View Full Version : Batteries & Chargers
- New to lipo, charging question?
- 8000mah Dual Core LiPos from MaxAmps.com
- Soldering Batteries Help?
- Hitec X4
- Converting a Hard Case Lipo to a Soft Pack
- IMax charger problem
- Charger/Balancer advice for a LIPO Noob
- Adjustable voltage 18V PSU
- First time using lipo batterys need help
- Cycling a LiPo
- Reusing battery connectors?
- Trickle charge/household timer?
- 2 batteries?
- BVM-8S 1-8 Cell Battery
- Help to find 22.2v 6S 5000mah 35c li-pos
- battery charging question?
- 6V Nimh Packs- Do you need a regulator?
- Unique Charging Situation
- IMAX B6 multi-battery type charger review
- iMax B8 Lipolymer Battery Balance Charger
- Expanded Scale Voltmeter
- I am looking for a charger with dual output
- Unmarked Sanyo Batteries
- My battery pack is not able to power my r/c car. Please help.
- Best charger for A123 LiFe packs
- could some body explain this to me please?
- Best PSU for Power Lab 8 ??
- Revolectrix Cellpro 10S Charger
- Need help with dual output charger...
- icharger 206b question
- Equalizing lead battery with Turnigy charger?
- Hot LiPo balancer?
- Problem with LiPo batts and BL motors.
- What battery for AR6210 6-Channel DSMX Receiver
- What would you pay?
- IMAX B6AC charger issue
- Great Planes Triton Charger Peak Sensitivity
- Look what I just dropped $720 on
- Using lipo battery's in series????
- Charger for two pack planes
- Thunder AC680 - User Manual (PDF)
- charger software problem?
- Futaba 8J battery pack size
- Astro Flight 112 Charger False Peaks
- Need help with charger settings on my Lead Acid battery
- Need a battery case for my Lipos and charger
- need some info on the bobbico accu-cycle pro series please!!!!!!!!!!!!!
- Thundar AC6 or T610 software
- A123 batteries and Obama
- LiPo Battery Availabilty
- # Everyone-Should Read The following L-I-P-O DISASTER!!!
- Can u charge a NiMH on a Nicd charger?
- How many mAh should I get?
- Lipo Fires Are Real![Fantastic Advice!] Can I ask for further help?
- duratrax nihms
- Hobbico Accu-Cycle elite question!
- Duratrax Onyx 245 vs. Traxxas EZ Peak Plus
- Have some NiMH battery questions
- Charger suggestion ?
- Can I resucitate my dead li-po pack?
- Which 2S battery? Enerlands 25C, Gens Ace 50C, SPC 25C/30C/50C, ProMatch 25C, or Turnigy 25C?
- Nimh batteries going dead
- nicad vs nimh
- Turnigy MEGA 400Wx2 Battery Charger/Discharger (800W)
- Duratrax 235 and Tamiya LF1100
- choice beetween TRITON EQ OR HOBBICO ACCU-CYCLE?
- two 4.8 nicd packs y'd into rx?
- Balancing charger question
- Need guidance on purchasing a charger
- GForce LiPo Charge Rates?
- Thunder AC680 - CONNECTION BREAK?
- Adapter help
- LiPoTrak iPhone app
- Connecting to a 18650 Li-ion cell
- A123 stops charging at 84%
- A connector question
- Color Options for our MaxAmps.com Race Edition LiPos
- How not to fry the chicken or the egg
- Bought new charger, which balance board do I use?
- When cycled battery 3x, mA are higher then quoted
- futaba charger question
- 500mah to 180mah, which resistor?
- Finally here High performance long lasting LiPo batteries
- Putting banana plugs on Tx and Rx charger
- Triton charger&LiPo charge rate
- Ideal Rx battery for Bird of Time?
- Twin battery setups
- Another battery question.
- Newbie battery questions
- CellPro 10S Charging
- iPhone App for lipo batteries
- charger output voltage/R/X batt. voltage
- Parallel And Series wiring of lipo packs
- Pin Spacing
- First time lipo user concerns
- Ace Charge Master and NiMA battery
- Wiring Schematics
- Pro=Tech
- Is this a valid test?
- a123
- power supply for Turnigy Accucel-6
- How do I Fix a low Voltage lipo in NIHM mode
- Charging 2 lipos simultaneous with ICE/EQUINOX?
- JR r/x battery & charger
- Hype Xtreme Charger X7 - What are your thoughts?
- NiCad battery charging
- Share an experience
- Need a charger for multiple types of batteries...
- Erratic charging patterns
- Best Bang for your buck high charger
- Batt charger help
- How long should it take?
- TURNIGY MEGA 400W 20 Amp V2
- Discharge Rates for Parallel and Series Wiring
- My LiPo batt packs have ballooned???
- 6S charger!
- Maximum Charge Rate for NiMh Quick Charge?
- Wire a LiPo into a Field Amp for Music?
- RC nooby here
- Anyone use this charger?
- Hyperion 0606i charging NiMH problems
- Dynamite sentry battery checker
- Looking for suggestions on a good Lipo charger with wall adapter
- 110 v charger on 220 v outlet !
