PDA
View Full Version : Speed - RC Nitro Boats
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
  1. ops.45 starting problems
  2. K&B 7.5 Outboard Question
  3. Thundercat31 yes or no??
  4. 7.5 mystery hull
  5. Greasing flex shaft with wheel bearing grease???
  6. OS46 VXM no longer?
  7. 40 SIZE OUTRIGGER
  8. which engine?
  9. Help choosing a new boat
  10. Nitro Mono Hull Set-Up Question
  11. OS 90 MAx Marine. Does Anyone have one???
  12. looking for a boat
  13. Broken Boat
  14. O.S. .21 rebuild
  15. Flex Cable Collet For OS 90 Max???
  16. Looking For A New Piston&Sleeve For A K&B 7.5 Pro Outboard
  17. Sportin'Wood
  18. What boat to get?
  19. PICCO .65 Production Year?
  20. Tuned pipe for Go marine .28
  21. Hi-Jack Outboard mount
  22. Help identifying this boat?
  23. spanish rigger
  24. Miss Vegas in IMPBA Sport 20 class
  25. Miss Vegas Deuce
  26. How to fix crack in hull
  27. TC31 OS .21 VZ-M
  28. pipe
  29. 36 inch sprint cat!....Need Help with Motors??
  30. Please Help!
  31. Please help Identify
  32. Looking For a Cowl that will fit a 1/4 scale DPI Hydro
  33. Queensland Champioships Racing 2009
  34. UL-1 Turn Fin help
  35. castor oil from CVS ?
  36. Manufacturers of Deep Vees
  37. tunnel hull newbie please help
  38. Dumas Thriftway Too Rebuild
  39. What nitro do you use
  40. sw 36 carb settings?
  41. importing engine from Australia
  42. pipe's deal
  43. fastest bj 26 boat
  44. Aquacraft 18 backplate part #?
  45. 3.5 adjustment ?
  46. Any one run a Mecoa .46 Marine
  47. tuning a cmb 90 evo
  48. Prop for K&B 3.5 outboard
  49. PICCO ENGINES
  50. Nitro Fuel
  51. For Sale
  52. .67 for 1/8 scale Hydro
  53. My Miss A
  54. Miss Vegas Flex Cable Repair?
  55. formula fastech nitro
  56. submerged propellers
  57. Surface Drive Strut Hardware
  58. TurboCat GO 3.5cc rc boat
  59. blackjack 26 ss water retention
  60. AQUACRAFT'S NEW MISS VEGAS U-18 "The Deuce" Thread
  61. Miss Vegas - Alternate cowl lock ideas
  62. Carb settings....
  63. Speed Chart for 330' Straight
  64. Orange you glad Prather Tunnel ?
  65. Crashed my BJ26 so I had to pimp it out
  66. Right Thrust on Strut...
  67. 7,5cc outboard leg
  68. OS Needle valve assembly???
  69. tape removal ,goo
  70. OPS engine parts
  71. OPS engine parts
  72. 38 Dumas scarab build help needed
  73. prop thrust
  74. South Florida boaters (are there any)
  75. .21 in proboat hydro
  76. Tuning temps sv27
  77. Stupid out board ?
  78. After run oil?
  79. name this tunnel
  80. First run .25 vertex 29in woodie
  81. Good day
  82. Flint, Michigan
  83. go .28 pipe length
  84. My Screamin Demon project
  85. SV 27 GO .18 Mod Build
  86. CANT START
  87. Novarossi
  88. Fuel
  89. miss vegas stiffing tube issue
  90. OPS 40 or 45 Carby
  91. hooker on arrow shark hull.
  92. Miss Vegas vs. Blackjack26ss
  93. Cen grey thunder
  94. motor is toast
  95. Ready for start up
  96. New HD Vid long but check out the successful back flip at the end.
  97. Working on boats is relaxing
  98. Go Engine Replacement parts
  99. fuel tank placement
  100. .21 Mono - Gear Drive or Direct Drive?
  101. exhaust
  102. 3.5 or 7.5 mono??
  103. ASP .91m
  104. Rebuilding a 30 year old Dumas DV 40!
  105. crah please respond
  106. blackjack
  107. Nitro Falcon Electric conversion
  108. My ops .90s keep going bang
  109. engine placement for kb 7.5ob
  110. Picco.65
  111. THUNDERCAT 31
  112. Is Lighter Really Better?
  113. Are Graupner props available in USA?
  114. .18 shovelnose hydroplane plans
  115. Martin Truex .12 Rigger Video @64MPH!
  116. I need k&b 3.5cc tuned pipes and headers.
  117. Robbe Lightning 46 Nitro Conversion..?
  118. boaters from new hampshire?
  119. need some advice
  120. WHAT'S THAT OLD ******* DOING NOW
  121. Kyosho Sunstorm 1000 fails to startneed HELP
  122. teflon or brass
  123. bulkhead fitting
  124. Older gentlemen asks for advice about engines
  125. NEW/FIRST PROJECT
  126. finally gettin me a boat..!!!!
  127. Back to Basic
  128. STUFFING TUBE info for newbie's
  129. SV27 how much weight and where
  130. prop upgrade for blackjack 26ss?
