View Full Version : Aerodynamics
Pages :
1
2
3]
4
5
6
7
8
9
10
11
12
13
14
15
16
- CG Question
- Lost my nickel glider
- Flying Snake's, Pentagon Research, No Joke
- my take on wings
- Extra 330L strange flight problem
- UAV Design
- Scale Airfoil - Potential Problems?
- Effect Of A High Aspect Ratio
- benefits of ailevator?
- rudder hinge line angle
- can you suggest an airfoil section for a large old timer please
- Flaperons Problems
- Is the term “stall speed” proper for model airplanes?
- Slow flying repro
- Dihedral/anhedral effect on lift?
- AIRFOIL
- slow flyer pitchyness
- Aileron reflex for landings
- 25% Pilot RC Yak 54 Attitude Problem
- Straight and Level - nose up or nose down?
- Ballast Placement CG Caculation
- Tip stalling remedies?
- Airfoil for 48" minimoa
- WING VOLUME VERSES SURFACE AREA
- Cg-Both aft & Up/Down
- center of gravity
- WHAT IS OPTIMUM V-TAIL ANGLE????
- PREDIMRC Aeromodelism & Aerodynamics
- Balance Point Determination
- Nose pitch
- Wing snapping when too much elevator given
- Another man powered airplane flys
- kf Airfoil questions
- Lift 2: Fowler vs. Conventional Flaps; Dual Airfoil(root/tip); Winglets
- Wing Loading Vs Airspeed for big and little versions of same plane
- Engine Thrust Line&Horizontal Stab Incidence
- Understanding C/G
- Electric Rotowing
- Electric Rotowing
- Hanger 9 PT - 19 Flight Question
- CG help, please
- WING LOADING - (LET'S TRY THIS AGAIN)
- wing loading
- Wing incidence
- Wing flutter
- Wing Loading of Hand-Launched RC Planes
- HOTS
- the rational of trimming
- up-date on those canards
- CG Problem
- Help with designing a big bird?
- NACA numbers?
- lift
- Horizontel stab dihedral
- 4-60 aleron mods what do do you think
- playing with front canards
- electronic wind channel
- getting effective angle of attack from 3D VLM computation
- My plane experiences snaking
- Prop Pitch
- Aerodynamics and aircraft design
- Relationship between moment arm and tailplane area?
- Angle of incidence?
- Help me understand static thrust
- Extra 300S 60 Size balance
- How to calculate the force an airfoil gets ?
- Downwash, vortice and beyond (experiment)
- Drag Estimation for an Aircraft?
- Youse guys are causing problems
- Airfoil coordinate format question
- Boost Tabs
- Finding CG
- vertical stab area for delta
- Do-335 w/ freewheeling rear prop.
- Need Help With CG Determination
- Super Soprtster Elevator question ?????
- Sailplane Calc V-Tail Updates
- What creates lift with fully symetrical wing?
- Parkzone Cub wing and ailerons.
- Elevator size
- Converting from a 2-blade to 3-blade prop
- Flat plate file and analysis question
- NACA profile
- Elevator Size Question
- Aileron dimensions
- CG location, converting monoplane to bipe
- MOVED: Programing Expo on Radio
- Serious Rudder / Pitch problem.
- changing c/l models to rc
- MOVED: Should ailerons move for pitch
- Center of Gravity calculations
- Right Thrust
- Zero-Zero glider design
- Pilot Extra 260 wont land
- pitch-yaw coupling
- MOVED: Nice Flat Wing!
- Sig Mini Smith Airfoil
- Motor incidence problem, NEED HELP
- Taper change on a simple flatbottom foiled wing
- MOVED: need information on building
- MOVED: What to look for in a ducted fan
- How much thrust do i need for a custom jet?
- What do wing fairings do to flite characteristics
- elev TE shape-True or False?
- GP Spectra. Whats to much prop?
- Need help with CG location
- Super Chipmunk 52
- NEED HELP!
- Need Help on Lift Coefficient
- drag force on cylinder with finite length
- wing conversions
- how to calculate the drag force of cylinder
- Flat Bottom airfoil
- need help - tail group alignment
- Biplane aileron?
- CG position question.
- The Red Bull Air Race: two questions
- Wheel pants, performance or looks
- MOVED: landing gear problems
- help choosing an airfoil...........
- Finding wing area
- I need a crash course on what rudders/elev/ailerons do.
