PDA
View Full Version : Batteries & Chargers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. Lithium Charger Repair?
  2. Understanding LVC Targets for Lipoly Packs
  3. Safety Li-Po charging setup
  4. 80 Flights on a Flight Pack: Is this Normal?
  5. Charger Repair
  6. MRC Super Brain 977
  7. When to replace transmitter battery
  8. Help!!! PICA 1/6 P-51
  9. Protecting the Label?
  10. Caring for "stick" battery packs (Newbie questions)
  11. Ace Digipulse modification?
  12. Charging li-po's w/vision peak ultra?
  13. very cheap lipo with charger
  14. WHICH TYPE OD BATTERY AM I ABLE TO USE?
  15. which cell line good for receiver
  16. Charging bank ideas (got to be a better way)
  17. Pirahna AC/DC peak power charger?
  18. Volt Watch flickers in red
  19. 800 watts?!?!
  20. Newbie needs help with mAh
  21. Need help. Charging a Ni-MH with Futaba NI-Cd Charger.
  22. Charging Ignorance Question
  23. The best High Rate Li-Polymer supplier for RC markets
  24. LiPoly in Cordless Drill
  25. charger ? newbie
  26. What's the rule of thumb for charging?
  27. Power Supply for ICE?
  28. Prolux Li-Po DC 1-3 Cell Charger
  29. Best Nickel Metal Hydride
  30. High capacity 9V NiMH cell
  31. Battery/Cell for Mamba?
  32. Which charger do i need?
  33. Prolux Li-Po DC 1-3 Cell Charger
  34. Budget Lipo tested by Independent Tester
  35. li-ion is pissing me off. i need some help
  36. mini lst battery pack
  37. Hobbico Mark 2 field charger and LiPo
  38. The Lipo Burn - Pictures! Another WARNING
  39. Oval Racing with LiPo's!!
  40. Adjust amps on Accu-Cycle (charging)
  41. Very Quick Lipo Question
  42. mini lst chargers
  43. battery covering is cut
  44. Novak Ionic D Charger
  45. battery connectors
  46. How to charge litium ion?
  47. balancing lipo's charger question
  48. Any Pics? to show how to connect dual 6V to a receiver
  49. battery not charging - please help
  50. Charging aaa & 9 v. Batts ?
  51. how to check battery for mah???
  52. Charging question
  53. nimh or nicd??
  54. 6 cell Battery Amp Output?
  55. Lrp Charger CANT FIND IT!!!
  56. e-Station 301 now updated with more features!!
  57. Welcome to Common Sense RC
  58. Parallel 2 5 cell 1400mah packs
  59. Easiest charger?
  60. Form charging on Delta Peak charger
  61. 2 lipo in series help
  62. how to hook 2 kokum 2000 15c in parallel?
  63. Looking for Nimh AAA
  64. Triton Charger & Balancer FAQ
  65. Triton Charger & Balancer FAQ
  66. when to recharge and for how long??
  67. Radio Shack GP3300 Bat. Pack ?
  68. Help with Orbit Microlader Pro
  69. Thunder Power ProLite Series
  70. Question about the MRC Super Brain 819
  71. battery maintenance questions
  72. Christmas Specials at FMA Direct
  73. 3800 Care
  74. PSU as power supply, FYI
  75. pirhana digital charger
  76. Source for cells and shrink hoses
  77. JR 10x Transmitter pack vs. polyswitch
  78. Batteries with my old ESC/Motor
  79. alligator clips
  80. connector question
  81. lipo connectors
  82. Balancing connectors
  83. Sources for single cell LIPO?
  84. LN-5014, how to charge 7.4 Li-Ion packs?
  85. On/Off Charging jack
  86. 7.2V battery and charger questions
  87. How do these perform??
  88. Lipo Battery Discharge ?
  89. Field Charger Setup
  90. charger problem
  91. 16x9v6 won't charge 1 or 2 cell packs ???
  92. Saved Drill Battery
  93. lipo charger/balancer all in one?
  94. Charge time with LIPOs?
  95. Are these Battery and Charger any good ?
  96. this is probaly a stupid question.......
  97. 12v lead calcium charging
  98. Voltage Regulator for Futaba RX? 6V or 5.4V
  99. Battery and charger question
  100. ice,power supply?
  101. Rewiring a 7.4V Lipo to 11.1V, possible/
  102. lipo charge container?
  103. TO ALL FUTABA 3PK OWNERS....
  104. NEED HELP! Batteries for EDGE 540T
  105. Swallow advance charger question?
  106. Almost Ready-to-Fly Airplanes at FMA Direct?
  107. Formation charging
  108. Formula for battery discharge
  109. Digipace 2
  110. Peak Detection Setting
  111. Hands down the best charger
  112. 2-hour chargers....friend or foe??
  113. Correct charger.. hot batteries???
  114. Common Sense Li-Poly charger
  115. duralite...fromeco
  116. Duralite Li-ion charge rates
  117. Need batt what type?
  118. Li-Poly vs. Li-Ion
  119. Programming my ESC for max battery life?
  120. Storing Ni-MH batteries.
  121. Please help with new MRC 977 display interpretation.
  122. onboard volage regulator
  123. How much discharge for my Ni-Mh pack?
  124. What charger to get
  125. triton vs intellipeak ice
  126. HELP! Which battery pack to get?
  127. mrc 969 inquiry
  128. lipo batt charger wont read Kokam battery
  129. Battery recycle question ???
  130. Chargers-E-Station,Prodigy,Multiplex
  131. ERR2 on Dynamite Prophet Plus LCD?
  132. battery/charger problems
  133. Thunder Power Production Dates???
  134. battery discharge rate and cold weather?
