- JST-XH bulkhead connector?
- will old charger work with NiMH
- How to charge my new Lipo Battery + IMAX B6AC Charger
- 25% off all 5500mAh Revolectrix HV LiPos
- NiMH battery not fully charging?
- NIMH charging to over the rated capacity?
- Admiral Lipo Batteries - Any Good?
- Battery Connectors
- LiPo Charger question
- Reducing wire guage...looking for an elegant/solid solution
- How connect Turnigy Lipo to eflite esc
- Lipo fire!
- Four button charger - Thunder AC6.
- Battery Question
- really cool sales going now!!!
- battery help please
- Puffed up LiPo
- EC-5 Connector Variants
- SkyRC e6 ACinput charger is giving me fits!!!!
- Looking for a cellpro 4s
- A123 Dual switch set-up question
- Duralite Plus A123- Can I use my Cellpro Multi-4 charger???
- What am I doing wrong need help
- Replace Alkalines
- Battery Discharge Rates
- Charger Won't Charge!
- Duralite Plus A123 4600 battery-Dual switch setup ???
- DYI Voltage Regulator
- Saddle bag lipo suggestion for Team Durango buggy. What do you run?
- Best charger for my application
- Please set my mind at ease
- switched to deans plugs chargers not charging very little or non at all HELP
- please help with ripmax propeak prodigy II identify chip
- Power supply and charger question
- Where are the CellPro Multi 4 chargers
- disposal of LiPo
- G Force 3S 1800mA Life Tx battery
- New Accucell 8150 charger fan and screen back light not working.
- Transmitter Battery convert to Lipo
- Buyer Be Ware
- Use Lipo Bags and a Metal Box to Charge your LiPos!
- NimH Battery Cycling
- Recommendation for Aligh 100 battery
- how t make a car bub lipo discharge the right way or not
- A123 2300- On board balancer or not???
- 7 V+2.5A Charge,am i right ?
- Chargers Balancer for Lipo
- trouble ordering batteries today
- Can the onyx 210 charge AA's?
- Double Horse 9053 helicopter charger box problem (I think)
- A few basic LIPO questions
- Lipo Discharging
- Is there one charger that will do all I need?
- cant adjust the turnygi 420 charger with this video
- Jan hermkens B-17 build, batteries and servo connection
- 15 min quick charger ?????
- Thorium Batteries
- Peak Electronics (Sirius Pro Chargers, etc.) - Out of business?
- How to charge Gens Ace tx lipo?
- Are LiFe batteries safe to charge/store in the plane?
- Need a dependable power source in the middle of no where... help?
- Simprop NC Master Pro
- Gawd I love this charging setup!
- A123 2300 battery in 50cc plane-Is a single battery set-up practical?
- Dr. Battery
- Charger Needed for Hydrimax 4.8 v Nimh
- Discharging Lipo
- NiMH battery - Accu Cycle Elite will not cycle, please help
- Single cell NiCad glow starter capacity test
- need help with plastic covering
- Replacement battery pack for Futaba 7 CAP
- Charge time for nimh receiver battery?
- Lipo to use for slow flyer. 2 cell or 3 cell?
- Charger Needed for A123 batteries
- Lipo Explosion
- Hitec X4 going into "breakdown" mode
- When is IR too much or too different?
- 3S, 4S Lipo Batteries and Charger
- LiPo Cell imbalance- PLEASE HELP!
- Advice on Brand of Lipo and where to but them? (was considering Zippy from hobby king
- SPECIAL PROMO OFFER :Buy 2 units Apple iPhone 5s 64GB - $300 AND GET ONE FREE
- Li-Po batteries
- AGA Power Attended the AMA Expo in 2014
- batterys for 370 brushed?
- fromeco badger switch problem
- Is Ballisitc Batteries still open?
- Love or Hate - Lipos or chargers, that is!
- What amps should I use for charging?
- What type of battery setup do I need?
- Why isnt this charging
- Life Battery Error?
- Digipace II will not discharge
- Thunder AC680 - SkyLiPo voltage discrepancy
- Lipo IR,and track testing.pl8 and 308 IR comparisons.real world results
- charging with Hyperion EOS 606i through balance plug only
- Fast charging lipos and battery life
- Need LiPo replacement help
- An old Newbe to electrics questions
- basic understanding of batteries
- Using cellpro multi4 to charge 1S 25C 500mAh ?
- Need 4 x 100(+) Watt LiFe Capable Charger Suggestion
- 2 batteries
- Excessive Amp Draw - Why?
- onyx charger help
- Adjusting the screen brightness on a Turnigy Max 80 charger
- *Hyperion Super DUO 3 Charger*
- Baisc rules for measuring IR of different size packs?
- Battery Terminology
- Hobby king fraud alive and kicking...you won't like this transcript.
- ez flite lipo vs g force lipo opinion
- Balance-charging LiFe packs while still in the plane
- GoPro 3+ Power with UBEC
- Hyperion 720 problem!
- Multiple batteries in to 1 receiver
- question about battery maintenance during off season
- Hobbico Accu-Cycle help (charging a JR 5 cell 2700mah 6 volt
- Combining multiple Lipo packs together
- dynamite 10 w peak nimh charger problem
- charge life 6.4v batteries on 6.6v charger?
