View Full Version : Batteries & Chargers
- I have no idea what I'm doing
- can batteries ever be reconditioned if....
- Lipo volts
- Hobbico Model 930 DC can I use it for NI-MH
- Powerflite Charger with Duralites?
- Just a quickie!
- Battery pack question
- Question for Red: Parallel Packs & Impedance
- Perplexed about batteries in big planes?
- Low voltage cut off device for makeshift bulb battery discharger.
- Cooling fan on Triton
- Batteries for brushless TC3?
- RX voltage display
- Alpha4 no startup message
- NiCD question
- Am I harming my Nicad batteries...
- Need help on deciding for charger and batteries!
- Charger and Batteries compatable?
- Any good Battery Info Sites?
- How to work out when to land?
- Building your own packs?
- Triton VS. Accu-Cycle Elite
- Sub-C pack with 2 leads
- TRITON charger question ** anyone had this problem ***
- Charging + Dis-charging 6cell packs
- Voltage of battery packs - I am confused - why so high?
- New Battery technology!!
- how long to charge?
- Battery Life Expectancy
- charge lipo
- small 9 volt with a triton
- Auto Cell Detect Low Voltage Cutoff
- good all around charger for 75 bucks or so?
- Trying a AAA NMHD Flight Pack
- Question about converting PC power supply?
- Help 6 volt in rambler
- What rate to charge Nicds??
- Apex 12v switching power supply - opinions?
- LOOKING FOR A FEW GOOD 12V POWER SUPPLIES
- Need Meter for Ace R/C Charger
- Next Alpha4 opening
- Lead Acid battery and charging
- Whats the deal with these chargers???
- Length of charging leads
- Positive Temp. Coefficient Fuse (PTC Fuse)
- 5000ma D cells?
- Triton help?
- 1650 NiMH& triton
- Accu-Cycle elite
- Charging Batteries
- The New Duralite battery company
- Homemade Discharger
- DuraTrax IntelliPeak Ice
- regulator duraliteplus
- Nickel Metal Hydride Question
- AC/DC Charger L. Polymer 3 cells
- help with charging
- NoBS Batteries
- li-po questions on 2p+
- What Brand Voltmeter?
- HELP !!! - Graupner MC 19 charging first time
- picking a std mv or temp. for nimh
- Help needed Charging 6v Battery !!!!!!!!
- Super Brain 959 Problem
- MAHA nimh's Yea or nea?
- Hey Red, need a favor...
- Charging 10 D Cell 9000Mah NiMh, Help!!
- Deleted
- Lost Equipment
- Look what I picked up
- Charging Question
- 4.8V vs 6V
- R/CCarBattery Charge Time ?????????
- Quickie question (hopefully)
- Charg Lead-Acid with Accu-cycle elite?
- another dumb trition question
- Servo / Batt Question
- Average age of batteries when you retire them from R/C
- Question on Ignition Battery
- Sanyo 2100mAh Charging
- Location of Diode on T6YG
- Li-po charger questions
- is this enough battery
- Triton compared to Accu-Cycle Elite
- Another Dumb Newbie Question(s)
- TRITON charger by Great Planes
- Duratrax ICE charger...Triton's big brother
- Not overjoyed, eh Red?
- NEED CELECTRA EFLC3005 Manual
- Quick help on charging....
- Multi pac charging leads?
- Platinum Polymer
- HELP PLEASE !!!!!!!!
- free plugg
- Power supply question
- Triton writeup
- Help charging Tx pack
- Storage?????????
- Hitec CG-340- how good does it work?
- Are there any flat Nimh cells out there?
- Min. Triton Input Current (Amperage)
- The dreaded Black Rot.
- What are you getting in feedback from your cycler?
- Futaba CR-2500??
- Why won't They Charge?
- 1650 mAh enough for 5 hitec hs5645MGs?
- Digital multimeters
- XMitter battery pack
- Question about the use of Tadiran cells
- NEED HELP CHOOSING A CHARGER - TRYING TO STAY UNDER $50
- CYCLING BATTERIES
- question on batteries discharge
- See the Future - Zinc Matrix Batteries
- What is zero delta volt?
- Battery - remaining capacity percent per volt
- How should I store Battery's
- Battery Confusion
- Hey Red, did you see what Fred Marks posted about li batteries?
- weird problem
- How Warm When Charging
- Tired, Old battery?
- ??? Gold Peak Batteries ???
- Someone with a Turbo35FX or other high end charger please help!
- Battery markings and identification
- Is this charger any good and are these batteries any good?
