View Full Version : Batteries & Chargers
- Standard Connector good for 4amps max?
- how long should i not leave a battery fully charged for?
- 12V battery question
- Nicad Identification marks
- 12V Power Supply?
- TRITON CHARGER !!
- overheating
- duratrax ice charger help .please
- Small Ni-cad cycling?
- Kokam 3S 3200mah problem
- Battery State and Expanded Scale Voltmeter
- New battery charging help
- Building a discharger
- Need seeting for AA on Piranha charger
- LN 5014 Charger and PS Questions
- should a add a fuse?
- NEW Lipo Prototype Battery Charger Questions
- Li-Ion vs Li-Po for Rx
- Why can't I charge this way?
- how long to wait after charging to use battery?
- li-po battery with li-ion charger?
- NO BS Batteries lives uo to their name
- How fast can i charge a 12v lead acid battery
- How's this battery pack?
- battery pack size ?
- need good deal li-po and charger
- Need help converting ATX power supply
- Batteries for Evader transmitter
- Charging single cell GP3300 on ICE
- looking for cirrus cycle pro manual
- ni need to discharge rx ni cads is there?
- My Sanyo's are to big...
- NiMH Tx question
- Dishcharge Rate and Voltage
- LiPo question
- Bad li-poly?
- ICE Charger error message?
- NiCad v's NiMH
- Hobbico Field Charger MkII Question
- Ripmax Pro Peak Constellation charger
- max amp Nimh
- West Mountain Radio Computer Battery Analyzer
- FMA Survey on Synthesized Receivers
- What lipos do I need?
- squishy lipo
- best charger
- Battery/quickfied charger question
- Nimh condition
- Got one! Need CR 2000 Charger Manual
- Help with electric flight......batteries?
- Is it ok to top off LiPo's all the time?
- Newbie 2 Lipoly Batteries - Dumb Question
- Home Made Battery packs
- DYMOND LIPO AC wall charger for 3 cell Lipos
- NiMh fails with Helis??
- Size of Battery?????
- Should I have brought a Triton???
- Converting a Triton to wall outlet?
- Hobbico Accu-Cycle Elite & 1650mAh NiMh Tx pack.
- new battery pack
- Want an Inverter
- 12Volt Gel Cell vs. Lead Acid
- New Product - PowerCube Battery Analyzer
- ice charger, maybe?
- nihm
- what pack
- Eagle Racing CDC V 5.0
- 4.8v last longer than 6.0v? Really?
- Is my LiPo sick?
- Multiplex or Dymond Super Turbo???
- Hobbico Quick Field Charger MKII - will it charge 7.2 batteries ??
- settings for an ICE charger
- Lead acid and gell cell confusion
- Over Geared
- Solar Battery charger???
- Triton Manual and LiPos
- Do Battery Holder's work?
- Would Someone Please Explain...?
- Lipo charger for Lion's?
- Battery Help
- FUTABA transmitter won't charge with Astroflight 112D
- How to Questions.
- 6 volt RX question
- ANY WAY TO SAVE THIS BATTERY?
- AccuCycle with HiTec TX
- charging nimh's
- Red Anybody, More charging/charger help please
- Multiple nicads pack
- Rechargeables for my t-maxx.
- Shelf LIFE of Nicad Batteries
- Help with charging and discharging rates
- battery charger, cycler purchase
- Begginers battery help
- Battery Charge rates
- Another Loaded Digital Voltmeter Question
- help the new guy
- Ripmax pro peak 12v power supply , faulty ?
- Lipo pack need to be discharge or cycle
- Warm Batteies ??
- What are the specs on this pack please?
- Safety circuit Kokam ??
- Loaded Digital Voltmeter Question
- Lipo selection for Big scale on 2 Axi motors
- Is this a decent charger?
- Li-ions in parallel
- Thunder Power earns a lifetime customer
- SC vs SCR sub C NiCd for Starter Power pack
- How to use Triton for NiCd initial charge
- battery charger died
- Hows this charger
- What Mah rating for a LiPo Rx pack?
- Charging set to 2000mah for 2600mah lipo?
- Futaba CR-2000, correct power supply?
- Accu-Cycle Elite....huh?
- Lipoly going FAT!
- Help me play Frankenstein with a dead battery
- Using Cells with Tabs for packs - Question
- charge rate?
- Futaba battery charger
- Making a battery pack
- Will my Ace Digipulse charge li-po's?
- TX Charge plug ?
- Multiplex LN-5014 Charger Ships & Review
- lion batteries for my giant scale
- Understanding True Failsafe Operation
- Which charger will satisfy my needs?
