View Full Version : Batteries & Chargers
- battery charging issue
- Hyperion To Dn Balance CHarger
- A123 vs. Hyperion LiFePO4
- Fitting a fan to an Imax B6, Bantam/clone owners help please.
- Receiver packs
- 1/16th style lipo charger
- Pro-Peak Prodigy II repairs
- 2 NiMH packs on rx.-different mah?
- chinese power supply
- Battery recommendations
- can someone explain how to do this or if i can do this.
- Mega Power 960SR/Robbe Infinity 3 help
- New to Li-Pos in scale boating
- AccuCell-6
- Graph 6sx3000
- disturbing trend "blind balancing"
- disturbing trend "how low can you go"
- disturbing trend "ask lvc when to stop"
- disturbing trend "series balance board"
- balance tap type...
- charging question about lipos...
- NiMH Battery issues
- What to do with cgr18650c Cells
- Bantam BC8 charger
- max charge rate
- New SpyderBatteries
- My new batteries (lipo help)
- lipo
- A123: Dewalt Harvesting & Fleabay alternatives
- problem with new Onyx charger - design issue???
- Balance Tap pics and descriptions
- need a 10+ amp battery power draw pack.
- Hobbico Hot-Shot 2
- when to charge A123s
- Best do it all battery charger?
- Balancing a jst plug lipo?
- Blinkey LiPo Balancer
- A123
- Quick question - Lipo charge
- UBEC'S
- Got a car with a missing charger
- How to insulate binding post(banana jacks)
- Gray wire Power ok on atx
- Looking for a good charger...
- how do I find the battery capacity?
- What is a good charger for 2 batteries?
- Lipo battery survey
- LiPo Balancers.
- Should I discharge my lipo?
- I need a better nimh charger
- Adding balance lead to lipo pack
- Battery charger
- Nitro Guy Needing A Bit Of Lipo Charging Help
- HELP Conditioning a new NiMH Battery for TX
- RX an TX NiMH batteries
- Will the Triton2 EQ work with Zippy batteries?
- Battery Questions
- Want to cycle my battery pacs
- I'm trying to charge some Nimh batteries.
- 2000ma NiMH battery-cycle question
- Hyperion EOS615i DUO3 best choice?
- Tahmazo T-15 Plus Nicad Charging
- Lipo balance charge lead
- Charging Lead-Acid or Gel-Cell batteries?
- charging saturated?
- Venom RX Lipo question
- Best Connector other than Deans
- Premium Power LiPo Balance Connector Identification
- Thoughts on Onyx 230 Charger
- checking li-po charge
- I shorted out the balance tap on my hyperion lipo...
- Questions about Duratrax Intellipeak Twin Pulse
- Break in for Lipo - is there such thing
- Li Po's for transmitters??
- Inside a Lipo
- Accu Cycle Elite used to charge Duralite Li-Io?
- Hobbico quick field charger mkII & NiMH
- Lipo setting help
- Charging Lipos
- Anderson Power Poles
- Li-Po Batteries Time Out when charging
- Do i need a new chager. ?
- Battery cycler
- Adapter for E-Flite LiPo??
- 2s +3s for boat
- How to store various chemistries
- Weird LiPo problem
- replacing the 12v lead battery for glow engine starter
- cycling lithium-ion batteries
- Discharge a receiver battery pack with a PC fan?
- Best Hobbycity balancer only
- Good Rechargable AA's?
- Triton help needed
- Is my battery messed up?
- Fromeco website
- voltage questions
- Solar Battery Chargers
- DIY discharger
- Equinox Balancing at 4.2 amps?
- VXL Battery Suggestions?
- 1000 MA Wall wart
- NIMH odd situation question
- Astroflight Blinky??
- RADICAL RC
- Newbie problem
- battery 101
- Hyperion charger
- Triton charger question
- Charging a LiPo battery
- Batteries for nitro cars
- Li-ion questions
- CBA II qustions
- Polimax B6 Lipo Charger - Does anyone know it?
- Splitting lipo packs to reduce voltage and to make others.
- Understanding My ESC
- blade cx2 lipo charger
- From Lipo to A123 power?
- Help with battery plugs
- Lipos cell at 2.95v
- New "smart" battery charger fried a battery. Possibly a second.
- Slow Charging LiPos
- battery
- Forming a starter pack
- Puff Puff and SmokE.....
- Too Long Balancing
- Nicads won't take a full charge
- A123 for rx pack, regulator required?