- Battery identification markings
- Overcharging Battery?
- Please help..scared newb gotta prob!
- One receiver 2 batteries question.
- Pb Battery just for topping up Rx
- hangar 9, sure cycle
- Charging small packs on transmitter charger
- Novak Smart Tray problem
- Whcih battery matchers
- MOVED: 160 twin
- Digital Voltmeter
- Dual power source wiring
- Charging Nimh's with Nicad chargers?
- Charging/Discharging questions
- Pro Peak Supernova/Mercury Ex
- what is the best charger hangar 9 double vision or astroflight 114
- Single cell charging = difficult?
- Charging Futaba Tx Batteries with a Triton
- Did i do what i needed....
- Question(s) 4 Ace Super Smart Test & Digipulse Owners
- ISL 6-330d field charger and Power supply
- Hello, I'm not sure if people understood my question??
- Cant figure out which batteries are what???
- NiMH or NiCD? How to distinguish an unlabeled cell?
- Trinton Manufacturer's flaw
- SUPER NOVA 3000s
- batteries & speed control
- Is this pack big enough
- hydrimax nimh RX packs
- Fromeco reliaswitches
- New 2 NiMh Batteries - Quick Question???
- Charging li-ion with Triton??
- lithium non-rechargeable question
- Newbie to 6.v needs help!!!!!
- Li-po
- Is there a max mAh rating for Mini-Z's?
- am i in any danger??
- A couple of questions on batteries.
- Help with my first car
- New NiMH pack charging beyond capacity
- Charging Question
- Triton charge question
- Accu-Cycle Question
- MEN Chargers
- General question about nicads and charging
- Reversing the polarity on batteries
- Nimh Cell Battery Care
- Litco - oder list opens tomorrow
- NiMH 9.6V TX pack for 11.6V 50mA wall Charger
- Hobbico Voltmeter Question
- Welcome to the FMA Direct / Lithium Power Solution Forum
- LIPO 1200mah 11.1v (NEW) | Hobbico Field Charger MKII
- charging batteries
- how long do i charge a new battery
- Which chargers
- Who makes the best batteries ?
- Can't a regular charger/discharger equalize packs?
- Robbe Infinity 2 charger, which power supply?.
- Triton Charger? How good is it?
- High Powered Wal-Mart Rechargeables
- New NiCD doesn't take charge until complete discharge
- dymond super turbo question, what do the numbers mean?
- My Cosel and Triton for fun
- Solder NiMH packs.
- Charging AA's and AAA's with a Durtrax Digital pirahna
- Best Charger for Lipo, NICD & NiMh
- 7 days!!!!!!!!!!!!!!!
- pacific aeromodel charger / power panel
- A good 6 cell NiCD battery stick for racing?
- Battery management onboard
- Voltmeter Question...
- Newbie from the past, I need some help...
- SuperBrain 959 and 3300 NiMhs
- 12 volt field battery for charging?
- Quick Charging NiMH?!?!?
- Accu-Cycle discharge cutoff volt. confusion
- Is the Cirrus safe for NiMH??
- Low reading on a new Ni Cd 1100 pack
- Triton charger Help
- Very old ACE CVC, need help
- How many volts/5cell pack?
- Accu Cycle Question? Hope not too dumb
- Robbe Infinity 2 charger, good or bad?
- New 10C TP 2100 packs
- Understanding battery ratings by cycling
- which is better
- Nicad Question
- increase capacity on trainer
- reciever and transmitter battery charger
- Accu-Cycle Elite
- peak detect overnight charger
- Need advise on Batteries
- Litco Alpha 4 display question....
- battery help
- Mistake in Accu-Cycle's Manual........
- Power Panel/Rx & Tx Charger Combo
- Salt Water?
- Triton NiMh charging problem
- I need more power
- New to LiPo's
- Global Hobby 12V charger gets HOT!
- hobbico accucycle elite/ capacity ???
- battery management at the track
- Question about lithium polymer packs
- 6v Charging
- Is there a charger that does it all?
- Comercial NiMh question
- Higher capacity pack for a 6XA
- Building 4.8 v or 6 v NiMH packs
- 7.2 Volt Question
- How do i check my battery??
- Hangar 9 Voltmeter
- battery charging help needed
- Two different Mah packs into one Rx??
- Swallow charger acting up
- Perfect parallel battery set up
- Nippy 0808/98
- Soldering Li Cells
- Charging Li-Po -vs- Li-ion
- Best field charger??
- Hobbico Battery Cycler
- 12v power supplies
