PDA
View Full Version : Batteries & Chargers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. Dual Batteries for Big Bird
  2. Cheap and Good Li-Po's
  3. High amps in...high amps out??
  4. Triton2 question
  5. battery connector question
  6. super brain 989
  7. 6.0 v Set up for Giant Scale
  8. Triton 2
  9. Batteries , Batteries, Batteries, where are thou ??
  10. Good charger for sprint 2 rtr??
  11. 2/3 A nicad receiver pack?
  12. Charger options
  13. Difference in cells
  14. 6v BATTERY HELP WANTED
  15. Does the Dewalt battery pack have a build in motor controller?
  16. 12v battery help
  17. POWER SUPPLY HELP
  18. Choosing a Charger
  19. Ready for a good charger...
  20. MPI Miracle Switch and Li-Ions
  21. Fromeco Pearless Batteries
  22. Duratrax Warhead
  23. NiMh Problems
  24. Triton charger and Lipo *please help*
  25. Current measurement
  26. NiCad internal shorts ?
  27. ICE ? Triton ? LRP Pulsar?
  28. Good source of Rx/Tx battery packs…
  29. li-poly over discharge HELP!
  30. Wall Wart modification?
  31. General NiMH question
  32. Using a battery and charger from booster pack?
  33. Cell Pro 4s and a123
  34. how to connect 2 LIPO cells
  35. 6volts pack on Digital Servos
  36. Multiplex LN-5014 charger and lithium ion batts
  37. Battery Breakthrough?
  38. Mislabeled Apogee LiPoly battery...or wrong battery?
  39. Triton Charger Question
  40. 12volt charger
  41. Nicad/NiMh Charging with Triton issue
  42. Another Ignition Switch Question
  43. lipo batteries and cell balancer
  44. Best field battery tester?
  45. Heat shrink blower damaging the A123?
  46. Battery cycle
  47. lipo packs and chargers
  48. cycler prices
  49. Nimh mah rating
  50. Why Are Dualsky Batteries Different?
  51. Charging 2s 800 MAH
  52. A note on using Intellect 4200 for glow drivers
  53. mAH or Volt`s
  54. *Charging 1800 mAh Ni-MH Packs*
  55. totally confused about buying li-po battery
  56. Help!!! Lipo battery and charger question
  57. Turn a 3 cell into a 2 cell???
  58. Good place to buy Lippo batteries
  59. New Batteries
  60. cell dead in the lipo????
  61. Battery Help
  62. Platinum EX charger and SJ Propo balancer
  63. Thunder Power 205
  64. Heli use anyone???
  65. Thunder Power Lipo Cell Balancer Review
  66. Swallow charger and charging
  67. Parkzone ?
  68. Futaba 14MZ Battery & D/C Charger DEAL!
  69. Dell Server Power Supply
  70. DID I KILL IT?
  71. good charger for 3300's and up
  72. A123 shipping help needed!
  73. Ace Digipace II
  74. Tenergy 7 cell 4500mah packs
  75. Futaba 14MZ battery
  76. Futaba 14MZ battery
  77. Lipo Charger with balancer
  78. a 14
  79. FMA Scorpion Lipo pack?
  80. Discharge Cutoff Voltage - Nicad and NiMH
  81. voltage error
  82. What type of battery can i charge with this
  83. Very Basic Battery Questions
  84. Accu Cycle Elite and Lipo Battery's?
  85. Swallow or E station??
  86. discharge rate of a 700ma nicad pack
  87. Triton2 Charger Question
  88. LiPo with regulator and NiCd for RX pack
  89. ? re Accu-cycle Elit
  90. battery help for stampede
  91. Replace NiCads in Tx/Rx with NiMhs?
  92. Hitec 3D Lynx Lipo pack available?
  93. 6v rx help
  94. Receiver battery help
  95. Help finding 4.8V 350mA 2/3AAA flat pack
  96. LiOn TX pack for JR 10X
  97. Rules to charging Batteries
  98. Discharge help please!!
  99. Futaba Tx/Rx NiCd - not reaching advertized capacity ?
  100. Lipo problem
  101. other sized A123 FePO4 cells ?!?
  102. Would 9.6v walmart type battery work with ...
  103. Triton2 and Fromeco 7.4v Li-Ion HELP!!!
  104. Reciever Battery for 50cc Plane
  105. help with DIY 12v power supply
  106. XTM XT2 BATTS
  107. Batteries not fully charging
  108. Padding RX Packs
  109. OK, How old and should I bother
  110. New Accu-Cycle Elite
  111. Triton Charging through Fromecto Badger Switch???
  112. RC airplane servo batteries
  113. Battery pack
  114. how long will A123 last in my application ?
