- Filton Extra 260 Mini
- Hacker x AXI x E-flite in a Divo
- what plane for a Rimfire 35-30-1250?
- tourqe roll
- RUDDER AILERONS AND ELEVATOR THROW HELP!
- Greatplanes Flatouts
- Monster Power brushless motors
- dual elevator servo setup help...
- DW Foamies
- Dose any1 know were i can get a small 3d plane?
- new 3d plane ?????
- byp yak grounded
- E-Flite Sobre x BypYak x Divo x Funtana 300
- Help with 3d(please)
- byp yak/pluma
- Multiplex Easy Glider Electric
- A 500g Parkflyer that does 3D and Precision Aerobatics!
- First 3d
- Looking for father/son I met at Costa Mesa Bluffs
- Eflight mini funtana x help needed before august 7
- Battery recomendations and setup question for Hyperion Yak 54 40e and E-Flite model 12 Pitts
- First ARF Mini Mini Funtana X
- AEROWORKS 50 CC Extra 260 ELECTRIC CONVERSION
- Should I use a switch harness or not?
- Motor question for Reactor Bipe
- PA 260 Maiden Today
- Rolling Circles / Harriers
- Can you identify this flying wing?
- Expo on YAK Stiffy?
- which foamy?
- Can I replace 4s 3700 mAh with 3s 5000mAh?
- Art-Tech Cap 232
- Dual Sky Extra 260 EP plug in wings?
- Overlander 55" Yak and Extra
- e-flite mini funtana
- Build Thread: Airfoilz Full Fuse Yak 54
- Climbing When Inverted
- OMP Yak 54 v2 stiffy which is the best motor?
- charging lipo questions brain 989
- need a new plane
- First flight with Mini Pulse XT
- What would be a real good scratchbuilt or kit for 3D
- HELP - My Prop Adapter is Stuck On!!!
- Cermark Edge 540 EP vs. PA Katana Mini.
- MICRO RC 3D
- I'm looking for plans of a good Foam 4D airplane?
- Fiberglass L.G. can't last!
- Electric Shock and Weight question
- Great Planes PLUMA 3D Foamie
- charging lipo batteries
- ShowTime ESC
- Best Foam 3D Plane
- What to ARF to use with Typhoon Guts?
- 3D Hobby Shop 47" Yaks
- Great planes electric yak54 vs Eflite edge 260 ep 3d
- 3D Noob's review of the DW Foamies Yak Jr.
- what motor/battery to use in new Electrifly Pluma?
- Any Info 39" Katana sebart lookalike
- New plane decision
- ELECTRIFY YAK & PARK 450
- Funtana 100X anyone did it?
- E-Flite Extra 260 3D Profile or Great Planes Flatout
- 49" QQ Yak-Hacker A30-12L Help
- help!?!?!?!?!?!?!?
- APC-E VS. Mejzlik-E
- EXTREME vanquish Video!!
- Flat Spin To Inverted Flight Stall
- You guys gotta build one of these..
- Cermark Yak
- Question about Mixing Dual Rates
- Charging a 600mah 3s 11.1V 10c lipo
- Rimfire Prop Saver Ring
- Taping Hinges
- Tensor 4D?
- ultimate bipe or reactor bipe?
- Hacker motor in E-flite Extra
- Carl Goldberg Sukhoi SU-26
- VANQUISH GLITCHING
- connectors
- I picked up a PA Extra 260
- Help wire my first electric
- Typhoon 2 3d first flights
- LUM Family of Foamies
- phoenix models magic what motor?
- park 450 in gp electrify yak
- Fancy Foam Gernot Yak 55M
- new to electrics and need help outfitting an arf
- 3D
- New to 3D. Need indestructible plane
- New profile or foamie?
- 3D Foamy Help Which One Etc
- Super Sportster EP FIRST FLIGHT
- Getting First 3d Plane Yak or extra 300s
- Mods or Upgrades for Typhoon 2 3D?
- CP 1300 SCR
- g p yak 55 maiden
- Help! - what battery for GP Reactor
- new extra 260 ?
- cypher 3d?
- tNew 3-D flyer which plane?
- Fliton CG
- Now I need a new motor!! burned the other one
- Starting fresh after years away - where to start?
- need help with GP Reactor
- profiles
- Typhoon 2 3D with Spektrum DX6i - how to setup dual rates??
- great planes fun force
- E-flite Enticement F3P ARF
- balancing lipos
- RTF electric 3D
- Hyperion 260 40e
- VIDEO: Maiden Fliton Rogue 3D
- AMP Question
- 19g Brushless motor in knuffel V2?
- Is this the best priced HV controller?
- NEW PLANE!!!
- EF Extra 260 480 trim question
- 3DHS Yak Extended Torture Test
- Lesson Learned Cap BP
- magic formula 3d engine question
- epp 3d plane for flatout outrunner setup
- Extreme flight yak 54e First flight!
