- THE INDY MASTERS RACE
- Newbie Help with bj26
- Why are props so far behind the transom??
- Cat w/Twin Surface Drives
- paint shops
- PICCO .90 Header
- Kits or scratch plans?
- Lookin for a Freedom RZ
- Picco .90 exhaust
- Anybody order from Dumas lately?
- which direction?
- Trim Tabs
- System Three Clear Coat Pigment
- What is the breakin needle setting for a .12 CVR?
- traxxas vee ???????
- K/B Motors - Should We Quit Using Them?
- Vertical screw-adjustable strut?
- Spektrum in boat??
- using a car pipe on a boat?
- Drill And Tap Motor Mounts
- Rossi 3.5 outboard
- Lawless outdrives
- Clubs?
- nitro conversion
- Dumas Hot Shot 45
- What size?
- What model & make is my new boat
- cutting a K&B lower outboard unit
- kyosho jet stream 1000 w/ os..max 32 (good or no good)
- Help my son and I
- SHOCKWAVE 36 WITH OS 46 ENGINE
- STARTER DIFFICULTIES!!
- Engine upgrade for Shockwave 36?
- "Big" Hydro Resources
- Aluminum Hydro Strut for 3/16" shaft?
- CRANKCASE COOLING
- TS 2 FUEL TANK
- Chine Dancin
- looking for motor mounts for 1/12 Miss Bud flex drive style hydro!
- Bones's new ride. Firefighter .12 outrigger
- Desperate Need Help: Broken K&B 3.5 Con Rod
- Turbo or Non-Turbo?
- Looking for a tower hobbies part
- Where in Toronto area you run rc boats?
- New To RC boating
- Who's the maker??
- the tiger shark
- Twin Engine Nitro Hammer Winter Build
- nitro boat engine queery
- always thought the cen aquajet ran a .16 engine
- what tunnel and what size???
- There has to be some way..
- %^$# LHS's, I need help again please
- Sanding Bottom Of Hull
- Dumas Skee Vee 10
- Outrigger Strut hieght
- Prop Help!!
- Selling engine question
- Looking for a boat to build.
- Break Inn Fuel
- Exhaust Coupling for Miss Vegas
- BENCH TUNING AND BREAK IN
- Tuned Pipe OS 21
- Nitro hammer problems! Help!
- Dual Outboards
- my 7.5 dpi tunnel
- Supercharger for OS .21 outboard?
- flywheel too light??
- AquaCraft U-18 Miss Vegas IN STOCK
- What's make & model is this outboard
- cooling head ???
- Pro Boat hardware?
- Header and Tuned Pipe for OS 21 XM Outboard
- aqua jet queery
- How to finish a wood boat?
- Have a problem with my engine
- How does the flywheel fit onto an engine like the .12CVR
- What is the indication of a tired engine?
- TS2 Hopup
- My new boat need some questions answered
- .12 Engine?????
- 1/8 scale hydro hulls where to buy?
- Scale Hydro or Sport Hydro Race Video?
- Titan .21 Questions
- CMB 21 Valvola Tuned Pipe?
- WHAT SIZE MOTOR
- NITRO ENGINE HELP
- .12 outrigger turn fins
- Brian Blazer's Whiplash Sport 20 Build
- Upgrade advise
- just got 70 more dollars
- 3/16 flex shaft collet
- O.S. .21 RG-M flywheel/collets
- Sold and now on to the next one!!
- Introduction
- prop help
- 4-stroke outboard speed boat
- Fuel
- how loud
- finally got me a boat
- Rigger videos (Dumas Lil Rascal)
- TS2 TUNNEL AIRBOAT the Making...
- K&B Outboard 7.5cc ?
- RB/ROSSI WET HEAD?
- Prather 215 props
- What make and models is my new boat
- 1/12 miss LLumar hop ups?
- NOW IM PIST OFF
- O.S. TZ 18.
- Aquacraft Top Speed 2
- If strut is listed for 3/16th inch stub...
- Reading the glow plug...
- Pictures of stuff tubes installed wanted
- New Boat Advice
- What is the purpose of a skeg??
- U Joint fix for Black Jack 26
- Nemesis and Villain S1 Tunnel's
- hey everybody
- crunchy sound?
- One hour R/C video on google
- Make your own Nitro Fuel...
- FF .12
- SHOCKWAVE 36 IN CANADA
- Buggy motors for Boats????
- KYOSHO JET STREAM GP 10
- Third channel mixture needle setup.
