- Futaba 9C =Rudder
- AR 7000 humming noise
- HFP 20 New programmer
- dx6i 4.8 V battery pack
- 12FG pricing question
- lockouts on spektrum ar6200 2.4ghz
- Futaba 7c Fasst
- Mixed radio gear
- Futaba / JR Servo Comparison Chart
- What do I need to have flaps?
- Dual elevators on DX7
- Please help me get a radio/receiver for my mini
- futaba 6channel 2.4ghz rx compatible with 7ch 2.4ghz?
- Traxxas RX 2215 max volts to servos? 75mhz tx/rx compatibility
- Stock spektrum servos...
- Program or Match new Chinese Digital Servos???
- New Global service for Airtronics is crazy pricey
- Royal Evo/Cockpit 7.2 volt battery ?
- Futaba 7C P-Mix Problem
- Dual conversion and transmitters?
- DX7 switch question
- futaba FP-7UAF SUPER
- Tetra RX vs GWS
- Futaba 14mz with Spectrum/JR 2.4 Module
- Need a cheap 27mhz receiver for my mini-t
- BEST PRACTICES FOR INSTALLING SPEKTRUM/JR RECEIVERS
- Flysky Sim & JR Radio
- 607 vs 617 RX??
- 3PK Hole plug?
- is this a good radio
- Bad Rx or my fault?
- servo torqe
- please delete
- Futaba 7c rudder twin engine mixing??
- Spektrum Latency Spec?
- Need help with Expert radio
- DS 821 Problems
- Radio/Ignition Switch Placement For Max Separation
- Crystal change
- Crystal change
- COMPACT FLASH CARDS
- JR xr2i
- extra batterie 14mz
- 14MZ max compact flash capacity
- 2 battery setup
- Futaba 12Z or maybe a 14MZ PC interface
- 2.4 ghz signal operating distance?
- DX7 Flaperon and dual rates question
- Metric screw size for Hitec MG shaft?
- Help my Radio doesn't work anymore
- Futaba 7C 2.4 dial setup question
- Spektrum Radio Cuts out at 700ft, Crash video included. : )
- Newbie DX6 Charging Question?
- damaged rx antenna
- HYPERION RECEIVERS - How good are they?
- I want to make my own servo extensions where can I buy the wire, tools, and connectors
- 6 volts batteries & servos life
- glitching
- Rustler XL-5 Servo Help?
- 2.4 Ghz - Failure rate comparaison between manufacturers
- gears
- Castle creation Micro stamp RX question
- Two servos flap setup with mix... DX7/Raptor
- Spektrum 2.4Ghz DSM2 VS Futaba 2.4Ghz FAST
- Want to test a RP4S1-72 corona receiver to destruction Need ideas!
- Best battery for specktrum?
- Berg 7 w/ JR Buddy Box
- Where do you....
- 2.4 Ghz and 72Mhz - Rate of problems
- Spektrum DS821 Sevos Junk or good
- Airtronics receiver issue... WHERE TO BUY?
- Tower digital servos
- JR 3v battery repair/replacement
- I am impressed!
- Multiplex Cockpit MM
- JR 531 STD. Servo
- Servo repair and testing
- JR 12X Add Looks Just Great!!!
- Futaba 2.4ghz and fibreglass
- X9303 FUSE/WHERE IS IT???
- DX7 SPEKTRUM RADIO FOR A TANK?
- JR 783 Resale value?
- 9303 or dx 7
- AR7000 vs AR6200 size????
- JR SPORT 126 or Hitec 645
- Servos for 84" Flybaby With 1.20 FS?
- Question about CC's Berg receivers...
- 4.8 V "only" servo list?
- Futaba 14MZ with Futaba Module
- She DUMPED @ 4.5!
- i need a good radio system
- JR Spektrum radio SS channel selection?
- Travel Adjust
- Cheap micro servos
- FASST w/ Large Fuel Tanks ?
- Looking for TRIM manufactures
- X8 2.4 GHz module systems
- syncronizing Aux 2 and Aux 3-JR
- Optic 6 Just quit
- Fixing receiver
- Airtronics RD8000 and twin engine
- Spektrum Issue, DX6i/7 QUESTION
- Setup question for JR 9303 2.4 transmitter
- NEED HELP PROGRAMMING FLAPS ON DX-7
- Airtronics MX-3 FHSS vs Futaba 3PM 2.4Ghz
- Hitec Programmer and X9303
- Need new receiver for old Sanwa (Airtronics) Space 6P PCM
- Berg 7 connections
- Radar Guns & 2.4ghz spread spectrum ...
- NEW SERVOS FROM HITEC?
- Which radio is best for me?
- FUTABA 7C AVAILABLE
- Plug into any open receiver slot!
- Did the search For aluminum servo arms for the Hitec HS-65 MG..NADA..!