  131. HELP !My OPS.80 runs backwards?
  132. OS 46 AX versus OS 46 VX-M
  133. Best Vendor to try and find metalk prop for Jet Steam Nitro???
  134. K&B Outboard throttle cable help
  135. New here
  136. another identification thread
  137. need help identifiying hull.
  138. Dumas Tunnel Hull? help identifying...
  139. blackjack 26 or thundercat 31?
  140. IV Bag Fuel Systems Research
  141. what engine?
  142. miss bud steering
  143. Converting 11/32" Strut to Lead bearings
  144. Sealing/Water Proofing NiCad battery packs
  145. o'donnell plugs
  146. 7.5cc O/B tunnel hull set-up questio
  147. Anyone buy from Funrcboats.com?
  148. Andy Brown Rigger
  149. who makes this boat?
  150. Water pick up locations?
  151. wet exhaust
  152. How much castor oil to add to 20% "Car" fuel
  153. Locals around Charlotte/Condord NC
  154. CMB parts
  155. Horsepower-vs-Prop selection?
  156. miss vegas engine advice
  157. prather 31 engine
  158. prather 31 inboard engine
  159. TRX 3.3 in Ms vegas
  160. Awesome day on the water!!!!
  161. Anyone Own a Kyosho C1
  162. older k&b throttle exhaust
  163. Great First Day with my Nitro Boat! Have a few newbie tuning ?s
  164. Need Help ID this Tunnel Hull
  165. Airstreak 500 GP
  166. BlackJack 26ss
  167. OPS 60 carb question
  168. muffler (silencer)for mv
  169. k&b 3.5 muffler (stocker)
  170. Cant get my supervee started
  171. dual engine rig!
  172. Engine Break In On Bench
  173. Recommendations for DV or Hydro Kit, .20-.40
  174. DYNAMITE Engine throttle settings
  175. Nitro vs Gas
  176. Who owns a nitro Jet Boat in NZ?
  177. sprintcat setup question
  178. Prop Cups
  179. Outrigger design for 3.5 outboard
  180. SpeedMaster 0.21
  181. Advice.
  182. Need help determining fuel type for rc boat engine!
  183. Flex Shaft Modifications
  184. FiberGlass Cement?
  185. Still Looking For a 46 - 80 For my sprint cat!!
  186. Go Engine Marine
  187. fail safe for miss vegas?
  188. Is re-glassing necessary?
  189. exhaust timing
  190. RC Boat Videos
  191. Picco 80 in 36inch Sprint Cat?
  192. Crask in Sv27 hull..help
  193. OLD K&B 7.5 with square carb...frzn carb cleaning...crank &PTO freed up !
  194. Best Boat
  195. old K&B 7.5.. .45 cu in..took it apart..crank shaft frzn, now what please ?
  196. help nitro vee onwers
  197. old boat with K&B 7.5.... .45 cu in....starter motor ?
  198. NEW
  199. Dumas Miss Unlimited Build Progression
  200. Semi Custom Boat-Which Prop?
  201. 1/2A Size Dumas Boat Club
  202. Wildcat Fuel
  203. OS 21 in a MV
  204. i need parts for a picco 90
  205. old 7.5 K&B outboard questions
  206. K&B 45 INBOARD ?
  207. OS 18 Piston
  208. Need help picking out a boat
  209. Sigma 51 for CMB90RS
  210. am i on the rite track (time to buy hardware)
  211. coyote daytona
  212. O.S. 46 VX-M for 36 Inch Sprint CAt
  213. What tuned pipe if any for my OS Nitro Motor....
  214. What would be a good Motor for a 36inch Aeromarine Sprint Cat
  215. Thanks For the 7.5 K&B Inboard Help...
  216. looking for tunnel sold in upland
  217. Info on Picco 90's
  218. MISFIRERING O.S. 46 VX-M
  219. new to nitro need help buying
  220. Old 3.5 K&B outboard setup help
  221. Wat speed have the fastest Shockwave 36 with the same 32 Dynamite engine?
  222. Plug For 7.5 Inboard K&B??
  223. Glow Plug Selection
  224. i need to know about picco p90
  225. First Hydro
  226. quick quiestion about paint prep ?
  227. What kind of boat is this?
  228. MVVS .40/6.5cc marine engine
  229. Best Prop for Miss Vegas???
  230. HB .61 pdp marine
  231. gator 60 outrigger help
  232. 1/12 miss budweiser
  233. head changing
  234. need help with K&B outboard carb
  235. Mean Machine rebuilt
  236. Need Help First Boat Ever Undertaken
  237. SF (SureFire) 32 Marine Engines
  238. buggy engine to flex shaft help plz
  239. Need help on what sand paper to use on my Jet Stream hull/top...
  240. Third channel fuel mixture
  241. Bring out the old stuff
  242. Is it just me or did Domantor Models?
  243. lost intrest.....but now im back!!!
  244. Looking for a COUPLING FLEX HEX
  245. Miss Vegas w/stock OS 18TZ - Prop?
  246. Picco .90 Marine Repair?
  247. Futaba Megatech
  248. Dynamite-15
  249. OS 21 outboard on a cat
  250. Dumas Hydro Exhaust Problem
