View Full Version : Batteries & Chargers
- Can I charge a NiHM Battery with a NiCad Charger?
- What connecter is this called?
- Using a Lipo 3.7v charger on a 7.4 batt?
- Are my batteries shot?
- CellPro 4S Charger Attachments
- which is better
- Triton 1 Question for Lipos
- Rx battery question ... 4.8v or 6.0v for .46 size
- r/c 1/24 and 1/16 tanks
- Alternative Uses
- Uneven Lipo cell discharge (3S), Problem?
- Duralite & Orbit Pocketlader
- 6V 12A charger help needed, suggestions
- Charging a Dual Battery Setup - Question
- Manual settable charger?
- A123 Batteries Vendors
- GP 3300 MEC tube project
- Looking For a Neew Lipo Charger???
- Xtrema or Cellpro 10
- New to this please help!!!!
- Whats the deal ?
- charging batteries in cool temps
- Custom wiring from my charger to my batteries
- Homemade charger
- Triton charger & LIPO
- TRITON 2 SAFETY TIMER
- Trick Hobbico MKII to switch to trickle?
- My opinion CSRC
- Charger for A123 cell
- Need some advice on charger
- Question-Digital Peak Charger with NO Cell Count Option
- LBA10 in network mode
- Charging two gel 12v cell batteries wired for 24v
- Is the MRC 977 limited?
- What resistor do I use to check battery with VM
- Pleaces to get A123 batteries?
- Prodigy batteries
- Battery and Charger Questions.
- Ain't she pertty?
- Someone want to do some leg work? :)
- Longer life batterys
- Best balancer for my Super brain 989
- MRC Charger Enough!
- team orion 4800
- What batteries are best?
- Looking after Lipo batteries
- MRC 959 amp ?
- 7-cell 4500mag 1st charge resulted in ..
- imaxb8 power source?
- beware
- Pro max 885600 charger
- Memory Problems & initial charge
- JR Battery Packs
- Don't get those A123's Quite Yet
- Doubled 6.6v packs for motorycle?
- DuraTrax IntelliPeak AC/DC Twin Pulse question
- Cell Pro 4, adapters, and apogee battery's
- Venting with FLAMES!!!!
- Battery Size??
- make a battery pack
- Compatibility between LiPo balancer plugs
- Battery Extension Lead
- Propely 'breaking in' a new LIPO
- SPECTRA 4 now includes A123 cells
- Charging a Airtronics MX-A......
- LIPO BATTERY HELP NEEDED.
- LIPO CONSTRUCTION QUESTION
- Won't Balance, Why HELP!!!!
- How to make side by side packs?
- DynamiteVision Peak2 Question on charging
- Battery Holder for Futaba Tx?
- Li Ion Nano Phosphate batteries
- My Swallow Charger is Dumb
- Any New Better Lipo's coming?
- A123 Brand Balance Taps
- NiCd 7.2v 6cell packs OLD vs New.. Old Better???
- Does anyone else have the DBC-14 LiPo charger ?
- Best Batteries ?
- boom boom bull_ _ _ _
- inverter + Mastec 5020
- Mastec + inverter
- Lipo Charging ICE
- Mega Power Charger
- Vision Peak Ultra question
- Cell Pro 4 wattage??
- e-STATION BC6 Dual Power Charger
- Looking for a general formula to figure amps/volts
- NiMh - Voltage Degradation?
- Airlines and lipo's
- Li-po & Triton charger
- New Battery Technology
- how many amps to charge at?
- GAS SET UP
- Strange idea about sealing side by side battery build
- Should I discharge?
- Help with new Tenergy Batteris
- Receiver Battery Question
- ZAPPING Batteries for increased voltage.
- Here's a question that's never been asked before...
- Can I over-charge my Field Box Battery?
- Fromeco question?
- What is the advantage of LiPo?
- yeah..
- Nano-wire Lipos ?
- My next battery?
- Why does it SEEM so hard to find a (lipo) battery?
- AC/DC Chargers vs. DC only Chargers What advantages??
- how many cylces should i do?
- a123's and stock rustler?
- Charging 8x AA's at once, Not good?!
- triton charger question
- What Recommended Charger for NiCA NIMH & LIPO
- Plz Help, URGENT!
- Please help Fast!
- Hypersonic charger
- help!!!!!!!!!!!!!!!!!!
- Battery Help
- New battery packs?
- Question about my charger ..little confused. Maybe?
- Confused about what gives a longer run time
- JB 1100 charger
- A123 how many charge a day ??
- where to get cells
- Initial Charge question
- Strange A123 issue
- General Battery qeustion
- Rebuilding packs with new cells question
- Reedy vs Orion
- will this discharger work?
