- Whoops! - NiMH Forming Overcharge
- Lipo Battery Suggestions
- Can you charge a LiIon through a voltage regulator
- What Charger Should I Buy?
- Noob question
- cold
- Help !
- Simprop intelli bipower
- Pro-Peak Prodigy II Oddities
- Lipo question
- Battery Charger User Reviews
- Lipo balancer connector help Parkzone Li-Po
- 2200mAh battery max amps when charging
- Flight Box Battery and RX Pack Advice Needed !!!!!!!
- Need larger battery and new charger
- quick battery discharging question?
- Optimum Temp for Lipo's?
- Apex 3rd Gen Experience??
- Lipo saver choices?
- N cell Nicads
- Why are my nimh hot after running?
- Do I have a bad LiPO? Cellpro error code
- button cells
- 3 cell Lipo back will not charge
- NiCd Receiver Packs
- cell size
- Charger/Discharger allways reads 100mah less
- Over charging Ib4200's: is it ok?
- 9.6v Bank Charger/Charging Station
- Lipo Cut-Off Question
- New Bantam e-Station BC-6 AC/DC charger announcement
- Question on Duralite battery life and power box
- Weird charging incident
- Amondo Tech batteries
- Order tracing
- Tabs on Cells should not Be turned.
- Charging 4 10 Cells Lipo's at a time?
- What should my new 4200's volts be?
- can't read"How to build a race pack"
- 2200mAh battery how do i charge it?
- HI IQ by Victor?
- Noob , buying batteries.
- Who makes Rx adapters for a Super Brain 989?
- Futaba Twin RX 6V Battery Charger ?
- RX battery charger question
- Ultra-Balancer
- Tremendous runtime for 40 size nitro
- How Many flights should I get ?
- Lipo balancing question
- Charging AA in holders?
- Next Litco Alpha4 opening?
- 6V Rx Pack
- lipos in E
- Charger Recommendations
- How to charge 4S lipo??????
- Equation for Charging Times
- charging ni-mh with triton
- Cellpro charger charging lipo more than 1c
- Why discharge a LiPo?
- 3s1p pack reconfiguration
- Confirmation on charging lead/acid gel cell
- battery suggestion
- Hobbico Accu-Cycle Elite and non-Airplane packs.
- Who sells lipo balancing taps/leads?
- ignore , double post- sorry
- 2/3A charging
- Lipo Charging with a Ni-MH charger
- greatplanes equinox - lipo connectors
- which lipo ??
- Accu-cycle Elite charging flight box battery
- Robbe infinity 2
- StartFlight support for Somer Charger the best!
- li ion Q
- Hyperion 7i Charger + AMPS??
- ENELOOP batteries
- Coco Lama V3 Battery Support
- Trinity Spec Packs[TECH]
- Flight battery for Trex 600
- Charger recommendations
- Need a new esc......which one???
- A good deal??
- Help me convert this power supply
- Rookie question about Batteries and Chargers
- Lipo charge rate
- Will this charge?...
- Li-Po Charger for a 12C battery
- DIY glow plug starter
- quick Q: CE Turbo35 GFX
- NI-MH Battery charging. Y/N ?
- question about li-pos
- Triton Chargers going beserk
- Triton Chargers going beserek
- charging hump battery
- A lipo Charging Question
- newbie batt charging question
- SMC 4200
- Peak Charging/Discharging at different rates
- Integy cells
- looking for a Li-po balancer, which to buy?
- charging individual 9volt nimh
- MRC 989 (compare to Triton and Ice)
- NiMh battery higher voltage issue
- Triton 2 question
- Question for the battery gurus
- First time charge / chargetronics
- New Pack
- 6 volt hump pack problems
- NiMH pack charging beyond rated capacity
- SPECTRA 4 MEMORY SYSTEM
- squeezing lipos while charging?
- Got gp3300's from radioshack and dynamite prophet plus charger and have a few Q's
- AA nicad charge rate
- Battery Life
- Elite 4500
- Can the Duratrax Piranha charge high capacity NiMH's?
- First charge
- AC-DC Power Supply
- Lipo Newbie Has A Question or 2
- 7.zv 1200mAh
- Need a charger and new batt. LIPO
- Balancer-charger compatability?
- Duratrax Piranha charge rate?
- Lipos for Dummies
- Is it really worth the extra price? I need some help...
- Do I need an adapter? Quick question...
