PDA
View Full Version : 3D Flying!
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56
  1. 67" Fusion with OS 91 fx
  2. Twist 60 3d with 26GT
  3. E-flite Mini Pulse XT PNP for second plane?
  4. Saito 150 vs Saito 125 For Showtime 90
  5. funtana 100x with saito fa-150s ???
  6. Who Makes a Good Wood Prop (16x6)
  7. UCanDo 3D Prop Size With .55 AX
  8. Funtana X 100 vs Showtime 4D 90
  9. 50 size 3d??? Which one???
  10. Profile Suggestions
  11. aircraft, car and boat user gallery
  12. possible fuel delivery problem
  13. Funtana X100
  14. 3D Flying Instruction
  15. Tunnel Vision coming soon
  16. Surpass 52 which 3D plane
  17. Harrier .46 note
  18. prop size and elevator setup
  19. new plane saga
  20. Hangar 9 Twist 40 with a O.S. 46 FX, vertical hover?
  21. Showtime 50 or U Can Do 46
  22. What would you recommend?
  23. tufflight?
  24. What IC Engine to use ??
  25. os .25
  26. funtana 100x surface throws needed
  27. YS 63S enough for a Showtime 50???
  28. wheat fields
  29. AeroWorks .90 - 1.20 Yak 54 QB
  30. Which Ultra RC plane??
  31. 3D progression
  32. glow fuel v.s. depron
  33. 60" Yaks?
  34. FLATOUT RC UNIVERSE EDITION - WHAT MOTOR WORKS BEST??
  35. DP Edge 300 ARF - Problems?
  36. DIABLOTIN XL CANOPY ?
  37. .40 Size (YS-63) 3-D/Pattern Plane Recommendation?
  38. easiest way to get into 3d flying
  39. Possibly the Last new MINI 3D
  40. Peak Edge540 76" + Peak 45cc arrived
  41. Aero Works 1.20 Yak has arrived
  42. Aero Works 1.20 Yak has arrived
  43. 3d plane for a 32 power e-flite motor
  44. Goldberg Edge 540
  45. 3D propeller for Seagull YAK-54 90-size
  46. Which First 3d plane??? need lots of help peeppsss
  47. Aeroworks Edge 540(40-60) VS Fliton Edge (40-60)
  48. Torque Rolling 101
  49. 3d setup servo question
  50. options for 40-60 Edge 540
  51. Yaks Suck Whats The Big Deal
  52. Yak 54 .50 size? or ...
  53. Getting fuel through the YS110 when starting for the first time...
  54. Mayhem vs. Funtana 100
  55. I can do it !!!
  56. What Makes A Good 3D Plane?
  57. Goldberg 77" Edge 540
  58. Fliton Inspire without pumped engine?
  59. E Flite mini funtanas
  60. best plane for a BRILLELLI 46GT
  61. Hitec 5955TG on 50cc gas airplanes
  62. E flite Brio 10
  63. JR 3421 or Hitec 5245?
  64. UCD 60 as a second plane?
  65. Which One from Facny Foam Models I need your Opinions!
  66. chip hyde split time
  67. Need an advanced aerobatic.
  68. Compensated rollers
  69. Extreme Flight Yak-74" or Dave Pat 330L?
  70. UCanDo Problems.....
  71. spinner question
  72. Showtime 90 and evo 26gt?
  73. Two elevator servos
  74. Death Slide?
  75. Good props for OS 55AX?
  76. Can the Peak Models Yak and SPE 26 combo 3D?
  77. SebArt Funtana S 140
  78. What do you think about the BYP Yak 3D?
  79. Showtime 50 and Saito 82. Best prop for 3D?
  80. Newb question, High Alpha???
  81. Which one Arghhhhhh!!!!
  82. Chip Hyde Wins in Cyprus
  83. EDGE .90 SEAGULL
  84. SPE 40cc strong enough for 3D?
  85. Goldberg Matrix
  86. Eflite Cap 232 Proflie
  87. Adrenaline prop size
  88. Harrier Wing Rock
  89. Funstar 3D?
  90. NEED HELP PLEASE! wild stik 40 setup
  91. Looking for a good 3d kit.
  92. chip hyde cap 232
  93. GP Reactor - which power source?
  94. Weston Groove help
  95. Edge vs Extra
  96. Velox Revolution II. CZ
  97. Funtana X100 or Showtime 4D
  98. Plane for YS 110
  99. funtana x50 2s engine
  100. Spinner Recommendations for Saito 100 on Ultra Stick
  101. hanger 9 27% 260 extra good 3d?
  102. What's Your Favorite Bird?
  103. AR6100, AR7000 Field reports needed.
  104. Servo help?!?!
  105. 1st U Can Do
  106. Twist 150 and havin fun
  107. adding a smoke system
  108. Funtana x50 with saito 120 S
  109. Stay grounded! I'm flying my 3-D
  110. Best 3D ARF for Saito 82?
  111. funtana x100, saito 125 fuel problems
  112. best 3D ARF under 400$
  113. Showtime 4D 90 problem
  114. World Groovy 90 Video
  115. Funtana 40 S Weight V.S Power
  116. 3D profile opinions
  117. Best 3D ARF 50-100?
  118. any 50cc su-31 kits or arf's?
  119. Showtime 50 Fuel tank question......
  120. Yak 52 3D 50 - 56"
  121. satio 100 in showtime .90?
  122. Pitts style muffler hitting motor mount on saito 125 and Funtana...need help!
  123. RD8000 Users, quad flaps?
  124. Katana V2 40 Size Engine Selection
  125. Da 50 plane?
  126. what make is my cap?
