- voltage reading after a full charge
- Best place/price for battery/servo leads for rx packs?
- Cigarette lighter adapter for use w/chgr
- Run Time..Question
- Litco Webpage
- Cooling Batteries???
- Now testing my new Orbit Microlader V6.21!
- WHAT BATTERY FOR A SPEED 600 ON A GEAR BOX
- Making a 3s pack with Kokam 1500HD cells
- Litco Alpha4 ordering list
- Super Nova 250S strange readings..
- Sirius SuperTest Pro?
- MRC Super Brain 969 Pro any good?
- Can I configure a Triton as a timed charger?
- Peak Charging?
- Hangar 9-Sure Cycler - won't charge TX
- connectors
- Li-PO vs LiMN : Whats the difference ?
- powering Triton charger
- cycling tx
- does more mAh = more weight ??
- MRC superbrain 959 free upgrade!
- are these cheap rx batts on ebay any good?
- FMA LiPoly Receiver Packs
- How to charge a single cell NiCad at 1C on a Triton
- Another Triton Thread!!
- THunder Power 2S 2100.. How many Amps?
- y harness battery
- Sirius vs. Triton
- Lowest servo power consumption
- NEW PILOT 12VOLT QUESTION
- Li-Po Battery care
- $.25 for a sub-c with pic
- Can you recommend a charger?
- E-Flite Charger: right or wrong???
- Need help to undertand basic battery charge rates
- Power Supply Conversion Page Update
- Power distribution box
- Graupner MC Duo
- pico-stick battery alternative
- Is it SAFE to cycle RX & TX packs with Triton?
- parallel wall warts to get required amp charge?
- chargers - orbit V schultz ??
- Please I need help with my DC 30min Quick Charger
- What is this? Battery size?
- Lithium cells in new Dremel
- What may I have done?
- Can you charge Poly with ion charger
- Help!Triton still won't work!
- cycling batteries on alpha-4
- Why's my Triton so slow?
- Alpha-4 Question
- Help with my Schultze charger
- Slow Charge / Over Charge ??????
- Help to take apart and re-assemble battery pack
- HELP PLEASE...WILL IT SURVIVE? HOW?
- Triton / Car Battery / How long will it last
- Battery holders??
- Peak Charger Multi RX / TX ???
- battery size- does it matter?
- battery charging question
- 2100 mah Energizer pack
- SuperBatterypacks.com
- Duralite vs Powerflite?
- Sirius Chargers question
- what is the best battary for a pt trainer
- Auto bulb for cycling
- i have "old" dualite single output charger...
- where to get a SC2 Dual Output li-po charger
- Bench Power Supply Blows Fuse
- Aurora 2000 digital battery charger
- What kind of charging is best?
- charging nimh batteries
- Can i mix brands of batteries in one pack
- Diff't discharge readings
- Extra Peak Charge
- Help: 12v Start System Mystery
- what to set delta peak threshold
- HE cell pack upgrade/Rogue cell?
- Ni-Cad Batteries ?
- duralite batterys
- (Futaba 9c) Wall charger
- New Transmitter Pack Burns Up - Why?
- Battery Question For Red
- Li Po power capability
- which battery pack last longer
- Charging: is Li-ion=Li-poli
- jr pcm10x battery
- NiMh capacity question
- Schulze Chargers
- MRC Super Brain 969 pro Charger
- Using loaded volt meter a simple discharger?
- Early adopter bonehead purchase #???
- Li Po Burn Out
- Fast charging KAN1050 Pack
- How to charge lead acid battery with a Dymond ST?
- normal discharge rate in one day?
- what bulb to discharge 1.2v glow battery
- Discharging tx battery in Futaba
- NI-MH question
- Why does the my battery run down by itself
- Glow plug battery
- Zagi battery Help... charging
- Duralites at a lower price?
- 6 volt cutoff & regulators
- Nimh or Nicad How to tell
- Pics of the 12000mah Lithium Polymer!!!!!
- schulze isl6-330d Charger
- Limiting 12v gel cell voltage
- Triton Probe
- Beginner Q, what's the difference?
- pb acid rechargeables
- 4.8v 600mah vs. 4.8v ?mah
- What to charge with Triton
- battery power and temperature
- gell cell battery
- WH Extra
- 1900 mah battery
- NiCad Winter Storage
- Please Vote on The Best Charger for Li-Poly's and Li-Ion's
- New Futaba volt meter / cycler question
- Tekin BC67 and NiMH question????
- Discharging/Charging NiCads
- Kokam confusion, LiPo application question.