- Multiple port charger
- charging a 4.8volt, 700mah, 0.7Ah batterie on a 50ma plug ...
- what voltage before recharging 6 volts battery?
- Soldering LiPo tabs
- Lead Acid Batteries in parallel
- Triton & li-ions
- ESV modification
- discharging battery packs for capacity???
- Help with LiPos!!
- Help me
- Digipace 3
- triton cooling fan
- Is trickle/toppoff const cur or pulse in chargers like Triton?
- Whats all this 1C, C5, C2 ... etc
- Well priced battery sellers in the UK?
- Question about batteries
- West Mountain Radio CBA-II
- scam
- li po battery questions
- Profit from the real inside information.
- Charging 20 loose cells with a TRITON ?
- Battery Box Vs Standard Battery Packs !!!
- VOLTWATCH & JR Connector
- Linear Charger using AC/DC
- Schulze Chamaleon---Charging LiPo's Question
- Need Help, Batteries, Chargers
- Hobbico ESV MKII and NiMH battries?
- Hanger 9 7amp gel cell charger
- Best Charger Medium Price?
- Charging in plane with wall or triton safe
- NIMH 9.6v TX chargers?
- Cycler Recommendations
- Futaba TX pack- good price?
- Current Charger King
- Hobbico Accu Cycle and 2300mAh batteries !!!
- Charging NiMH Batteries: Help New Guy
- Checking polarity of charger/cable.
- Left Tx Switch On!
- Labeling Charge of the Batteries for know their charge history
- DC Power Supply - Good and Cheap!!!
- Need Help Choosing Between Two Chargers
- charger question
- Schulze Charger Broken---Please HELP!!!!
- Which 220v charger...Please help...
- Apache 2500 & Li Ion?
- Polycharge 4 undercharging
- Lipo Full Charge
- CYCLING NiMH's USING A TRITON CHARGER
- Airtronics battery question
- How to go LiPo
- How to test charger??
- NiCad use declining
- no light during charge
- New Nicads lossing capacity
- Best deal on sub c batts
- DuraTrax IntelliPeak ICE Charger - Manual, tips? (a frustrated customer)
- Charging questions
- PowerBox Lithium Poly Batteries
- Turbo Thirty and LiPo's
- Help needed with a smoked Hyperion emeter
- Accucycle Elite and Lipo Batteries
- Total noob! Need help choosing a battery charger
- 3 + 3 saddle pack batteries
- Best Charger For $150 Bucks or Less
- Checking individual batteries
- 6v 1500mah Nmhi
- The Battery Clinic/MA Magazine
- Redundant Battery Setups
- 5 Cell (6V) NiMh battery - Regulator or No Reg.
- ebay batteries
- lipo pack damaged
- tx loses flyable power in 15 -20 min
- Tamiya Y-adapters for Charging two batteries off single charger?
- Which would you consider more reliable??
- No Contact Problem
- Battery Upgrade Question
- Starter box battery charging,, please help
- Cigarette Lighter Adapters and DC chargers...
- Fried Transmitter
- Using CBA 2 and questions about discharging.
- Triton NiCd Cycling Problem
- Hobbico Quick Field MKII
- how many mah to fast charge a 6v pack?
- battery wire?
- this is for battery expert
- What are all these mA and V's ?
- Lipoly batteries
- Need a charger- Help!
- how long to charge a 3300mah battery?
- can the same charger be used
- Align charger for polyquest packs?
- UBA4 Battery Charger
- BalancePro - 2s Cell Balancing Charger and Battery Packs
- How do I locate a Byron Originals Re-Inactment?
- Deans Ultra Polarity
- ICE charger?
- Charging Fromeco Batts with Duralite Plus Charger
- LiPo Flight pack Charger??? PLZ help!!!
- Hobbico Charger Popping Fuses
- MRC Super Brain 969 Manual
- LI-POS VS LI-ION reciever pack
- new NiMmh failure to take chart
- Duralite Regulator
- triton confusion
- When does the std. 700 mAh Rx battery pack become inadequate.
- vision peak ultra charger-horizon hobby any good?
- Best value charger.
- Charging NiHh
- NiCd question
- Trinity batary packs
- looking for charger that can charge 2 bats at a time
- Gell Cell Battery to Field Charge My Equipment
- Charger recommendations ?
- Acuu-Cycle Elite Question
- dc voltage
- 9c Charge Leads
- Flashes "Cool"
- Prolux 4-8 cell 1,2 & 4 Amp peak charger
- Charge LiPo's on any charger!!
- help..I need a charger....
- Triton Manual-Or Lack Of
- Is it safe to fly below 4.8 volts??
- nimh battery charger
