PDA
View Full Version : Speed - RC Nitro Boats
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
  1. my mono build so far
  2. .67CMB uses engine running issues.
  3. Looking for?
  4. flywheel and flex collet help
  5. Dumas Hardware Kit
  6. Stupid Question
  7. How long will fuel last?
  8. 3.5cc outrigger hydro
  9. need info/help
  10. outrigger hydro
  11. Winter Builds
  12. ski boat scratch build?
  13. Local Park Closed
  14. 1/8 scale Hydro hardware
  15. JetChopper30 mono deep v hull frp
  16. throttle servo travel
  17. which engine for aeromarine challenger 43 pro
  18. Who rebuilds picco engines?
  19. thew rod and piston on miss vegas AQU 18. upgrades????
  20. Picco 90 build
  21. 7.5 (.45) Tunnel
  22. Help! New Boat problem
  23. field box battery
  24. New canopy for AMPS tunnel
  25. Who has O'donnell #89 Glo Plugs?
  26. 7.5 k&b outboard mods
  27. OMRA offshore powerboat race Brixham-Torquay
  28. OPS .67 nitro marine engines help
  29. Asp 21m & Asp 46m
  30. Nitro engine needed! Please help
  31. New 40
  32. shockwave 36 price jump
  33. Back into RC Boating
  34. Hull Weight?
  35. Miss Vegas .18 motor
  36. F1 tunnel help !!!!!!!!!
  37. CMB carbs
  38. .32 Inboard Motor
  39. Thailand Outrigger Boaters
  40. off subject
  41. FULL OF QUESTIONS THIS WEEKEND...
  42. .67 muffler
  43. FUEL FILLER CAPS...
  44. PROP SETUP
  45. 1/8 Miller set up
  46. Hooked on 1/8 Scale Hydros
  47. Pro Boat Discontinued
  48. Homemade rc boat
  49. Re-Engineering A Dumas Pay'N Pak
  50. picco .67 glow plug choices
  51. newbe to tunnel hulls
  52. VISION CRAFT 21
  53. OPS .45 hull size?
  54. Need Prather DV-46 instructions
  55. getting back in it
  56. avenger spider/ rigger
  57. NEED ADVICES!! => Time for boating at Hobbyland, Dominican Republic
  58. Servo Glitching !!
  59. Flysky binding
  60. trim for shockwave 36
  61. Help Identifying this Boat !!!!
  62. OLD SCHOOL-I Want to Build an Aeromarine RC Nitro Boat after 17 Years!
  63. Thunder Tiger .21 Help
  64. Newbie help Vegas Deuce
  65. on board starting system
  66. Thundacat 31 Tiger Drive
  67. Engine identification
  68. Proboat Fastech nitro
  69. DUMAS SKATER 67
  70. Gut my BJ26 and build new?
  71. Prop size for Miss Elam 12th
  72. clear coat ?
  73. New boat
  74. Coming home.
  75. proboat hydro
  76. my boat wont start
  77. 2007 CMB 67 Green Head bearings problem
  78. McCoy 9 glow plugs
  79. .18 TZ header
  80. 21 Tunnel Talk
  81. boat NITRO engine guide?
  82. More Twin Hydro Racing
  83. need new radio for fastech
  84. AquaCraft Super Vee 27 Nitro (RTR)
  85. Hobbico Top Fueler MKIII
  86. Mounting holes for a K&B 3.5cc in a Top speed 3
  87. Need Help Nitro glow plugs and prop and propshaft
  88. Roadrunner Multi-engineNitro Rigger
  89. Happy Farthers Day !
  90. Running 1:12 Elam
  91. Newbie needs help and advice
  92. 91 marine motor
  93. AquaCraft SuperVee 27
  94. sk daddle too
  95. going to run my 1/8th scale hydros,what do i need?
