PDA
View Full Version : 3D Flying!
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56
  1. Twist 150 engines?
  2. Aero-Works Yak 54 .60-.90 Size
  3. Seagull edge 540 .46 size CG?
  4. 3D/Floater for a Saito 100
  5. Great Planes Ultimate Biplane ARF 1.6-1.8,65"
  6. what servos for mojo moass 60?
  7. New video of the Hangar 9 Su 26MM
  8. 3d foamie
  9. 3d for .91 4 stroker??
  10. I have, NO Mojo
  11. TBM's 23x8 Prop
  12. 3D plane for a Brison 3.2?
  13. What happened to the Funtana X100 ? Why Discontinued ?
  14. MUST READ!
  15. wing rock
  16. Peakmodel Sukhoi SU 26 (68 inch) Maiden complete
  17. youll think im crazy!!!
  18. Reactor 3D GP question
  19. Airframe weight - QQ, Aeroworks, Magichand, EF
  20. Hanger nine 260 gasser
  21. Big Bird this weekend
  22. DOWN ON THE DECK 3-D FLY-IN @ BOMBERFIELD OCT 24-26th!!!
  23. perry pump for OS 120 AX - does it help
  24. Aeroworks Extra 260 and Yak54 60-90 size
  25. Outcast..
  26. Problem starting the motor on a Mini ultra stick PNP
  27. Best Aerobatic Design: Extra 330 vs. Edge 540 vs. Cap 232 vs. Yak 54?
  28. Need a 3D plane
  29. Keimod store
  30. FUNTANA X50 SET-UP HELP NEEDED
  31. I have an O.S. 61 and a 46 what plane to get?
  32. CMPro Extra 330L 50 Size 56”
  33. AW 540T for first 3D plane?
  34. Plane recomendation?
  35. Plane for a Brison 2.4 ??
  36. My hover blows away in wind
  37. Seagal Edge 540
  38. SY props and RC Only Site
  39. Katana MD
  40. Nitro Plane - Edge 540T 40cc~50cc
  41. 71" Peakmodel Yak 54
  42. Specs for a Hangar 9 Funtana S40
  43. Dual Elevator Setup
  44. New Toy
  45. What is better 3D plane than a Funtana X100
  46. 0s 91 fs plane. Stuck between 3
  47. What is good ARF for a Saito 100 ??
  48. evolution engines
  49. Hover question.
  50. Aeroworks Edge 540 .46-.60 or Seagull Edge 540 .60
  51. Great Planes Yak54 or Extreme Flight Yak54??
  52. ΥΑΚ 55 58"
  53. 3D Prop Sizing
  54. CG for a U CAN DO 60
  55. Oh my gosh!!!!!!!!!
  56. Setup for Aeroworks .90-1.20 Yak 54
  57. How far back can I move my CG?
  58. Swanyhouse Taco
  59. fliton edge 540 freestyle + YS63FZ
  60. Zenoah 45 Profile model ?
  61. good pack for 7 servo's
  62. Funtana X100 stock gear
  63. Anyone deal with PAU?
  64. TBM vs EF Yak the same?
  65. please recommand a best 3D plane for SAITO 180
  66. how the hek .............can someone please explain lol
  67. Hyde mount and 3D
  68. 3D maneuvers with high wing plane.
  69. Need advice on doing the Harrier
  70. Need advice on doing the Harrier
  71. 3D plan differences...
  72. crashed Edge 540, sensor switch no good
  73. Showtime 90 4d. little help needed
  74. First 3d plane 46/55 ax sized
  75. Is there a good 3D plane for 26cc gasser
  76. Kevlar pull-pull system installation
  77. Looking for a .90-1.20 3D plane
  78. walbro carb parts ??????
  79. Quique YAK 102 DA 100
  80. Quique 102 YAK DA 100
  81. Lookin for good 3d KIT. any out there?
  82. Tru-Turn cone spinning!!
  83. Help on choosing a replacement for OS .46 AX
  84. Saito 2.20 in GP Ultimate
  85. Are these too good to be true?
  86. os 91fx problem
  87. Elevator to flap mix
  88. Elevator flutter on a LASER 3D
  89. Showtime 4D motor OS 120AX or Saito 125?
  90. Looking for combos
  91. 3D With Full Scale P3 Orion
  92. COG on Funtana X100 for 3D
  93. dual elevator servo setup help.
  94. Electric plane setup
  95. 3D RC Airplane Help!
  96. Znline madness
  97. Another Phoenix extra 330s ??
  98. Twist 40 O.S.55 engine rpm
  99. 50cc Biplane
  100. New Plane
  101. phenix extra 330s ???
  102. Fliton Extra 330 cowl.
  103. TLT Aviation 25% Yak 54 build thread
  104. Great Planes Reactor 160?
  105. Giant U-Can-Do...engine/servo advice please
  106. Recommend 2nd 3D balsa plane
  107. Extreme Flight Jeremy Chinn Yak-55SPs build thread
  108. rossi 40 for 3D what prop???
