PDA
View Full Version : Helimax
Pages : 1 [2] 3 4 5 6 7
  1. 400 3d servos
  2. Novus FP for first non-coax
  3. A few gyro questions. Need help fast.
  4. LPM/ESC Question (CPv3)
  5. novus cp outside 1st time
  6. CPv3 Questions Gyro/Receiver
  7. B-Hiller on v1 Axe
  8. Helimax axe 4003d part swap?
  9. CPV3 Geared Tail Conversion Help.. A few questions
  10. should i get it?
  11. battery problem?
  12. First Forward Flight >>> CPV3
  13. axe 400 tail rotor problem
  14. Identifying new posts
  15. Wierd CPV3 Issues. I need you experts' help.
  16. novus fp
  17. AXE_CP in Separates
  18. CP V3 Flybar Weights. What do they do?
  19. balancers
  20. Helimax Axe CX Micro
  21. mx 450 xs and te rex 450
  22. Axe CX Micro - new receiver... Again?
  23. Axe CP inverted Success!!!!
  24. Axe cp gyro selection
  25. HELI MAX 450MX
  26. GWS N60 tail motor for cpv3
  27. axe cp3 reciever help
  28. My CP V3 Came..... Now I Need Some Help
  29. Axe CP Heli- Replace ESC with lipo compat? Broken part identification? (pic)
  30. trying to learn how to fly axe cp
  31. Helimax 400 3D... which batteries?
  32. adding weight to a cpv3
  33. Bought a new CP V3 what do I need to know?
  34. heli max cp3 help
  35. axe cp help?
  36. cpv3 pitch
  37. How to Set CPV3 Pitch? And Blade Track?
  38. Axe 400 Night Flight
  39. cp and cp3
  40. Novus CP... wow.
  41. cp battery for cp3
  42. biggest battery pack for cpv3?
  43. broke swashplate, can i?
  44. Axe CX Micro, no response & stumped!
  45. Went to the Joe Nall
  46. Convert Helimax Axe CX to mode 1
  47. 2.4 gHz 6 ch PC programmed TX
  48. Help identifing this Heli
  49. Helimax N60 tail motor
  50. Heli-Max Novus Cx
  51. NOVUS CX NO WORKIE??
  52. LiPo Battery Selection Question
  53. question
  54. Novus cx gyro gain?
  55. 4n1
  56. Heli-Max Novus CX, FP, and CP?
  57. SERVO SOUNDS?
  58. CNC Blade Grips
  59. CPV3 problems out of the box
  60. CPv3 problem
  61. Axe CP E board settings
  62. No Lift AGAIN!
  63. Bell Hiller Adjustment
  64. Heading Gyro
  65. BELL HILLER PROBLEM!!! please help somebody
  66. How to set pitch
  67. Just wanted to say thanks
  68. axe cpv3 eboard
  69. Brushless help
  70. Axe Cp Problems (No Lift)
  71. Heli-Max CPV3 E-Board
  72. CP main gear/shaft
  73. Axe CP Issues
  74. HeliMax CP Swashplate
  75. Crashed my Axe CPv3
  76. Gyro Lock
  77. Axe 400 tail rotor
  78. HeliMax CPV3 Pitch adjust
  79. I'm just getting into this hobby and new...your hel(i)p is appreciated...
  80. Help with picking out Electric RC HELI (ANYONE?)
  81. Axe CP brushles upgrade trouble. Warning, kind of long
  82. Battery Switch
  83. Swashplate question
  84. CPV3 Pitch info
  85. receiver help
  86. pitch control knob
  87. Help
  88. MX 400 Questions
  89. WHAT GYRO WORKS GOOD ON A CPV3
  90. axe brushless tail??
