View Full Version : Helimax
- Compatable AXE Products
- Blade tracking
- Question about blade grip replacement??
- Quick question
- Feeling Like Modding Up!
- Common Sense Lipo
- 3 and 1 board adjustment
- Axe CP: Life of motors and usage times
- Heli max cp axe to spectrum dx7 receiver
- Align 325 woodies Great Tip!
- CX motors fit in Axe EZ?
- New Member
- LONGER TAIL BOOM, 2 QUESTIONS PLEASE HELP!
- Why helis are like children
- Flight question
- To Gyro or not to Gyro, That is the Question.
- How tight?
- Main shaft question
- heli maxx ez controller
- Axe direct drive....
- Axe Cp upgrade parts...
- Axe CP Flight time..
- Rotofly EX
- Why the high cost....
- First Flight Success, However
- I just realized something....
- Plastic blades
- AXE CP Receiver connections???? Help!
- axe ez rotors
- Tail rotor issue??
- Dean Connector Question
- anyone else have this issue?
- "Stock" Axe CP in MA magazine
- My axe cp is great but......
- tracking problems HELP!!!!!
- Is this correct?
- AXE CP On Board Video
- Axe cp main rotor grips
- Axe tail belt drive
- Axe-cp loaded for sale
- Flying in tight spaces... Video link inside.
- Motor for axe cp confusion
- Axe on order...a couple of questions
- Helimax AXE question
- My power switch mod...
- built the MX400, looks great, don't fly
- Stylin with the AXE CP
- Need some info?
- Lipoly is good
- Which Charger and Balancer for TP13203
- helimax axe cp HELP
- Some Information
- need some beginner tips-stable hover
- Lipoly on
- Axe CP main rotor blades
- Totally Noob ?
- PURCHASED MX400, now I'm scared
- Blade CX2 Questions
- balancing?
- axe cp climb-outs and the tail
- common sense lipoly
- stock charger
- lipoly
- Optic 6 Tx
- lipoly
- Selling my Axe CP. Why? Please read.
- axe cp gy401, what gain% ??
- axe cp what motor to use for the tail?
- On board camera filter
- heli maxx ez
- Electrifly battery placement
- Feel Like Giving Up!
- JCS BLADES
- Motor/pinion Helimax
- Axe cp tail rotor
- New to heli
- Total noob question Axe CP and a Futaba 6exap Tx?
- Power loss
- ac power option?
- Helimax MX 450 pro/DX6 ccpm settings
- Where to buy Axe CP?
- Discharging Lipo info.
- Direct drive tail
- axe cp seperates and the gy401
- Axe Headspeed and Pitch settings
- MX450 ESC and Motor question
- Charger for TP1320
- Head Speed
- hitec optic 6 setup and axe cp
- Heli Max Ex or Blade CX
- 10C Lipo's ?
- axe ez
- Very little lift with AXE CP
- axe cp main and tail motor, what esc's to use??
- axe cp vs. night ranger cp 3d rtf
- Axe CP with gyro
- Gyro questions: Why Futaba??
- Tail rotor one way only
- Axe CP 3in1 and receiver for sale brand new
- Tail Authority MX 400
- linkage bend
- glitching
- replacement stock blades
- Helimac, not enough lift
- Axe CP Full Brushless Conversion w/Pics
- Advanced Orientations
- Glitches
- USE OLD BLADES
- E-flite blades
- Mx 400 /Futaba 6ex radio setup
- need help with a lipo set up on my Axe CP
- AXE BLADES
- pinion suggestions
- Axe CP for FMS?
- MX450 or Titan E325?
- Idle up vs. Normal flight mode question
- Autorotation?
- AXE CP tail rotor question?
- E-flite blades
- AXE CP gyro. i dont think it's working!
- MX400 Center Hub failure
- HELIMAX PRO SETUP ISSUE !!
- Axe EZ Flybar Link Control and Stablizer
- Is it a bad thing to top off a partially discharged lipo pack?
- AXE EZ gain adjustment
- Well I just had an interesting flight....
- New Axe CP - no tail rotor response
- floats for Axe? (for those who can fly better than me)
- Helimax MX400 tail wag with Jr 500T Gyro and 3400G servo
- Heli in Hangar Video
- What size brushless motor??
