PDA
View Full Version : Batteries & Chargers
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. 1200 mah battery 500 ma charger
  2. Balance charging 2S Life batteries
  3. Hobbico Digital mini-Tach
  4. Upgrade battery for longer use time
  5. Cheap field generator
  6. Vok 2s lipo balance plug
  7. Voltage Question
  8. battery and charger rec for old and new
  9. Battery connectors ?
  10. flat lipo battery charging
  11. traxxas
  12. Jumping back into hobby need a new charger
  13. Chargine NiMH batteries
  14. Speedpack Silver 3000mah not charging?
  15. 4 port charger ba. single port with parallel board
  16. 20-30A 300W AC/DC charger
  17. Hyperion eos 0606i parallel charging?
  18. Enerland A123 charger; need instruction manual
  19. Hyperion eoso 606i charging issue
  20. hi tech 2x 400 charger
  21. first post
  22. What is this connector type?
  23. What kind of battery would give me a max flight time?
  24. LiPoly Conversions
  25. Fleureon lipos. Any good?
  26. Help with Hexfly charging setup
  27. transmitter battery recovering it
  28. Lipo battery current draw question...
  29. 14.8V 2200mAh 50C 4S RC LiPo or 40C lipo
  30. Over heating a lipo battery?
  31. Battery and charger question
  32. Recommendation for 4x 6s Lipo Charger Under $250
  33. Ace Super Smart Charge label reversal
  34. Ammo can for LiPo's
  35. Any links to a DIY battery charger toolbox? Like what fans do I need and so on?
  36. Hyperion G7 Silicon-Graphene Batteries
  37. Lipo condition?
  38. How to solder - Frustrated with multiple connector ends.
  39. Need help charging AA/AAA batteries from this charger..
  40. hexfly 5800 life expectancy
  41. I need a charger
  42. DIY RC car 7.4v pack from 18650 3.7 batteries...
  43. SkyRC imax b6ac v2
  44. Which Connectors for 12S 29 Battery Pack
  45. Tattu 5200mah
  46. Triton 2 can't select charge
  47. Intellipeak ICE problem, Please Help!
  48. how can this chargr balance without any balanc connectors
  49. Best Bang for the buck on a dual charger 200w per channel and internal resistance
  50. AARRGGGG! The PUFF!!!
  51. All my R/Cs discharge very fast after 2 years standby
  52. HRP lipo batteries
  53. NiMH guideliness.
  54. What if I plug a Lipo battery into my RC vehicle without a balance plug?
  55. Digital camera with plug in battery charger?
  56. Dromida Nimh-charger, crap?
  57. LiPo voltage way too high
  58. Can't figure this out.
  59. If I understand Li-po batteries right
  60. New LiFe battery - how many cycles?
  61. Conection Dangers
  62. Duraflight A123 Sentinels
  63. Lipo Battery: Good or Bad:
  64. Charger mod ?
  65. Using Accucel 8150 charger with Traxxas NiMH
  66. Landing lights electrodynamics battery?
  67. Switching from Nimh to Lipo.
  68. Charge / discharge or?
  69. Lipo pack not fully charged
  70. Battery Fire
  71. Help!! Need 30c 14.8v 2200mah li-po battery for my ft011
  72. 2S and 3S batteries for Walkera Rodeo 150 Racer drone
  73. is thia a dud
  74. Is this a bad battery?
  75. 6 volt battery
  76. Power Lab 8 or GT 1200
  77. LIFE Battery Charging Issues.
  78. Battery Leads
  79. What's wrong with my lipo charger ?
  80. What is your experience / recommendation for a charger?
  81. Traxxas batteries
  82. Charge lead for Futaba RX LiFe battery
  83. Low voltage for Life-Li-ion
  84. Can i use this battery with drone ?
  85. Timeout before reaching max voltage with 680AC charger
  86. Issues charging zippy life battery- help needed
  87. Hitec X1 mini Balance Charger Question
  88. ponderosa
  89. Unknown Battery Charger
  90. Lipo Parallel Charging board DIY
  91. Can I do this with Lipos
  92. Is this a 14s Lipo pack??
  93. LiFe or NiMh?
  94. Is this normal?
  95. New 8s battery capacity meter
  96. What charge rate?
  97. Stock Small Lipo Chargers
  98. Go-to RX battery?
  99. RC plane noob saying hello.
  100. NiMH vs LiFe Available Current
  101. Hitec charger not going to set amperage
  102. 5C to 90C High Quality RC Lipo Battery
  103. Looking 4 a way to have one charge input to charge several battery packs
  104. Li-Ion battery for airplane starter?
  105. Real Balancing chargers?
  106. Battery Returns
  107. Hyperion EOS 0840i 8S DC Charger (1000 Watt output)
  108. Hyperion EOS 0720i SUPER DUO3 7S CHARGER.
  109. Hyperion G7 Si Graphene SV Lipos
  110. Multi-Use Charger
  111. Thunder AC6 not saying FULL anymore.....ideas?
  112. LiFe Charge/ Discharge rates
  113. Blade 200 S battery supplies
  114. Battery & Remote Controller Car Charger with Digital Display ,Will it useful?
  115. Onyx 210 question
  116. Looking for more mAh
  117. Lipo not always charging.
  118. Charging params chart - peer review
  119. Charging Params chart - peer review
  120. How do I charge this?
  121. Thunder AC charger getting extra duty
  122. Hydramax 2000 mah Battery - Use it or Not?
  123. Traxxas ez peak dual charger
  124. Drain on car battery question
  125. NiCad, NiMh Charging
  126. Noob to 'lectric RC - Like idea of parallel charging multi-batts, need massive info
  127. Field battery testers
  128. Rx battery help
  129. RC battery run time question
  130. NIMH batts. vrs. the newer-Lithium-ferrite_Phoshate batts.
  131. 1954 Chevy west coast choppers
  132. How to make a 6 cell battery from two 3 cells
  133. Is this normal?
  134. May I have your expertise re swollen batteries please?
  135. Ultra Power Chargers
  136. Newbie having battery trouble?
  137. Bad Battery
  138. what is this connector?