- Newer Battery Types
- Charge Life TX battery
- Manual for older Hobbico accu-cycle charger
- How to Cylce a NimH Battery
- Frozen LiPos?
- Need NiCad Receiver Pack Supplier
- DX7S TX Battey
- How long a 48V 2*300 Amp-hour battery will last?
- ROC Battery
- Wire Gauge for electric set-up
- What might this be useful for??
- Question about cell balancing
- Question on Thunder AC6 Charger
- lipo storage setup
- Triton2 Charger Question
- Fromeco lithium ion life expectancy?
- 2S lipo upgrade - AE RC10t4.2rs
- DPL 8 and storage
- Charging LiPos with a 4 button charger?
- Less voltage = more power?
- NiCd battery pack sources?
- Hitec X4 NiMh Question
- Turnigy Accucell 8150 charger
- Pro Boat impulse v2 Will it handle 6s 5000mah batteries without overheating problems
- Finally making the jump to LiFe batteries from Nixx
- Battery ignition and electrical setup
- Need A Charger For Under $165
- Flightmax or Traxxas Zippy?
- Charger that charges thru the balance lead only!
- Best $150 lipocharger 2014 Q1 ? =)
- HELP NEEDED! charging battery's
- Multi use charger
- Adj. cell pro 10xp
- Fast charging
- LIPO v A123
- Paraboard for Thunder Power TP 1430C
- HELP NEEDED! GT Power A606-D
- 50cc and NiMH Batteries
- Receiver Battery Advice
- ESC no reverse fix
- Newb using the new Hitec X1 Touch
- lipo pocket charger complication
- charging battery
- FMA CellPro 4s went "POOF", help identify chip?.
- 3rd pin on 12V ni-cd battery
- charger working right?
- New to Lipos
- Battery ID ?????? Help !
- Genuine A123s?
- What battery to use
- Losi Micro T 1/36 Battery Options
- multi 6v receiver battery charger???
- Still Trying !!! Orbit MicroLader Manual Needed - Yes, Ive written Radical RC
- Oldie/Newbie Battery and charger advise
- What charger do I need for this battery:
- ANYBODY know how to bring a LiFe 3.3v cell down to 1.5v~1.6v for onboard glow heat?
- Can I use this Cycler/Charger to DisCharge 30mAH LiPo Batteries?
- batt. discharge recording
- Hobby king deceptive practices strike again (and again)
- 4 Nikko 1296 packs on eBay
- LiPo Balance and chargers
- Voltage regulator to bring 3.3v LiFe battery down to 1.5v for onboard glow heat?????
- One cell charges .15v lower than the rest!
- Best Priced and Quality lithium-ion batteries??
- Cell Checker Recommendation
- Charger & Lipo's
- Onyx 230 and LIPO
- 7.4V LiPo smokes flight power wiring
- I have a really strange problem with my Li-Po batteries.
- Custom Charging Case
- Reduntant Receiver Batteries
- Getting into 1/10th buggies!!!
- Battery question
- Hobby King battery shipment and customer service EXTREMELY POOR
- Ignition battery
- Charging life battery inside plane fuselage?
- 1.2 V......6000-9000ah Ni-Mh??????
- What's the difference?
- 9.6 vdc 600mah charge question
- Pinewood Derby with Ducted fan motor - battery wiring question
- Receiver& ignition on same batter
- Battery MaH ratings and flight times
- Lipo battery storage temp
- RX Battery Not Holding Charge
- B6 imax sky r/c charger
- Icharger 308 DUO - from BuddyRC / Junsi
- reducing voltage with a diode
- LiPo Discharge Numbers
- Suggest 2S Li-Po for the Orange T-six Transmitter (needs JST plug)
- Charger recommendation for 2nd BETTER charger....
- lipo question...I just picked up a 6 prop drone.
- Battery Advice / Help
- Battery/Charger Question
- Battery help
- Orbit Microlader Manual ?? Anyone
- LI-PO battery charger question?
- Error messages in the Hobby King Quattro 4x6 charger
- NiMH Discharging
- batterie Question
- Is this a decent cheap charger?
- Turnigy Mega 300W 8S Dual Charger Issue: Seems to be Locked up!!
- DELL Vostro 3500 thinks it's running on battery
- When to charge LIFE packs?
- Charging question for 4000mAh Lipo on 3A or 5A
- Need battery answer to do a upgrade
- hitech x1
- recommended quick charger for 7.2 NiMh battery with bullet/banana clips
- older Team Orion Marathon Lipo help Please
- Unboxing and Review of the OES Pack Sentry Hyperion Battery Checker
- Charge without balancer ?
- can not adjust my turiby 420 charger need help
- Lipo Charging Rate
- Networking the EOS 720i & 730i NET3
- HiTech 4X charger capabilities
- Cell Pro & Charging Rate for A123 2200MaH Battery
- back in the game rx/lipo?
- Power charging at max C??
- Are Lithium Ion Batteries No Good?
- life battery charge question
- multi port chargers
- Lipos on Venom Pro charger Warning Low Voltage
- LiPos & Pets
- Charge or Discharge?
- li-po battery question about swelling up
- A Noob question about NiMH battery voltage
- Newbie question
- Voltmagic Saved My Arse!!
- Good Lipo Charger for Newbie?
- 2s or 4s lipo
- What are the best rx packs?
- low voltage shut off/alarm
