8 charger
  191. Sticky thread for battery charging basics ?
  192. Hobbico Elite Charger- Need a balancer !
  193. To charge or not to charge (again)
  194. lipo battery balancer
  195. AA Battery pack or 2/3A?
  196. Im building a 12S A123 from dewalt pack
  197. Redundant battery setup
  198. Charger
  199. Team Orion Li-Po
  200. Stock Strycker 27-C charger
  201. Reciever Pack Performance
  202. what delta peak setting??
  203. lithium polymer discarge????
  204. Just Bought the Ultimate Field Charger
  205. JR Charger for Spektrum 3.0
  206. thunder power 3s 2100 mah lipo questions
  207. what do i do
  208. need some input
  209. SOLDERING! GRRRRR>..
  210. Megatech Juicebox 2
  211. New battery for my HoneyBee CP2
  212. Rigid 24v Xli li-ion battery pack @ Home Depot.
  213. Thunder Power 3s 2100 Mah
  214. what charger? please recommend
  215. is my pack fubar?
  216. Need Charger advice please!! Opinions needed!!
  217. Lithium Ion endurance question
  218. new tx battery or cycler?
  219. loose lipo cells??
  220. Charge/Discharge lead length
  221. Super Brain 959?
  222. which reciever battery
  223. JR 2700mah rx battery how many amps?
  224. TP 2070 New Battery Swell?
  225. 6V Rx packs. Sub C or other?
  226. battery charger for JR 2700mah rx?
  227. Misjon flite life tester
  228. align esc plz help
  229. 800 mAh 4.8 volt Nicad battery pack.
  230. 2/3 A NIMH question
  231. Common Sense TX batteries
  232. RX Battery Suggestions
  233. Rendundant Packs with PowerBox ?
  234. Lipo voltage regulator--11.1v to 9.6v
  235. Blinky balancer Ques??
  236. Has anyone thoroughly investigated Tenergy batteries?
  237. Manganese Batteries
  238. Battery weights by capacity (is there a standard?)
  239. SJ Swallow V2 AC/DC Charger
  240. Power Supply?
  241. jr xs3 stock losi lst2 radio,, another question
  242. jr xs3 stock losi lst2 radio
  243. damaged True-RC lipo ribbon cable?
  244. Power supply?
  245. Fromeco ION-3 cube charger
  246. How long till Ni-Cad's are dead?
  247. Integy LiPo balance connector
  248. New Li-po battery, what should I do.
  249. How would I calculate batteries in series/paralell??
  250. Dual Batteries for Big Bird
