- nitro conversion
- setup... need your opinion
- muffler help
- Newbie question
- How about a 2.6 HP 36 Shockwave with a clutch?
- cooling head
- What hatch cover will fit
- traxxas nitro vee one way prob.
- Potentially dumb question regarding throttle setup...
- Tap size for glow plugs
- Aqua jet
- Outboard set up - how and why?
- HPI Mirage tunnel hull?
- nitro hammer question...
- Dumas Miss Unlimited
- Travel case ideas
- best nitro airplane engine for a 35 inch outrigger
- Can you identify these for me?
- knew dumas outrigger
- Leaning out my engine HELP ME PLEASE
- OPS .45 Speed
- DOES MECOA STILL DISTRIBUTE K&B 7.5?
- SW 36 prop and coupler
- Prop Size for OS .46?
- Need flex drive info.....
- what transmitter is the best
- first nitro boat..help!
- I have an OS21 outboard. Centrifugal Props? Do they exist?
- looking for Magnum 91 XL manual
- Instructions
- 1/12 Miss Bud Mods
- nitro drag boat kit or RTR ???
- Outrigger Plans
- Precision Boats
- plans
- First time running OPS .67 problems
- Flex cable
- Shockwave36 or Kyosho Lambo Cat?
- Prop Bushings
- Anyone in South Western Colorado
- Scratch building
- Kyosho nitro viper
- shockwave36 engine temp
- K&B Outboard Modification
- Shockwave 36 upgrades
- Can I take a prop made for a 4mm shaft work for a 3/16 shaft
- Highest nitro content ?
- Tidewater engineering
- what nitro engine on apache 52?
- why wont it work
- Webra and K&B engines
- Can't decide
- twin engie 2.5 traxxas engine in a boat
- What boat should I buy?
- BIG news for RTR boaters!
- motor upgrades
- Atlas Van lines Running Hardware
- Alum Soldering Help
- Irvine .46 in Viper R
- prather to octura prop conversion
- WILD THING is it worth building
- Strange hammer promlem
- New Jersey
- OS Vs CMB is bigger better??
- nitro vee problems
- Hull suggestions ... ideas ? Any?
- NEAVER LUBE YOUR FLEXSHAFT AGAIN READ THIS
- can i get a radio box for aqua jet
- proboat
- ASP 0.21 Marine Engine
- ALL SHOCKWAVE 36 OWNERS LOOK HERE
- Thanks for help - Dumas deepV Pic
- 1.25M Boat, Whipper Snipper engine install`
- compatible prop for 235
- cen aqua jet .16 or 775 ?
- 15cc SHOCKWAVE 36
- Fastest rtr under $400?
- I need advice on the cen aqua jet
- Official race between CEO & ejp67
- Nitro Vhull water drain
- Pros & Cons of offset & inline rudders?
- Pro size
- CMB dealers
- looking for picures
- key biscayne?
- im new to this, have a few questions
- Nitro Vhull fuel tank setup
- (Ron Olson) What do you think of this hull is it worth 150$?
- SW36 gone
- What hull types do you own????
- props
- getting my power down
- twin nitro woody
- fuel tank setup
- Info on K&B 40 model 8060
- OPS .67 rebuild problems
- STARTING OF WITH NITRO BOATS
- help needed
- Dumas Nitro Hawk question
- Dumas Eagle Sport 40
- Monohull/DeepVee/Speedboat plans
- Can I put a car clutch on my .15 and .21?
- prop depth
- re surface piercing props
- engine/flexdrive/boat combo question
- Help me with my new /used 54" Dumas Scarab
- Nitro Boats
- Re Set up of 28" nitro boat
- Understanding Fuel...Surface vs Air
- CEN Waveshark Hop-up
- Need help with parts required to get this hull back in the water
- What type of material are your hulls made from????
- I need some advise setting up a cat.
- I am this close to giving up!!!!!!!!!!!
- O'Donnel Fuel
- Boat Vs. Airplane Fuel
- How does carbon fiber work? What resin do I use?
- Which to buy?? Futaba or Airtronics!!!
- Quick Question on a K&B inboard...
- Dumas Hot Shot Sprint 3.5
- First boat pics
- found this awesome boat video here
- come and post what you bout this
- Deep-V Hull Depth
- Another Tunnel hull video,More speed this time
- SW36
- I Am Buliding A Boat, Need Some Suggestions
- Need a Hull where to get one?
