PDA
View Full Version : Batteries & Chargers
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
  1. Question about balancing charger
  2. NiMH failures
  3. Newbie Battery Question
  4. li-po battery without balance leads
  5. New batteries - How to deal with them?
  6. HiTec charger dead; charge battery direct?
  7. swollen lipo
  8. Yet another Lipo charger question
  9. Ni-MH or Ni-Cad?
  10. li-po voltage and esc
  11. Brand new dead cells?
  12. Team Checkpoint 1030 Charger
  13. Futaba TX/RX charger problem
  14. How to treat your 4.8V NiMH pack?
  15. lipo damaged?
  16. LIPO MAH NOT KNOWN
  17. Thunder Power/CellPro adapter anomally fix.
  18. Imax 3S 2200Mah 20C Lipo
  19. Imax B5 Charger
  20. New cell, yo ????
  21. Red Mexican Sanyo battery cells?
  22. LiPo Battery price
  23. Charger for batteries with Traxxas High Capacity plugs?
  24. Accu-Cyle Elite Question
  25. Seperate battery pack for retracts
  26. Sonic charger
  27. hy5020e cccv power supply 50v 20amp
  28. NIMH Charge Rate
  29. Price Check! Please Help.
  30. Elite 3600 battery question
  31. Looking for help or pointers
  32. My little field charging system is ready to go.
  33. Urgent Li-Po Question
  34. What MAx Volts on 5 cell pack
  35. Cut-off voltage and 80% discharge depth.
  36. Are These The Same Cells?
  37. My impression of the Multiplex LN-5014
  38. Accu Cycle Elite and Li Ion Bats
  39. nimh temp when fullycharged
  40. Ripmax Power Supply
  41. can you use rechargable batteries in nitro???
  42. DC->AC
  43. Nimh vs lipo question.
  44. POLYCHARGE 4
  45. LiPo Charging Help
  46. Charge/Discharge Calculator
  47. Lipo and hot temp ?
  48. Intellect 1400mAh 2/3A cells, what current for initial charge?
  49. Battery Checker
  50. Question on Triton JR
  51. WHICH BALANCE CHARGER?
  52. 2S Foamy , possible???
  53. UK versus US chargers and plugs adapter questions
  54. experience with onlybatterypacks.com?
  55. What rate should I charge my batteries?
  56. Litco Alpa 4 Charger repair - no response.
  57. unmarked NiMH or NiCD
  58. Hextronic Charger - Any Good?
  59. Li-po batteries, good qualities:li-po batteries, high quality:Stands overdischarging without inflati
  60. Battery Temperature
  61. Hangar 9's Pulse XT 40 & A123
  62. Wall Wart Help
  63. What airframe are you using with your A123 3S packs?
  64. NMH Help
  65. Charging LIPO Balanced cells without a balancer?
  66. Best charger around $150
  67. Problem with e-station 902
  68. Astro Flight component problem
  69. xC = ?
  70. New battery
  71. Balnacers question
  72. Ni-MH Charging Question...
  73. using or charging multiple lipo packs in series
  74. new lipo battery and charger - need tips (changing connectors)
  75. Storage temperature for lipo's.
  76. Triton Charging Question
  77. Storing Lipo batteries at 100%
  78. lipo charger
  79. Futaba charging jack dimensions
  80. which Lipos for my Hobbico Electristar RTF
  81. lipo charger - need help
  82. To disconnect or not to disconnect
  83. Charging a battery backwards will..?
  84. Charging a battery backwards will..?
  85. How hot is 2 hot?
  86. Nimh cool-down or time-down before recharge?
  87. Lipo cool-down or time-down before recharge?
  88. This battery any good?
  89. 3s lipo battery meter modification
  90. Smartech Monster Truck - No speak
  91. Crimping tool
  92. Which type of battery ?
  93. Need charger that will charge two 7.2V 6 cell
  94. Problem charging receiver pack on triton.
  95. PROBLEM- ALPHA 4 or NIMHs ??
  96. battery charging help for nimh
  97. Charging AA's in a series....
  98. fast charge for Nih Mih and Ni-Cad?
  99. A123 - spec sheet for 32157 cell
  100. How would you charge these?
  101. NIMH Charging issues HELP HELP
  102. Titanium 1800mAh AA (18A discharge) anyone use?
  103. hyperion EOS 1210I manual
  104. balancing wires
  105. Making and using A123 packs for my Hobbico Electristar RTF
  106. NIMH Questions
  107. I just charged my 1700mAh lipo in less than 1/2 hour at 3C, My experience with the balance pro HD
  108. IntelliPeak Charger
  109. Brand New HiMh Battery Pack
  110. High output wall wart.
  111. How to make battey packs?
  112. Choosing batteries for 30% aircraft
  113. Weird Lipo problem
  114. HydriMax Ultra NiMH Receiver packs
  115. Charger comparison
  116. Battery location
  117. Have I ruined my Lipo pack?
  118. Charging time.
  119. All-battery.com 7 cell 8.4V 4500mAh NiMH packs
  120. Deans on RC18B pack
  121. Charging Batteries
  122. Multiple "AA" 1.5v cell chargers??? NIMH
  123. International Shipping Now Available
  124. A123 cell self-discharge rate?
  125. AccuCycle Elite. How to read cycle results?
  126. Effectiveness of my Deans Plugs
  127. Is this charging behaviour normal?
  128. Newby. Nicad battery help??
  129. 2-16 cell battery packs?
