- 989 lcd display issues
- best easy LiPo charger?
- Can I use higher mah batteries
- batteries
- MRC super brain 969
- Super brain 989- charging LiPo batteries help
- Help with Superbrain 989
- Triton EQ
- 965 help
- Introduction
- Charger Voltage Question...
- LRP ZR32 Roto Start issues
- MRC 992 Palm, I'm not understanding how to set the MAH...
- Battery Charger not working
- who's still using nicads for rx
- Question - Charging 3 LiPos via one balancing charger
- superbrain 820 won't recognize battery.
- Gas or electric
- Lith Ion vs Lith Po
- HELP! Need info on multi Chrgr: Trans & Rcvr
- 91 os conversion
- Charging Ni-MH with MRC Super Brain 959
- Superbrain 992 interface cable
- what battery to get
- Need a new chager????
- MRC 977
- super brain 820
- how do I find the best charge rate setting for my batteries
- how does a peak charger work
- default settings and software versions
- Superbrain 992
- How do chargers work?
- 977 and LiPos charge method
- MRC 922 Charger - Where are you?
- Super Brain 977
- Super Brain 977 Power Supply dropping out
- Major MRC 977 problems
- 989 questions
- 977 fan bearing???
- battery pack
- radio battery
- Another Superbrain 960 charging problem post
- Help with mrc977
- discharge problem
- How to balance lipos on a 977
- what charger
- LiPO discharging after flight
- 977 problems/questions
- battery ideas
- Max discharge power?
- Hey Tim still having 960 charger problems
- 989 and Nimh packs
- Having 960 charging problems?
- how to charge a lead acid bat with the super brain 989
- just got my 989. got a few questions..
- 977
- MRC 977 Fix
- which charger
- Super Brain 989 problem charging 1 cell lipo
- SUPER BRAIN 969 frying reciever batteries
- 989 Green Plug
- flustered!! need help!!
- 989 balancer & connectors
- 977 and Equinox Lipo balancer
- MRC 959 SuperBrain Damage
- Superbrain 969 charging high
- charging help for these batteries
- MRC Super Brain 959
- 989 and Lipos
- !!-HELP-!! Super Brian 969 Pro
- 959 questions?? Thanks
- Tim Sandor Mailing address?
- Super Brain 977 **READ**
- 969 super brain LIPO compatible?
- Super Brain 989 Reliability
- 989 help please
- mrc 959 problem
- How many watts
- MRC 977 balloons LiPo's
- Using 977 pro as multimeter
- Super Brain 989 Problem
- 960 doesnt charge properly
- Profile setup for 989
- 977 and stupid.
- SuperBrain 977 Discharge Question (Regarding Delta Peak)
- need a balancer
- Super Brain 959 Codes
- SB mrc 960 question
- 977 not good for LIPO???
- what does this mean?
- looking for a lipo charger reasonable
- great customer service
- MRC Power supplies (part numbers?)
- is there a problem with my 977
- Can I still trade up the 969?
- *** THANX Tim and MRC***
- power supply question.
- MRC RB982 Power Supply - high output voltage.
- Form chargin/cycling wiht a 977
- 977 output connectors
- mrc 969 upgrade
- LiPo Batteries not compatible with 977
- Super Brain 960 - warranty voided!
- MRC SuperBrain 977 and A123?
- New 989
- Power Supply question for 989
- mah question
- need your help Tim
- another charging question.
- blinky question
- MRC 959 charging question
- have question about 977
- charging apogee batties
- SB 960 giving problems. Please help
- 960 help please
- 960 stopped working
- 977 pro 4s lipo?
- Is 3700mah it for SB 960?
- Problem charge led acid battery
- 959 super brain wont charge
- 960 LED problem/stopped working
- MRC 960
- Charge/Discharge info for a couple batteries
- MRC dedicated!
- MRC 960 Superbrain 7.2 volt batts reads much higher voltage
- Brain 989 Lipo starts at Amps
- SB 977 Channel A Volts != Channel B Volts
- Super Brain 960 heat question
- Serious MRC Super Brain 960 problem
- Mrc Superbrain 960 exploded!
- Superbrain 977 Charger for sale
- MRC Super Brain 989 Best of the Best.
- 977 keeps shutting off
- Super Brain 960 Problems
- Delta peak setting for LIPO?