  115. Did I ruin my battery?
  116. Hydrimax battery question
  117. futaba 3PK
  118. new to piranha charger
  119. Help looking for A/C charger?
  120. Walkera charger
  121. Ignition Switches
  122. Help understanding 80% charge rule with Lipo batteries
  123. Li Poly run time?
  124. charging 8000 2s2p
  125. Is the superbrain 977 a cc/cv charger.
  126. How long will a lipo maintain %100 charge?
  127. A123 as receiver pack - no fly voltage?
  128. Retrofit balancing leads to old Lipo pack?
  129. Futaba Skysport4 T4VF need info about it
  130. accu-cycle elite lipo question
  131. a123 experience
  132. Equinox balance Charger and Skyshark battery
  133. duratrax ice charger questions
  134. RC-POWER 601BC BALANCE CHARGER/DISCHARGER.
  135. li-po battery and charger
  136. Tejera Microsystems Engineering Xtrema charger Review Comment
  137. Fromeco badger switches
  138. Fromeco Peerless 4800 Help
  139. Micro-T NIMH charging with Dynamite Vision Peak Ultra
  140. Transmitter batteries, are they still good?
  141. Is this normal?
  142. Triton2 and Ice Charger......
  143. Braum Electric Toothbrush
  144. NiCd test interpretations
  145. ADDING 1 cell to 7 cell NIMH Pack - HELP!
  146. GP 3300 Nimh Packs
  147. Confused with Accu-Cycler Elite
  148. Is my Li Ion battery pack ruined?
  149. AC/DC Chargers
  150. Bantam e-Station BC-6
  151. A123 charger
  152. NiMh charge rates
  153. charger/cycler
  154. best Lypo charger for my...
  155. Weak 3S 10C 1250mAh packs?
  156. SuperBrain 959 Settings?
  157. New to lipos and charging - basic how-to questions
  158. NiMh & NiCad long term storage
  159. AccuCycle Elite and Lead Acid Battery
  160. need opinions
  161. Battery charger Prolux ni-po-charge
  162. Duralite battery pack falls below 5.5v
  163. MRC Super Brain 989
  164. Triton Jr Lipo Setup
  165. Peak charge a JR Quattro TX?
  166. How long would this hold a charge for?
  167. The answers to a lot of your LI Po questions
  168. please explain how lipo's get charged?
  169. Vampower Battery?
  170. Imax B5 lipo charger
  171. NIMH and Litco Alpha 4 Question
  172. Please Help - Batteries in Motor Go Straight to Dead
  173. A123 question for new user?
  174. 1 lipo or 3 nimh
  175. equinox cell balencer
  176. 3S2P LiPo Help
  177. Form charging NIMH with Elite
  178. ** HELP ** battery charging question
  179. Charge 2x FP4900 Packs at same time ?
  180. FMA Balance Pro Update for A123 Cells
  181. SPECTRA 4 and higher charge currents
  182. How to drain your packs??
  183. Discharge voltage - with load or no load?
  184. Alpha 4
  185. Forming NiMH's ?
  186. words
  187. Testing/charging older batteries
  188. What supplies do you use to create a battery pack
  189. 6S Li po: charger/balancer?
  190. need help..making own charger coard (TX)
  191. Ni-MH question
  192. TP1010C Manual needed
  193. build my own hump pack?
  194. Accu-Cycle Elite - is there a new version???
  195. Balancers....
  196. Early Triton on LI-po's?
  197. Noob question
  198. Mega 1 charger help...
  199. anyone out there know about the Hobbico quick field charger mkII?
  200. looking for a high end balancer for astroflight 109
  201. Digital Piranah charge question
  202. On board glow batteries
  203. Will these batteries work for the propulse
  204. Can anyone help with a soldering question
  205. Confused on 6 volt 2700mah packs and Wall Warts....
  206. Tracking data on battry packs
  207. Shorted Left hand charge port on Elite....
  208. super brain, problems charging 12v gel cell
  209. Interesting
  210. New soldering iron
  211. HELP is a cell bad
  212. NiCad or NiMh for Heli-Max Super Starter?
  213. A123 balancing and Hyperion LBA6
  214. restoring a dead NIMH
  215. Newb / Batteries
  216. Is my math correct on charging new pack?
  217. NiCad quick charging
  218. Will 1 Nimh battery be enough?
  219. Triton 2 compare to Triton
  220. Triton Jr. + LiPos
  221. How long to charge NiCad Receiver pack
  222. Triton 2 and Futaba Tx battery
  223. nimh cycling? battery experts needed
  224. Triton Jr. + LiPos
  225. Looking for good, cheap battery cycler
  226. Hobby Shop Location wanted
  227. NiMH batteries and Elite charger ?
  228. split pack
  229. NIMH Brand Preference?
  230. two 7.2v NiMh packs in series
  231. battery hook up
  232. Blinky vs. Equinox
  233. Dest company to get IB4200's from?
  234. WHERE CAN I BUY THIS CHARGER?
  235. Discussion - Robbe Unicharger 6 - Accuracy?
  236. www.maxamps.com your new source for A123 cells
  237. charging li-po under 1 c
  238. Battery charging Q
  239. Digital Piranha charger question
  240. Superbain 977
  241. Wall charger question
  242. 6V hump pack need help charging
  243. Can I use any of these Wall Chargers?
  244. Apache 1500 lipoly charger/ got info thanks
  245. Balance plug spacing question
  246. NI-Cd and Ni-MH discharge amounts
  247. Help, Choice of charger.......
  248. JR or Expert Battery 6V
  249. Topping off NiMH's.
  250. Spectra from Hughes RC
