PDA
View Full Version : Batteries & Chargers
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. Is (2) 2700ma- Enough for a 100cc???
  2. Ace Super Digipulse wire set?
  3. Charging on 1:1 car battery?
  4. LiPo storage
  5. mulit charger
  6. Charging Gell Cell At .1C For How Long?
  7. Hobbico LIFE discharge voltage???
  8. Getting back into the hobby, need batteries.
  9. batterie life
  10. XPS Platinum Plus 2500mah 6S1P 65C/90C
  11. Gel cell charging
  12. Trouble with Hobbico NiMi
  13. Which Charger?
  14. Delta peak cut off value for NiMH 4.8V batt.
  15. series or parrell
  16. Battery connected all the time?
  17. 12 or 15V t power a li-po charger?
  18. Venom lipo harness
  19. Protecting Bullet Plugs
  20. Gens ace in 2011 Beijing model show
  21. Ebay lipos
  22. Newbee Here
  23. Thunder AC6 Charger Question: Connection Break
  24. It takes HOW LONG to charge a LiPo?
  25. Is there a programmable charger out there?
  26. B grade Lipos
  27. ?'s about balance charging
  28. Need Some Input
  29. Chargers
  30. Simple Circuit Extends Battery Charge - Longer Running Times for Your RC Model
  31. MaxAmps.com LiPo Sale - Limited time only!
  32. Turnigy 8150 Charger Only Sees 5 of 6 Cells
  33. 4.8 volts
  34. NiCd vs NiMH
  35. Dynamite Passport Ultra Question
  36. MK2 charger
  37. Need LiPO battery advice please
  38. 5000 ma MiNH Is this enough???
  39. Charger says 5S when auto-detecting battery (battery is 6 cells though)
  40. Super Digipulse manual
  41. new to charging
  42. Newbie Question
  43. 4.8 Pack Question on mAh readings
  44. Triton EQ question
  45. Guver Battery recomendations
  46. Replacing wall warts with RC charger
  47. Need help Discharging my NiMH's Packs
  48. How Much Puff is Too Much?
  49. nimh 5 cell 2000 charge at 2000 or 4000
  50. accu-cycle plus
  51. onyx 220 vs Venom Pro Charger
  52. Did I kill my lipo?
  53. Accu-Cycle Elite HELP
  54. Dell Power Supply
  55. Damaged LiPo 4S - Pics Added to OP
  56. Hitec X4 and HK Quattro
  57. can i use 650 mAh charger to charge 350mAh Lipo battery?
  58. guver charger recommendations
  59. a123 charging on thunder ac6 help
  60. Lipo for starter battery
  61. Temp Probe on Thunder AC6
  62. Single Battery w/Dual Switches
  63. In need of lipo charger.
  64. LIPO Volts vs Amps?
  65. Please Recommend Battery Type and Power
  66. speed control amps and volts? what does it all mean?
  67. What portable power supply with Honda 1000i and 5S Lipo 5000?
  68. Usable Capacity
  69. question about chargers
  70. 4 port charger for 7.4 li-po
  71. duracell battery n charger issue
  72. li-ion drops from 8.2 to 7.5 on 1 amp load
  73. need to claify somthing on charging
  74. Venom Pro possible to charge 2 nimh's?
  75. Battery life questions
  76. 4 Channel Balance Charger for 3S packs
  77. lifepo4 packs.
  78. Eneloops-Conditioning & Routine Charging?
  79. New Hitec X2 Ultima two
  80. 18650 li-ion rechargeable batteries
  81. 12V PB Field Battery - At What Voltage Drop To Recharge?
  82. let talk chargers
  83. 4.8 or 6.0 nicad for 2.4 radios?
  84. Need some help with Lipo Charging
  85. Thunder AC-6 charger pc help
  86. DEAD NIMH 6 Cell pack.
  87. Onyx 230 won't charge LiPo,
  88. Electr-fly charging 5000ma nimh gaettery
  89. SEARCH A CHARGER HELP PL!!
  90. Hyperion EOS720i problems
  91. So I screwed up
  92. new to lipo's need charger advise
  93. CONNECTION ERROR [MUST READ]
  94. Charging 4 lipos at the field - 4 chargers VS one Quattro charger
  95. HItech X4 - Will It Display Charge Data When Finished?
  96. NiMH Eneloop AA's-Will They Benefit From Conditioning?
  97. Charging Lipos and performance
  98. ESV-Loaded Voltmeter-Which One Do You Use?
  99. NiMH Conditioning - 3 Or 5 Cycles?
  100. Expensive US made vs Chinese Batteries
  101. DVM problems
  102. ElectriFly LiPo 11.1 3200mAh - open circuit
  103. EZ-Start charger for receiver batteries?
  104. 1 cell 3.7 1000mah charge time
  105. One cell cuts out?
  106. I cann't reach the max Capacity....
  107. Is HItech X4 Charger Good For Conditioning NiMH Cells?
  108. New to Electric, Have a Question
  109. Conditiong Process For NiMH Packs?
  110. ATX PSU overload protection - Myth???
  111. RC Power BC6 charger
  112. which lipo for my associated t4.1?
  113. lipo batteries need a break in?
  114. lipo charger
  115. Dumb Nicad Question
  116. Load Tester & Watt Meter Combination Tester?
  117. Alternative of Pb(12V) starter battery ?
  118. Sanyo AA 2700mah's NiMH No Good For Receiver Pack?
  119. Recommend a charger for me...
  120. HItech X4 Charger For Dummies?
  121. How close can I solder?
  122. slow discharge on triton eq
  123. Charging Ni-mh on a NiCd charger?
  124. LiFeSource Balancing Charger
  125. chargers????
