View Full Version : Batteries & Chargers
- Battery for Dubro Kwick Start
- Help ID - Lithium Ion Bats
- What Setting to Use on My Charger?
- Problem with GP Triton?
- Best Charger???
- wireless LIPO battery checker
- Lithium Ion TX pack ?
- Safe Charge rate
- Battery Charging, Please Help
- 6.0 volt Regulator
- wrong first charge on NIMH
- How big and how many??? (A battery Issue)
- Sealed Lead Acid battery flight pack?
- Need identification help!
- ,,,Want to switch between 12 & 24 volt,,,
- Batteries
- How Cells are Rated for Capacity
- KOKAM 4TH Gen Cell Safety
- Exploding Lithium Battery Pack -= Video =-
- I need a volt meter with a load...
- Triton discharge Inaccuracy
- Schulze 6-330d Quick question !!!
- Intellipeak ICE problem
- "Do all" charger with Neon light?
- How to cycle a Transmitter battery
- charger
- battery pack for AXI 2814/12 on a Junior 60
- Question for experts... Battery change in turbine
- 2 Li-ions on a Y to reciever
- Cheap batteries for playing around?
- Triton: Discharge to 1.1 0.9 or 0.8 volts/cell
- How many amps should I set charger for?
- Batterio
- Battery questions
- MRC 969 help!!!!
- TX battery help
- Battery Seller Truth in advertising
- total Li-Po confussion
- New Pack Over Charges
- New discovery in LiPo ?
- Duratrax Intellipeak Ice looks like a better Triton
- New Toshiba Lipo recharges 80% capacity in 1 minute!!! Breakthrough
- Electronic Guru needed
- 3C li-po Parallel Charging ?
- NIMH battery charging question
- Toledo show
- Slow charging large packs with GP Triton??
- Future batteries ! Recharge in 2-3 mins
- new Orbit Pocketlader
- accu-cycle vs accu-cycle elite
- 3C li-po chargeing?
- Eliminating receiver battery with MSC?
- Cell unbalance
- NiMH recharged on a NiCd Fast charger
- Combo - LiPo Charger / Wattmeter / Motor Driver ?
- Will my Tekin BC112c charger charge GP3300's?
- Mah drawn working 1 servo
- My Battery is too HOT!! Can someone help me?!?
- Lipo not charging?
- Batteries for reciever??
- Futaba BR-2000 Battery Checker/Discharger
- Great Battery Prices???????
- Where to buy Lipo cells
- powerhouse batteries
- How do you charge you big lipo packs?
- Will 5 cell 7.2v fry my receiver??
- NiMh got hot when charging ???
- Buying Nimhs
- Best Charger/Cycler
- Sirius Pro for Cheapo?
- Understanding and Measuring Cell Performance
- KOK 3200 Discharge Curves
- Using Kokam HDR Cells in Big Models
- multiple lipoly recharges
- ni-mh battery pack good for transmitter?
- Inflated packs
- rechargeing lithium tiny batts
- Someone please answer this~!
- Cheap power supply (AC to DC)
- 8UAF Tx battery readout.
- Radio Shack NiMh RC pack
- IMAA's Marez speaks out on parallel systems
- Triton Charger step by step.
- Heco
- Charging NiMH batteries
- Lithium battery analyzer
- Charging correctly?
- ESC to battery connector?
- What DC Battery to use with the Triton ?
- Charging TX Battery
- "THE M.E.N." charging Ni-Mh batteries
- powerflite 1800mAh battery question
- Kokam HDR Cell Resists Ignition
- Alpha 4 lottery......
- jr batteries
- Batteries
- 12 Volt Battery for Starter - Help Please??
- Excessive discharge - Did I kill them?
- Lipo charge times?
- question about lipoly being wired wrong in series
- battery charging help
- Battery Questions
- Old battery disposal
- Charger doesn't have 1500 mAH jumper
- NICD or NIMH
- power waste from regulator
- Charging jack on plane
- Pack forming
- Charging 160Mah rx pack
- NIMH Capacity
- another lipo question
- VOLTAGE DROP?
- Best Glow Plug Starter?
- How slow can you peak charge?
- Trickle Charger options
- park flyer battery advice?
- Charger for 2000mah NIMH ?
- Lithium Hydride?
- Max power of hobbico Elite?
- quick charger for futaba 6exa question
- Sirius Chargers
- Triton charger
- LiPo, when are they empty ?
- JR tx charging question
- soldering a connector question for the newbie
- Help.. Messed up
- Can my SuperNova charge this battery?
