View Full Version : Batteries & Chargers
- what is a good run time
- hobbyking.com
- lipo in edf
- Parallel
- TRITON EQ Balance Port Connector
- Turnigy Accucell 8 150W How to...
- charger for car
- Weird 2.4 radio issue
- Astro Blinky and E-Flite LIPO
- noob charging Question
- Only charge Lipo through balance plug?
- how many amps is good for Summit?
- Need some good battery/charging advice...
- Discharge or not?
- Can someone answer this question?
- how many mins does a 1600 6v receiver batt last
- Noob Question!
- Can I charge 2 batts in parallel at once?
- Are venom lipos any good?
- which lipo can I use?
- To all those using a Triton2 EQ for LiPos
- Ace chargers and volt meters
- what does "absolute max charge rate" mean?
- Thunder AC6 charging rate
- New to Lipos got a few questions
- hyperion duo battery charger gone bonkers ??
- Parkzone battery question
- Graupner Ultramat 12
- New to Lipo's
- Shorted LiPo
- NiCd cells
- replace 12v with a lipo
- li-po batterys longgivity
- Help me buy a lipo charger
- Hydrimax Batteries
- Correct charge rate for Nicad battery
- 7 cell duratrax dtx 5000 problem
- what to do
- Delete
- I think i screwed up here
- Higher mAh rec batt
- Formation charging new Nicad batteries
- A123 Help???
- 16v/ 4A power supply need to reduce voltage
- Revolutionary new batteries
- Lipo Batteries
- heli blade
- Questions.
- i still flying without any problem on my funtana 125 (5* hitec 5645 and 1 635 with futaba 7c fast 2,
- charge a123 with a triton
- MaxAmps 9.9V LiFePo compared to 7.4/11.V LiPo
- s2 to an s3 battery lipo
- Dynamite Passport lipo 6s balance charger
- Will this work?
- Lipo Batteries
- modify current Ni-MH to make it less cells?
- fast charging 600 mah nicad battery
- Slkelectronics
- Can a NiCd with holes in it still work?
- Hyperion EOS 0606i 6S 6A AC/DC Balancing Charger
- Weller WES51 or Hakko 936 soldering stations
- In need of reciever packs
- Charging Problem
- newb question about charging lipo's
- Stupid Newb question. My apologies!
- ATX PS
- declining lipo capacity
- balance plug
- I think I killed my A123 flight pack...
- HOW DO I CALIBRATE VENOM PRO CHARGER?
- Quick Charger Question
- Venom Procharger - StandAlone Balancer
- Good full featured charger for the money?
- Photo-Pro-Peak Quattro charger circuit
- Aurora 9 LiPo's
- V6AC LIPO CHARGER
- All in one charger? (ac, charge, discharge, balance)
- lipo battery 3.7 volt for Blade Heli
- Anyone in Orlando/Clermont area with a Cellpro 4s or 10s ?
- Charging Help!
- Fully charged Lipo catches fire
- Can someone point me in the right direction (charger)
- Triton 2 EQ Charging Problem
- how to fix Broken Hump cell wire
- IMax B6 AC Lipo NiMh battery Balance Charger
- Help with Lipo or nicad
- Car charger as R/C charger power supply?
- 2S2P Charging
- triton 2 eq nimh help
- Anybody Try Tenergy Batteries? Great Price
- Balancer plug help needed
- nihm help
- A123/Lipo 3-bank field charger
- LIFE battery charger
- New to R/C and LiPo. Need as much help as possible.
- Is this normal?
- Lipo Puff?
- Problems with my Zippy Litemax 2200 3s lipo batteries.
- Lipo Speed controller?
- lipo charging
- lipo futaba 7c help
- Dynam Lipo Batteries
- Rx Packs for 2.4gig Systems
- astro-flight chargers for a123 anygood?
- Battery lead to short
- Turnigy Life pack swells up
- 4v Lead Acid
- Replacement battery pack for Futaba 7 channel CAP
- LiFe charge Adapter
- Charger Problem?
- Lipo help needed...please
- Unable to charge Hyperion batteries with thunder AC6
- new lipo battery trouble
- Lipo for E-Revo
- Run time is dramatically lowering...
- Balance charger output current
- New LiPo Battery Voltage?
- Triton charger NiMH
- Need your opinion on small lipos without balance taps
- Peak Electronics Sub C charger
- Good Battery?
- Old Question
- Battery charging ????'s.
- Tx Li-Po Question
- Astro Blinky Balancer Help
- To Cycle, or Not Cycle
- question about the ichargers
- GP power bank U-Smart , just blinking red?
