View Full Version : LMH Helicopter
- Need help
- Hornet body for corona!!!!!!
- Successful first day of flying - Corona
- lmh 116 with a .15 Norvel
- My military corona
- GY401 and T7CAP Settings
- Corona Replacemnt Canopy
- Corona 120?
- CP Corona 120 servo question
- Fiber Classics F-86 Info
- Help! Broken screw and Broken tail
- new gy 240 gyro
- How easy is a Corona to fly???
- LMH Corona - Crash #!
- Best way to balance rotors and flybar for corona???
- servo faliure
- where to find the CF flybar
- LMH 116 questions
- Corona 120 upgrades?
- Trimming for Forward Flight
- Corona 120: mounting battery under landing gear?
- Cyclic inputs cause altitude drop
- Multplex BL-480/4D Motor and ESC
- question about landing skids on corona
- Futaba GYZ40 Gyro question
- LMH 110 wont start **HELP**
- Corona tail rotor gearbox
- Corona Operators Guide
- Problem arming Electro-Fusion 35 Controller
- rotors spinning all the time
- Has this ever happened to You?
- Corona 120 R4P receiver question
- Mounting an FMA CPD4 in a LMH Corona
- derlin tail rotor
- My Corona.... First heli º First flight
- Corona gyro mounting question
- LMH 116 Long Rotor Conversion
- LMH 116, Less power the 110??? Help!
- TR gearbox loose or crush
- How to increase head speed of Corona
- Hello, I am new to RC helo's
- "Fun" Piccolo to Corona 120 ?????
- Fitting jr 331 servo in Corona alum crutch
- New Lipo over powering my Corona 120
- 16/15/3 Enough Power?
- brushed engine on lipo´s ?
- Interferance - Hitec Feather RX and deans whip
- Servo question
- Corona LHM 120 - Complete list of stuff to get start.
- 110 is a 116??
- can someone give me a list of whats needed to convert 110 to electric?
- .15 engine conversion and still have same problem as the V6 READ!
- Old 110+ part for LMH
- Where to buy Corona parts
- flying carona in extreme cold?
- altron or electronic gyro on a corona
- Corona Tail Rotor Control
- MEGA 16/15/4
- LMH 120 Tail Rotor
- Corona 120 Blade Pitch Question
- CC25 with Mega 16/15/3
- Esc Pixie-20P and Corona
- is this engine a v-max 6 or 7 ?
- motor timing on Atomic Force?
- Just built my 120M - have some questions
- Just Ordered a LMH 120!!
- 5mm MAIN SHAFT KIT
- Keep burning out glow plugs
- Esky Radio and LMH Corona
- LMH 110 Mods
- Hacker motor windings loose
- Fuel change / Engine HOT
- New LMH Modding Page and WEBSHOP !!!!!
- motor temperature check
- Hi
- What kind of batteries are preferred?
- Gyro set-up
- Gyro set-up
- Best brushles setup for Corona?
- corona tailrotor problem
- DANGER, "BREAKING BLADES"
- Hey Darth!!
- Buying my first heli... a Corona!
- No lifting Power!
- Dont throw away your Broken Corona BLADES
- Went to the LMH site
- LMH V-Max6 (just posted for sale)
- Variable Pitch 120
- GWS PG-03 Gyro Question
- got the power
- Help Needed with HH Gyro
- gas converted 2 electric
- V-7 - How Many Washers are you using?
- Corona 120 Vibration
- lithium battery setup
- V7 - It Works (worked!)
- another question
- New corona questions
- leaking fuel from carb
- If going to Brushless, Can I keep stock gears
- Problem with upgared belt drive!?!?!
- What kind of paint?
- Corona 120 belt tail with 45 degree tail box?
- glitch is a *****
- ALMOST DONE
- wow its been awhile
- Blade pitch
- Need Help.
- I got me a LMH 117
- Both Corona 120's Haunted by Glitches, HELP!
- Cart before the Horse
- LMH 120 spare parts inquiry
- VMax 7
- Question
- LMH 116 in a steep dive...
- Looking in to a 120...
- 116 Blades ???
- Corona 120 power Cutout problem
- .074
- Bummer/bonus
- from the Vm7 to an AP .09
- CORONA TAIL BOOM PROTECTOR IDEA!