- AccuCycle Elite
- What charger to buy
- NiMH 2200 Discharge rate
- Accucycler elite too high voltage problem
- THE MEN rc charger
- Batteries America
- Using Integy charger to charge TX batteries?
- Sirius charger
- Triton for dummies?
- Alpha 4 power supply
- How to charge a 2volt-1000 mAh battery with wall-wart.
- Need Power Supply for a Turbo 35 GFX
- Using Duralite charger on Fromeco?
- Ok...I guess I need a charger.
- Trickle/peak ? and Quick Glow Plug ignitor
- Securing battery connector in the Tx
- is it ok to change
- Will Alpha 4 charge 6 volt???
- Hydramax NiMah Charge / Discharge Rates.
- Best way to estimate Battery need
- interesting news on new lithium batts
- FROMECO'S Outstanding Service
- Charging 6V with "stock" wall charger
- Charging Receiver packs with ICE Charger
- 1000mAh charging at 100ma = 10 hour charge time?
- will limh bats sub for nicads
- do everything charger under $200
- slow charging 120mA battery
- Hyperion EOS 7i Charger
- ,,,Oops!!,,,Silly me!!,,
- Anybody using the Hughs charge+?,,What happen to the Alpa4?,,
- What voltage should I look for??
- Hobbico Power Panel problem
- Charging Li-ion battery
- Totally new to R/C - use NiMH or LiPo?
- False economy
- nmhd and sirius charger
- Poly-Quest Lithium Polymer/ Lowest Prices ever
- Lipoly Break In
- Fromeco TX packs!!
- electra arf motor
- Kokam 402 info needed
- Nmh batteries would not charge
- Power Box LiPoly Battery 2800
- What is the ideal charge rate for NiCd?
- charge voltage.
- regulators overheating??
- " AA " Nicad Questions
- kokam 502 charger
- need help choosing power supply for duratrax ice charger
- Pyramid PS7KX Power Supply
- Ace Super Digipulse
- Transmitter Charging
- ignore
- Battery Physical Size?
- Peak Charging Lipos?
- How does an automatic charger calculate number of cells ?
- milla volts
- milla volts?
- Is this a good deal?
- Futaba 9z battery case?
- individual cell taps
- glow plug igniter
- Triton Charger
- Sanyo 6V HRU 2300mah pack
- Hobby Lobby Quick Chargers a JOKE !
- Lithium battery question
- NiMH under loads
- Charging 8 AAs in parallel...
- Where percentage of capacity do you stop using Li Ion packs?
- Li_Po Box, container etc...
- Newbie Needs HELP
- Fut 'Ni-Cd Only' Servos w/Duralites ?
- Power Supply
- Futaba Packs VS Tower Packs
- Etec 1200 mah 11.1v, 10C LiPo battery pack
- 8C or 15C??
- Lithium Ion Rechargeables. Any Source?
- How to charge my Field Batt 12 V, using TRITON?
- BATTERY SET-UP FOR 28% QUESTIONS (RED)
- Argh! Ebay batteries keep peaking early.
- My Triton troubles
- Is it true?
- Voltage Test of Li-Poly
- Charger..Will it work??
- MRC 959 vs. Intellipeak Deluxe
- Accucycle Elite Question
- What charger do I need?
- Motorola wallwart for charging Li-Po?
- will it do the Job???anyone using the
- Astroflight 109 Discharge Cycle
- Li-Po Voltage at zero can I save it?
- Help, need 1 AMP load
- Anyone have experience with Dynaminte Vision Peak Ultra for LiPo's?
- airtronics battery pack
- Some preliminary battery test results
- lipo charger
- Battery Charging Rules
- AT & ATX * Updated *Computer Power Supply Conversion to 12 volt field charger power supply
- Fromeco Reliacharger OK at 1C ??
- Discharge or cycle NIMH
- Elite - can be used to check battery voltage at field
- Nicd and NiMH
- Chrging 2000 MA battery with 50 MA charger
- Dymond Super Turbo Charger Button Issue
- Charger for Futaba FP-T8SGA-P
- Whats the board for?
- Modding a 905 hobbico.
- Accu-Cycle Elite Question
- Charging multiple packs
- Limitation on DuraTrax Piranha AC/DC Digital Peak Charger
- problem with Pro-Peak Multi 'Q' Triple Output FET DC Quick Charger
- different capacity packs in parallel
- Futaba CDR 5000 not charging right.
- Discharge rate please?
- Hobbico Voltwatch & Voltwatch2
- Variable Amp settings
- NiMh, NiCd charging
- Sirius charger
- Hobbico Quick Field Charger MK II li-po incompatability?
- what to do with 2 cell lipos?
- Charging NiMh