- Tapered wing or constant cord wing
- yak 54 wings ??
- Comet Skyray
- How to quantify two different designs without wind tunnel
- Twice the scale, now how about the motor?
- Frankenplane - H-Stab size
- 1/4 scale schneider cup airfoil?
- What is on that aileron
- XB-70 AIRFOIL? HELP
- Spanwise Lift and Stall Sequence
- Pusher: thrust angle required?
- wing loading
- World Models Sky Raider Mach 1 -Balance ?
- Thrust Line move on an Ultrastick (Shoulder Wing)
- Cant get CG on my plane
- what is ment by coupling
- Piper Cub aerodynamics question
- Why are ducted fans considered so inefficient?
- Help for balance point
- Two Islands
- Control surface ratios
- CG / Landing gear relationship
- Mini Telemaster Airfoil
- Airfoil question
- flying wing thrust line
- Increasing size(scaling up) of an airfoil
- MOVED: Venus II Airfoil
- zero trim on wings?
- Climb on speed change
- c.o.g. and wingtube relationship
- Neutral point effects of long nose
- Aerodynamic Resources and Online Tools
- what is wash-out?
- AR vs. Winglets for reducing induced drag
- Tip Stall
- center of thrust
- naca airfoils
- Readings on Indoor Aerobatics and Dynamics
- Airfoil for a MiG 15
- Thrust Line
- Anyone heard of Greg Cole airfoils
- Wing, hor stab incidence and CG affect on flight attitude
- Wing Loading....
- Rudder area
- help with non-planing shapes
- How important is dihedral for a Low Wing?
- Kit Builders
- New build
- MOVED: obeche veneer
- Rudder force the low wing plane to dive.
- Delta wing CG
- gp 40 ultimate biplane flutter
- how to figure out the CG on this wing?
- how to design the dihedron on a sailwing?
- Question about lift
- wing
- Stab twist: one side. Effect?
- Balancing a canard or tandem wing biplane for initial flight.
- BAE HAWK FLAPS
- Where to mount landing gear?
- can you compensate for weight?
- question about airfoil
- Full flying elevator question.
- Shrouded Prop? does it work?
- Golf ball dimples
- MOVED: AILERON TRIMMING.
- aerodynamic center and CG?
- Elevator SNAPROLL
- DROOPS
- MOVED: Wing load for L-19
- naca foil datas
- Penetration
- CG issues
- rolls right
- how to calculate dihedral angle?
- Eliptical wing
- Double Reflex Airfoil
- Aileron "activators"
- incidence
- angle of attack limited by landing gear
- what to expect from my power sailplane design ( motor mounted on fin)
- tandem wing biplane
- Wing spoilers vs. ailerons??P-61 Black Widow had spoilers....
- Right Wing drops suddenly
- Anti Yaw Device
- Thrust Stand
- Insect flight
- washout on Hershey Bar wings?
- Raising stall speed?
- Help, plane has a mind of it's own.
- ENGINE THRUST ?
- sealing control surfaces- why?
- What it thes ?
- Rudder counter balance - for better rolling?
- Engine thrust angles
- real scale flight
- anyone know of any Wing airflow software??
- Shear Webbing
- Rudder on Big Stick 40
- This Citabria doesn't want to roll!!?!
- Questions about converting inverted engine to standard engine.
- CARBURETORS, BERNOULLI, AIR COMPRESSION, LEAN OR RICH????
- flutter fun
- Complex shape flying wing/delta CG calculator
- Incidence question
- Reality setting in
- Does "negative" ground effect exist"??
- ok brainwaves: maple seed flying wing
- High vs Low Aspect Ratio for speed
- Pusher engine thust angle Question
- Induced Drag
- Do not exceed speeds for model airframes...
- Flying Wing question
- Free Flight Pitch Stability?
- Let’s discuss facts about stall-spin
- NACA # for a 40% IMAC plane ??????
- Flying wing design proves to be efficient
- Mean aerodynamic chord
- Electric Sailplane problem
- Best low rpm/high efficiency prop choice
- Wing loading for twin?
- Fuselage OK?
- F1E
- f16 set up how will it fly
- Astro Hog Stabilizer
- Wing chord and Alpha limit
- New Aircraft Aerodynamics website- very interesting and highly recommended
- EDF Mounting Incidence and Toe out?