  139. Ace dmvc
  140. Ace Digipace II instructions
  141. Battery suggestions for Velineon brushless
  142. What battery would go good with this motor/esc combo?
  143. RC lipo in non-RC use without ESC
  144. Which charger between these two would you get...?
  145. Resistance difference in battery cells
  146. 12 V Supply to get rid of.
  147. New JR tx battery preparation
  148. What does the word "dry" mean on my Tenergy TB6B
  149. Traxxas ID chargers with Traxxas LiPo batteries.
  150. Need help with voltage alarm
  151. Need Reco For Smaller Than Std NiMh 7.2V Battery
  152. Lipo
  153. a brand new NiMH battery to charge
  154. venom pro dual 80w ac/dc charger? Good?
  155. New to hobby, need some advice for CC-01
  156. IMAX B6 acting strange
  157. Breakthrough in Physics Has huge Implication for Batteries
  158. Is it possible to replace 6 AA batteries with a li-ion
  159. Charging Time for NiMh
  160. Batterie help
  161. FOR SALE: Prodigy 640 DC Charger
  162. Battery Questions Concerning EDF
  163. Orbit Micro Lader
  164. Quad battery chargers
  165. iCharger 4010 up in smoke - again...
  166. Charging discrepancy in instructions
  167. Using large 7.4 volt NIMH packs in Truggy that uses 9.6 volt LiPO or Li-ion
  168. Voltage checker and battery question - need recommendations
  169. Ridiculous Battery life
  170. Battery
  171. Let down by 2S Lipo compared to 7cell NiHM....
  172. Li-Po charging
  173. Question about battery charging
  174. Need some advise
  175. Looking for Li-Ion advice
  176. what to think of this battery?
  177. Newb battery and charger advice
  178. Charging LiFe 6.4 volt battery.
  179. 5 in 1 DJI Mavic Pro RC Drone Battery/Remote controller charger
  180. Newbie understanding batteries
  181. All kinds of batteries needed - used and old batteries
  182. Reconditioning batteries instead of buying new one - really cool method
  183. What is Your Favorite Brand Of Alkaline AA?
  184. New to rc have several questions
  185. How many 6v can I use in a receiver
  186. what kind of battery to use??
  187. Onyx batteries
  188. Lipo Charging/Dischrging/Cycling Refresher
  189. LIPO Storage voltage on iCharger 3010B
  190. 2S2P lipo inherent flaw
  191. Venom Pro 3 charger
  192. Newbie needs charger and battery advice for new RC truck!
  193. How to charge a 12v Pb battery with a 680 AC balance charger
  194. Nimhs charged or discharged?
  195. Alkaline to NiCad Conversion
  196. TME Extrema Wattmeter
  197. Battery burst !!
  198. Floureon Lipos
  199. Newbe to lipo batts and chargers
  200. Need charger for HPI 101942 PLAZMA 7.4V 5300mAh 30C LIPO BATTERY
  201. Looking for a good lipo balancer/charger
  202. TP820HVC manual in .pdf form
  203. Lipo questions
  204. safe charging
  205. How can I power my led light bar to a lipo pack.
  206. Newbie battery help.
  207. BAlance board connector for Onyx charger?
  208. NiMH Battery False Peaks
  209. Futaba t6j help!
  210. Radio Shack Black Wolf
  211. LiPo receiver battery pack for 8ight-t 3.0
  212. ISDT SC 620 Smart Charger
  213. 12v Li-Po charger voltage.
  214. Venom 8.4 5000mah
  215. Help please
  216. My FMA Powerlab horror story.
  217. Newbie here...can't even charge. Help!
  218. CellPro Powerlabs 6
  219. LIFE battery as main flight pack.
  220. Twin Packs
  221. Balancing Unbalanced LiPo Batteries
  222. 3s lipos??
  223. Please visit our "If I ran RCU ....." thread!
  224. Tired in Charlotte / ;-) / Batteries got me down!!
  225. Team Associated SC10 Brushless Combo - Need battery suggestions please
  226. Hobby RC Newbie
  227. New with LiPo
  228. LiPo/LiFe storage mode
  229. Need charger and possibly batteries for 3 ECX Amps
  230. Thunder Power Batteries - No Images?
  231. EXC Ruckus Issues
  232. DC charging question
  233. Electrifly Triton EQ Error codes
  234. Got my Lipo a little wet
  235. Help for a Falcon 40, battery issue?
  236. Internal Resistance Measurment
  237. Turnigy Accucel 6 & IMAX B6 from Hobby King
  238. How to set up charger
  239. New to rc cars
  240. iSDT SC608 Smart Charger
  241. Need You Assistance (Generator to Charge 4 6S 5000 45C LiPo)
  242. Charging Batteries
  243. What's the correct charge rate for NiCds?
  244. Help choosing a charger
  245. I have some questions about 18650 batteries.
  246. High Power NiMH AA Cells
  247. Lipo battery on a Brushed motor
  248. is my LVC enable???
  249. sprint 2 Flux RC battery recommendation!
  250. Batteries difference