  91. How to get to swashplate assembly on CP v3?
  92. CPV3 HOW DO I "DIAL IN" ADJUST\SETUP GET ER FLYIN TIGHT N' RIGHT
  93. Lipo battery
  94. axe cpl tail spin
  95. New micros from Helimax!!
  96. Heli-Max CX Micro - Tail twitch (rotates suddenly)
  97. cpv3 with futaba 6ex
  98. AXE 400 RTF - Some Quick,Simple Advice to Save a Headache,..
  99. SREWS !!!!!
  100. Anyone buy here
  101. main blade question
  102. belt drive tail
  103. speed and torque
  104. axe cp spinning, help
  105. AXE CP v3 tail wag (video too)
  106. Axe 400 JR X9303 setup
  107. Still Unresolved Problem with Heli-Max LPM E-board Axe CPv3
  108. cx flybar fix
  109. AXE CPV3/ CP-L
  110. AXE CPL with Trex landing skids
  111. Hopping Heli????
  112. axe micro doesn't go forward
  113. Total Newbie w/acouple of ?
  114. Helimax not responding...
  115. CX micro battery tray?
  116. axe cpv3 remote gain futaba radio
  117. Quick question about my LiPo's
  118. axe cpv3 help
  119. newbie battery question for cpv3
  120. SEE THE PIC / WHAT IS IT ?????
  121. axe cpv3
  122. First Crash, How to put back flybar correctly
  123. Flipping the Axe v3
  124. e-sky gyro on axe cp
  125. CPv3 Belt Drive Motor
  126. Axe v3 Spektrum conversion
  127. POST YOUR AXE CP AND CP V3 PICS
  128. axe with e-flight G100 gyro
  129. Axe cpv3 burning thru motors
  130. Axe CX...fried?
  131. Axe CP V3 and 25c burst?
  132. Axe CP component measurements
  133. First Heli?
  134. axe cpv3
  135. axe cp jumps
  136. MX 400
  137. Need help picking a gyro/servo's (I would like a jr model)
  138. axe cx micro or mcx
  139. axe cpv3 tail rotor
  140. Giving up on axe cpv3
  141. First chopper AXE CP-L
  142. Arming the 3 in 1
  143. Axe cx micro.....Spinning??
  144. My new looking CPV3-4
  145. First major crash Axe CPv3
  146. check out my axe tail
  147. axe cp leans
  148. Axe Ez/Cx Micro radio extra channels?
  149. RDS8000 2.4GHz
  150. What servo for the mx 450 pro
  151. Check this out.. cpv3 cp parts
  152. check out this axe makeover I found on ebay
  153. Axe Dx6i settings
  154. question axe cpv3/hm4000/c12
  155. my first flight axcpv3
  156. Problems with HM4000 gyro on Axe CP
  157. Axe EZ Battery
  158. HH gyro on AxeCPv3
  159. Cold wx behavior with HH Gyro
  160. NEWB QUESTION HERE
  161. axe cp-g110 HH help me....
  162. help with my mx 400
  163. heli gyro for cpv3
  164. Help with BL setup
  165. Helimax axe CP V3 becomes uncontrollable
  166. Expensive crash of Axe CP-L
  167. Here is a cool axe cp rebuild video I found..
  168. Changing Blade grips
  169. bearing in blade grip
  170. T Rex tail on a MX400
  171. Tailess Electric Helis
  172. Need Help to Install Tail Rotor blade.
  173. Need help with Axe CP!!!!!
  174. Just bought a CP-L
  175. New AXE CP owner
  176. Brushless Axe CP High Head Speed
  177. Axe CP Re-Assembly Help.....
  178. Helimax 400 3d
  179. New to Helimax cpv3
  180. Anyone running a HeliMax HM4000 HH gyro?
  181. Axe Parts Compatibility between models
  182. Axe CP-L Motor life
  183. Axe CP servo bad
  184. Soldering Battery Charging Plug
  185. Heli-Max AXE CP-L
  186. Axe CP stock Transmitter - Using Charge Jack
  187. Axe CP problems
  188. Li-po capacity and useful life on AXE CP
  189. TO BEll OR NOT TO BEll?
  190. mx 450 set up with 9C
  191. Axe CP not responding to transmitter
  192. Might be getting a Blackhawk!
  193. AXE CPv3
  194. Futaba 6EXP
  195. AXE CP lift problem
  196. Wiring a LiPo & Charger
  197. Intermittent Throttle
  198. Where to connect the orange wire
  199. DX6i helimax axe
  200. AXE CP Help
  201. AXE CP Alternate parts
  202. New HELIMAX Heli!
  203. Little to no Lift - AXE CP-L
  204. Axe CP brushless motor pinion
  205. Eflite G90 on axe cp
  206. Axe cp wooden blade corret pitch
  207. Best Main Motor Running Amps
  208. G90 mounting??
  209. weird oscillations in main rotor
  210. New battery pack, possiblity.
  211. What did I screw up on my axe?
  212. ESC's & LiPo's
  213. AXE CP Canopy and LiPo contact
  214. Axe CP Fried E-Board
  215. Axe Cp / Spektrum DX6i Throttle curve
  216. 3 in one mixer setting
  217. AXE CP V4 just around the corner?
  218. AXE CP TX Programming
  219. Scale AXE CP Video
  220. wagging/pulsing/oscillating tail - gyro problem?
  221. Awful Squeal
  222. berg rx mod
  223. Having problems with motor! Need help!
  224. Bell-Hiller Rotorhead Performance
  225. Uhhhh......
  226. mast size
  227. Axe CP Tail motor
  228. securing Lipo battery to Axe CP
  229. Scale Axe CP MD500
  230. Main Rotor Blade Damage
  231. 400MX going up and down
  232. MX400 info
  233. AXE CP Tail Rotor not working
  234. mx400???????
  235. help with nitro heli
  236. Axe EZ connections
  237. Recall replacement batteries LPM watch out
  238. Problem with Axe CP - no throttle
  239. The Axe is a toughie
  240. Axe cp tail motors?
  241. Axe CP Gyro
  242. Helimax Catastrophic Blade Failure, headspeed limit?
  243. HBK2 + AXE = belt driven tail
  244. Partial Pitch !!!!
  245. radios for Axe cp
  246. tracking issue
  247. Axe CP Cyclic trim
  248. MX400 Landing gear
  249. axe EZ.. bigger lipo????
  250. E-flight stock charger Will charge your GPMP0401 ElectriFly™ 3-cell 950mAh 11.1V LiPo Battery