  109. 3d rossi 40
  110. .46 size beginner
  111. Saito 180 prop for Funtanax100
  112. Yak 54 choices
  113. Thrust ?
  114. funtana 50
  115. "Small" Yak Rolling Harrier
  116. First real 3D airplane, suggestions on setup?!?!
  117. ? about Hitec receiver
  118. 3D plane for OS 120fs or OS 55ax
  119. 3D Prop
  120. gp cap 580
  121. aerowork edge 540 or showtime 50
  122. Props
  123. TWIST 40/RATES
  124. *Saito .82 Hot to Trot*
  125. Showtime 50 or 90?
  126. Hangar 9 Extra 260 27% Expo/radio set up
  127. looking for Klett landing gear
  128. OS MAX 120AX tuning help needed for HOVER
  129. Phoenix Extra 330S or Seagull Edge 540 ?
  130. U-can-do falling right from hover problem.
  131. Prop for 3W200
  132. Throttle Exponential
  133. Two battery's??
  134. Xoar vs Apc 17-18"
  135. hitec servo ????
  136. *Fliton Inspire 60 Manual*
  137. O.S. 120 AX what prop
  138. Omp help
  139. DP Ultimate
  140. Need help with my 3rd 3d
  141. Say
  142. Ok, am I going crazy????
  143. Eurokit Diabolo
  144. H-9 Showtime .50 engine?
  145. Modeltech 3-Demon????
  146. Control Set ups EPA or Dual Rates
  147. saito 100 best prop
  148. How's the Wingloading?
  149. 3D plane for OS 1.60
  150. Fun World 3D
  151. xtreme composites/bvmprops 540 spar ?
  152. EXTRA 330S WITH GAS ENGINE!!!
  153. 26cc gas prop size
  154. Best engine for Showtime 90 ???
  155. Quick U-CAN-DO 46 Servo question
  156. Hitec Centering issues?
  157. prop choice? himax 2025 5300 6.6:1 eflight ultimate fx
  158. better typhoon motor
  159. Twist 3D 40 size set up advice
  160. Hanger 9 Funtana X50
  161. DA-100 prop size?
  162. Hanger 9 Funtana 50X
  163. Night freestyle on Funtana40
  164. Control Surfaces at Hover
  165. ZN Line Madness 2
  166. HOVERING RATIO???
  167. Metal gears or Karbonite?
  168. need cowl for velox
  169. Anyone try a 16x6 or 17x4 prop on Saito 100 ?
  170. Saito 125 - first time such a problem!!!
  171. Showtime 4D .90
  172. Hangar 9 Tribute 36 + YS63 FZS ??
  173. Hangar 9 27% Extra 260...need feedback asap
  174. Pull Pull Rudder
  175. Ever fancied competing in an Aerobatic Competition
  176. Inspire 60 power????
  177. Satio 100 in SHOWTIME 90 - hover help !
  178. Aileron Reflex
  179. 3D with Saito 120?
  180. The old kyosho G-trick wih a supertigre
  181. How many Frenzy 100's out there????
  182. Ultra RC Katana 50 COG
  183. Showtime 50 O.S. 4 stroke engine choice?
  184. New fliton 330s 120c size?
  185. Katana Freestyle 40 / 81 Tops
  186. Quest 50, what engine should I have in it?
  187. First 3d yak
  188. 3D Model for a Saito 1.25 4-Stroke
  189. Hangar 9 Showtime 90 + OS 160 FX Project
  190. Stronger landing gear for Lanier Radical 330?
  191. 3D beginner type plane with requirments :)
  192. TT TOC 71" Yak 54
  193. YS 140 + Kit
  194. Help with Yak 54
  195. Smoke???? Im lost
  196. Header Tank Question
  197. SHOWTIME 4D 90 + S3152
  198. extinct airplane
  199. 2-stroke engine useless for 3D, so I was told..
  200. Dual elevator set up
  201. Peak Models or Maxford Yak54
  202. nitrous oxide on a gas plane
  203. TLT aviation sukoi su 26 ?
  204. 3D Plane for a Saito 100
  205. Mojo MoAss video
  206. nitro models edge 540
  207. U Can Do 46 prop?
  208. Fliton Extra 330S tracking issues
  209. tru turn spinner problem
  210. Smoke on a Showtime 90
  211. True 3D plane for my OS 55ax?
  212. funtana / katana C.O.G.
  213. Spektrum DX6i settings for Typhoon2 3D
  214. strange thing happend during breakin saito 180 4 stroke
  215. Questions about yak 54 3D versus U-can-do 3D
  216. help needed ~~ just brought a saito 180 question about crankcase valve
  217. Small 3D Glow Planes!
  218. Hover V Torque Rolling
  219. Bought a sukhoi. dont know what model??
  220. Pull Pull Slack
  221. Fliton Extra 330S-120
  222. modeltech demon
  223. YAK 54 72" QQ NIB Value??????????
  224. I know it's an Extra
  225. thrust test prop selection
  226. YAK 54
  227. U-Can-Do 60 with a Tower 75 Engine?
  228. Muffler for YS FZ 110-s
  229. Hitec 5985 vs JR 8411 vs Hitec 5955
  230. Plane Specifications
  231. fliton 330s help please!!!!!!
  232. neoplanes yak 54???
  233. Fliton Votec 351
  234. Nitro'ing a Hyperion Cap580?
  235. aviastar engine review 46
  236. Anybody With Hobby People Special Buy Fun Fly 90L?
  237. Joe Nall Thurs 15th Photo flood
  238. props for 3d
  239. my first video
  240. Saito 100 with 30% Nitro
  241. 3D Airplane
  242. Best RC simulator to practice 3-D on
  243. double vision
  244. Tower .75 for 3D flying?
  245. 55 AX equal to Saito 72
  246. 15x4 MA Prop is a crock ?
  247. Saito 100 low-speed nedle factory setting?
  248. Transmitter position
  249. TT 3D Spirit, CG Point
  250. prop selection for OS 120 surpass 3