  126. Questions on NiMh Batteries
  127. Thunder Power TP 610C & Life packs?
  128. Good Source Various Pre-made Banana/Battery Plug Adapters Used With Universal Chargers?
  129. AC/DC adapter, please help
  130. Charger with DC input of 12v DC, 3 AMP question
  131. TBM Li-ion Battery Question
  132. Hobbico Accu-Cycle Elite problem (?)
  133. GRAVITY BATTERY DONATION FOR RC CLUB
  134. 3200 Life Battery
  135. Where Do You Buy Your Battery Packs?
  136. New to RC
  137. Recommend NiMH Receiver Battery Pack Please
  138. Hardcase Lipo H-E 6000mAh 7.4V 60C results
  139. Charging 3s 5000mah with Accucell 8150
  140. What Attachment Needed To Charge AA Batts With HItech X4?
  141. My HItech X4 Charger Is Defective & Reliability?
  142. charger leaving cells at 4.23/cell ok?
  143. Battery helps!
  144. ************ battery
  145. Universal charger
  146. li po battery with vintage ESC
  147. lipo
  148. Charging at the field
  149. NiMh storage
  150. Is this right??
  151. Series using bullet plugs (no adapter)
  152. over charge
  153. Life batteries for Reciever packs - wiring connections
  154. supermate dc6 (DC) ?
  155. New battery?
  156. An Interesting Experience with A123 Battery Packs
  157. Seeking 25-30 Amp PSU For Battery Charger With Volt & Amp Meters
  158. thunder ac6 balance ?
  159. New NiMh, Peak charge??
  160. Dummy needs batt tester help
  161. How Are These Batteries Used?
  162. Nimh, Nicds, Li Po, LiFe, Li On Did I Miss Anything?
  163. What Is Best Of The Best Universal Charger?
  164. Zippy Flightmax 2200mAh 20C - High IR
  165. Eflite Micro pack charging
  166. Need help from lipo experts..
  167. Newbie Seeking Battery & Charger Advice
  168. LiPo Packs in Parallel
  169. Balance Tap
  170. Ac/Dc or Dc with power supply???
  171. Battery compatibility (Urgent Help Required)
  172. 2s lipo cells at near 1.5 volts each need advice
  173. Lipo Batteries HELP!!
  174. Thunder AC6 Software
  175. What battery and charger do I need?
  176. Ibec and battery
  177. Battery Help
  178. lipo charger question
  179. ENELOOP batteries
  180. lithium shortage by 2015?
  181. Capacity Cut-Off Setting for 12V 7Ah Pb Battery?
  182. How Many LiPo Pack Charges in the Field?
  183. New to RC have a question about chargers
  184. New Traxxas Summit, Educate Me Please...
  185. LiFE IN TX??
  186. Lipoly battery problems...
  187. Hobby King Quattro Charger
  188. Under cowl ingnition battery
  189. Lipo Battery
  190. what is it with my venom pro charger computer program? it wont work
  191. Great Plane L-39 Albatros - Need some advice - Help
  192. Low Voltage - A123's
  193. OPTIMA Yellow or Blue???
  194. hitec X4 charger
  195. Question on 6V NiMh packs
  196. Did I buy the wrong Lipo battery?
  197. LiPo puffed
  198. Multiple adapters?
  199. Which cycler for multiple batteries?
  200. Venom Prop Charger
  201. Thunder AC680 Settings
  202. 6.0 v 1400 mAh Charge Time Question
  203. venom pro charger-cell block balancer
  204. Thunder T10 Charger - Sais it charges LIFE but can't see option
  205. LifePro4 question?
  206. Switching to Li-Po for reciever Need regulaltor how many Amps
  207. Digital Multimeter
  208. Stand Alone LiPo Balancer Recommendation
  209. need charger cycler TX-RX only
  210. graphs 2s x 5000 lipo
  211. Deans to bullet adapter?
  212. ALWAYS charge on a concrete surface?
  213. HPI Plazma lipo, and their reactor 500 charger (will they fit? and replacement?)
  214. Do these have bullet connectors on them?
  215. Best quality batteries
  216. DuraTrax Onyx 100 vs. Associated LRP 610 Reedy 447-S for receiver packs
  217. lifepo 700 mah for Rx?
  218. lifepo 700 mah for Rx?
  219. What? Charging batteries
  220. Is this 12v source enough for my LiPo charger?
  221. Battery Charger/Cycler Recommendations
  222. LIPO
  223. I know very little about batteries need NiCd charger/discharger
  224. Li-Po balance question
  225. A swollen Li-po.
  226. Digital Voltmeters
  227. Nicad vs. Nimh
  228. Schematic for Accu-Cycle Pro Charger?
  229. lifepo4?
  230. Li-Po Charging?
  231. Charger for Fromeco Relion 2600 Lithium Ions?
  232. 7.2 v mini baja charging question
  233. Wire color code on wall charger
  234. how to charge AA NiMH - accucel 6
  235. imax b6ac lipo fast charge question
  236. Electrostar SuperCycle Battery Charger
  237. Venom Pro ultimate charger
  238. NiMh "on the shelf" life question
  239. Newbie Q: How do you charge your batteries at the field?
  240. Triton 2 EQ Questions/Problem?
  241. 12v pb battery voltage question????
  242. hobbyking eco 8 can't get to aut mode
  243. Discharging Duralite Lipo Packs Question
  244. why the price differance beteewn car nimh and airplane nimh
  245. 12v pb battery 7ah question??
  246. Which LIPOs for an Electristar?
  247. these ebay batts any good ?
  248. Recommend a LiPo charger for this app?
  249. turnigy li-po batteries
  250. Rustler battery choice
