View Full Version : Batteries & Chargers
- Batteries difference
- Life battery
- Eflite battery connectors vs. everything else
- Li-ion and LiPo drain then charge?
- Nimh
- Volts vs MAH question
- Switching a low DC 3.7 V, 140 mAh for a higher 3.7 V, 500 mAH
- LiPo abnormality, need help! 6.63V cell?
- Help
- Charging multiple batteries while connected in SERIES?
- Un Balanced A123 Pack
- Blade CPS Battery
- new battary with problem, my fault
- Lipo balance wire broken, how to fix?
- Best way to storage charge a Lipo battery
- Floureon lipo batteries warning.
- DISCHARGE and/or STORAGE the Lipo battery?
- Charging a 10 amp 1.2 volt battery
- Can Lipo Capacity be restored?
- Lipo charging on life settings
- LiFe Battery Discharge Characteristics
- Charge individual cells with Protek Duo 612
- Hmm any suggestions lol
- LiFe Balancing Connectors
- Batman Monster Jam Battery
- Wired Power Supply for Testing?
- Opinions wanted... 25C to 40C or 50C ??? question
- HAHA I beat thunder power( how to use the balance plug on jst board w/o an adapter)
- Ddvc
- Do I need a lipo upgrade for my hpi mt2 nitro g3 ?
- suggestions on chargers
- looking for the real truth
- Newb Rant re: Dumbass Traxxas Charger
- Charge rate vs Discharge rate
- Dynamite Li-Po balance charger electric circuitry
- low voltage on idle lipo battery
- Why do I only get 10 minutes play?
- New (old) Batteries
- LIPO Charge Rate on a CellPro Multi4
- Charge Bag
- Lipo Battery Basics
- Lipo charging help
- Electrodynamics A123 Packs Vs Hangtimes A123 packs
- Lipo Battery Repair
- Battery for Field Box
- 7.2V and or 8.4V NiMH
- Sub C
- Need simple basic layman's terms
- Need Cycle help for 6v 5c 2000mh pack
- Online Source for Batteries
- Icharger 308 Duo
- Hangar 9 Power Panel Amps Needle Doesn't Work
- Heat shrink size help
- Best battery for micro car 1/24
- Is my transmitter trashed?
- Tenergy TB6AC+80W Help needed
- What settings to use when charging a lead acid battery?
- How to Charge LiFe Receiver Battery with Hitec Multi Charger?
- Battery help, diagram + positive or negative first?
- Having trouble getting a LiFe battery charged
- iCharger 308DUO or Revolectrix GT500 DUO?
- RC powered bike, please help with initial setup
- LIFE batterys, Imax B6 charger...
- Ecx ruckus help battery problem? I think...
- Can you use an auto battery float charger on a 12v starter battery?
- Upgrading the battery in a cheap RC car - Need some help!
- Battery Good or Bad ?
- HSP battery advice for a newbie
- 7.2. 4000 lipo
- First time with lipos. Need help breaking in. (and everything else)
- Need Advice on Battery Charger
- Hobby King Has Graphene Batteries?
- Hitec mini xi balance board type
- Charging help HiTec X1 AC Plus charger
- Manual for SR Batteries Charger / Recycler Deluxe
- Revolectrix Powerlab 8
- Lipo noob questions
- Help! at what point do Lipos become unbalanced?
- Bad Venom pro 2 charger was bad NIMH battery help
- What is the best 5, 6, or 7 cell nim battery pack available at amazon.com?
- New way to pronounce "NiMH" easily!
- Charge time 10,000mah s2 lipos?
- Complete Newb needing help with 3S Lipo selection for Traxxas Rally/Slash VXL
- RC Help
- Need 'short' (in length) lipos
- Both NiMH Batteries won't charge
- New charger GT500 DUO Revolectrix
- Nitro guy needs battery help
- DIY professional High Current AA batteries holder - Charge / Discharge test bed
- Need help on dual chargers/power supply
- AOK Cellmeter 8 cheap easy battery and servo tester
- New Technology Promises 10X increase in Power
- New Product - Bat Safe battery charging box
- My active project: Repair of ANSMANN Energy 16 Ni-mh charger
- Bump Controller Demo
- replace old nimh 8-pack
- ULTRAPOWER-HK chargers, beware! UP100AC, UP120AC, UP200AC, UP400AC
- SMC Factory Spec Lipos
- New Turnigy "Graphene" Batteries
- Help choose Charger good
- HELP Newb issues
- LIHV battery?
- different battery, different sounds?
- My New Favorite Charger
- Ok.....what's the catch with the lighter 5200 4S vs the heavier 5000 4S battery?
- USB type A cable connection to D cell battery bank???
- Which high capacity NiHM for Dromida 1/18?
- Maverick strada xb evo s
- How to Choose A Proper Battery
- damaged battery wire help
- newbie help please
- New to RCs, need an opinion.
- Hitec X4AC
- Battery for the Sullivan onboard glow driver?
- Join US!!! Hobby Sales Wanted from Gens Ace&Tattu
- jumping voltage 7.4 to 11.2
- Japanese 8.4V NiMh Batteries won't charge???
- Japanise 8.4V NiMh Batteries won't charge???
- HLG battery packs?
- Help with HITEC Charger
- Slash battery options
- GensAce & Tattu Warehouse Move!!!
- Hummmm.u a high performance hitec charger? The x 2 700.?
- vertical tail, left deflection
- Newbie to Charging
- cARA PRODUCTS cycler won't cycle anyone still have one of these relics?