  96. Pipes available for Supervee 27
  97. What is the best smelling Nitro fuel while burning
  98. Identify the hull?
  99. proboats 18
  100. Miss Vegas Deuce Engine Starting and Running
  101. Rescue Boat
  102. Sidewinder By Morgan Fuels
  103. Circus Circus Unidentified Hull
  104. K&B 7.5 inboard
  105. 2 Blade Prop Versus 3 Blades
  106. Running Issue OS Max XM
  107. K&B 3.5 outboard engine to inboard mount
  108. Where do I find an engine for my Wicked Angel (.16)?
  109. Woo0d kits or plans for IMPBA Sport 40
  110. 21 JAE
  111. Questions about type of boat
  112. What can anyone tell me about this?
  113. Nitro Boat in Montgomery, AL
  114. fastech question
  115. Please Help Identify this Boat???
  116. Why do they put silacon in the center of the crank
  117. SMOKED HIS TERRORIST A##
  118. Brand new here and I need some help!
  119. Please help identify this tunnel
  120. Rare New O.S .81 VR-M
  121. K&B .45 ourboards question?
  122. JAE .12 BUILD
  123. Equi tuned pipe
  124. Racing 2o tunnelz
  125. Picco p.67 marine engine
  126. Drive Shaft for SV 27
  127. Mono Hulls
  128. Flotation under the cover.
  129. NovaRossi motors?
  130. Please advice for fast boat plan for an OPS .60
  131. WTB K&B .67 main needle valve
  132. K & B 3.5 Question
  133. K&B carb help
  134. Any good RC Hobby Shop in Las Vegas?
  135. engines revs up and increases speed
  136. New JAE outrigger
  137. VINTAGE THUNDER TIGER .21 NEED SOME HELP PLEASE!!!
  138. Exhaust Pressure Fittings
  139. Miss budweiser
  140. Zippkit .21
  141. Outrigger
  142. Engine suggestions
  143. Carb Access for Miller American? Need help
  144. my new hull
  145. twin nitro or gas engine setup for 42" cat
  146. Applying Primer............
  147. tuned pipe setup
  148. Cant see forums at Intlwaters
  149. Trying to identfy my Miller American
  150. thundercat 31
  151. remote trouble
  152. New Losi SC buggy
  153. Best 2.4GHz radio for water and land use.
  154. NItro Boat Kit (fiberglass)?
  155. nitro prices?....
  156. TRX .15 cooling
  157. Which nitro boat?
  158. ASP 21MX First start?
  159. OPS TUNED PIPE
  160. Check this Miss Vegas out,if you need a good laugh
  161. First custom build complete! Need a little advice.. pictures and video
  162. How many ports does the .18 engine have for MVD
  163. Dumas Sport 20 Pay'N Pak Build
  164. identify this tunnel hull
  165. RC Boat glow plug and fuel
  166. CMB 21 Parts
  167. Looking for a remote needile valve for a cmb 21 red head
  168. MOVED: Site issues
  169. MHZ Blackhawk Drive
  170. Site issues
  171. 59 inch supercat aeromarine lam.
  172. enya 60-4c 4 stroke marine help
  173. Where to run rc nitro boats in Connecticut
  174. What prop would you get the most top end speed out of
  175. Balancing a prop without the balancer?
  176. You'll get a kick out of this! :)
  177. Why won't my boat start?
  178. Hey guy's alot of you and your kids have cars and trucks
  179. Good first boat to race in Ampba
  180. RB marine 10 engine
  181. Hi guy's my toys are growing lol,you have to check this one out,omg
  182. Hurry I want the hpr rc catamaran boat plans please !!!
  183. Small Block vs Big Block
  184. can you help identify this boat?
  185. Rigger Question
  186. .90 to jet drive
  187. Wanted - OS flywheel #7 for 61VR-81VR-M
  188. wanted k&b 7.5 inboard flywheel
  189. BlackJack 26 with Dynamite .32 = 50mph??
  190. Exhaust Flange
  191. Mac's Pipe and header
  192. Frog 349 Marine Motor
  193. Miss Vegas Duece not wanted:(
  194. Which engine coupler do I need??
  195. miss vegas and a .21 motor?
  196. Dumas 54 Scarab KAAMA race boat build
  197. 36 X 55 and 36 X s0mething-prop. exa
  198. Any one here have an r/c car also?
  199. I need help identifying a vintage Shovelnose Hydro
  200. RC Engine Analysis Software
  201. rudders and prop help
  202. please delete
  203. Newbie here need some advice
  204. Prather 32" Tunel Hull. Need radiobox Kit?
  205. Motor Mount Help
  206. Prop Size for Go .18
  207. Tank size
  208. New to the forum and Nitro
  209. what size turning fin ?
  210. Hydroplane with or without turn fin..
  211. Tired of this weather wanna try my miss v
  212. Zippkits SG flywheel and 12TR modification
  213. Cooling coil came today
  214. Rigger/Hydro size for OPS 45?
  215. Outrigger Help
  216. Miss Vegas Duece .18 header
  217. blackjack 26 nitro
  218. okay i dont use rc boats but was just curious about this
  219. Engine aliment help
  220. Twin .12 Texan video
  221. Well cooling problem solved
  222. k&b 3.5 pipe lenth
  223. If anyone could provide a close up picture of the header cooling coil
  224. Hi,quik cooling question about the Miss Vegas
  225. Reminder to double check
  226. sprintcat help
  227. replacment carb for st.18
  228. 36" Excaliber
  229. Digital speedometer Q?
  230. Need help please-rigger Questions
  231. CMB 67 Gold head
  232. Where can i find scratch pads for props?
  233. Fuel and props for Miss Vegas.
  234. cmb 67 header
  235. uncensured tanning pics !
  236. New at this never ran a boat,r/c anyway?
  237. Need help identifying hull
  238. Suggestion for first nitro rc boat.
  239. Could i use this in the mss vegas?
  240. O.S. 91 VR - Ducted Fan
  241. Mss Vegas Duece .18
  242. Need advice and wisdom
  243. old
  244. Best RTR Nitro Boat to Buy ...
  245. Where can i find a site for kits/plans drawings
  246. X435 vs Y535
  247. Get well Ron Olson
  248. older aeromarine .21 cat
  249. Miss Bud Overhaul
  250. New Videos