- Aero Works Extra 260
- RIOT 3D
- All thats lwft is to FLY!!!
- Going to maiden my EF 260 480 this weekend
- great planes esc and jeti esc's
- team orion gust mn or axi 2204/56
- Rimfire 28-22-1380 - 3DBatix Diablo
- TYPHOON 2 3D ..OR...???
- Antenna route
- Multiplex Acro Master
- Any market for a used ME 540?
- SebArt Sukhoi 30E
- Help installing wheel pants on EF Extra 260
- Which motor for my EF Extra 260?
- Rookie Needs Help
- What size battery in your EF Extra 260?
- power system foamie
- need a link for gas to electric conversion
- New plane from Jesky and 3Dhs
- Precision Aerobatics Extra 260 or Katana MD
- EF 47.5 yak
- BRUSHLESS ESC Help
- Fliton AJ Extra 330S or Seb Art Katana S30E ?
- Fliton mini 260
- Acromaster Motor Mount Vibration
- Power system
- Hacker A30-22S, what do you guys recommend?
- Will this fly a DW Yak
- Turning In Harriers
- HOVERING A FOAMY HELP
- SebArt Katana NIGHTFLYING setup!!!!
- I need some tutoring in shaft reversal....
- Differential for Ailerons
- foamy plans
- SEBART KATANA 50E - FLIGHT REPORT
- set up for a Ultrafly Yak 54
- need 3D airframe for hackerB50-15L
- Blue arrow ESC's
- question about ESC and amps
- E-Flite Yak 260 Foamie Offset??
- Chargers
- Sport Flying The 3dhs Extra 300 Shp
- a
- lipo batteries question
- Great Planes Yak54 EP
- What is a good foamie 3d to start with?
- Can you tell me if foam Shock Flyers are any good?
- Gyros for airplanes
- learning to fly the typhoon2 3d
- Help with setup
- shocky out of balsa sheet?
- QQ 49" Yak or EF Yak
- Can a Funtana X100 fly 3d on 6s
- trex 500 pro tail , anyone try this
- nitro plane sucks
- Aileron Hinges
- p 51
- Ultimate 20-300 10e E-Flite
- flatout hinges
- New to lekky's
- dx7 aileron adj?
- What brussless for my Yak 55?
- Need help selecting plane
- what's a good first 3d foamy?
- RCU Review/Build: Airfoilz Extra 260
- flat-out set-up on better plane?
- Cheap foamy setup?
- how to install a rx for a typhoon2 3d
- what moto/esc for this plane
- park 480 outrunner backwards rotation
- Gaui products are coming to Canada
- Axi 2208/34 enough for Bipe Yak?
- Phase 3 crash repair
- Motor spinning the wrong way
- Anyone have a Quick Time?
- Futaba S3156
- great 3d plane
- flaperons?
- This is Plane Wrong
- CHP TUNNEL VISION
- Sport Flyers Wild Fly 3D Good for Indoor?
- Project Bipe-X New Flight Videos added!!!
- Brio and Showtime malfunctions.
- Help me choose a new foamie
- FlightPower LiPo 11.1V 2500mAh 25C EVO25
- I need a new biplane
- Park 450 in Mini Funtana?
- Brushless confusion! Which motor?
- what afr "slow" plane to get?
- Knife Edge / CofG Effect
- Extreme Flight Yak-54 Electric Profile ARF
- Foam safe cianoacrylate for my new hacker super zoom??
- GP Extra 330S or E-flite Extra 260?
- SPEED CONTROL QUESTION
- Phase 3 Eagle should i buy one?
- Airfoilz / Futaba 9 C radio set up?
- BYP YAK Question
- I REALLY enjoyed the Typhoon...Where to?
- Thoughts on Reactor Bipe?
- 2008 ETOC Pilot List!!
- Seagull Edge 540 46 ARF.. anyone flying one yet?
- Micro flight pack
- Seagull Edge 540 60 e-conversion
- yak 55
- PA Katana MD or Sebart Katana?
- 40" Yak?
- Axi 2217-16 versus Scorpion 3008-32
- Inverted Flight / CofG
- have a 3d
- Increasing the number of cells?
- 480 Park motor problems
- Airfoilz Yak-54 full fuse!
- 4d Spektrum DX7 eflite extra 260
- 25 Flights: Extreme Flight Extra 300E
- Please help an electric NOOB!
- Hacker A10-15s damaged
- RCU Bipe and general electric flight question...
- Great Planes Reactor 3D ARF .46 E-setup
- good 3D plane for windy days
- radix 3d question
- elevon setup for dx7
- Best Sub 40" 3D Plane
- Precision Aerobatics Addiction
- Spinners for 3-D APC props
- 2008 ETOC Sequence with video.
- Anyone flying the Addiction??????
