- xtals
- Servo City 4:1 gearbox...anyone used one yet?
- chatter buster ? anyone know which magazine had the article ?
- transmitter modules
- Tracker II at 50mhz
- Royal Electronics Servos
- Weird 9C problem
- What to do with 3rd channel...
- Can carbon fiber cause radio interference?
- Dz8550?
- i4C V-Tach?
- Which Servos?
- which PCM radio to get for FMA co-pilot use?
- strong servo
- Which Servos for my new 1/8th?
- futaba 8UHAP manual
- Molex connectors
- Graupner MC-24
- Which way to go?
- Ham Radios
- which servo
- Flash 5 to Focus 4 via Futaba Cord - Watch out!!
- R-1 Guide in Spanish
- Radio controls....
- Crow?
- manual wanted for a Heathkit 1205 Tx system
- Where are you guys buying servos from?
- Dual Receiver Questions
- JR & Hitec
- JR PCM9 Manual
- anyone know what's up with RD8000?
- Help with esc (bec working motor won't run)
- Good Quality Standard Servo?
- need help with radios
- 2nd battery for back up
- futaba 9c
- vtail mixer overheating
- the better radio
- Who knows SIMPROP, what happened to them( radio gears)??.
- Orbit Electronics
- Cirrus 9gram Servos????
- This worked for me
- Futaba and Hitec Buddy Linked?
- 2.6mm screws - where to buy?
- Jr Radio Channels
- JR 8103 3+1 digital trim transmitter
- can u use 72mhz AM anymore?
- Futaba T6HXS Problems
- Stumped!
- Traducción del manual de la emisora JR R-1 al español
- Futaaba 9C Tx Flap Operation
- R-1 Transmitter Guide in Spanish
- Futaba 6Xas PCM or PPM Version??
- rea time airspeed data
- Servo and Receiver Interference
- Flying Site Spacing/Radio Interference
- Tuning receivers
- RX and TX channel change
- Airtronics VG600 6-Channel FM
- Pros & Cons of Putting All planes on One Radio???
- Servo Brands
- GWS Digitals
- Servo Question
- Gidderiing Servos?
- Why is the Futaba 148 servo so popular for throttle?
- Aluminum Diamond Dust Spars?
- JR receivers don't ALL s***
- S9201s jittery, have repaired or pitch?
- RCS Servo controllers?
- There is a tracker ll
- problems with voltz servos and long leads
- 180 Degree Proportional Servos?
- World engines Expert Radios
- Testing with a different crystal
- Dumb newbie Question
- Multiplex receiver
- changing tx crystals
- Futaba 6XAS Programming
- newb battery question
- Optical Coupled Servos ???
- I accidently cut my antenna wire, can I solder it?
- buzzing servos?
- AM vs. FM
- Crystals
- Antenna question
- Profi 3030 question
- Lots of radio questions!
- One channel Xmitter & Recvr for Freeflight
- is RD8000 a good heli radio?
- JR Horn Supports
- what voltage for JR R610m receiver
- Has anyone ever had a Rx repaired?
- Cockeyed control stick on JR radio.
- Crystal brands ... any difference ?
- reciever problems
- Servo Centering?
- Older Futaba FM
- Pinouts and specs for 9C trainer jack.
- Futaba 9CAP vs. 9CHP (Again????)
- compatible servos
- antenna
- 9c
- Hitec's Eclipse 7 PCM
- 8103 spoiler mixing
- Futaba 8u super series
- JR super servo and digital servo
- Futaba R148 & FMA Co-Pilot mating to Quad Flaps
- Futaba 9CAP Questions
- Umm Ok. (servocity.com)
- Hitec Featherweight receiver question
- Adding Flaperon and other Mixes to Airtronics Vanguard
- Servo Isolation
- Umm. REALLY strange problem.
- battery to powersupply
- Hitec Servos ? ? ? ?? ? ? ?
