View Full Version : Batteries & Chargers
- nimh rx packs on ebay
- What to use as a charger for 12V bettery?
- Graupner LiPo Balancer Plus
- Why Wont my charger charge?
- Triton JR ? and Triton SR ?
- NiMH Questions
- Which Charger ?
- Did I Ruin My 4200's?
- Hobbico MKII charger
- LiPo recommendations
- charger question
- Which Charger
- FMA Inc Signs Exclusive with Horizon Hobby
- Over capacity charge
- 12v power supply problem
- Lion setup on 28%
- how do you tell if.....
- Where To Get Clear Shrink Wrap
- burned some wire coating
- Lipo Problems
- all R/C Application Batteries , need help
- Lipo pack Building info required
- NiMh or NiCd?
- How lite, or how safe?
- my lead acid battery is making a slight buzzing sound
- Electric Engine Questions
- Next multiport charger ?
- Newbie Power Source Question
- Advice on buying charger!!
- parkzone charger help!
- twin batteries
- Help me spend my money
- RX packs - 6v to 7.2v?
- High-amperage power source
- Bad cell in 3S pack?
- Balanced BNC connector?
- testing amp draw
- AAA NiMH cells for Rx pack and Jeti ESC query
- ? About SuperBrain 977 and new packs
- power source
- Battery for cessna 182
- NiMH battery trouble
- jr 10X lithium
- Battery help/advice
- Futaba to JR
- 1/18 vs 1/10 scale batteries
- Opinion on "Blinky"?
- Dumb(?) Charger Question
- Lipos living in the heat
- Speed ex15pro charger.
- Apex Mu Plus Charger Questions?
- Hump pack ?'s
- question about wiring my charger to a glow stick
- UHOH.Tell me it's not dead..
- Charging 1800 ma battery
- field battery charger
- Battery question
- Misspost
- 6 or 7 cell packs?
- GP 3700's
- Looking for a good Peak Charger
- switching a global wattage CAP to Lipo power
- Need help on choosing adapter?
- REAL capacity?
- need balancer/adapter for packs
- JR extra 1800 Rx pack and switch has 3 wires?! how to charge?
- Low voltage on polyRC li-po 3cell
- THUNDER POWER PROLITE 11.1 VOLT
- Newbie to RC with Q's About Charging
- Wall Wart LED is Dim?????
- Newbie Charging Question
- Need 1amp load for 3 cell lipo - for loaded DVM
- Side by side packs = More power?
- Battery help?
- TRITON ( HELP NEEDED )
- CBA II
- 3v Lithium Back-up battery
- PC power supply to DC source issues
- Charging with Hobbico Accu-Cycle Elite
- Benefits of cool batteries?
- GREAT place to buy batteries
- Battery selection for maximum output.
- stampede
- Help... New Ni-mh packs loosing charge???
- Triton and Ice.. price
- charger and battery compatability?
- Cermark power panel
- looking for batteries to make 6v reciever pack
- Battery health check-which minimum MAH???
- My charger wont detect my battery, please help
- Li-ion questions??
- Article for complete education
- Battery
- Discharge single cells using a diode
- Trouble with my PC power supply conversion
- I build my own packs but...
- Great Planes Triton/field box battery question
- 2400 NiCd/Triton question
- Cellpro DPM cutting out too soon?
- Ni-MH + Accupulse
- Sanyo NIMH HR-AAAU 720 only taking 550mh charge, should I toss them?
- Is there only one?
- advice on cheap chrager for nicads and nikle metel
- Triton Electrifly and Zagi battery charge question
- Very Noob Charger Question
- Have I toasted my 4/5SC batteries for good?
- HR3U-2700 for TX?
- What lipos and charger to use for.........
- Is there a better battery???
- drain rates on Nimh vs. Nicd
- NiMh battery temp's while charging
- what am I doing wrong?
- LiPo amp output ???
- FMA CPD4 V2.21 Co-pilot jittering servo problem.
- how to use duratrax ice charger?
- Lipo batteries won't discharge
- Expanded Scale voltmeter
- The Ultimate, Best, Price
- Q: Charging 2/3A batteries
- Hi, help on buying Lipo
- A little help please for a LIPO newbie
- Fortress 8 CH FM RX Shift Change
- Buying a charger
- can I reuse cells from an inflated lithium pack?
