PDA
View Full Version : Batteries & Chargers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. starting own lipo packs.....
  2. LiPo swollen or just the packaging?
  3. Overvoltage Charger Error
  4. Dean's T-Connectors - HOW MUCH CURRENT??
  5. Did I do somthing wrong? Fried Turnigy Accucel-8
  6. How often should i use my balance charger vs. polycharge4?
  7. Would you like to see some packs tested?
  8. Forming charge on nimh with nicd wallwart
  9. Using an accu cycle Elite charger
  10. lipo battery and charger
  11. NiMh Charge rate
  12. Lipo's manufactured in U.S. ?
  13. Need help with simple electronics circuit (voltage regulator)…
  14. Anybody running A123's in a 450 size heli?
  15. Discharging Lipos and other questions??
  16. FMA Multi 4 and Duralite tx pack question
  17. 6v cutoff
  18. Who can service batteries?
  19. NEED A GOOD 5S LIPO PACK!!!
  20. 42 Percent Products - 2Pac" HD Dual Battery Share 50 AMP! - Deans Connectors
  21. Balance Plug Adapters
  22. On a cycle the batteries only show taking 625mah
  23. charging a lead acid battary with the Super Brain 989
  24. buzzing packs? when charging
  25. Lipo Charging Questions
  26. 9V Alkaline battery OC voltage?
  27. Charger search
  28. Internal resistance of nimh cells
  29. Lower Charge Rate on Lipos
  30. Battery connectors - please help!
  31. Adding a load to my voltmeter
  32. Are my batteries toast
  33. noob .....needs charge info
  34. Using an Accu-Cycle and a wall wart charger
  35. Charging Ni-Cd Batteries
  36. battery dosen't have any low end power
  37. Graphs NIMH 4200 +
  38. Charger / Battery Protection
  39. Battery advice
  40. Nimh with low voltage - help
  41. How to tell if a battery is charged
  42. Hobby Charger for Standard AA's
  43. Super brain charger question
  44. Do NiMh need to be " Formed " ?
  45. C Ratings
  46. Any Battery testers SAY Good or Bad lipo
  47. NiCd & NiMh in parallel ? Please help.
  48. TESTING LIPO BATTERIES
  49. wall wart to charge 1650 NiMH?
  50. Battery switch, with charger slot??
  51. Accu-cycle plus will not charge fully
  52. Hooking multiple NiMH to one charger?
  53. lipo size a123 packs
  54. Battery started smoking, then caught fire.
  55. charging 2 nimhs at once (Traxxas 1/16 E-Revo Power Cell)
  56. graphs lipo 2 s x 4000
  57. rcats glow plug heater
  58. Hobbico Dual Peak charger
  59. Super brain 960 issue
  60. How to make the Bantam e-Station Software work in Vista64
  61. NiMH and ALPHA-4 charger
  62. HYPERION G3 VX 5500 MAH 3S 11.1V 35C
  63. NMP CHARGER HOW TO??
  64. Help w/LiPo batteries
  65. WHy are my batteries getting so hot?
  66. Question about my Hobbico Accu Cycle Pro Series charger/discharger
  67. Deep Cycle Procedure???
  68. HYPERION EOSO610i Duo II freaking out
  69. Thunder Power RC 11.1V 3S 4200mAh Pro Race 40C LiPo Battery
  70. where to buy nimh batteries for flight packs
  71. GREAT service Mastech HY5020 Power Supply
  72. Whats a good balancer for the Onyx 230?
  73. May be switching to 123's
  74. New to LiPo balancing ?
  75. Receiver Battery Cycling
  76. Charging LiPo's with a Hobbico Elite ?
  77. Options for charging Li-Po's from different vendors
  78. jetcat lipo connector end?
  79. Hobby Services AAA +++ Support
  80. eneloop aa batteries
  81. help with lipo balancing plugs
  82. Newbie LiPo user question ?
  83. slo lipo charge
  84. Thunder T6 balancing board
  85. idle nicd
  86. two batteries different capacity
  87. Aircraft switch on while charging Rx Battery
  88. nicd battery
  89. 2.4 gig receiver battery ?
  90. New Battery Goes Dead After 3 Minutes
  91. spectrum battery pack help
  92. first time pack...
  93. EOS 0403i - connections
  94. Charge input Question
  95. ACE Batteries (Li & Ni) - Power Oriented
  96. question about novak smart-stop lipo cutoff
  97. chargin lipo's
  98. Glow Starter Battery Replacement
  99. Trition EQ Charger Problem
  100. GWS charger problem
  101. HDMI caps fit Hyperion taps
  102. Batteries join a cult and all commit suicide??
  103. Which battery charger ?
  104. AAA receiver batteries
  105. Nicd battery self discharge
  106. new to lipo battery NEED HELP
  107. Lipo Noob....advice please
  108. First time charging LiPOs
  109. Large capacity charger querry
  110. i hope its not bad
  111. need help fast
  112. Triton chargers? How many?
  113. 20c lipo compared to nimh battery?