- Does porting and polishing help an engine?
- .21 in 1/12 MISS BUDWEISER
- 'Wild Thing' Construction Pictures
- Prather 40" Deep Vee w/ 7.5 K&B Outboard
- Kyosho 'CAT' ?
- Radios??????????
- Avenger/Spider outrigger
- new traxxas marin engine
- Outrigger covering or painting?
- Atlas Van Lines Boat
- rossi .60 maifold and tuned pipe>?
- Weight
- Speed?
- Nitro hammer upgrades?
- OutBoard 7.5 TunnelHull Video
- Nitro ProBoat Shockwave Video
- Nitro Hammer Piston and Sleeve
- prop modifications
- starting the nitro hammer
- Dumas question on waterline
- why did i get wiped out last night off the list
- Looking for an Outboard Trigger for 3,5cc
- water cooling
- What size prop for a .40 size ?
- Does anyone know where I can find a cheep but reliable .21
- run time
- HOw do I winterize my boat.
- l
- HELP!
- LETS SEE SOME PICTURES AND SPECS
- hardware for dumas atlas van lines
- glow ignitor
- Coyote Outrigger Information
- THE UNOFFICIAL SHOCKWAVE 36 THREAD
- Information from the net
- RADIO INFORMATION
- Prop Question
- What is..... Irwin Pipes!!!
- Looking for "Octura" Inline Rudder System, please help!
- PORTING THE .32 DYNAMITE MARINE ENGINE
- Throttle
- Nitro Hammer Paint
- Where can I get plywood for builing. CHEEP!!!
- Has anyone built a Wild Thing??????
- Reviews for a Traxxas TRX Pro .15 w/Pull Start Marine Engine
- Can you help me. I want some good boat plans. I need a winter project
- Simple boat stand
- hobby stores?
- rebuild K/B 7.5
- Has anyone had any luck with the tiger drive. I'm thinking of one for my Nitro Hammer. Please Help.
- Should my pull starter be lubed or dry?
- help
- need help
- How do you like your aqua jet. I might get one.
- SHOCKWAVE 36 W/ .32 HOW DOES IT RUN
- Were to buy a .12 Marine engine??? jeees
- Anyone OWN a Megatech Wicked Angel Nitro Boat
- What should be my next hammer mod??
- Oh man im king of newbs!
- "Marine" vs "airplane" pipes: difference?
- Inboard compression
- fuel tank
- Shockwave 36 prop experience
- Boost Bottles
- Unglued NH radio box
- MAC or CMB Engines????
- MOVED: Kyosho Windrush
- want a os 45
- CHOICES NITRO HAMMER VS CEN AQUAJET $200 rtr
- Nitro Hammer cracks!!!!
- K&B .40
- Where to buy H&M hardware
- .21ci/3.5cc Outrigger
- Set up Questions on a tunel hull
- I'm looking for a new boat.
- putting together race boat need help
- os 40 engine
- anybody have a header for an os21f srm old engine
- anybody have a header for a os 21
- Hammer...
- 2 fuel tanks ?
- Shockwave 36 Motor .32 marine
- Miss Bud Help
- please help more painting questions
- my brain is working,new idea
- BOAT RETRIEVAL-Add your ideas on boat retrieval
- SHOW OFF YOUR UPGRADES AND CHANGES TO YOUR SHOCKWAVE 36
- twin engine setup????
- Buying a outrigger kit
- where can i find a hammerhead .12 rigger
- Some one delete this stupid thing plz
- Hmmm, i need some help PLZ!!
- rear exost.
- up in smoke
- traxxas nitro vee
- which motor??? pleeze HELP!!
- Servo Help
- hey im new
- Shockwave problems
- question need answers
- need help
- Engine Mounts?
- shockwave engine upgrade
- what type of paint should I use
- Dumas Nitro Short Stuff Prop Bite Problem
- any local boaters
- send in your boat pics
- looking for a boat hull
- having trouble soldering a 3/16 flex shaft.
- Engine Temp. ??
- Which one?
- Monohull and/or deep v plans
- Max engine size with standard servos.
- My madly modded hammer
- boat prop
- Shockwave 36 Pics
- How do I fix the whole I put in the bottom of my nitro hammer????
- from electric to nitro
- Have a new .21 motor... which deep-v hull should I put it in?
- Recommend a boat kit
