View Full Version : Batteries & Chargers
- need to buy charger
- Traxxas 1/16 Mini Revo Slash Supercharge 1300 Stick Pack NiMH 8.4v???
- Charger Recommendation
- A123 construction wire size question & more
- Killed my JR Receiver ???
- NiMh Rx battery charge ?
- Poly RC Lipo BLOWOUT!!!!!!SALE!!!!!! All Models need to go
- charger's
- How big deep cycle battery to charge 5amp lipos at the field?
- Lipo wiring parallel vs. series
- Supermate?
- ni cad rx pack 5 cells equals "6 volt" pack?? Correct??
- Charging AA's with Triton2 EQ
- esky battery wont charge please help.
- What size RX pack?
- HOME MADE GLOW DRIVER.
- battery temps
- Good Discharge rate for testing RX packs
- Battery wires made contact, battery ruined or damaged?
- Batteries up front?
- 6v ni packs more like closer to 7v ?
- Onyx 230 vs Triton
- Battery pack wires
- Using a wall charger to charge my RC submarine?
- BATTERY HELP
- Battery Charger
- Charging Lipo, blinking lights.
- Charging NIMH WITH GT POWER A6-10 No cell number to enter? CONFUSED
- newbie charger question, charger for 6S or 2-3S
- 20-24'extentions ?
- Correct charger for lithium ion 7.4v 2600mah battery
- NiMH max charge rate
- lipo extentions
- Trion 2 "Open circuit" Error.
- Death by storage
- accucel-6 and NIMH
- lipo charging question
- Sj Propo Absolute 3014 dual charger, - Where?
- Power supply?
- Three wires?
- How to charge batteries?
- Pro Peak Prodigy back screens ?
- bought 2 atx 400 watt to do a psu for my chargers
- NiMH Receiver Pack Minimum Voltage When New?????
- Charging Losi Lipos
- Accucel 6
- accucell connectors
- which battery is suitable use on Trex helicopter?
- accucel 6 charger question
- Checking a new A123 pack
- Battery brand question?
- Power supply problem
- AA NiMH's with ICE charger
- need to figure out load on battery ?
- Regulated Switch vs Switch + Regulator
- Schulze nextGenn 10-36-12JR12X NimH?
- Battery basic question.
- ONBOARD IGNITION BATTERY
- Blue Lipo
- Lipo problem?....Need help
- Need A decent Charger for Lipos
- series and parallel batt charging
- Help with new battery!
- Reviving a 2000 mah nicd battery
- Li-Po PCM wiring
- Nicd question
- battery upgrade
- Charging in the transmitter
- Safe lipo batteries?? alternative to lipo?
- need charger for 1/16 E-Revo and 4x4 Slash please help
- Can a super brain 969 charge lypos ?
- Lipo Issue
- Thunder ac6 questions
- Triton Jr DC charger
- 24V 10+ amp power supply, where to buy?
- hello from...LDesousa
- what is a good Lipo standard?
- thunder ac6 problems
- Charged 7.2V pack to 8.6V with Passport Ultra.??
- NEED ADAPTOR HELP CHARGER
- Charging Batteries In Advance
- New idea
- Li-Po Newbie... Question on ESC, will it catch fire...
- cell/charger recomendations
- Use of an accu-cycle elite charger for a Li-Po Pack
- Traxxas RX Charger Probs
- Need help with power supply
- battery help
- charging tx pack
- Duralite Lithium Ion compatible chargers
- Cold Temps and NiMH Batteries
- Please recommend an inexpensive 2S LiPo low voltage alarm
- Duratrax 4200 nimh battery ??
- Would this work?
- New Lipo battery won't charge
- E-Revo VLX whit LiPo 11.1v
- Charger for 7.2v 5000mAh NiMH.
- LVC(low voltage cutoff) for slash
- Triton EQ/EQ 2 or Dynamite Passport Ultra
- Racers Edge Sure Charge 2000
- Thund Power tp-535
- True DC Power Supply
- Help with Soldering Station purchase...
- new turnigy 5800mah 25c lipo balance problem
- AA and AAA charging with Triton II EQ
- Is the Duratrax Ice a good lipo charger??
- Can static electricity hurt my charger?
- FlightPower EON X problem
- Battery help
- Screen on my venom pro charger went blank help please
- battery charging
- will my triton 2 charge lipo ?
- I have a very imortant question about lipo packs, warm after run????
- NiMH / NiCad problem
- lipo or nimh need help deciding
- Can I upgrade my lipo battery for more flight time?
- A123 Charging
- 1140 mAh Li-Ion Cells > Conversion For RC?
