- Tiger scheme
- Wild Hare Extra 260
- Baby 540/260 wings needed V2
- Edge 540 V 2
- 50 cc WH Sukhoi electrical system
- Rudder servo arm WH 35% Extra 300?
- 35% Extra 260 maiden
- is anyone building the new 35% 260?
- WH Edge 540 v.1 ??
- Battery setup for 35% Extra
- Engine thrust angle?
- 41% Extra
- Baby Edge Engine
- Servo Arms for WH Sukhoi 35%
- Used 35% ..New Engine??
- 50cc sukhoi h-stab location?
- Baby Extra & Edge for 2009
- new 88" Edge 540 maiden flight report
- 3MM 114
- death of my edge
- Baby Edge SPE 26 Combo
- Help finding 41% build
- WH Ultimate aileron hard points
- Wildhare 35% Giles wingtube
- Wild Hare Ultimate comparison
- wh ultimate with rcign g62
- New video of Giles, manuals
- Giles best engine option
- Anyone have a Wild Hare 41% Extra lying around
- 28% EDGE Maiden and Review
- Cap 85"
- Baby Edge Extra Question
- TOC 53 update info
- Baby Edge on electric
- 28% Extra300 (V2) Hatch
- Xtreme Composites new U.S. distributor needed.
- A QUESTION FOR TOM
- Repairing pocket hinges
- FMA Charger and A123 Combo
- 35% Wild Hare Edge 540
- 73" Extra 260 gas engine
- Did you use right thrust on your 35% sukhoi
- Wild Hare Baby Kit Contents?
- Landing gear info needed
- Wh cap
- New 35% Edge
- 35% Extra 300 w/ DA 85
- 50cc Extra 300 final assembly questions
- Baby Edge Saito 180 Combo
- baby extra 260 engine mounting
- 41% Extra 300
- 50 cc sukhoi ???
- TOC 53 Ignition Voltage
- WH 'old' giles 35% - need help installing the ZDZ 80
- Extra 300 Special carbon fiber gear
- baby edge question
- Baby edge 25% replacement wings?
- Edge 540 25% Zenoah G23
- different gear for 50cc Sukhoi?
- baby edge/extra question
- baby extra and bh hanson g26
- 88" Edge Specs
- Edge colors?
- Baby Edge and Saito 1.80
- A123 Tanic Packs
- Wild Hare 50cc CG question
- 540T V1 root CG location
- 50cc carbon wingtube
- Edge V2 Trim and Batteries
- 85-87" Yak ?
- Price difference between planes
- 50cc Giles 202?
- DL-50 Carb Connections question Extra 300
- Different Landing Gear Design?
- 28% Extra V2 with Saito FG36...doable?
- Landing Gear Repair Suggestions
- Maiden Flight 35% Extra 300
- Baby Extra 260
- News and products 2. New planes coming!
- News and new products 1. Engines!
- It had to happen!
- Need an Extra 300 fuse
- New accessories
- 50cc sukhoi fit a wrangler?
- Landing Advice
- Single servo for 35% Sukhoi wing?
- 5oCC Sukhoi CG Question.
- 29% Ultimate and Engines
- CG on Extra 300 50cc version 2
- Sukhoi Video
- Extra 300- Trim schemes
- Thanks in advance Tom!
- A Fun Day Flying Wild Hare R/C!
- Orderd two new WH brids! Any feedback on these?
- CG QUESTION ON WILDHARE YAK
- 50cc Sukoi wing tube question
- Late questions..
- 28% Edge V2 Balance concerns / problems
- 28% Extra light weight parts
- Servo mounting
- WH 35% Sukhoi - spare parts
- V1 Edge cowl...anyone have one laying around?
- baby series servos
- baby series gas other then evo?
- 3MM 53 Reed Block Damaged - Dummy
- Wild Hare operating at low rate for a while
- Original baby edge??????
- 35% Extra Wing Help!!!!!
- 41% cowl in stock?
- Canister`s and 41% extra
- Bulking up the LE...
- Canister in Edge540 V2
- R and D
- V1 Edge 540 - No Glue in front end!!
- WH 300 Extra Foto Shoot
- Extra 300 Canopy
- (Cap-Edge) Flight Report
- What batteries do I need with these servos
- 3mm updates
- DA standoff for 28% Extra
- WH 300 extra 84 comment and question
- Wingscrew to Extra 84"
- 3mm TOC-53 canister results
- 35% bird question
- Canopy's and various glues
- 26cc in the Baby Edge question
- instrument panel
- Yo WHyou there?