- realflight G3.5 help with setting up axe cp
- Rotofly main motor suggestions
- Axe CP Blade options
- what is going on with my CP?
- ELECTRIFLY
- dx6 and axe cp (NEED HELP)!!!!!!!!!!!!!!BAD
- Rotofly Blade Flex
- Question about discharging a lipo
- Just bought an axe cp
- Quick ? about Axe CP swash
- axe cp tail blade
- Axe CP with jr 10sxII
- GWS 400
- lipo
- Axe CP stock blade pitch
- New radio in Axe, setup questions
- Anyone seen this.
- I'M SICK OF OVER PAYING FOR HELIMAX STUFF!!!
- tail rotor direction??
- extra fly bar weights
- upgrading flybar mount. please advise.
- has anyone taken their Heli-Max radio apart?
- Blade rotor blades Square tips non symetrical
- Is this normal???
- First flight on Axe CP...
- changing to CNC swashplate questions
- cnc blade grip for axe cp
- Broken tail motor assy on Axe Cp
- Axe CP-Wimpy Swash Plate
- Axe vs. T-rex size
- The Axe CP YOU WANT HOPUPS
- Switching freq on AXE CP
- Sudden increase in RPM [Axe CP]
- Question about lipo pack voltages
- Axe CP, GY240 trimming
- DX 7 on Axe CP
- a couple of questions
- eflite g90 gyro?
- Servo problem?????????????
- Flybar-less mod is it possible on the Axe CP?
- Axe CP Feathering Spindle Upgrade Kit
- FlY bar heli-max cp
- charging amps of rotofly batt
- Small video unit on 400
- Mx 400 motor. What are you all using?
- Axe CP Lipo Battery Rating
- Battery not lasting long?
- Axe CP control borad questions?
- the strangest thing!
- Just ordered an Axe Cp...Any advice???
- New Axe Cp with extras for sale !!
- AXE CP Tail Boom Moving
- Questions about trimming my axe cp
- g190 gyro on axe cp
- Homemade camera mount.(sort of)
- Balance Axe CP
- Inverted Flight
- How accurate is G3 with the Axe CP?
- Analog radio
- mx400 or axe cp
- AXE CP Headlocker ????
- Screws for feathering shaft Axe CP
- how to put on flybar collar weights?
- Align Head on MX400
- Looking for AXE CP set-up tips
- Can Blade CP/CP2/Pro upgrades be used on the Axe CP?
- MORE FRANKIN AXE PLEASE
- bought the axe cp
- Axe CP flybar weights
- more stable- less responsive?
- axe cp cyclic problem
- PROBLEMS with blade grips
- is this battery to much?
- helimax does fly
- axe cp radio adjustments
- Replaced stock brushed motor from wear?
- Best Balancing Lipol Charger
- One of the absolute greatest things about the Axe...
- Older transmitter with the axe
- RX Antenna shortened
- Trex canopy
- May Be buying the Axe CP tomorrow if convinced....
- Moving servo linkage to shorter throw on AXE CP
- MX400 tail control rod
- HeliMax
- How to tighten flybar shaft on AXE CP?
- Axe EZ Motor Question
- 4 in 1's where to buy
- More Stick Time – Alternative Power Source
- Do cyclic inputs cause loss of altitude?!?!
- help please, lots of spinning but no thrust
- Newbie, deciding on a Heli
- axe cp blades
- Using different transmitters
- Futaba Fasst NOT COMPATABLE with AXE CP
- axe no like roof
- heading hold gyro?
- Project AXE CP Main Gear Transplant
- wow! this isn't going good!!!
- MX400 Setup - Motor
- K&S Rotor balancer for AXE CP
- Helimax EZ
- Blade Grip Replacement
- First forward flight Axe CP
- Axe CP Vibration???!!!!
- MX 400 for a beginner?
- Compatible Batts. W/Equinox
- AXE EZ with stock 800mah lip flight time??
- MX450 XS Discussion Thread
- Mics.
- gy 401 on axe
- TAIL MOTOR
- 9C and your helimax EZ?
- axe cp with lipo?
- Anyone have experience with the EFlite 2-in-1 on the AXE?
- rotofly
- Axe EZ spins out of control
- feathering shaft