  130. When is the TC1030 coming out?
  131. Lipo Charger
  132. Starting with Li-Ions....
  133. C Rates?
  134. 7 Digital servo's, how many mahs are needed for a 4 cell pack?
  135. Tronics 25C 4800mAh batteries
  136. Backup Battery
  137. DeWalt DC9360 control modules needed
  138. Lipo Feedback
  139. Wall wart for everyday charging?
  140. NIMH Charger recomendation needed please
  141. Triton NiCD Peak Detect
  142. Better with higher temp?
  143. powerizer packs
  144. Charging Spemtrum Battery - Accu Cyle Elite
  145. no more worry lipoly batt
  146. maxamps lipo 1100 mah loose cell
  147. ACOMS technisport V Battery cover
  148. Bantam BC-6 Charge Cable Length
  149. Pack Charging ??
  150. FMA Digipulse Charger
  151. Can we use 2/3AA batteries for receivers
  152. sanyo 3600 durable ??
  153. Need some Advice on a Charger
  154. Lithium Charger
  155. Found a Victor Engineering Super IQ in the garage
  156. 2/3 AA batteries for Receiver
  157. TP balancers
  158. how to add balance taps on 3S2P
  159. Triton V1 Manual
  160. Dualsky PCM Pro LiPo Balancer
  161. hyperion wiring
  162. Minimum battery voltage under load?
  163. Checking battery
  164. Questions about Balance Pro HD charger
  165. Is this a good deal?
  166. Battery Question
  167. Charge rate for packs in parallel.
  168. DC input for Super Brain 977
  169. NIMH Battery help needed
  170. The best LiPo containment system I've seen
  171. New member with a question.
  172. Lipo Charging
  173. Can the ICE charger just charge my pack and not discharge?
  174. polyquest pq 3100, is it dieing?
  175. ProTrak discharge error fix
  176. Hrmm hrmm.. Issues. (Hobbico elite + battery)
  177. Testing voltage
  178. Failure modes
  179. Basic questions.
  180. Emoli 2s2p pack
  181. 4 Amp Quick Charge
  182. charger question
  183. What battery?
  184. 370 nimh 4.8volt battery pack charge time?
  185. radioshack battery question
  186. Battery Question
  187. Kit Cutters
  188. ICE Charger says= END:FLAT-LIMITED????
  189. A123 - new 32157 battery capacity
  190. NI-CD Question
  191. Do I need a 7A voltage regulator or 5A?
  192. reversed battery pack connection
  193. If it keeps going like this, I'll have a 4-cell, 11 volt battery!
  194. ESC Settigs for the A123 Hypersonic 2300 9.9V?
  195. Overheating Battery Problem
  196. Using 959 to charge misc use AA batteries
  197. ICE settings for sensitivity when charging 4 cell 1700 scr
  198. Fromeco Super Reg Relia Switch + Glo Driver
  199. Output voltage too high?
  200. Adapter cigaret lighter
  201. Homemade discharger?
  202. LITHIUM - ION PACKS
  203. JUST CHECKING (3300mah) (newb durr durr)
  204. Battery charger longevity.
  205. Competition Electronics Matcher Questions
  206. Lith-Ion Failure
  207. DN Power 2150 20C Swell Question
  208. Enough battery?
  209. Astro Blinky need help
  210. Are LiPo really as unsafe as I've read?
  211. Futaba Skysport TX Battery Connector
  212. Receiver battery.
  213. Li-po charger
  214. charging electrifly lipos
  215. Is there a do-it-all Charger for Aircraft ?
  216. Step down transformer
  217. 5 Cell Pack Without Regulator???
  218. BALANCER ADAPTER
  219. lithiun-Ion ?
  220. Thinking about buying a Novak Ionic
  221. Sanyo 1700 4/5 C SCR pack only giving 1400 mah
  222. swallow charger
  223. E-flite Celectra Supply Voltage
  224. DuraTrax ICE,gp triton2 or mrc 989?
  225. Hobbico Torqmaster LC Charging
  226. li ion battery fell in water.
  227. Battery Temperatures
  228. Good Deals on Lipos
  229. charge two batteries with one charger
  230. Balance Plug Install Advice
  231. battery capacity
  232. Just ordered my first NoBS pack!...
  233. Switching balancing plugs
  234. Help me charge this battery....
  235. LiPo's Versus NiCad/Nmhi
  236. Dialing in a new Lipo- By Mah or Volts
  237. Charger for Duralite 4000mah Li-Ion
  238. Charging Transmitter AA's with ICE
  239. Breaking apart premaid 3500 Battery packs to make smaller?
  240. Deans Plugs
  241. Yea or Nay? (NiMh)
  242. Triton2 problem : BattT. too low
  243. How to I find out or calculate what rate to charge batteries?
  244. Triton 2 millivolt sensitivity for NICADS
  245. lipo charged on nicad setting
  246. help
  247. Mr. NiCd's Batteries America
  248. TRITON2 or ICE?
  249. recycle nicad info
  250. battery drain
