- pattern flyers wanted Southwest Vintage Model Aircraft Festival Cedar City, Utah
- F3A Retroday in Pfaeffikon /Switzerland
- Great Cust Svc from Klass Kote
- Benito Bertolani`s Komet
- Bearings for a Novarossi R91F (61 Speed-13)
- Can a 6s 4000 mAh pack make it through the Expert schedule?
- Is it safe to order from BlueJay?
- Sun Fli 4 for SPA
- MK Aurora 90
- Need help for os 86 carb
- Classic event at Retford MFC (UKCAA)
- I want a couple of RTF classic pattern airframes
- Please help identify these planes
- Supertigre 60 Blue Head
- OS Hanno NIB
- Mac's tuned pipes
- Sun Fli IV build
- Dumas Triton
- Grand Prairie, TX Pattern Contest
- Vertigo II kit
- Design date for Bridi UFO?
- Classic Pattern Contest May 23-24- Virginia
- Contest - Do you want to fly ?
- Where do they print the 60 size plans?
- Atlanta retracts questions
- Photo with Emil- an honor
- Phoenix 7 plans
- mk cosmos 60 plans needed
- CPA March Newsletter
- Best pipe for the YS 61-R Classic ?
- YS 61-R Classic vs Novarossi R61F Speed13 w Perry pump for classic pattern ?
- Kwik Fli finished
- Bear Mountain Flyers Wild West Pattern Showdown
- Help identify
- Classic pattern planes at swap meets ther
- YS61 R - long stroke used
- MK PLANS 60 size
- Lost Field - Gadsden AL , Kidd Field
- Discussion and info on NovaRossi R61F and R61F Speed/13
- UFO Balance Point
- SPA Pattern Contest Grand Prairie, Tx
- Aerospace Composite Vac Pump
- Classic Pattern @ Perry Ga.
- Hatori #730 Header
- Johnnie Cashburn LFX-6
- MK Arrow Restoration needed
- Webra Speed .61 black head
- What is it?
- Hobby shops are no longer hobby shops
- classic pattern plane for rear exhaust 61
- best wheels for .60 atlanta
- New NovaRossi Engines for 2015
- Phoenix Typhoon
- Bridi UFO knife edge flight
- 2015 AVTI Winter Classic Pattern Contest 2/8/15
- Taurus and Astro Hog, engines
- Foam wings, mechanical retracts
- Used YS 61R
- Bob Klineyoung's Phantom I
- Supertigre X60
- 2015 Pomona Classic Fly-In 1/24/15
- Bridi XLT radio install
- Classic pattern restoration
- 90 size Kaos
- Classic Pattern Association question
- Free CPA and SPA Novice Sequence Caller
- MK Beetle fibre glass kits
- Mach 1 from MAN plans
- 2015 CPA West Coast Event Schedule
- O.S. Hanno special question
- The Shrike, Virginian and Unknown
- Aurora 60 original kit for sale
- What plan is this? ~58" span
- Classic Eclipse 60 pattern plane
- Happy Thanksgiving
- Atlanta Wing
- Compensator
- Comming Soon All Wood Aurora 60 Kit
- Akrobat II
- Tiporare 60 build from plans.
- dc ADVANCE 60
- Seeking Don Coleman (Cutlass Supreme, Sweetater, etc.) Biography Info
- Salient Designs Brochure
- Which is king of the ARF's
- Will the YS 60FR bolt in the same as an OS61SF for direct swap?
- Flying (Pivoting) Stabilizer for my 1970's Don Coleman Cutlass Supreme
- CG for my atlanta
- TigerTail
- Intruder 90 R
- CPA contest in FL - November
- Jim Grier's Anonymous
- Tiporare illusion kits
- YS 61 Classic question
- Found in an attic!!!
- SPA Top Novice
- Mk curare 20
- Curare ARF air retracts?
- Question for H9 P7 builders/fliers.......
- To finish or not to finish............................................ ...............
- Hangar 9 Phoenix 7 recommender retracts
- R/C City Fresh-Aire
- Summit III
- OS 61 RF Pumped engine
- Dirty Birdy went down
- Pomona Valley Model Airplane Club Classic Pattern
- CPA West Coast Regional Championships Point Standings
- Qwick fly 111 short kit or kit
- Kazmirski,s SIMLA flys in SPA contest
- Need OS 61 SF-ABC Engine Box
- Classic Pattern Reproduction Project Review
- Dick Hanson Elite
- Henry Piorun Meridian CG
- Phoenix 8 C/G location?
- Micro X Exeter?
- Is anyone still manufacturing a .61 rear exhaust?
- What is the best way to attach canopy to Bridi Chaos
- Carb For Old Super Tigre 61 r/c
- OS 55AX - Phoenix 7 Tank Height
- Italian made Super Tigre .60 Rear Exhaust 1970s-1980s
- Grid Leaks magazines in PDF here
- Hotlanta SPA Contest - July 19-20
- Kidd Field - Steele AL.
