View Full Version : Batteries & Chargers
- Using "Blinky" balancer with your lipos?
- Cell balancing for Nicad & Nimh cells?
- Need Receiver Battery?
- Accu cycle elite+9V rechargable---????
- How to use miniron to format NiMH
- Battery and Charger Questions for TL-01
- Tenergy brand 7.2 3300 nimh??
- GAS GAUGING LI Po Packs
- UNBALANCE AND THE ZONE OF TEMPTATION
- Anyone fixing the old Accucycle Plus?
- The BEST Charger --- ICE or the TRITON ?????????
- super Newb looking for RC Batteries for dummies page..
- Triton question? How to?
- Charger? Soooo many!
- cox radio batteries needed.
- what battery and charger to get?
- Nimh duracell "AA" batteries
- Time to charge
- FS8CP
- $20 LiPo Charger
- Li-ion battery
- Wanted - Futaba RX/Hitec Eclipse 7 batteries
- I think I really "F"'d up my LiPo's
- New Triton, Green Sticker, Li-on max rate .01A
- DuraTrax Intellipeak AC/DC Digital Pulse Charger
- Duralites dying & crappy charging
- how to tell Nicad from NiMh
- Charging LiPo's - advice needed
- Lithium-ion charging
- BalancePro HD 4000 2P6S for my Extra 300 and Stick
- 3 packs at once?
- calling all 4-step experts
- 12 volt
- Triton/ICE ??
- IS My LIPO Battery Ruined?
- 11.1 li-poly to run servoes???
- Change Battery?
- NI-CD Discharge procedure
- Triton charger question
- LiPo charger question
- 115V-AC to 12V-DC question
- How to run dual batteries......
- Dean Plug charging
- FMA Cellpro - fantastic job
- Receiver battery charging
- Intellipeak has trouble charging equalized pack
- Problems with KAN NiMH cells?
- Slow charge a 2400mah single cell?
- Battery Pack for my Reciever?
- NiMH 1200 mah HPI hump battery problem
- Lipos on airline flights
- Discharger
- Epic 3000 Nimh
- Duratrax intellipeak
- Type of Batteries for Hacker
- Solderless PC power supply conversion
- AccuCyle Elite Problem
- 1800mah transmitter pack $20?
- .9a or 1.8a
- Help-Charging with stock chargers
- Swallow Charger detection sensitivity
- Black Widow charger?
- Forming a 3200ma battery
- 18v battery
- Multiplex LN-5014 (Propeak Prodigy II) - Misleading !!
- Problem with triton charger.
- RS 232 Cable for 6S Charger / Viewer
- How much time for 2AMPS
- TRITON help pls!
- Graupner Extra 300
- Accu-cycle Plus and a computer
- chargers for appliances
- Glow plug amps
- Batteries false peaking
- kokam 502 lipo charger
- battery temp charging??
- Too late to form charge?
- Where to buy Batteries
- Skip NiCd / NiMH and go straight to Lipo?
- electronic ignition battery
- SR BATTERIES ARE THE BEST NICADS?
- Making battery packs: Solder gun vs Iron
- Hobbico Torqmaster 90 starter
- NiMh 7 cell, 600 mah, 8.4 v battery pack...HELP!
- Tower on board voltage monitors
- Charger Question
- Time it takes to discharge 3300's
- Peak detection sensitivity
- RX Pack-Nicad or Nimh?
- Charging help with IB4200s
- Delta peak
- Old Ace DMVC charger??
- Hughes Charge Plus Charger ?? Good or Bad
- Using LiPo packs in parrallel
- I NEED HELP!
- difference
- Futaba 6EXH: Bad RX switch or battery.
- combination switch, charge jack and volt watch
- One Charger for all?
- who sells large Mah tx batteries?
- HECO Lithium Solution Charger ! Have you seen one of these ?
- gp4300's,super brain977
- ALKALINE mAh ????
- When do u stop flying with 3 cell lipo?
- What is the best all around LIPO?
- I know almost nothing about Batteries and i need a charger please help!
- How to use Tanic Taps?
- NiMh dead cell
- lipo chargers
- Nicd Charging question
- What voltage for RX?
- bad lipo or bad charger? help please!!!
- Charging a field box battery
- Graphing a charge/discharge cycle
- common ground charging
- Thunder Power problems
- Terrified Newbie
- MRC 989 PRO CHARGER. IS IT OUT?? WHAT EXACTLY IT DOES???
- How much capacity do I need?
- Powering DC Chargers
- Trickle charging
- Litco Alpha 4 - Is there anything better (for my needs)
- Wanted to buy FS8 -Where to get?