- LiPo charging
- Hitec Multi Charge-A-Matic For Nmh?
- Want to get into larger electrics...worried...
- RX LiFe's left connected is OK???
- ebay battery recovery seller?
- Power Pacer by LR Taylor
- So I Ordered A HYPERION EOS720I... What Do I need For Traxxas Batteries ?
- 11.1 lipo charging question
- Onyx 5000 mah 7.4v 25c
- Tyco RC Drift King Battery Question
- replacement battery- Hobbyzone Champ & Super Sonic Double Horse
- What power supply for Cellpro 10XP
- RC Car Jerking.. Is this normal ?
- Charger for LiFE 6.6v's
- What Cutoff Points for 6.6v LiFe & 11.1v LiPo?
- Lipo set matching
- Ace Digipace Super 3
- Help me decide, Lithium packs for tx or NiMH
- Lipo pack capacity,how to measure?
- I need some help.
- My first lipos!!!
- New zippy 2s packs?
- battery question for stock Rustler.
- Charging life4 batteries
- Max mah and C ratting Batteries for Velineon 3500??
- Battery not reaching full charge??
- are these batteries roar legal?
- Help with my 6-15 volt 25 amp Pyramid
- TME xtrema parallel charging and balancer issue
- Has anybody tried the Zippy Flightmax LiFePo4 batteries from HK?
- FMA Multi Carrying Case
- iCharger or Cellpro?
- Help with Futaba charger wanted
- Lipo "C" ratings
- Using lipo batteries
- Which battery charger and power supply to get.
- Charging one cell with FMA Multi
- venom charger
- Oynx 245
- FMA Super Nova 250S Reset & Manual
- Shelf life of unused LiPo Batteries
- 3s batteries in parallel one 15c other 20c.. OK?
- Need a Lipo balancer
- Charging rates?
- Hard case lipos
- Battery and Charger
- Lipo Balancing leads question
- Hyperion and Li ion help
- A123 BATTERIES AND BLACKAND DECKER VPX BATTERY
- Signal wire
- Parallel & Series?
- Triton Jr. Input Source
- Hyperion EOS720i Super DUO3 battery charger
- 3s lipos
- Battery Charging Question
- lipo battery charger
- Will a Hitec X4 charger work with A123s?
- 12v power supply question
- Question about mAH
- Jomar battery backer
- Tenergy Li-Ion 18650 11.1V 6600mAh PCB Protected Rechargeable Battery Pack
- 4x100 charger Turnigy
- First Charge Help
- Battery testing
- Dual Battery Setup Help Needed
- Lipo battery connection panel?
- Turnigy 5200 2s lipo?
- Sparking Connectors Solution
- Hitec X4 programing NiCd in Auto
- Gens Ace imars charger problem??
- LiPo or LiFe??
- batteries
- Please help me pick a pair of batteries for the HPI Apache C1 Flux
- NEED HELP. Boiling new battery?
- Power Max Sport 4200 Lipo current to charge?
- Power connector
- Traxxas fast charger
- A123 Charging Rate
- A123 Tanks at 3.455 Volts
- AC side of my Onyx 245 quit! any ideas?
- LiPo calculator for RC
- A simple reliable &inexpensive NiM charger
- Determining AWG of silicon wires (using four, 4 cell 5800mAH LiPo)
- Uninterruptible Power Supplies
- What battery is this?
- differentiate these three hobyking chargers
- Field Battery
- new to lipo....only charging to 4.2 on 5000 mah? why?
- Powerful Chargers
- Ace Smart Charge
- Looking for a charger for 1/24 RC car
- New! MaxAmps.com LiPo Battery Tester and Low Voltage Alarm
- Hobbyking no customer service?
- Eneloop NIMH Receiver Packs
- Issue charging new GensAce 3s battery
- Looking for a manual
- Looking for Beta Testers for new 65C lipo for cars
- Car battery charger as power supply
- Charger for 3.7v micros to 11.1v+ lipo's.
- Hyperion EOS 0720i Super DUO 3 Vs. FMA Power Lab 8 V2
- "Lipo Fast Charging" or All Day at the Field??
- lipo storage
- LiPo question - can I use 2 instead of 1?
- NiMh help
- NEW!! High Wattage Chargers
- Pack Warms with Charging?
- 11.1v 2650maH 30c's on 30 amp ESC
- B6AC LIPRO BALANCE CHARGER & MCX2
- Charge help!
- Charging at high C's
- Traxxas Slash 4X4
- Micro Battery Question
- New lipe battery and charger.....questions.....
- Battery Holder where can I find one
- Hobbico Quick Field DC Charger MKII > Hobbico 12 Volt Charger
- Extend balance wire on LiFe packs?
- Can I charge thru the balance plug?
- Converting PC power supply Q
- Why lipos taking longer to charge now?
- trying to understand C
- Looking AC adapter to power my Hobbico Acc-Cycle;
- Any one knows DNK POWER lipo packs?
- Lipo charge rates
- DC Converter to ??? (Whatever it is Called)
- Futaba 9 Cap with a 11.1 Lipo... safe?
- Newbie seeking info