- lots of help needed
- How to wire a Charging lead onto a single Cell
- Pro Boat 7.2 Volt Ni-MH charger
- good entry level lipo charger?
- Relion 7.4 2600 mah chargers???
- Wiring Two Packs to One Charger, HELP!
- Comprehensive List of Electric Flight Components with Specifications, Prices, & Comparative Data
- eSky Honeybee CP2 and a new battery
- What Cells in Dynamite speed pack???
- charger balancer or not?
- what amp rate is best for lipo batteries?
- Do a123 packs need lot of ventilation?
- NiCd voltage meter checker?
- battery question
- Switch Harness w/ Short Circuit Protection
- Parkzone T-28 Trojan charger
- give me the laymans on batteries
- IB 4200 PROBLEMS PLEASE HELP!!
- Connecting Lipo w/ trx connector to charger output
- Power Supply Comparison
- Balancer question
- How should I charge this NiMH battery?
- New member
- will water damage my radios and batteries and recievers?
- Pipe burst , sprayed water on my radio and recievers, batteries...will they be ok?
- Li-Manganese
- Great Planes 0345 & 0351 Batteries
- Maxamps still builds their packs??!!! Ughhh
- Ice Charger help needed
- 8.4v vs 7.2v
- Good charger for NiMH AA batteries?
- Charger setup
- Hyperion EOS 5i charger question
- Cirrus Cycle Pro
- AMA Convention
- Best charger to buy to charge multiple Lixx packs
- Recommend me a good all round charger
- Do you think my batteries are okay?
- Spintec Battery Manager
- Cordless drill battery charging
- Where can I get BIG CLEAR heat shrink tubes?
- Power Supply Specs for the Prop-Peak Prodigy II Charger
- Battery and SxS Build questions
- TP 205V w/ align balance tap?
- MaxAmps Packs
- Club safety director/Lipo fire video
- 2 cells low volts
- History of R/C Battery Packs?
- whats safest /max charge rate for 5s a123?
- swallow advace charger
- Can New Tenergy 4500mAh Propels compare to the big brands?
- Help - A123 Astro blinky balancer issue!
- Charger ID
- battery building Q's
- Sizzling Batteries
- Cell Pro 4S Problem
- two 11.1v batteries on a 6 cell charger?
- Soldering cells and flux
- Calculating charging costs
- Re-chargeable batteries?
- where to buy super nova cycler
- Fast or Slow charge? Conflicting info.
- Rustler VXL battery+charger
- Cycling cells and cell chemistry
- Another Triton problem???
- Looking for a certain lipo
- Rechargeable AA battery bay?
- trinkle charger adapter for batteries Receiver and radio
- compatible?
- 6 volts Wall charger
- Charge rates for matched packs
- Double the capacity?
- Tenergy Lipo Vented/Expanded?
- new to electric please help
- how long does the charge last in A123 cells if not used ?
- Where to get A123 cells?
- 2S1P A123 RX Pack for 50CC AIRCRAFT
- balancing adapter
- balacing adapter
- low current cell reversal?
- max voltage of Multicharger by Hobbico?
- lipo building supplys
- What battery for new e-maxx?
- Swallow 2 ACDC Discharge Problems
- Not sure which battery to purchase
- I killed a 1100mah pack
- Battery Voltage?
- can I charge 2 LiPo packs at same time on one charger?
- Stop fly voltage for NIMH packs
- Anyone know if this will work?
- EnErG-Pro NiMH batteries 4.8V
- what amp meter to buy?
- How do I determine the proper size Rx Battery?
- Team Integy 12V 36A Power Station Undervolt
- Peak Detection Chargers/Accu Cycle Elite
- Receiver battery question
- Charging Rate for a Ni-Mih Battery Pack
- New battery build
- HELP! E-Sky Battery Charging Question
- 12v gell cell charging??
- are these compatible?
- Team Check Point High price???
- Charging a relatively high capacity Li-Po, using a low-output charger...
- Winter Maintenance
- Independent lipo testing. Who does it?
- Are These Lipos Useable
- ice problems?
- shrink wrap split open from heat
- LI-PO & Triton I?
- Parrelling Lipo battery?
- Charging 9.6v batteries
- NiMH warning?
- e-Station 902 Trickle Charge
- New Product - New Bantam e-Station "Dual Balance Board" for BC-6 Charger & PB-6 Balancer
- Is Litco Out of Business?
- Discharge Lipo battery pack
- Odd LiPo Charger problem
- where ( inside or ouside) do you charge your LiPo batteries?
- which side has more amps
- NiCad to Li-Ion or NiMH?
- 6Volt battery- No regulator?