- how does a charger get ruined???
- Battery and Ram Landing lights
- Whats going on with TRINITY?
- Newbie help with a new charger
- PowerGenix NiZn Batteries
- Ice Charger Setting's LiPo
- LiPo Tutorial
- Do I need a balancer with the Apache 2500?
- Good All around Charger For Eletric Rc
- Is it bad to use a 4 amp charger on a 3000mah battery?
- Tenergy batteries for flight packs?
- Charging Light Colors
- gt a-6-10 200 w 6s charger
- A123 packs with balancer
- Min voltage for LiPo
- No voltage showing.
- Source for LiPo packs for E-Revo?
- Need help with Apache 2500 Li-Po Charger
- Turnigy Accucell-6 Reboot on starting charge
- ALL round charger 4 the Savage xl?
- What charger to use on NIMH
- Battery charging question?
- receiver packs
- Problem with NiCad battery pack
- Adding additional charge...
- nimh charge question on onyx 230
- venom saddle packs
- 0_0 Bent Lipo's..
- Compliments to FMA Direct
- How to Formation Charge with Accu-Cycle Elite?
- paper batteries
- Bantam EAC300 graphing software kit update
- Not sure what to get...
- Electric Airplane Battery Question
- Balancer for Charging
- What's your opinion of rc-battery.com products?
- Hyperion Eos 0606i ACDC frozen
- Traxxas EZ-Peak EZ Peak Smells
- Added a lipo and lost distance......
- li-po batteries
- quetion about this SUPER BRAIN 989
- Charging time for Nicd 4.8rx battery
- Low battery while on simulator
- Battery ID and INFO
- Lipo Lifepo or A123?
- Connector Question for a Noob
- RC-Power BC6 Software
- Are these voltage readings okay
- Newbie - need charging & battery advice
- FMA Balance Pro HD 6s charger won't charge - Help
- i need info on a charger, help.
- Lipo battery Education
- Help me find a new charger
- How I can connect my Ice Charger to new battery
- Discharging NiMH?
- forming batteries
- A123's Over Time, Unused???
- When to toss Alkalines
- IMAX B6 good or not?
- How to field test 6 volt receiver packs?
- Using 11.1v Lipo Batteries
- Cheap way to match lots of cells?
- E10 Lipo
- computer power supply for a triton charger?
- SLA Capacity Ratings???
- Laptop power supply
- Discharging and Charging on Lipo battery
- battery charge time ?
- lipo vs lifepo
- Acuu-Cycle Elite
- Running in parallel
- LiPo Charge Times
- 30C 5800 vs 5000 ?
- which charger can handle a common negative ground?
- ORBIT POCKETLADER
- 4.8 nicad sale
- Will this power supply work with this charger?
- 4.8V Nicd reading 5.32V on Triton charger
- spectra vs. fixed frequency radio
- orbit pocketlader
- X-Cite battery
- Power 15 Outrunner with Nimh??
- Question for Cellpro 4 users
- Battery weight help
- Run time
- Lipo balancer
- Storing NiCd, Ni-MH for winter
- putting lipo away for the winter.
- 2 ubec's?
- battery discharges too soon?
- help needed what lipo battry will be beteer ??
- Battery tech how to change connectors
- quick question
- Low cost charger - help!
- On Hyperion 0606i charger, how do I set a partial charge?
- please need help
- e-fliteblademcxcharger
- *6 Volt Nimh Pack*
- moving up in size
- lipo balancing question
- Lipo Beginner Questions
- Battery adapter tenergy to eflite
- My NiMH exploded in my room, small fire resulted
- Which type of battery can stay charged the longest
- Do you discharge LIPO befroe charging
- two 3s to 6s lipo adapter???
- ONYX 230 problem
- Wiring up two batteries? (Ni-Cd)
- "storing" LIPO with Hyperion 0606i charger
- Did i ruin my batteries?
- Pics of Parallel and series charging
- *Charging Issues*
- Help with new 2000 NIMH issue
- accucel 6 5A.. what power supply are u guys using??
- Nicad shelf life
- Am I damaging my nicads
- Another newbie charge question
- Litco Multi-Cycle
- Rechargeable zinc-air batteries
- Ballancing lipo poll
- supply low price lipo battery with high quality
- Turnigy Accucel 6 charger question
- Charging multiple packs at once?
- enerland 5s 3700 strange problem
- Lipo Series/Parallel Combo
- LiPo Shield
- mah/amp charge rate.
- Lipo question
- Is a Futaba 500 mah battery sufficient for a 9CHP transmitter?
- FlightPower in North America
- Triton 2 Communication Error
- Litco Alpha 4