- need help deciding on nimh battery charger PLEASE Help, been out of rc for 5 years!
- Not sure im in the right place for this but
- is this a good charger?
- does this charger balance too
- Dean connectors for battery, mini or fullsize?
- New member, out of range solution
- Can a charger rated at 2000 mah charge a 3000 mah battery?
- Are These Batteries Any Good???
- GP4300 problem
- Rayovac AA Hybirds
- A123 pack life in real world uses?
- The Ultamite Charger
- Quad output chargers
- What's your run time?
- Charging Problem
- Discharging Question
- Will a Superbrain 959 Charge a Li-Po?
- MRC Super Brain 989
- Can I charge two batteries at once with the triton 2?
- Accu-cycle elite owners
- New to li po
- Batteries and digital servos
- What is the best NiMh
- Higher charging rate ok on wall warts?
- Battery Voltage
- What are the best R/C NiMH batteries?
- Did I fry my new battery
- delete please
- Balancing plug adapters
- Looking for article on using wall warts
- Newby...I REALLY need help!!
- Lipo vs NIMH
- Need help on battery selection for Cap 232
- Capacity & Cycling - What are you getting?
- High discharge batteries
- Help with charger settings, 1400 6-cell NiMH.
- first charge with piranha
- vision peak charger
- will this charger charge a maxamps battery
- Managing the A123 Cells
- Which Battery Pack
- NIMH or LIPO?
- Newbie question about nicad charging
- Battery voltage
- 2500mAh AA's for Tx+Rx packs?
- 2 nimh for recieve?
- Which balancer and how?
- GLOW PLUG IGNITER
- Wall charger and Nimih
- Crack in starter battery casing...
- MOVED: x2610 range?
- Hobbico Quick Field Charger MK2
- Lipo battery and Li-ion charger
- Judgement Awarded against Duralite Plus.
- Discharger question
- Customer Support Number?
- why does my battery heat up so fast
- Balancer for Hextronic
- How to detect amps
- Have I Buggered my LiPo Battery?
- Duralite Voltage
- Astro 110D to Lithium?
- Triton2 Am I going blind?
- Would you buy this? What would you pay?
- T-rex450xl battery and charger
- A123 cells for receivers
- LiPo Fully Charged Voltage
- My lipo smells like Jack Daniels
- any way to discharge sport packs without discharger?
- e-flite batterys?
- International shipping of LiPo batteries
- Emcotec LongGO S batteries and DPSI
- temp of IB1400's while charging
- Prophet Plus Resister 13
- IB4200's, MaxAmps 4.4K 4400's, Elite 4500's! Ahhhhh!
- A123 Sonic Charge: Which PS?
- which lipo should i get
- LVC Help for a123
- Why did my battery pack swell up ??
- LiPo or LiOn ?
- One charger for all batteries?
- Deep cycle vs. power supply for charging.
- Do all chargers require a 12V power supply?
- SuperBrain 989 vs. Triton 2 vs. ICE
- what battery do I need to achieve 15 min flights Hobbico Superstar EP
- Dynamite DYN1420 7.2V 1100mAh Ni-MH Speed Battery Pack
- tyco and nikko?
- Need balancer for Ni-mh batteries
- HughesRC Charger
- HOW TO TELL WHICH CELL HAS GONE BAD...
- Ice Charger
- cell arrangement - NMhi
- What's The Difference? Worth it?
- LiPo charging and balancing questions
- lipo 2500mah 200gr
- charger
- TRITON ZXDC dual output charger
- 7.4 or 11.1
- A123 for T-rex 600CF?
- digital voltmeterfor NMH batteries
- About charging a LiPo
- Question about connector clips PLEASE HELP!!
- FMA Adapters Now Cover the Field
- Much more 3S Lipo
- Nimh batteries
- Best way to 1st time charge Nimh batteries
- Bulk Pricing...
- Anybody else using The Duratrax Power Supply?
- A123 3S MambaMax5700 / Traxxas Rustler
- PC Power Supply Conversion
- A quick question about IB4200's...
- Which Charger
- Computer Power Supply Question
- MRC 989 Brain Charger Question
- new GP 2000 cells show .7 Volts any Good
- Li-Poly Battery.
- power supply
- Power Supply for the ICE Charger
- piranha digital peak charger Qs..
- A123 cell info
- Charging batteries help please!!!!!!!!!!
- Max. charge currents
- Charging question
- New NiCads not used for a year question
- Battery packs got VERY hot..