- 28% extra 300
- Landing gear cuffs (50cc Extra)
- CG Problem On Wild Hare SUKHOI 87"
- thank you ,folks at wildhare
- cowl color
- 28% Edge / Extra Cowl cutting?
- Hare today and gone to Toledo
- Whats the main difference between wild hare and extreme flight?
- OLD Giles 202 - Help needed!!!
- tail wheel for 28% wh
- Sukhoi 28% and TOC53 Standoff length
- MTW 110 canister and DA85 in Extra 35%
- Da 85 or the new Da100
- ball links hitech arms--WH Suhkette?
- edge 540 covering colors
- WH 28% extra power system ?
- Sukhoi - TOC 53 Canister - Cooling required
- Help needed in picking servos for V1 edge
- Old Edge/New Edge interchangeability?
- Going to 2.4? Great deal from Horizon
- Toledo show info
- servos
- Canister mount - teflon connector
- 35% extra rudder cables
- 28% extra
- Recommended servos 29% Sukhoi
- 35% Sukhoi - DA85 Build
- 35% Sukhoi with DA-85 and canister
- 35% Edge with DA-85 Building!!!!
- WH 121" Extra 300 CG
- WH Edge V2 50cc question
- 28% Extra V2 with DL50...who's got this combo?
- SU-26 - All Good!
- Wild Hare 50cc Sukhoi DA-50 Mounting ?
- Old 50cc extra with new wings
- Spinner Balancing?
- 28% Edge 540 V2 new Video!!!
- Just wanted to say hello and thanks!
- deleted
- please help I can't decide between Wild hare sukoi or wild hare extra 300
- Version 1 28% extra or edge canopy hatch wanted
- Edge v2 question
- YAK prototype CG
- SU-26 Suggestions
- Canister for TOC 53
- older 28% extra canopy/hatch needed
- Giles build by Tom
- A123 and switch
- Built tough enough?
- Wild Hare Edge 540T V2 Build / Review
- LR-1
- 3D flying with a Jet ???
- w h 84" edge
- Help Wildhare su26 87inch
- 35% Extra Build
- Wild hare 28% extra
- February shipment of Honda Sukhois is here
- Sukhette red/yellow, great deal on east coast
- 28% Extra V2...beautiful!
- A lot of information was gathered today! Extra 300 with DA-85!
- Downthrust on Extra 300 38%
- Engine Templates
- Extra 300 28% review and maiden
- I DID IT!!!!!!
- WH pilot figures
- 35% DA-100 Mounting
- extra300 50cc input needed
- WILDHARE 29% EDGE QUESTION
- Extra 300 50cc
- 35% Extra Setup Question
- WildHare 35% Extra 300 Build
- Da 50 with mejilik 23 x 8
- Wildhare Extra 28%
- Baby Edge Gas Motor
- Sukhoi SU-26 For 50cc 3D Plane??
- Hitting the wall too hard with a SU-26
- Prop distance From Cowl?
- Long Arms?
- Maiden flight ..finally SU-26
- Vess prop for 3mm 53cc
- drilling robarts
- new accessories
- toc 53
- Canister for 3MM TOC 53?
- wing bag promotion
- WH 35% Sukhoi or Extra?
- Edge 28% V2 End of the year Flight VIDEO!!!
- wh ultimate cg
- Prop hanging and prop size.
- WH Giles G202 40%
- Recommended throws 35% SU26?
- Merry Christmas
- happy holidays
- WildHare 28% Edge540T V2 Build and Mod
- Edge 540 V-2 Engine Cowl
- Incidence experts needed!
- New 35% Edge samples available
- Graphics from 91 Design
- Baby Edge Build Thread
- Tom....big Sukhoi question for ya.
- Last chance for Ver 1 Edge parts
- Wild Hare 73" V1 Edge Gas w/A123?
- Video of Extra 300 84"
- WH Extra 260
- Tom, Joe Hunts DOD Graphics!!
- market research question
- Coming soon, new Giles G202
- Su-26 Finally got her done
- 28% Extra
- Wild Hare Giles 93'WS, 3D possible?
- H-9 advertisement in W/H Forum
- WH CAP
- Wild Hare Ultimate?
- WildHare 28% Edge V2 - 3W 55i too heavy?
- SUKHOI 35%
- Real world data on power requirements
- Batteries for 50cc aircraft
- First Flight Extra 300 50 cc
- Sukhette and DA/DL 50 exhaust
- Servo Arms?
- 33% Extra 260 - DA 85 combo question.