- Tunnel Hull
- Project "upgrade lil rascal"...with questions
- Tom Moorehouse
- Outboard pipe advice needed
- Build Pic's of my son's FF.12
- HP...
- MECOA MOTORS ANY GOOD?
- Thundercat 31 vs. Shockwave 36
- size of a flexy cable?
- Pull starter slipage proublems!
- Fuel Tank for FF.12
- MHZusa Flash Hull owners
- Which .12 is better?
- Flex Shafts???
- new agitator 28" offshore cat/// which engine, drives> hmmm
- Baby Rigger Build Log
- Another Warning!!!
- Need boat advice
- where does the nut go????
- Just a warning!!!
- Crankshaft Start Pin
- Boat trailer???
- bandit boats
- Dumas Atlas Van Lines 18"
- Swash Drive and V8 RC Sprint Boat
- needle valve setting for K&B3.5cc on topspeed2
- NJ FUN RUN CHECK IT OUT
- MHZ - 6 x 15 Sextett.. what would u use in a cat?
- list problems to look out for with the Thundercat 31
- sprintcat 36 turbo cowl
- Radar or GPS
- german offshore cat "agitator"? hmmm
- what rigger hull for .21
- 1/8th Scale Hydro Build
- glow plugs
- How tight to tighten prop?
- What Rigger?
- Paint and Gelcoat
- First build question
- Easy way to Calculate Engine RPM **AND now Speed**
- New Member Welcome
- What size hull would suit.
- Exhaust Gasket
- What is it and what's it worth ?
- ? on trim tab length
- NEW SCALE BOAT
- i was just told any boat under AUD$700 is crap
- jet stream 800 clutch or no clutch
- .15 rigger plans
- PIcs of WILD THING RUN from hpi build
- Dynamite .15 needle settings!
- Aquacraft miss vegas opinions
- radios ??
- Miss. Bud problems- Help!!!!!!!!
- nitro vee help please
- Dumas Deep Vee kits- how are they, what hardware?
- Cant uscrew motor mount screw- HELP ME, Help
- Pro Boat Thunder Cat
- AC Hydro/Rossi 45
- Project Restoration (1st nitro boat)
- How does your motor act with a bad glow plug?
- Miss Elam BLOOPER!!
- Miss. Bud out of storage= Crunching sound? Tiger Drive
- SK Daddle
- HSP .18
- Questions on converting an old boat to a strut system.
- Anyone here ever dealt with "Fuller's fast electrics"?
- Bud .21 hydro
- 1 twisted hammer(update)
- A NAMBA 'under hull' strut for Miss Vegas?
- How do you seal your radio box lid?
- topspeed 2
- OVERHEATING!!
- Sport 40'S
- Engine ID?
- stuffing tube
- Any pictures or comments on "retrieval boats"?
- Hot Wheels Radar Gun
- sport 40 prop
- new boat-31" Victory off shore cat updated 31/12
- turbine hydroplane
- Need prop suggestions...
- WHERE DO I PUT THE PRESURE TAP ON A TUNED PIPE
- Traxxas .15 engine
- Boat Race Class
- HELP with the Dolphin Nitro!
- Help which boat? Need advise, any at all!!
- help! me
- nitrous express
- Frosted Flakes
- .18 TZ MARINE HEAD
- Blackjack 26 flex shaft problems
- Whiplash 20 Hydro the making...
- Soldering clevis to control rod?
- New Panit Job (tropicana Green)
- 26 inch mono build thread
- sullivan tiger drive
- looking for plans
- Hull Repair Help
- Build a Baby Rigger with me! (FREE PLANS POSTED)
- TS2 .32 INBOARD MOTOR the making...
- OPS engines, Parts Where???
- Whats the best vee hull for an outboard?
- Why do you suppose this thing cavitates B4 the prop grabs???
- .15 Engine
- AquaCraft SuperVee 27 Nitro RTR
- Newbie Q's. Thundercat 31, Aeromarine Mean Machine, Miss Vegas?s
- Winter Build - Rigger -
- 29 more new pics has been added and 1 new video been added of my Miss Bud.21
- air scoop/ vent??
- Pics of Misshydros Miss Budwiser.21
- would this work?
- huh? pro boat bj 26
- FF .12 and a Dynamite .15
- Traxxas Nitro Deep-V ????'s
- trim tabs
- Record SAW vs Record Oval vs Heat set-ups
- Prather outboard deep vee
- K&B 7.5 Outboard Tuned Pipe
- Tuned Pipe lengths
- Glow plug problems
- Help building a FLOW METER
- newbie need info for freedom rz
- Belt starting problems