- Ace Digipulse replacement?
- Powerful Power Supplies?
- LiFePO4 batteries
- Cycling Nicads..how often?
- How long after charge are you still safe?
- Battery trouble....help please.
- Upgrading batteries
- How many Amps?
- What is the proper charger cut off voltage?
- Accu-Cycler Elite or What?
- H9-DL50 What Rx. Battery is best?
- 4s lipo adapter to 2s needed
- Rx Battery pack charging question...??
- Powerwheels BaTT -
- AC charger help
- Converted computer power supply question ?
- Accu-Cycle Elite charge problem
- Battery problems
- RC Accesary.com are these good batteries?
- charging question
- 12v 7.2Ah Lead Acid - Charging?
- Voltage and AMP testersm
- will an Airsoft battery work?
- Power Supply Units
- lipo info....
- breaking news
- lipos+water = .... =(
- Other than LiPo
- Which is + and -
- Please help with my charger settings.
- Wall Wart
- how to to tell voltage
- Volt Watch shows green and red
- Charging a "dead" Pb battery
- What charger should i go for for the $$$ VALUE
- how should i fix this?
- laptop supply as DC charger power supply
- micro heli batteries
- charger/balancer
- power supply amp Q
- Oops with a nimh
- Lipo batteries and chargers 101
- Old Ace FFC Charge System
- I'm a bit confused about Nicads.
- Megapower infinity charger
- 20C, 25C, 30C, 35C, 40C ?????
- Battery Help
- large crystal growth
- Triton2 Lipo Charging
- What the heck happened??
- Discharging too low
- Lithium Nanophosphate (LiPhos) charger?
- Turnigy LiPo caught fire
- Junk power supply
- Lipo battery charging questions
- ENERG-5000 any good?
- DTX 4200
- looking for GOOD battery, Advices please.. thanks.
- Ni-Mih Question
- wal wart charge
- How 2 measure MAH
- Discharging NiCds w/ a Tower 420
- Triton 1 charger Question
- Storing batteries
- Charge rate question, nimh nicad
- Charger? Okay for motorcycle batter.
- Multiplex LN-5014 spectrum TX
- the best way to charge lipo battry
- starting own lipo packs.....
- LiPo swollen or just the packaging?
- Overvoltage Charger Error
- Dean's T-Connectors - HOW MUCH CURRENT??
- Did I do somthing wrong? Fried Turnigy Accucel-8
- How often should i use my balance charger vs. polycharge4?
- Would you like to see some packs tested?
- Forming charge on nimh with nicd wallwart
- Using an accu cycle Elite charger
- lipo battery and charger
- NiMh Charge rate
- Lipo's manufactured in U.S. ?
- Need help with simple electronics circuit (voltage regulator)…
- Anybody running A123's in a 450 size heli?
- Discharging Lipos and other questions??
- FMA Multi 4 and Duralite tx pack question
- 6v cutoff
- Who can service batteries?
- NEED A GOOD 5S LIPO PACK!!!
- 42 Percent Products - 2Pac" HD Dual Battery Share 50 AMP! - Deans Connectors
- Balance Plug Adapters
- On a cycle the batteries only show taking 625mah
- charging a lead acid battary with the Super Brain 989
- buzzing packs? when charging
- Lipo Charging Questions
- 9V Alkaline battery OC voltage?
- Charger search
- Internal resistance of nimh cells
- Lower Charge Rate on Lipos
- Battery connectors - please help!
- Adding a load to my voltmeter
- Are my batteries toast
- noob .....needs charge info
- Using an Accu-Cycle and a wall wart charger
- Charging Ni-Cd Batteries
- battery dosen't have any low end power
- Graphs NIMH 4200 +
- Charger / Battery Protection
- Battery advice
- Nimh with low voltage - help
- How to tell if a battery is charged
- Hobby Charger for Standard AA's
- Super brain charger question
- Do NiMh need to be " Formed " ?
- C Ratings
- Any Battery testers SAY Good or Bad lipo
- NiCd & NiMh in parallel ? Please help.
- TESTING LIPO BATTERIES
- wall wart to charge 1650 NiMH?
- Battery switch, with charger slot??
- Accu-cycle plus will not charge fully
- Hooking multiple NiMH to one charger?
- lipo size a123 packs
- Battery started smoking, then caught fire.
- charging 2 nimhs at once (Traxxas 1/16 E-Revo Power Cell)