- Heli Newbie
- Refugee
- VMax 6 Head
- how much slip should the tail gear be?
- Well.. crap. (What to do when you loose your muffler in flight!)
- Couple of 116 Questions
- LMH 110 Gyro?
- differences between LMH models? Upgrade paths?
- Mounting a Futaba gy240 on 120
- 117 HeliCam!!!
- Has this ever happened to your Corona 120, Or can you tell me why!
- thinkin about converting
- RC sport
- delrin gearbox
- pictures
- Corona Tail Wagging
- Battery/Motor Combo Question
- Vmax7 connecting rod problem
- corona 120 issuses
- Corona Umbilical for Training
- two questions
- Corona 120 Electric
- WANTED your old LMH
- Where can I find a clutch shaft?
- looking for parts
- My new Corona Tail gearbox
- battery for corona
- Tail belt drive on Gas 110-117
- Suicidal bugs
- crutch
- LMH116 fuel tank fell off?
- lmh hlei
- GP3300 charging
- metal main spur gear
- lmh 116 heli
- Lets keep it clean.. how to clean the Norvel Engines!!!
- Carbon Fibre Corona
- Corona Colective pitch?!!
- Converter for Norvel glowplug
- Lipoly Cutoff Voltage for Corona 120
- Vibrating again!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Balancing Corona 120 with Li-polys
- Erratic Idle on 116
- More Power!!!
- Corona Pinion gear Mesh
- chappahedz collective available
- best gyro for 110
- vmax7 question??????
- Top 10 of spareparts for LMH 116
- Flying with a darth canopy?
- 110 / 120 mixup...
- 120 Tail on 110!!!
- LMH Lawsuit Article...
- !@$! Turns!!!
- Please Advice
- Radio Selection for LMH's
- LMH .20 3D
- 110 Upgrades, Suggestions, Etc..
- 120 won't initialize
- thanks for great bodies darth...
- smoke pump
- Corona Keeps cutting out
- Corona Power Opinion Needed...!
- Flying courses?
- Tail rotor belt drive on LMh 116-117
- Bizzar Problem, Need Advice!
- Another DIY network r.c. helicopter show
- Master 40-B Heli Programming?
- Where can I buy a whip antenna for my Corona?
- LMH 120 Flyers
- Brushless Motor
- Brushless motor system not working
- 116 liftoff problem
- aluminum tail gear box
- Motor and battery for the Corona 120
- Please help!I'm about to order my first Corona 120
- Latest Corona video
- .074!!!!its alive
- very very sensitive corona 120
- Upgrade Links
- Is there an Alluminum gear upgrade for the Corona?
- Waring Stickers on Blades. What do you use to remove them?
- Problems with Corona 120 tial
- Brushless Motors
- Pulled a loop: Tail spin!
- MEGA 16153 or Astroflight 020 ?
- a canopy made from an OJ bottle
- ATOMIC FORCE motor Sucks!
- CLUCH
- HELP!! Vibration from HELL!!!!
- how can I tell the difference bt vmax6 and vmax7
- Is my ESC FUBAR?
- Fusion 7 motor Question!!
- ITS all got to go
- Corona 120 tail rotor speed
- conversion to OS CV 12
- Corona 120 Brushless set-up question
- hs-81 tail servo on carona help
- Tail rotor stuttering....
- Great flying day
- Can't Start my LHM110
- Having problems with the your rotor-head bolt holding tight to the main shaft?
- Corona Ring Gear...grrrrrrrrr
- How much can the Corona lift?
- No Time to Fly...
- CORONA HELP!! please :)
- 206 Jetranger scale Corona conversion
- Corona setup w/ Lipoly
- V-7 took a $h!t today...
- R114F or GWS on Corona
- 'Beefing up' the stock crutch
- Corona canopy
- Corona Collective Upgrade
- Posts
- Epoxy for lmh corona gearbox
- gy401/hitec eclipse combo?
- Well, I crashed today....
- max-6 is out ~~~electric in~~~now i need more help
- 4 grips
- Best crash?
- Hey Darth
- Darths new redesigned hughes 500 and Jet Ranger
- New Corona Motor
- corona yo yo
- cant get MAX6 running correct... NEED HELP!!!
- My Home-Made Boom
- Look at this allignment