- cheapbatterypacks.com?
- Shortening a 24' extension to 18"
- False peak Nimh
- Field Battery Question
- need lipo information
- Voltmeter for Lipos
- wet lipo balancing connector
- what should i do?
- TBM lions...couple questions
- double post
- Need Help w/Triton Power Supply
- dynamite vision peak ultra and lipos
- need some advice on batteries
- battery leads
- 6 Cell and 7 Cell Battery Pack Assembly
- NiCad/NiMh Discharge Rate - 10C? or more?
- Tamiya Conector with Gold Contacs???
- Simple question about MAH battery ratings...
- sub C or AAA ???
- Is charging my battery bad if it's not fully used?
- Charging with Quick Field Charger MkII
- how to reduce voltage
- NiMh 1.2 volts ?
- charger help, please!
- AccuCycle elite-false peaking
- Battery location with electronic ignition
- Extending NiMH Life
- One volt watch for 2 cercuits
- Charger for hawker Cyclon 25ah 2volt SLA "beer can" cell
- what bats 2 use?
- I'm a NEWB help!
- Charging AAs
- Recharging Hobbico Torqmaster
- Lipos in my nitro truck, simple easy questions.
- miniron chargers
- The C rating on a LiPo pack
- identical lipo packs in parallel
- Using New but Old battery packs
- HOW DO YOU DETERMINE USAGE
- LIPO CHARGE ON NIMH CHARGER
- lipos from fma
- newbie to li-poly confused about "balancer"
- Does Volts matter or just mAh
- How to Charge Ni-Mh 2100???
- 1500 maH sub c vs 1500 maH AA
- Hitec 335 charger question
- Nicads and Vibration
- Kokam Cell
- Kokam Cell
- Kokam Terminated FMA for Distribution in US
- All wall warts the same??
- lipo check
- multimeter
- Ice Charger Power Supply
- need advice on replacing a nicad with a li-poly
- li-po battery balancing
- FMA dropping CellPro / Kokam?
- Please help... HOT spots??
- Anybody know?
- Disposing of Li Pos
- LIPO BATT
- lipo batt check
- MRC Super Brain 977 pro good for Li-Po?
- Newbie Charging questions?
- Duel LiPo Help
- FS8 not compatible with JR Radio?
- Power Supply for SJ Swallow Charger
- e-station 301 charger
- How do i charge these cells? Please help!
- Super nova/lipos???Newbie
- dropped pack, bent cell
- Hydrimax Battery Current Rating
- Will this charger work?
- Lead acid vs ni-cd's
- Kavan starter battery?????????????
- Need help selecting high amp lithium charger
- NIMH battery advice
- Rechargable batteries, do they come flat?
- Stupidy by me/should I just get a new battery ?
- To power an Intellipeak Ice Charger
- Apache 2020 and Electrifly Safe Charge pack.
- battery selection
- battery
- TP-205 balancer
- Would YOU use this LiPO?? (damaged)
- Litco order list
- Panasonic Oxyride opinion?
- Form Charging a NiMH RX Pack
- avc1air question
- Auto LVC problem
- Battery Pack Question . . .
- 1.5V TO 1.2V??????
- Bad Cell?
- Is 5 Ah field battery enought?
- pro peak 'quattro'
- Newbie asking for help selecting correct specs for battery & charger
- Intermatic timers/garbage
- BATTERY\DA50 INGNITION SYS TYPE
- Turning Celectra DC to AC
- Accu Cycle Elite
- Celectra help
- Battery Life Question
- Form Charging: mismatched batts in series
- NIMH and Futaba S3305
- New display on my Akkumaster
- recommended LVC for cellpro
- Building your own packs for Rx & Tx, need help.
- How do I charge my NiMa Battery correctly??
- Where to buy good and inexpensive lipos?
- 2700 ma nimh charge rate
- Help
- New Li-Po
- Need battery recommendations for Evader ST
- Need battery recommendation for Evader ST
- batteries
- advice please
- What is the lowest volt per cell reading?
- NiMH packs in parallel
- charger for duralite 7.4v
- battery lead broken
- Fromeco w/ Duralite regulators
- Power supply help: Need a 110-240v for a Triton...
- BANTAM chargers