- RC Clubs - North Carolina
- Checkers by Jarold Schmidt
- Looks like the transfer from Japan is back in operation
- Great Classic weekend !
- Does anyone make FG fuselage kits/classic planes
- Selling RC planes! Los Angeles, CA. Pick up only
- Wanted
- Four classic pattern engines available
- Atlanta 60 & Y.S 61 F.R long stroke: What header and pipe?
- List of NATS and TOC winners 70-80's - exist?
- Prop
- Options for electric classic pattern planes
- Webra Catalogs
- Birdi Sun Fli 4 (California Models Version)
- 2nd Annual Desert Heat Classic Pattern Contest
- LVRCS Classic Pattern Contest 6/28 in Easton PA
- Help, Prettner's Supra Fly
- YS 60 and 61 pipe setup
- Special Thank you to SPA !
- CPA business
- Dave Brown retracts
- Classic Pattern Contest ! June 7th & 8th
- Phoenix 8 Restoration
- Custom Woodcraft R/C Flight Box
- Help with setting up ys 61r long stroke
- 2014 Alabaster, AL SPA Contest - April 26-27
- Classic Pattern Question
- Mach 1 40 - Laser Kit
- Pattern Question
- HELP!!! Modellsport Schweighofer Curare 60 ARF Ultra cote Colors - ANYONE????
- May Need Shipper from Newark, Delaware
- MK Cosmos 60 belly pan........Need one
- Phil Kraft Kwik Fli III
- Lookign for a Blue Angel Canopy...
- Y.S. .60 Short Stroke Parts
- YS 61AR Issue
- Prattville Alabama Pattern Primer March 8th-9th
- Citation
- Classic (Old School) at the Bash
- YS 61AR Mounts
- Hanno 61 Piston & Liners
- Need plans for IM Products "Corsair Acro Knight 45MkIII" pattern plane
- NovaRossi R61F-speed/13 Review in Fly RC magazine
- Jekyll 60
- best CAD software?
- OPS 60 red head manual
- A Few Building Ideas To Chew On
- R/C City
- 2nd Annual Lancaster Winter Classic Pattern - D-7 Season Opener - Feb. 15th and 16th
- On the hunt: Futaba 8JN parts.
- Couple Classic pattern planes available
- RC City has a new owner
- CPA Contest - Culpeper VA
- Building a Arrow from a set of MK plans
- 2014 Classic Pattern Get-together, June 7th, Riverside
- One or two day pattern contests
- Classic Pattern Association News;etter
- Fresh Aire II Help
- Scepter by Rusty Van Baren
- Modeltech Calypso
- Super Lucky Fly 2 redux
- Need some guidance for an OS 61SFP
- 2014 CPA/BPA AMA pattern contest Emerald Coast Contest June 27-29 2014
- Ho ho ho
- OS Hanno
- Upcoming West Coast CPA Events- 2014
- Mk curare 60 canopy
- Look at this: Giezendanner Skorpion III
- Cutlass Supreme kit by Don Coleman available
- Harry Brooks "Reb" Color Scheme
- Laser Cut DB40 Build
- Balsa/wooden kits
- 2nd Annual GTRCC Aerobatic Convention
- Ops super 60 se
- Z-40
- Bill Hempel Vulcan
- Hey Manitoba, Ontario, ND, SD, IA, WI, and MI!!!!
- Thank you !
- Picco 60 FIRE bearings
- Mach I - See Attached
- NovaRossi Engine Testbed
- Mini Curare
- Does anybody recognize this plane?
- Conquest VI CG
- Lancaster Fall Classic Pattern Contest - Saturday November 9th
- Novarossi .61F RE (blue head) vs 61F Speed 13
- Arrow CG
- Rossi.61 Rear Exhaust Carb
- Phoenix 6 - Wood Fuse Build
- Carolina Custom Aircraft
- Tuned Pipe mount
- Looking To ID This Classic Beauty Of A Pattern Plane
- Vintage Pattern Unobtanium
- SPA Fall Fling Contest - Saturday Nov 9th
- Vertigo
- '87 World champs.
- Classic Pattern Molds
- Fox .50 better than a TT .46 Pro?
- Os .65ax
- Miss Norway
- Yoshioka dash five 45
- Desire 60
- Phoenix 1 build
- new to classic pattern, could use some help.
- Tuned pipe length check - in flight
- Troublemaker kit from J & J Industries
- Curare Knock Off - Anyone Seen a "Cure-Air"
- Futaba programming
- Older and Slower
- Kaos .60 vs DIrty Birdy .60
- SPA West Open in Fort Worth
- MK Curare at rediculous price on auction site.
- So what about the Sig Kougar?
- Pattern Ship - What is It?
- MK Joker 60
- Rc City phone number?
- Como engines? Como 40
- Chattanooga SPA Sponsor T H A N K S !
- Lacquer base with Urethane clear
- 2013 SPA Masters Contest - Featuring Special Guest! - Asheville, NC - Sept 14-15
- Magic
- Rossi 60 FI RE rubber o- rings
- Chevron 2
- Vulcan
- How bad of a week have you had?