- IS ANYONE COMPILING A JR X9303 FOR DUMMIES?????
- Cable for Futaba radio
- servo speed
- Hitec Spread Spectrum?
- spektrum 6200, use with out satellite ??
- Transmitter wtih Buddy Box- Help
- 9 CAPS & FM /PCM receivers
- To Spektrum or not to Spektrum
- Make my own "Y" connectors
- Long Servo Arms?
- Receiver Interference
- ESC/RX question
- Quest about My radio
- SPEKTRUM/JR REMOTE RECEIVER EXTENSIONS
- Traxxas TQ Glithchy?
- zombie slot?
- Digital/Analog servos
- 149DP an DSC
- Inexpensive dual-conversion FM Rx?
- Test flew my 9CAS 2.4 today
- Two Rx batteries into the Rx...
- Futaba 5114
- helppp!!!
- Blue bird micro servo gear replacement
- Binding spectrum reciever
- Is my DX7 broken?
- HDX Full range receivers
- to all 3D pilots, how much expo?
- quick Spectrum questions
- futaba 6exh 2.4ghz
- New Throttle Servo Needed
- Dymond receivers
- 6EX 2.4 Antenna In Heli Canopy
- Futaba 6EX modification
- Receiver wiring - need some help plz
- Spektrum users please help
- Jr 7202
- flight sim
- Extreme Link for 9Z
- Antenna Length - FM Rx
- Rebuilding JR DS821 servos. What to use for lube?
- Futaba T2er
- Futaba 9350 gear slop
- Futaba Programming Question
- battery life short lived
- voltage indicator problems - older futaba
- 3PKS
- Wet ReceiverMy
- 8UAP glitch problem
- Signal voltage
- 7C and Dual Elevators
- New Futaba 7 Channel Fasst VS DX 7
- Where can I find transmitter stick extensions
- Spektrum Receiver Location Question
- Need help converting radio from mode 2 to mode 1
- Bob Fiorenze Air Speed Indicator
- FMA offering Ham band radios again.
- So Mr Somenzini also had a 2.4 problem...
- Futaba T12FG JR X9303
- Berg, FMA, and other second party Receivers
- HS 645MG Servo Noise
- Industrial Supplier - Servo Connector Pins
- 9CAF failure
- Eclipse in PCM configuration?
- Help needed with radio unit on my new airplane.
- servo choices?
- Best place to buy 14MZ?
- reversing a servo (HS-625MG)
- Hs-645MG or S3305
- JR R921-ANY REASON THIS WOULDN'T WORK????
- AR6100e Range?
- 12FG
- Easily make fast charge cable for Futaba 12FG
- Nitroplanes/Raidentech servos: Anything you recommend for parkflyers?
- Help with Airtronics
- Flaperons with 4 channel?
- Need Instruction Manual - 6 Channel Radio
- cant figure out how to setup my esc
- High band or Low Band?
- Fried my receiver which is best replacement?
- whats up ?
- Futaba 9C Campac - Why Not an SD Card
- what does this mean???
- CCPM with a 8U non super
- RF CH25 Reciever or Transmitter
- Spectrum buddy box question
- Best Gyro for nose wheel steering
- New Spektrum DX6I and AR6200 full range
- round servo horn
- ???RETURN OF JR 8103 FOR SERVICE
- A or B Band?
- Glitching? Good tech tip on this on RCTV
- Spektrum DX-7 AR7000 Receiver Battery Advice Needed
- Battery for Futaba 9Z
- 2.4 connect during turn-on
- 2.4 FlipFlopper
- Customer Support Horizon Hobbies
- servo choices ???
- Futaba 4exa transmitter with Hitec micro 05s reciever
- what does this compare to?
- Help needed: TX Antenna
- X9303 programming help
- Battery tied to servo lead
- Which is the better 2.4 gHz system??
- spektrum modules in dx7
- 3 position flap
- antennae
- 6 channels
- DX6 aerial (antennae) position
- PCM?
- 7c vs dx7
- dx6i vs. 6ex
- trim question
- hard decision......
- blade cp transmitter adapter
- Spektrum Radio - servo problem
- 9C upgrade to 9C super qustions
- Can an S9252 lose neutral position?
- SPEKTRUM 3-CH CAPACITOR
- PCM and PPM on a field force 9 super tx question
- Typical range check distance
- Programming Help
- THREAD BULLY
- Airtronics MX-3FHSS 3-Channel 2.4GHz
- Airtronics RD6000
- Hacking a Futaba Conquest transmitter
- Spektrum AR6000 voltage
- CNC Servo Case tops?
- do hitec servo arms fit futaba servos?
- Heathkit manual
- Range of Spektrum's AR6100 Receiver (don't make the mistake I made)
- DX6 set-up?
- Best servo for the buck? 90 size.
- Question about the Futaba 7CAF Radio's Battery Life
- Whats a good high torque steering servo?