  127. What is 3D
  128. Wide prop Spinners ???
  129. Tower .75 in a UCD 60?
  130. Will CA hinges be good enough?
  131. Fliton Extra 60ins
  132. Which prop for OS 91 Surpass
  133. funtana x100 wing tips
  134. Seagull Edge 540!
  135. 3d model for my Evolution 26GT gas ?
  136. Reactor landing gear setups
  137. OS 160 Drill size for prop??
  138. Gettin Down
  139. 90" Lanier Edge 540 score
  140. 3d
  141. Electric Shock motor
  142. Gorilla glue for pin hinges?
  143. What plane for a 3d newbee
  144. GP 232 Covering
  145. best prop for FA 82
  146. showtime 90 w/saito 125
  147. Alternative engine mounting on GP Cap232
  148. Sig Mayham 3D 40
  149. air bubbles / fuel lines.....KILLIN' ME !!
  150. Good Fun Fly
  151. edge, yak, extra, cap....?
  152. accipiter badius 4ch 3D flyer?
  153. Best 3D plane for 91 fourstroke???
  154. 3D plane for G-62??
  155. Aviation Models 30% Yak Setup
  156. 3D yak for Saito 82
  157. Funtana X 100 SERVO HELP!
  158. Hanger 9 35% Extra 260
  159. Maidened my Fantana 90!
  160. Question on hovering
  161. Pull-Pull on Funtana 90...how to?
  162. Servos For A 3D Gas Plane
  163. Thinking of a new radio now
  164. JR Announces 2.4Ghz 12 channel & 9 channel radio
  165. FUNTANA 50X
  166. Engine Help
  167. Great Planes Yak 54 thrust lines needed
  168. Aileron flutter Fliton Inspire 60, what now?
  169. Twist 3D 60
  170. 3D PLANE! NEED YOUR HELP!
  171. Goldberg Edge 540 77" What gas motor?
  172. Gyro question - trying to buy one for my Mini Funtana!
  173. Recommendations for a plane for Moki 1.8?
  174. Seagull Edge 540 - 77.5"
  175. Importance of Expo/Dual Rates on Rudder
  176. 16"-18" props?
  177. Zenoah G-26cc gas engine
  178. BEST $40 to $60 3D SERVOS
  179. Review: EF Yak 74" and Brillelli 46cc
  180. Homeless Saito 150
  181. PA Bad Boy V2 - Knife edge coupling?
  182. Low wing model- can it do 3D well?
  183. great planes ultimate .40 wingloading
  184. Seagull Space Walker 2
  185. Air Hogs Room Raider R/C
  186. New - SebArt 58" Katana 50E
  187. CG Obsession 3d / Saito 180 install
  188. Turbine Toucan
  189. Need a good 3D plane for a G38
  190. weston groove
  191. profile for a TT .42
  192. Here's a couple questions for you regarding 3D and power
  193. y do planes say they need a 50 wen they need a 91
  194. Lanier 87" Extra 330?
  195. Ultimate 40, 46, 120
  196. Yak- 54 glow conversion.
  197. Showtime 50 pic/videos
  198. Aeroworks Edge 46-61 weight
  199. learn 3d
  200. Funtana Frankenstein Build
  201. 25 size profile
  202. Funtana 90
  203. U-Can-Do 60/Saito 125?
  204. Goldberg Edge 540 ARF with a small gasser?
  205. Harrier 3-D .46 flutter
  206. best 3d airplane for .46?
  207. Gas vs Glow Dilemma. Cap 27%... Cant Decide
  208. Saito- how much nitro?
  209. YAK 54 26cc ARF
  210. First 3d kit? arf? NIB os .91 4c please suggest
  211. Expos for 3D flying
  212. AeroWorks 24% Extra - Need information...
  213. Servo Screw for Futaba
  214. Peakmodel Extra 260 25%
  215. Aeroworks Yak 54 QB or QQ new yak 86 inch?
  216. OS 91 4 Stroke on Funatana 50
  217. Funtana 40 (3D)
  218. ultimate for an 1.60 gas
  219. Recommended First Kit, Experienced flyer, Rookie Builder
  220. Saito 125 Tuning
  221. Best 3D plane
  222. What plane to buy? Help!!!
  223. Great Planes Reactor with O.S. 55 AX
  224. EXTRA 330L ( CMP ) + DL50 50CC GAS ENGINE = COMBO
  225. 52 size yak
  226. 3D plane for YS63 recomendations
  227. EF Yak 54 - 74 What gas engine would you suggest?
  228. I got STUNG by some bug while i was flying !!!
  229. Large Foamies
  230. YS 110 needs a home, looking for ideas
  231. Help me choose a YAK 54!
  232. Anyone knows anything about Pole Cat 50?
  233. Help me pick a 3D plane for SuperTigre S3000
  234. Showtime 4D 90 center of gravity
  235. Li-po batteries for receiver and ignition yes or no?
  236. harrier 46
  237. 3D prop for Magnum XL S61
  238. Extra 330 .60-.90
  239. New Katana MD Fiberfusion Film by Aerofun R/C!!!!!
  240. Hovering...simple question
  241. H9 Ultimate Panel
  242. Edge profile help?
  243. Funtana 40S fuel tank
  244. switch blade cg
  245. Best prop for OS91FS in 3D aerie?
  246. Radio equipment- Ignition distance
  247. New Plane Set-up
  248. 2 Rx array
  249. WESTON UK 3D MODELS AVAILABLE IN USA
  250. PITTS MUFFLER FOR SAITO 125