- Profi 4000/servo question
- Antenna Wire
- Need help setting up quad flap with jr378
- old servos
- 9C throttle ratchet
- RX crystal question
- Futaba 129DP om 6 volts
- throttle servo
- MPX Cockpit MM
- FS Futaba FP-R148DF
- futaba help
- more Kraft stuff
- Kraft radios,,any interest???
- Need schematic diagram please !
- servo jittering help!
- Hobbico Rx.
- Futaba FG "gold case" parts?
- Interference at the local field
- Best deals on JR 10x ?
- JR 378 programming for Ultra Stick
- How do I know which servo to use?
- Help Identifying Receiver Component
- RC Universe Crystal Exchange Swap forum
- New Futaba Release
- receiver glitching!?
- flying wire interference???
- JR R900 Receiver
- JR to Futaba
- servo comparable to the jr 537
- Futaba servo source,$$$
- jr 378 additional channel
- JR radio
- Bypass charging diode Prism 7x
- JR662 and Ultra Stick quak flap setup
- Charging Rx Batteries
- rd 8000
- Servo test function? Help.
- Multiplex 3030
- wet radio gear
- Help Me
- HS 605 bb hitec servo
- prizm 7 programing
- Great Do-it-yourself electronics site
- Servo's
- FM TX 27MHz
- Hi-Tec Challenger 4000
- questions about hitec digitals
- rx antenna routing
- Problems With Futaba FF8 radios
- Royal EVO reset
- is it possible to add more channels to the futaba 4vf?
- Stupid Question
- Help!
- Servo Reverse Scematic
- HS-81 servo problem
- Inverted flight with a mix ?
- Powering LEDs from a RX chan?
- FUTABA 6AS super(PCM) antena question
- 6XAS and twin elevator servos?
- Servo bounce
- Dan JR part for TX
- Transmitter Range Check
- Eclipse 7 setup for Ultrastick 40
- I messed up charging my JR 662 Tx
- Dual Frequency Tx and Rx.
- hi or low
- Phone #
- JR-TX fuse holder problem
- Have some questions, should I get FM or PCM?
- 6V with futaba rx and hitec servos?
- What is the difference between the older JR 10sx and the new 10x radio?
- HELP. Reciever or Gyro problem.
- testing servos
- switch jr servo to futauba question
- Looking for a nice Radio/RX for $200-$300
- Battery / Servo Question
- Receiver Question
- Opinions Pleazzzz
- Sanwa 6000 super or the JR 3810?
- JR XP8103 UK / USA frequencies
- Please Help with Servo Question
- Hitec Digital Servos
- receiver compatability
- Fp electro'Dynamics
- RX Antenna, Can you double length?
- Radio tuning
- Strange Radio noise.
- new radio
- AM > FM interference
- Which Hitec servo for heli ?
- Antenna inside CF reinforced fuselage. OK?
- Changing Rx shift?
- Battery for Futaba R127DF
- How much does a Futuba cost ?
- HS 5645 Problems
- FMA Direct receivers with Hitec crystals?
- Deans loaded Whip antennas
- Eclipse 7 programming
- Difference between High Band, Low Band Rx?
- Ever program your TX in the air?
- anyone have pinouts for Hitec (Prism 7x) Trainer Jack?
- wiring aileron servos
- Cracked RX casing
- Dual Motors
- Gas Engine & insulated servo leads
- Crystal Cover
- Question about 8103 ATV settings
- Frequency tag
- help!
- radio advice
- hitec receiver futaba radio
- Broken TX Advice -- XF622
- Servo Power Connection
- 3 pin deans/servo wire
- JR 622 only shows 0 Volts.. Can anyone Help
- Need radio advice
- Steering
- centering a servo
- Zhen Hua radio question
- Gyros-mechanical or piezo?
- Crystal changes Hitec Eclipse ?
- What size battery??
- must use dual conversion crystal with daul converion RX ?
- What's this spare cable for on the gyro?
- futaba FM will not pass range test ??
- Radio Channels
- Graupner MC 18/20
- Airtronics RD8000 Recall
- Hitec prices
- soldering servo wires
- Power for strobe lights
- Help!
- What are specifications for Airtronics 94151 & 94735?