- MRC Super Brain 977
- Superbrain 960 power button failure
- Super Brain threshold settings.
- SUper Brain 960 problems
- Lipo balancer for 989?
- SUPER BRAIN 820,960.INFO NEED PLEASE :)
- Super Brain 977 Lost Discharging, but still Charges Fine
- Superbrain 960 LED flicker
- HELP...newbie lost with 989 super brain
- SB969
- super brain 960 broken?
- Reviving dead lipos with the 989
- smart 989 with lead acid
- 989 Tutorial
- Can it charge two packs?
- Problem with Charger!
- SB 989 Charging Characteristics
- MRC Super Brain 960: Problem charging 9.6v 4200mAh
- SuperBrain 960 - is loud high pitched sound normal?
- SB 989 and Li-Mn
- 989 charging question:
- Green Connector on MRC 989
- New 989 User
- Charging lead acid batteries with a 977?
- SuperBrain 989 - 2 questions!
- 989 Auto Cycle and "manual" cycle charging
- How do you guys like your 989?
- Error Codes for the 959
- charging 2 batt's at once
- MCR 960 Question
- Super Brain 989 battery recovery settings
- Problem with 989 to charge Transmitter battery
- I've got an issue with my MRC 960
- Going to Toledo
- 1/25 scale boeing 747
- 989 is only charging at 42000mah at .5 amps max
- 977 charging and discharging Ni Mh batt
- 989 repair/replacement status
- Superbrain 960 not charging / false peak?
- charge AAbattery 2600mah with 989
- Superbrain 960 and this reciever pack
- Can someone help me figure out my Super brain 960?
- How do you get the best temp reading on a 989???
- 977 Lipo charging
- 989 voltage readout problem?
- MRC SB 989 charge issue
- PLACING CELLS IN PARALLEL
- Super Brain 960
- 989 Superbrain issue with NiMH
- noob needs help 1st time NiMh charge on 989
- Super Brain 960 battery charger combination??
- super brain "err"
- Will the 977 work for parallel setup?
- SuperBrain 977
- 977 - AMPs Drop When Charging with 12V DC
- 989 General Q's
- Super Brain 960 vs. Duratrax Piranha
- Bought a MRC Super Brain 977 and would like a balancer.
- Superbrain 989 power supply problem
- Mostly Dual NiMH now but lipo soon wich is best 977 or 989
- 989 charging a lipo at 1.2C
- Superbrain 989 green plug
- battery recycler
- Settings w/Super Brain 960 for Venom 3000niMh 7.2
- 989 can't change trickle setting for lipos
- 989 psu fan question
- Balancer
- Using charger while driving?
- New Super Brain 960....
- power wheel charging
- Super Brain 989 & 12v gel cell
- 989—What’s better, charging in series or parallel?
- Instructions manual spanish
- hey tim can i get some advice?
- Super Brain 960
- MRC 960 Only Charges 9.6v
- Looking for a NiCd voltage meter checker.
- Hey tim@MRC!
- Super Brain 977 Traxxas Adapter Help
- Super Brain 960
- sb 977
- Super Brain 977 HELP
- SB 989 and trakpower lipo problem
- Super Brain 960 - False Peaking?
- questions
- 989 question again
- MRC 969
- Super Brain 977 Changing Values
- 7 cell ib3600 reading 6 cells?????
- question about 989
- SB 989 charger problem
- Super Brain 989 power supply fan
- Balancer for 989??
- 977 doesn't recognize lipo's.
- Couple questions
- What happened to Tim@MRC???
- 977 and Mini-LST2 batteries?
- MRC 959 and Nikko batter paks...Hmmm?
- Just got my SuperBrain 989
- 20 amp power converter
- Upgrade MRC 989 for use with A123's
- 600 Can Motor - Suitable Battery
- Super Brain 960 gets hot and noisy - help?
- MRC 977 and 989 Charger Question
- MRC Super Brain 960 - my first charge of 6-cell pack
- quick question
- Super Brain 960 problems
- 960: Large Voltage Drop
- MRC 969
- Super Brain and Flight Power V Balance? Err b L
- Upgraded 969 Lipo question
- My wonderful 977 and lipo charge soon
- MRC 989 questions
- Team Orion Lipo with 989