- Speedpack Silver 7.4V 3000mAh 2S 20C Lipo
- N00b LiPo Charging question
- re: Charger choice selection from a noob.
- Rc101
- Two dead Venom batteries in one day.
- Lithium Ion Chargers/Balancers (multiple): Newbie Question
- Couple of quick question about batteries with EC5 connectors
- Looking for a specific lipo battery tester
- Help!!!!
- New LiPo battery
- battery for traxxas rustler
- Will this battery work?
- What is the 3rd wire for on a 1S
- GensAce Christmas Activity
- Christmas Wish List
- Charge Co-Ax Heli with connector
- lipo battery fire
- Need Help Identifying This Meter
- Anybody had luck with LION POWER batteries?
- Which NiMetal battery, 5 cell, for airplanes of all sizes....
- Help! New Thunder AC charger Chinese errors
- Using Alkaline Batteries, AA size in an old Conquest FP-4NL Transmitter?
- mixing receiver batteries in a two battery set up....?
- Update Revolectrix Charger
- OK Boys, I give in!
- Changing my receiver pack to life.
- separate battery capacity for 2.4ghz receiver
- Replacing 20C LiPo with 25C LiPo
- 9v 400mA charger for NIMH?
- Extremely poor battery life after a few runs
- Winter Storage
- Lipo battery for Hobbico HD 12 v Strater??
- Venom 700MAH 35C 1S LiPo - Does it have a voltage protection board?
- NiMh battery charge currents
- Balance charging a 2s Hyperion Life battery through MPI switch?
- Need assistance with LiPo battery storage!
- Lipo Balancing
- Puffing.
- 12v Gel Cell Starter Battery
- Prevent Explosions: Lipo Battery Safety & Explosion (Video)
- NiMh Battery Charger Help Pleaaase
- Batteries Won't Get to Peak Voltage
- Am I missing a cable/adapter to charge LiPo Battery?
- First time user of LiPo Batteries!
- Storing LiPo batteries
- how to charge a 11.1V 2000mAh battery
- Nicad to Lipo conversion
- Is my A123 Pack Bad?
- Total Newb: Venom Pro 3 charger ?'s
- First generation Triton charger and lipo balancing questions.....
- Thunder Power TP610 ac/DC issues
- When to recharge life rx battery at the field
- What is the Best Receiver Battery?
- Setting Charge / Discharge cut-off limits on Triton
- Lipo battery alarm detecting 4 cells in 2 cell battery
- First Time RC Buyer - Confused About Plugs/Accessories (LiPo) - HELP!
- Choosing New Wall Wart
- torqmaster lc
- Need help with adaptor for 200Ma from 150Ma battery
- Need help with batteries.
- Battery bad?
- Batteries from Wal-mart...
- Bringing a Near Dead LiPo Back to Life
- LiPo Battery Question About Balance Plug And Charger Ports.
- 6s battery not balancing.
- Can Fully Charged A123's be stored/not used for extended time
- What charger do I need??
- Battery and ESC Problem!
- 5 Yr old LiPo Battery, Is It Dying?
- 7.2v Ni-MH 5300mah charging on a wall charger.
- Making a Deans extension cord
- how long can one let fully charged batteries sit before use
- cheap and light batteries for a beginner
- More lipo help
- Lipo help
- Looking for a charger
- High or low "C" ratings
- 106B Plus charger problem can't create and save a Battery Profile.
- Not sure how to charge 9.6v 800mah with 3 pin molex connector
- How to charge this lipo battery on a 4 button charger
- Wire gauge for 6.6v LiFe to receiver?
- 1s 3.7v 150mah 45c multi charger needed suggestions needed
- Batterys for rx on turbine planes
- Where is the best place to buy batteries?
- Battery Pack Plumping
- Peak Charging Versus Constant Current Charging
- Noob to chargers and batteries, help appreciated
- Help Understanding Usage of Revolectrix Cellpro Powerlab 8 Charger
- How many amps can I charge my battery at?
- Newbie, Battery question/issue? First brushless/LiPo RC product....
- Charger help needed.
- Tx lipo problem
- Time for a new charger
- R/C plane without high voltage servos or receiver and 2S LiFE batteries
- Just got a brushless Revo....
- Source for NiCads and LiPo's
- Vision peak ultra charger
- $25.99!! Lowest Price for GensAce Battery
- Big Deal! GensAce battery Is Only $25.99
- Big Discount!! Only $25.99 for GensAce Battery
- Recommended AMP for 3 s Lipo Charging? Please Help.
- Amazing Promotion !!! Up to 50% off with GensAce Battery
- un-balanced Iife batt
- Temp Difference Between 25C & 40C LiPo
- Tx and Rc Batteries
- Lipo flying and charging
- LiPo bag and short wires
- 14.4 volt NiMH battery full charge?
- Snowflake Six-Axis Gyro, Charging Batteries Better? (n00b)
- Amazing Deal!!! $8.99 Gensace Lipo Battery
- best type
- RC Noob Battery/Charger Questions
- Dont buy these nicad packs
- Hot Sale!!! Best Value Super Battery
- Special Price!!! Promotion on GensAce battery
- sony us18650vtc4 high drain 30a
- about big power charger
- Part-time Join Us----Gens ace & Tattu
- Lipo battery charger
- help with lipo batteries
- Hos big power supply needed for certain charger?
- JuicePax Basher 2.0 LiPo Battery
- Free Battery&Big Discount-Videos&Articles Wanted