  114. DuraTrax Onyx 230
  115. Zippy Lipos????
  116. Lipo pck issue: Rhino 5s1p 4900mAh 20C bad cell?
  117. Will this Lipo work with my RC?
  118. How do I disassemble a Losi Lipo - Hard Case?
  119. China
  120. What Is Too Hot For NiMH?
  121. Not sure whether to switch to LiPO
  122. Does anyone use Dewalt DC9280 28V batteries?
  123. 14.8 volt battery and 370 motor
  124. Turnigy 420 (oops!)
  125. 8 cell battery question
  126. Hobbico TorqMaster 12V Battery Repair? Charging Question.
  127. delete this thread question answered
  128. Buyers Beware!
  129. Eneloop batteries internal resistance?
  130. Hydramax 1450MAH AA packs
  131. Connect batteries in parallel to charge them with a single charger
  132. ELITE PRO CHARGER-peak charger
  133. 2s a123 batteries
  134. Lipo Write up!
  135. Maxamps Lipos
  136. Salt Water Soaking Lipo's
  137. I think the guy at my lhs sold me the wrong charger.
  138. charging nimh with peak charger
  139. A123 and Duralite regulator, will get HOT??
  140. Flight power v balancer harness or board for jst
  141. Dual Rx batteries
  142. How many cells can a car handel
  143. Battery building
  144. Novak lipo cutff, 2 cell or 4?
  145. Is this what I need?
  146. Can anyone help me with a manual for Swallow AC/DC 2 Charger
  147. x-charger b6
  148. Is my TP610C going bad?
  149. anyone have exp. with venom lipo charg/balancer?
  150. 12 volt nimh charging question
  151. Fromeco Charger and LiPo
  152. Battery charger leaking
  153. Onyx 100 Charger + 3300mah Venom Pack = 2hrs to charge ?!?!
  154. lipo tester
  155. Lipo charger/balancer
  156. flight batteries I'm worried, help
  157. nicad battery cable ext
  158. looking for a Lipo charger
  159. Triton 2 and A123's
  160. Need Battery for Losi Mini-T
  161. 2S A123 1100mah safe charge rate?
  162. TX pack charging rate?
  163. mystery batteries
  164. cheap rx packs
  165. Nimh charging?
  166. Things went south
  167. Considering going Lipo but have some question
  168. ThunderPower TP-610C Display Swap
  169. where to buy Bandit ? tips for batteries?
  170. LiPo Charging Times
  171. Need Batteries for E-Maxx 3905
  172. Venon Pro charger - Connection break
  173. charging 1.5v packs
  174. Tenergy TB6 Balancing Charger
  175. ACCUCYCLE ELITE-the battery eater
  176. charging A123's through a switch???
  177. Left TX on overnight with 3 cell lipo, did i ruin batt?
  178. I know little to nothing and need help!
  179. Promatch Racing Order
  180. how do I construct two 5cell a123 packs w/balancers? From a Dewalt pack
  181. Looking for a Vintage battery pack Hi-Tec Radio
  182. receiver battery
  183. Lipo rechaging statistics
  184. quick question
  185. " NEED HELP !! "
  186. A123 compatibilty with futaba rx's
  187. What batteries for E-Maxx?
  188. ener-g 4200 cells? promatch cells? cheapbatterpacks..
  189. Where can i Find a Parkzone 11.1v Lipo?
  190. Futaba Fasst and A123
  191. Power Supply advice needed
  192. Lipo Cycling
  193. Cellpro 10s discharge Lion and Lipo's?
  194. Charging 2 2s lipos in series?
  195. Problem Pack
  196. Storage: Charge or discharge to a midway charge point?
  197. Triton charger typo?
  198. Triton charger
  199. What Batteries Should I Get For The Traxxas Summit?
  200. 2s battery with 3s balancing plug
  201. battery for my erevo
  202. CellPro 10 data port pin-out
  203. Wall Chargers.... how large of a pack will still work?
  204. Looking for advice on Receiver Battery replacement
  205. Charger at a reasonable pricerange?
  206. 3s1p pack with dead cell
  207. Large Batt/motor combo for UAV
  208. Flight Tech Regulator and Lipo charging
  209. 1 S Lipo 100 MAH and HK charger
  210. How to wire 2x 2S
  211. A123 Cells for Transmitter
  212. Triton EQ + Lipo 3s...
  213. FLUSTERED, need help!
  214. volts?
  215. Lipo charger "Low In Voltage error" help!!
  216. diffrent mah batterys???????
  217. Power Box batteries
  218. Any good?
  219. Charger any good?
  220. Turnigy accucell 6 5-amp, won't finish charging pb field battery?
  221. 989 balancer and connectors
  222. What prop do I use?
  223. Good NiMH 8.4v 4500+mah battery Sub C
  224. help onyx 230??
  225. Ebay B6 cheap chargers
  226. Cycling and balancing A123
  227. charger question
  228. how to tell if a nimh pack is dead/bad?
  229. BATTERY MAH QUESTION
  230. Looking for Lipo pack/s and Charger!
  231. Charger with LCD panel for less than 120USD
  232. Charging Two Batteries at Once???
  233. 3s to 2s
  234. Balance Plug Adapters, where to purchase?
  235. Charging Small 1/3aaa 160Mah NIMH
  236. Is FMADirect overwhelmed with orders?
  237. What settings for cycling/testing old nicad packs
  238. How warm?
  239. "New" A123 cells (evaluation to follow)
  240. charghing lipo
  241. The safest place to store Lipo Packs inside a house?
  242. ma discharge rate question?????
  243. new to RC - NiMH questions
  244. Vortex Zone
  245. HELP!! CHARGING AMPS??
  246. Triton EQ Charger
  247. Dented LiPo??
  248. battery size
  249. piper cub
  250. best charger with good price