- nicad to lipo change
- Testing Dual Battery Setup with Voltmagic
- battery blues
- CHARGING NICADS WITH THE BANTAM BC6
- lipo recharge
- New NIMH
- Need help in using a Hyperion AC/DC battery charger
- Li-Po's Won't Charge???
- ace Digipulse wanted
- New lipo on cheap charger/balancer???!
- Charging multiple LI-Ions
- Hyperion charger port?
- Team Orion 3300 MaH help
- Looking to buy a receiver battery pack
- Help Charging Li-Po
- a battery question
- Charging Big 12s Lipo’s fast at 30A or dual port 20A
- lightmax zippy 5000 Mah Battery Balancing
- Hyperion batteries and thunder AC 6 charger problem
- charger issues
- Quattro B6 Charger Adapter
- 2S vs 3S lipos
- Batery capacity
- Battery approved by ROAR racing orgnization
- Safe low Voltage cut-off for Lipo's
- Hyperion Super Duo vs TP-820CD
- Can this be used to SAFELY charge more than 1 LIPO?
- Swollen Turnigy LiFePO4 pack?
- tenergy 7.4v 5000mAh lipo battery shortage????
- What type of batteries do HPI RS4 Rally's use?
- How fast.
- Charger help
- Noob batery question.
- Arrowind Li Ion 2600mah 2S1P Battery 7.4v
- best 2s lipo 5000mah batt/charger combo (on budget)
- battery on exhibition
- Batterie connection names??!!
- Questions on Charger and Batteries..Please Help
- thunder ac6 nimh form charge
- accu cycle pro
- Battery adapters? HALP...
- 30C Batteries...why not used???
- Looking at "cheap" 2S 7.4v 20c lipos for 1/18th
- battery setup for 30% plane
- Charging my reciever battery
- DX7 TX battery question
- NiMH 5000mah batteries can't charge - low voltage
- best buy?
- onxy 100 charger.
- Calculating charge time for 6V pack using 4.8V charger?
- battery substitution? Newbie question
- What does that mean?
- HELP...RC10GT...Electronics (Servos) not working
- Is the thunder ac6 known to be slow?
- how to run 2 batteries together??
- onyx 230 settings
- changing charging polarity
- What charger????
- Triton 2 charging - use actual or written values of batteries for programming
- Which Charger/Balancer to Buy?
- Discharging batteries
- What charger do you recomend me for these batteries?
- MRC ACCUTEC BALANCER
- Slow stick Ni-cd battery sat 2-3 years
- What's the life expectancy of a field box battery?
- Kill switch
- 4 cell NIMH pack?
- first electric car , which Batteries & Charger ?
- Variac vs. Light Dimmer
- Cycling A123 on TP 1010c
- 7.2 nimh batterys
- Balance Plug on e-light battery
- Venom 2400 mah
- Turnigy Accucell 6 - Cooling Fan
- Okay 2 things,
- Turnigy Accucell 6 power supply
- ZIPPY Flightmax 2500mAh Transmitter Pack
- I'm lost, I need electric help
- Safe Charge Rate for 138mah 3.7 v lipos???
- Charge LIPO for 10+ hours safe??
- battery connector ?
- Himodel A123 batteries?
- Life Hump Pack question
- new 5 cell NiMH - really low voltage
- A real DUMB question
- 2268W with 4s1p Acepow
- Charging time
- Dual batteries
- Accu-Cycle Elite and Li-Po's
- Turnigy 4x6S Lithium Polymer Battery Pack Charger
- is this right
- Which is more powerful?
- AA NiMH charging off a triton
- Hobbico LiFe or A123 charged on a Cell Pro 10
- What to set mV to for eRevo?
- Question about maxamps new XL packs
- Good or Bad Battery?
- How Long To Charge!?
- ACEPOW announce all lipo batteries can be charged in 5C
- First charge on NIMH
- Best Multiple LiPo Charger?
- How to choose a suitable lipo battery
- Dynam Dc6 charger
- Multi pack Triton Charging Question
- battery comparation
- Battery question
- test report of gens ace 2200mah 3s 25c
- Charging 2700mAh Ni 6.0V HELP
- Good cheap lipos?
- Deans Pin Spacing?
- quick lipo ?
- Traxxas vs Deans connectors
- Lipos / Questions - 1/8th Electric Buggy..?
- A123 Consensus on Cycling?
- Hobby city restock
- Trying to get old RC Truck working
- Lipo problem at the local FedEx warehouse
- LiPo, Brushless Motors, ESCs for Dummies
- Triton2 EQ charging A123 problems
- TURNIGY ACCUCEL 6
- TURNIGY ACCUCEL 6
- TURNIGY ACCUCEL 6