- Triton Questions
- disregard
- Automatic charger shut down
- Triton won't charge Ni-Cd
- Triton will NOT charge/discharge lead-acid batteries
- What capacity can i use ..???
- asking for simply minds no charging lingo!
- flight time formula
- not much charge in rx pack?
- Measuring Mah ???
- 1800 mAh NiMH Batteries -good-bad?
- alkaline batteries
- Hobbico Quick Field Charger MKII question
- TX Battery Problem??
- which Charger / Batteries for Glider Application
- Ansmann Peak Detect Charger
- How to Replace Ni-Starter Battery (McDaniel)?
- 12volt storage?
- questioons abt charging
- Using LI Po Batteries Safely
- Where do you guys buy Duralite packages?
- Platinum Polymer 11.1 Volt 1600mah
- NiMH for Electronic Ignition?
- 12000mah lipoly!!!!!
- Ni-Cd or NiMH
- Red please read...Another Triton charging problem with Li-Ion Packs??
- Battery pack for aerohawk
- Opinions on Maha MH-C777 Plus-II
- JR XR2I radio battery charger (wall charger)
- 15 minute charge ?????
- Storage
- My 3rd Triton is going back for a REFUND...
- Info on Charge leads.
- Triton charging 9c
- TRITON...
- Is it SAFE to lengthen Battery lead or pigtai?
- help with charging
- DC Charger + Power Supply
- 800 ma AAA NIMH batteries available?
- Running Powerbox 40/24 with Powerflites???????
- Top-off RX/TX Packs between Flights- Shorten the cycle life of batteries?
- green or yellow sanyo battereis
- Crashed - Battery Problem?
- New to charging...i have no idea
- Dynamite Mega Peak Charger??? RX Batteries
- SuperNova 250S junk?
- triton "no battery"
- reacever battery
- charging lithium ion battery
- New Too Batteries GP Triton
- Quick voltage jump
- Batteries for a Futaba FG 7ch
- heelp me pleeeeeeeeeese
- Incorrect procedure?? Maybe not!!
- Battery Connectors
- Will this work??
- Is Triton overcharging??
- Help w/ new Duralite purchase.
- voltage regulator
- What battery monitor do you use?
- Hobbico Quick Field Charger MkII Problem
- Total Discharge
- Radioshack wall charger
- Hot Shot 2 Battery Replacement
- Buying Batteries
- Need help on how long to charge the battery for please?
- Digipace ll instructions
- Testing actual load on reciever batteries
- cycling batteries
- 1600 MAH NIMH TX Battery Charging
- joker batteries
- Tx & Rx Current Draw
- twin sail servo power
- Charger suggestions and questions/help plz
- Hobby Services/Triton
- Wander plug
- NiCd pack capacity changing!?
- Where to put plugs
- Triton on a 12V Battery?
- Proper care and feeding of NiMh???
- LiPol-potential WMD!?
- Lipo????
- Orbit Orbit Microlader V6.2 Info
- Graupner
- Need advise for charging
- Old batteries
- Slow Stick Battery
- what should i do?
- 6v vs. 4.8v?
- Alpha 4
- Multi Pack LiPo Charger/Cycler
- Which charger & cycler should use?
- Hobbico Accu-cycle Plus or GP Triton?
- Wall Wart ?
- Battery & charger question
- Chargers
- Amp. question
- 6v wet cell battery
- nickles and nikes on same charger
- Please help figure this out!
- Glow Plug Ignitor Charger Gone Bad?
- Battery pack suggestions for Aerobird Challenger
- Sirius Pro Charger
- ESV?
- MWhy is my Triton charging at 7.2 volts?
- mpi onboard glow batery setup?
- NEW Pro Peak Charger
- So very new to this! (Charger question)
- Thumbs up for the Triton
- Consumption of energy
- li poly and pjs 550
- Futuba CR2000/BR2000 New Products?
- Battery for off-road TL-01
- Where to buy the Orbit v6 pro
- US Repair Station
- Schulze I6-330/430 - Do they have a cycling mode?
- nimh and digital servo's
- Charging batteries
- Graupner Mc-Ultra duo Plus II
- Accucycle Readings + Digipulse Charger
- How long should a NiCd flight last?
- li=poly with lion charger
- 2 batteries, 2 switches, not enough RX channels available
- field power supply
- "TIMEOUT" when charging at C/20 rate- What does it mean?
- Reviews - Litco A4, FMA Supernova, Sirius Charge Pro & Ltd Edition & GP FFC.