- brain charger?
- 6v / 4.8
- SPEED CONTROLLER FOR LI-PO BATTERIES
- lipo question
- Mega Nitor Capacity
- Charging toys, love abuse?
- replacement parts
- best charger?
- Charging AA's
- Want Relaible 7-cell and additional charger
- Building Battery Packs?
- charging nicd
- my batt
- gp3300/ib3800/5 cell
- HydriMax 6.0V 2000mAh charge question
- How good is the Duratrax Piranha Digital?
- Nimh questions from a newb, answer from a pro?
- Energizer AA 2500 mAh at Wal mart
- Gel Cell Charging?? Quick Question
- How much battery do I need?
- How do I charge these?
- Battery Change
- Hobbico Quick Field Charger MKII Problem
- Using my 4.8V RX Pack for On-Board Glow & Backup
- PowerBox Battery
- Lipo question...please help...
- Cellpro Adapters and Pigtails - Coming Soon
- What Charger to buy for LI-PO
- sticky please!
- follow up of a building of RC helicopter with FS8CP
- Ni-MH 8,4 V 900mAh
- MRC 959 can charge 2 batteries?
- Anybody tried this Li-polymer 3.7V 6350mah?
- IB4200 Questions.
- 1800 mAh with hobbico elite
- Hughes analyzer +
- trouble with spektrum dx3 charging
- MRC 959 and reciever packs..
- GP does it again
- 6v 1050mAh NiMH question
- Battery connector
- Cycling NMh Batteries
- Should I stick w/ NiCD or get a NiMH battery?
- Weller soldering gun trouble
- Need rapid charger for amphibiCAR.
- Ripmax ProPeak chargers
- transmitter batteries
- Diamond Super Turbo
- Li-Po battery question
- Dynamite Vision Peak Ultra charger
- IS THIS OK?
- Batt Regulators yes or no?
- Need a recomendation for a field charger...
- problem with the viewer of FS8CPI
- How long should full charge take?
- The charger to get is...
- Is my battery toast?
- nicad battery expert wanted.....
- Anyone know what the Hobbico Elite temp sensor is?
- Intellect cells - 3300 or 3600?
- anybody knew this?
- Pulse vs. linear charger for nimh?
- Triton charger
- life of a lipo battery
- Best Bang for the buck lipo charger???
- Single stick TX
- Charger Recommendations
- overnight charging rate for nimh batt???
- Tech formulas for charging
- JR charger needed.
- IP3800
- BIGGER BATTERY = WHAT?
- What's a good battery for my Ex-Treme 330
- Sanyo Date Codes
- Fromeco or Duralites plus charger?
- NEW BATTERYS
- can't charge my nimh pack
- JR 6102 or 8103 - changing stick mode
- Thoughts on how LiPo performance is defined
- NiMH - How long between charge and use?
- How To Break In Battery?
- Question re Triton charger
- Voltmeter for 6Volt Receiver Packs
- wired 2 -600 mah packs together as one ?
- Duralite Packs with some Futaba servos ?
- integy indi 16x3v2.5
- AC adaptor charger - how long is too long?
- lipos and duratrax ice
- HOW DO I KNOW IF I CAN FAST CHARGE ?
- Duratrax 3600
- "Forming" Charge for 6 volt Receiver Pack
- Matching batteries at home?
- need help with 6v
- 6V ok for recievers? thought so...
- New 1000 mah 4 cell Nicad
- Winter Battery Revival
- did I fry a cell or two?
- Piranha charger question.
- Battery Recommendations
- Is a Li-Ion charger OK to charge LiPo?
- LI-ON / LI-PO Step Down?
- Anyone out there using "MaxAmps" Lipos?
- What do you suggest!
- LI-PO Pack Building (parts needed)
- Charging Question
- chager question, please let me know
- Is it sufficient????
- Making my own packs tips and tricks
- How many peaks can a pack experience near full charge?
- Nimh on a Nicd charger
- Quick Charger For NiMh Receiver Batteries
- Digipace 1 Instruction Manual
- UBA III plus cooling fan
- Shorted cells ??
- Dual li poly batteries
- 2 volt cell... where to buy?
- sub c cells in a mini ?
- LEAD ACID CHARGING QUESTION
- fast charging 7.2 volt car pack
- Reducing charge rate
- Need a 12 cell NiMH Charger
- Which of these 2 options?
- aerobird freedom
- Crystal salt formation in Li Po cells
- 1800 mH Tx Battery Pack
- Best battery pack for genesis