  135. 6V NiMh Causing Glitch??
  136. First Charge of Ni-Mh 5 cells(6.0V) 2000 mah
  137. Accu Cycle Elite ?
  138. Adapters for MRC 977?
  139. charging time??
  140. Wiring Batteries in Parralel
  141. am new ans need help! with batts
  142. Question Charging NiMH Batteries with Triton Chager!
  143. traveling batteries - best decision ever made
  144. AA's in radio
  145. power supply?
  146. newb question about charging battery with esc
  147. More Current: NiMH or NiCd?
  148. JR transmitter battery
  149. Power Supply ?
  150. best battery practices for racing
  151. FMA SuperNova vs. Triton
  152. Swallow Advance Charger: Not quite happy
  153. Charging Lead Acid with Duratrax Digital Peak?
  154. Multiplex LN 5014 ?
  155. Polycharge???
  156. New Duralites?
  157. NiMH bat. to Lithium bat.
  158. SUPER BRAIN 969 PRO
  159. Watch that drop off!
  160. charger/battery question (new to the hobby)
  161. Hobbico Quick Field Charger and Li-lon
  162. prodigy 2
  163. Where to Buy Tools & Parts for Making Leads & Extensions
  164. Quick battery question
  165. any suggestions on this charger and batterie choice
  166. Battery Leads on NIMH?
  167. Battery Size Recommendation
  168. what is the diffrence?
  169. Triton Charger and Sub C cells
  170. 12v lead-acid battery recharge
  171. Thunder Power 3s 2100 Capacity?
  172. dual batt charger
  173. Flight Pack won't charge to Peak Capacity
  174. Please HELP with Simprop Intelli Control
  175. Charging dual batteries w/ common ground
  176. New LiPo battery question
  177. FMA Li Po Pack Life of 452 Cycles at Heavy RC Discharge Rates
  178. Using Triton as a ESV
  179. Pb: Lead Acid Discharge
  180. Multiport charger for LiIon and LiPo??
  181. I really to some help from someone who understands batteries well
  182. Help with Dechargeing with Orbit?
  183. Fast charging older pack!
  184. Question about charger/maintainer
  185. 24 volt battery
  186. Chargers - recommendations or suggestions? Have listing inside
  187. Help! Strang thing happend to my Kokam 3200mAh
  188. Cold weather and Li-Po batterys?
  189. CE pitbull fuses. Where?
  190. Transmitter Charging
  191. Hobbic Accu-Cycle Problem - short-cycle?
  192. Charging the Gelcell starter Batt.
  193. Vision peak ultra charger
  194. Hobbico Elite Charger and Li-Ions
  195. Carson Expert-Pro Evo charger
  196. Battery mounting in 30% gasser
  197. looking for 1 charger that charges multiple packs at once
  198. Typical discharge rate for NiMH?
  199. Phosphate & Titanate Lithiums
  200. Settings for Ultramat 10 ????
  201. prodigy 2
  202. NiMH battery charging problem. Piranha Charger.
  203. Triton Charge Threshold Settings
  204. polyquest charging
  205. when is battery fully charged?
  206. My Triton and Thunder Li-polys/have I been doing it right???
  207. BalancePro HD Press Release
  208. Just Got an Intellipeak Ice... Now what? LOL...
  209. Triton vs. Multiplex
  210. Charging Rates
  211. Unreal !!! Can't find Anderson Pwr Pole Connectors local in Houston
  212. batterys in parllel
  213. Is there anything out there besides the Accu Cycle Elite for charging and discharging NiCd?
  214. Anyone own the CR 2000 Futaba charger?
  215. 1200mah NiMH
  216. What Charger? 6cell NiMH packs
  217. Spare receiver slot and 2nd battery question
  218. Max Lipo Charging
  219. really need help
  220. Great Planes 4-station LiPo charger: User feedback?
  221. 1500mah Lipo only charges to 1000mah - dead?
  222. Futaba 4VF Skysport...what charger?
  223. Li-Po or Ni-MH
  224. Ni-MH Sub C charging (first time)
  225. Help! Li-Ion, Li-poly, and NiCad charger needed.
  226. Transmitter Charger?
  227. how can I check my charger
  228. Hobbico Elite Charger help
  229. 2 Triton FEATURES...thanks for the answers
  230. nimh batterys
  231. Super Nova 250S
  232. Batteries & E-Maxx
  233. AAA Flight packs
  234. Electrifly Peak Charger blinking/flashing codes
  235. Need help with Li-ions and regulators
  236. Li-Polys: Babying vs. balancing?
  237. Swallow Advance Newbie Help
  238. Prophet Plus LCD?
  239. Triton overcharging ?
  240. Electronics Qquestions
  241. What charger would you recommend?
  242. black widow charger for ni-mh?
  243. Determining C rating
  244. Easiest/Cheapest Power Supply Ever!
  245. Checking for a poor cell in a a pack ?
  246. Duratrax Pirhana Digital Peak Charger
  247. Triton/Trickle charge
  248. Looking for a new charger... shopping list
  249. Triton
  250. CHARGING FROM A FLIGHT BOX BATTERY
